A laptop connects to an external monitor via USB-C, with glowing icons highlighting display, speed, and power features.
You plug a new monitor into one USB-C port and get nothing. You try the port next to it and the screen lights up. Nothing is broken. A MakeUseOf writer, Kanika Gogia, hit exactly this wall, and her experience points at a quirk of modern laptops: ports that look identical can behave very differently.
A laptop connects to an external monitor via USB-C, with glowing icons highlighting display, speed, and power features. USB-C is a shape, not a promise​
USB-C describes the physical connector: small, oval and reversible. It doesn't say what the port can do. Depending on the laptop, a port may carry data, accept or supply USB Power Delivery, output video, or combine several of these. The Type-C connector is common to several technologies while mandating only a few of them. Laptop makers decide which features each port gets. Thunderbolt in particular needs extra hardware, which adds cost. That is why one laptop may have a fully featured port next to a bare-bones one.
The same point comes up in industry explainers. One says USB-C offers no performance guarantees itself. Another notes that a USB-C port does not always mean USB4. It might carry USB 2.0, USB 3.2, Thunderbolt, or no data at all. A USB 2.0-only Type-C port is allowed, and its 480Mbps ceiling is slower than the old USB-A ports it replaced.
The four things that differ​
1. Data speed​
The naming doesn't help. The MakeUseOf piece lists these generations:
StandardMax speed
USB 2.0480Mbps
USB 3.2 Gen 15Gbps
USB 3.2 Gen 210Gbps
USB 3.2 Gen 2x220Gbps
USB420Gbps or 40Gbps
Thunderbolt 3 / 440Gbps
USB4 Version 2.080Gbps (up to 120Gbps asymmetric)
Thunderbolt 580Gbps (up to 120Gbps with Bandwidth Boost)
Some of these numbers are best-case maximums. USB4 has a 20Gbps tier and a 40Gbps tier. One reference also notes that the 20Gbps USB 3.2 Gen 2×2 mode is optional in the USB4 specifications, and most USB4 controllers don't implement it. So "USB4" alone doesn't tell you the speed. Check the exact tier for your model.
2. Video output​
Some ports support DisplayPort over USB-C. Others handle only data and charging. This is the most likely explanation for the monitor story. The monitor's plug fit both ports, but only one port had a video path behind it.
3. Charging and power​
A port might charge the laptop, charge a phone, power accessories, or do some mix. The wattage varies. A port that tops up a phone may not keep a laptop alive under heavy load. Microsoft's own guidance says nothing here is automatic is not quite the wording, so here is the substance instead. Faster charging needs the PC, charger and cable to all support the standards. They must also support the power level the PC needs. Microsoft's example is that if a PC needs 12V at 3A for fastest charging, a 5V, 3A charger won't deliver it.
The USB Implementers Forum says USB PD 3.1 allows up to 240W over a full-featured Type-C cable and connector. That is a ceiling for the specification. It isn't a promise for any given laptop port, charger or cable.
4. Thunderbolt and USB4​
These are the premium tiers. They are typically what you need for docks, multiple displays and fast external storage. The MakeUseOf piece notes that high-end and professional laptops may have two to four such ports, while mid-range machines may have one or none. Its shorthand that a lightning bolt always means "40Gbps or more" is a simplification. Confirm the Thunderbolt generation in your model's specifications.
How to tell your ports apart​
Step 1: Read the markings, but don't trust them blindly​
Some manufacturers etch icons beside each port. MakeUseOf lists these common ones:
  • A lightning bolt suggests Thunderbolt.
  • "SS" with a number suggests SuperSpeed USB at 5, 10 or 20Gbps.
  • A USB logo with 20 or 40 suggests USB4 at that speed.
  • A DisplayPort logo suggests video output.
  • A battery or plug icon suggests the port can charge the laptop.
Treat these as clues. Many laptops have no symbols, and some use similar-looking marks for different features. A missing symbol doesn't prove a capability is missing. Symbol conventions also vary between makers.
Step 2: Check the manufacturer's documentation​
Look up the full model number and compare the per-port descriptions in the spec sheet or manual. This is the most reliable general method, because the maker decides what each port supports. One caveat: a spec sheet that just says "USB-C" tells you almost nothing.
Step 3: Use Windows 11's USB4 page, if you have it​
On systems that support USB4 with Microsoft's USB4 Connection Manager, go to Settings > Bluetooth & devices > USB > USB4 Hubs and Devices. Microsoft says the page shows the system's USB4 capabilities and the attached USB4 peripherals. You can view a tree of connected hubs and devices and copy details to the clipboard. The page was introduced in the July 2023 Windows 11 update (KB5028185).
If the system doesn't support USB4 with Microsoft's connection manager, the page won't appear. On supported systems, Device Manager shows a USB4 Host Router. So a missing page doesn't mean your ports are slow. It may only mean there's no USB4 here.
Step 4: Try USB Device Tree Viewer​
MakeUseOf suggests this free Windows utility, which shows the speed each connected device negotiated. Note that it reports what is plugged in and negotiated, not a full inventory of each empty port. Its developer has described Windows 11 USB4 information as incomplete and experimental. Use it as a troubleshooting aid, not as the final word.
Mac users have an equivalent. Apple says System Information shows the hardware installed on or connected to your Mac. You can open it with Apple menu > System Settings > General > About > System Report. Or hold Option and choose Apple menu > System Information.
Test each port, and know what the test proves​
  • Display: Connect a monitor using a cable known to carry video. A picture proves the whole chain works together. A blank screen could be the port, cable, adapter, monitor or settings.
  • Data speed: Copy a large file to an external SSD, or run CrystalDiskMark on Windows. The result reflects the drive, enclosure and cable as well as the port.
  • Charging: Plug in a suitable USB-C charger and see whether the laptop charges. Phone charging isn't proof of laptop charging.
Don't forget the cable​
The cable is part of the connection. The USB-IF says outright that not all cables have the same capabilities and that choosing a suitable one is the user's responsibility. For USB-C to USB-C cables going through its compliance program, it requires a 60W or 240W power marking. Except for USB 2.0 cables, it also requires a marking for the supported data rate. A cheap cable can be USB 2.0 only, with limited wiring. Those are only good for USB 1 and USB 2 communications and Power Delivery.
Microsoft's USB-C troubleshooting page covers the common failure points:
  • Connect the device or dongle directly to the PC, not through a hub or dock.
  • Plug into the port that supports the needed mode. A DisplayPort Alternate Mode adapter belongs in a port with DisplayPort Alternate Mode, and a Thunderbolt device belongs in a Thunderbolt port.
  • For USB4 devices and docks, use the supplied cable or a certified USB4 cable. Also make sure the PC port supports USB4.
  • If Windows says a port has limited functionality, move the device to another port.
  • Too many devices using USB-C connections can limit what works.
What to do before buying a laptop​
Don't count USB-C sockets. Find out what each one supports for your needs: external monitors, SSDs, chargers and docks. Ask whether the port you'll use for charging is also the one that does video, and whether you'll need both at once. For USB4 or Thunderbolt peripherals, confirm both the port and the cable.
The bottom line​
If a monitor works on one USB-C port and not another, the likeliest cause is a difference in what each port supports, not a defect. Try the other port, check the cable and adapter, then check the exact model's specifications. Markings and software tools help, but the manufacturer's documentation settles the question.
  1. Your laptop's USB-C ports aren't all equal, and there's a way to tell MakeUseOf 2026-11-02T16:46:16+00:00
  2. System Information User Guide for Mac - Apple Support (CA) support.apple.com
  3. July 11, 2023—KB5028185 (OS Build 22621.1992) | Microsoft Support support.microsoft.com
