The thread discusses how to determine the system time on Windows. The original poster asks for tools or methods to find the system time, considering it's related to uptime minus lock time. A response suggests using the Task Manager's performance tab to view system uptime as a possible way to approximate the system's running time.
toppino77
Hi, anyone know a tool, methodology or wmi properties where is possibile to know the system time ?
System time is Uptime - Lock time.
Thanks Ale
if you right click on the Task bar and choose Task manager, look under performance and you'll see Uptime in the system section.
