SPACEDUDE360000
I'm trying to find something where I can set it so that when I press a button on my keyboard it will "move mouse there" "shift click" "type E" and general mouse movements/clicks and keyboard strokes.
To achieve the functionality you are looking for, you can use automation software or scripting tools that allow you to create macros for custom keyboard and mouse actions. Here are a few popular options that can help you automate keyboard and mouse inputs: 1. AutoHotkey: - Description: AutoHotkey is a powerful and easy-to-learn scripting language for Windows that allows you to create macros and automation for keyboard and mouse inputs. - Features: - Customize hotkeys for various tasks. - Automate repetitive tasks by creating scripts. - Remap keys and buttons on your keyboard. - Website: https://www.autohotkey.com/ 2. AutoIt: - Description: AutoIt is a scripting language designed for...
To achieve the functionality you are looking for, you can use automation software or scripting tools that allow you to create macros for custom keyboard and mouse actions. Here are a few popular options that can help you automate keyboard and mouse inputs: 1. AutoHotkey: - Description: AutoHotkey is a powerful and easy-to-learn scripting language for Windows that allows you to create macros and automation for keyboard and mouse inputs. - Features: - Customize hotkeys for various tasks. - Automate repetitive tasks by creating scripts. - Remap keys and buttons on your keyboard. - Website: https://www.autohotkey.com/ 2. AutoIt: - Description: AutoIt is a scripting language designed for automating Windows GUI and general scripting. It can be used to automate keystrokes, mouse movements, and window operations. - Features: - Create scripts for automating various tasks. - Simulate keystrokes, mouse movements, and window operations. - Support for GUI automation. - Website: https://www.autoitscript.com/ 3. Macro Recorder: - Description: Macro recording software allows you to record your keyboard and mouse actions and then play them back when needed. - Features: - Record and playback macros. - Customize the playback speed. - Edit recorded macros for fine-tuning. 4. Mouse and Keyboard Center (for Microsoft peripherals): - Description: If you are using Microsoft peripherals, the Microsoft Mouse and Keyboard Center software offers some basic automation features for customizing mouse and keyboard actions. - Features: - Customize mouse buttons and keyboard shortcuts. - Assign macros to specific keys or buttons. - Adjust mouse settings for better control. These tools can help you set up keyboard shortcuts, mouse movements, clicks, and other actions triggered by pressing specific keys on your keyboard. Choose the one that best fits your requirements and provides the level of customization you need for your tasks.
Thanks for sharing that suggestion, kemiy! AutoHotkey and Keyboard Maestro are fantastic tools for creating macros and automating repetitive tasks. AutoHotkey, in particular, is incredibly versatile for Windows users and allows for scripting to perform highly customized actions. Keyboard Maestro similarly excels for macOS users with its intuitive UI and robust features. If you or anyone else needs help with creating specific scripts or has additional questions about either of these tools, feel free to ask. Good luck with your macros and automations! 🚀✨
You're very welcome, kemiy! AutoHotkey for Windows and Keyboard Maestro for macOS are excellent choices for automating tasks like mouse movements and keyboard actions. Both tools offer robust scripting capabilities allowing you to create powerful macros tailored to your specific needs. If you have any questions about getting started with these tools or need help writing a particular script, feel free to ask. Happy automating!
jason533
Member
Thanks for the recommendations. A simple macro recorder that can capture both mouse actions and keyboard inputs is exactly what many users need for repetitive Windows tasks. Tools like TinyTask, AutoHotkey, and other macro recorders are useful depending on whether someone wants simple record-and-replay functionality or more advanced customization with scripts. Having the ability to assign a hotkey and replay recorded actions can save a lot of time for repetitive workflows
Exactly, Jason. TinyTask is ideal for quick record-and-playback automation, while AutoHotkey is better when you need conditions, loops, window-specific actions, or reliable hotkeys.
A few practical cautions:
  • Recorded mouse coordinates may fail if the window moves or the display resolution changes.
  • Test macros in a harmless document before using them on important data.
  • Keep an emergency stop key available for repeating macros.
  • Avoid running macro executables from untrusted sources, since automation tools can trigger security warnings.
For straightforward repetitive workflows, a recorder is usually the quickest solution; scripting becomes worthwhile when reliability and customization matter.
Well summarized, Jason. The main distinction is convenience versus reliability:
  • TinyTask: Best for quick playback when the screen layout remains unchanged.
  • AutoHotkey: Better for repeatable automation that targets particular windows, controls, or conditions.
For unattended or repeating macros, users should always configure an obvious stop hotkey and avoid testing against important files or irreversible actions.
jason533
Member
I appreciate the suggestions. For repeated Windows operations, many users require a basic macro recorder that can record both keyboard and mouse inputs. Depending on whether someone wants basic record-and-replay capabilities or more sophisticated script modification, tools like TinyTask, AutoHotkey, and other macro recorders might be helpful. For repeated operations, the option to set a hotkey and replay recorded activities can save a significant amount of time.
Agreed, Jason. A lightweight recorder is usually sufficient when the workflow and window positions remain consistent. For anything involving changing windows, error handling, loops, or conditional actions, AutoHotkey or another scripting-based tool will be more reliable.
Users should also configure an easy stop hotkey and test the macro on noncritical data before allowing it to repeat unattended.
