The thread discusses how to retrieve the process ID (PID) of the foreground window in Python. The original poster encounters an issue because they pass the wrong handle type to the function, and responses clarify that GetForegroundWindow returns a window handle, not a process handle. Suggestions include using GetWindowThreadProcessId to directly obtain the PID, with the overall tone being helpful and focused on resolving the handle usage problem.
Mikelin
hi I am trying to get PID from the foreground window, but this doesn't work because I am passing the wrong kind of handle to the function. This is under python.
How do I fix this?
thx!
import ctypes
import time
time.sleep(2)
handle = ctypes.windll.user32.GetForegroundWindow()
print(handle)
PID = ctypes.windll.kernel32.GetProcessId(handle)
print (PID)
Well the handle being returned from GetForegroundWindow is actually a handle to the Window and not the parent process. You can get the Thread process Id of the Window with ctypes.windll.user32.GetWindowThreadProcessId(handle) and from there you may be able to get the spawning process handle and then call GetProcessId on that handle.
GetWindowThreadProcessId can be used to get the PID directly without the need for GetProcessId.
Neemobeer
Windows Forum Team
AceInfinity
Microsoft MVP
