The original poster seeks a way to remotely check if a specific Windows service (SQL Server Agent) is running on multiple servers using a Windows 7 machine, aiming to avoid installing additional software on the servers. After some research, they discover that the built-in "sc.exe" command-line utility can be used to query service statuses remotely. Overall, the thread reflects a successful search for a straightforward, client-side solution to remotely monitor service statuses.
alberto
Hi everybody, I'll get straight to the point: I am trying to write a script, program, whatever to check if a service is running on a remote host.
My idea was to get this to run on a Win 7 Enterprise machine, check if a specific service (SQL Server Agent) is running on a bunch of remote hosts (Windows Server 2008 r2) and send a quick email with the status of my services.
I wanted it to run on the Windows 7 machine so as not to overload the servers. Of course I have admin access to all of the servers.
I know I could write a .NET program that check if the service is running locally and then call that program remotely, but I'd prefer all the computation to happen client-side and using the .NET framework so as not to install anything unnecessary on the servers.
So, does anyone know how I can query a remote service to check if it's up or not?
Thanks in advance!
alberto
Thread Author #2
Hi folks, never mind, I found a solution.
In case anyone is interested check out the sc.exe command line utility that comes with Windows.
