Executive Summary
- Vulnerability Severity: CVSS v4 base score of 8.4 (comparable CVSS v3 base score of 8.2)
- Attack Complexity: Low, meaning that a determined attacker with authenticated access could exploit these issues without undue difficulty.
- Vulnerability Type: Protection Mechanism Failure (due to insufficient security for EFI variables)
- Affected Vendor: Siemens
- Devices at Risk: SIMATIC IPC Family, SIMATIC ITP1000 systems, and SIMATIC Field PGs
In a nutshell, the vulnerabilities allow an attacker—with authenticated privileges—to either modify the secure boot configuration or disable the BIOS password. In environments where these devices integrate with Windows-based IT ecosystems, ensuring robust isolation and security is paramount.
Risk Evaluation
Successful exploitation can have serious consequences:
- Secure Boot Configuration Tampering: An attacker could alter the boot configuration, bypassing the trusted boot process essential for system integrity.
- Disabling BIOS Passwords: This risk renders the device’s firmware vulnerable to unauthorized changes, potentially leading to further exploitation.
For organizations, this means that even with traditional network security measures in place, the risk is not negligible if internal controls break down.
Analyst Insight: Even if an attacker compromises only a single segment, the ripple effect across connected industrial systems can be significant—especially in environments where Windows is used to manage or monitor these systems.
Technical Details
Protection Mechanism Failure in Depth
The issues stem from an insufficient protection mechanism for EFI variables—those critical settings that impact the system’s secure boot process. Direct communication with the flash controller exposes these variables to tampering if an attacker gains authenticated access. Siemens has outlined two specific vulnerabilities:
- Secure Boot Alteration (CVE-2024-56181):
- Score and Vector: CVSS v3 base score of 8.2 and a CVSS v4 base score of 8.4.
- Risk: Unauthorized alteration of the secure boot configuration could allow persistence of malware or bypassing of security controls.
- BIOS Password Disabling (CVE-2024-56182):
- Score and Vector: Similar severity rating as the first, with an identical threat profile.
- Risk: Disabling the BIOS password significantly lowers the barrier for further unauthorized configuration changes, adding another attack vector.
The root cause in both cases is the inadequate safeguarding of EFI variables, which are pivotal to the device’s trust framework.
Affected Products Overview
Siemens has identified an extensive list of impacted devices, including:
- SIMATIC Field PG Series: M5 (all versions) and M6 (versions prior to V26.01.12)
- SIMATIC IPC Series:
- IPC377G, IPC427E, IPC477E (all versions)
- IPC477E PRO (all versions)
- IPC527G (all versions)
- IPC627E, IPC647E, IPC677E, IPC847E (versions prior to V25.02.15)
- IPC3000 SMART V3 (all versions)
- SIMATIC IPC BX/PX Series:
- BX-21A (versions prior to V31.01.07)
- BX-32A, BX-39A, PX-32A, PX-39A, PX-39A PRO (versions prior to V29.01.07)
- BX-59A (versions prior to V32.01.04)
- Other Devices: SIMATIC IPC RC-543B, IPC RW-543A, IPC127E, IPC227E, IPC277E, IPC277G, IPC277G PRO, IPC327G, and IPC347G.
This comprehensive list underscores the broad scope of the vulnerability, emphasizing that organizations using any of these devices need to examine their security posture.
Mitigations and Recommendations
Siemens and advisory bodies like CISA have provided several mitigation strategies:
- Firmware Updates: Where available, updating the device firmware is the most straightforward mitigation:
- SIMATIC IPC627E, IPC647E, IPC677E, IPC847E: Upgrade to version V25.02.15 or later.
- SIMATIC IPC BX-39A, PX-39A, PX-39A PRO, BX-32A, PX-32A: Update to version V29.01.07 or later.
- SIMATIC IPC BX-21A: Update to version V31.01.07 or later.
- SIMATIC IPC BX-59A: Update to version V32.01.04 or later.
- SIMATIC Field PG M6: Update to version V26.01.12 or later.
- Access Restriction: Limit root/administrator permissions on the operating system level to reduce the likelihood of unauthorized modifications.
- Network Segmentation and Isolation: Ensure that these devices reside on segregated networks:
- Firewall Configuration: Isolate control system networks behind robust firewalls.
- VPNs for Remote Access: When remote access is necessary, deploy VPNs that are kept current to avoid known vulnerabilities in older implementations.
Additional Security Best Practices
Beyond Siemens-specific advice, consider these industry-standard practices:
- Minimize Network Exposure: Keep control system devices out of direct internet exposure. This can be achieved by not allowing remote access from the broader corporate network without strict segmentation.
- Implement a Defense-in-Depth Strategy: Rely on multiple layers of defense rather than a single point of failure. This includes both software and hardware security measures.
- Periodic Vulnerability Assessments: Regularly conduct detailed risk and impact analyses to quickly identify and address any vulnerabilities.
Pro Tip: While these recommendations may seem like common best practices, the devil is in the details. Every industrial system, especially those managed through Windows-based networks, merits a tailored security assessment.
Implications for Windows-Centric Environments
For many administrators and professionals working with Windows environments, the relevance of these Siemens vulnerabilities may not be immediately obvious. However, consider the following:
- Integration Concerns: In many modern industrial setups, Windows hosts or servers are used to manage or interact with Siemens devices. A weakness in one link of the chain can compromise the overall security of the network.
- Inter-System Trust: Windows systems often rely on secure boot mechanisms at both the firmware and operating system levels. A compromised industrial component could, in worst-case scenarios, serve as a conduit into otherwise well-protected IT environments.
- Operational Continuity: With increasing convergence between IT and OT (Operational Technology), the stability of industrial systems directly impacts business operations. A breach or misconfiguration in one area can lead to unexpected downtimes or complex remediation processes.
Final Thoughts
As cyber threats continue to evolve, this advisory serves as a crucial reminder of the need for comprehensive security measures across all platforms, from Windows desktops to specialized industrial control systems. Siemens' industrial devices are integral to the manufacturing backbone worldwide, and while the current vulnerabilities require an authenticated attacker for exploitation, the low attack complexity means vigilance is non-negotiable.
Administrators should verify firmware versions, restrict elevated privileges, and re-examine network segmentation policies to ensure that even if one part of the system is compromised, the rest remains secure. While Siemens is actively working to address these issues, proactive risk management is the best defense in our interconnected digital world.
In the ever-changing landscape of cybersecurity, staying informed and ahead of potential threats is not just a best practice—it’s a necessity.
By synthesizing the technical details and recommended practices from the advisory, organizations can better prepare their Windows-centric and industrial environments against these vulnerabilities. Stay safe, stay updated, and never underestimate the importance of robust security practices in an increasingly interconnected world.
