📎 AI Summary: The thread discusses updates and features of hardware monitoring tools, primarily HWMonitor and HWiNFO64, highlighting their ability to read system sensors such as voltages, temperatures, and fan speeds. Over time, users share software updates, improvements in hardware support, and download links, demonstrating ongoing development and increased compatibility with modern components. Overall, the sentiment is positive, emphasizing these tools as essential for hardware diagnostics and monitoring.
HWiNFO has released
v7.00 of it's Hardware monitoring app:
Latest v7.00
Released on Mar-09-2021
Enhanced sensor monitoring on MSI H510 series mainboards.
Fixed monitoring of +12V on some ASUS Z590 series mainboards.
Improved support of LPDDR3/LPDDR4/LPDDR4X memories.
Fixed a possible WHEA error/system crash during long-term monitoring of AMD RX 6000 series GPUs.
Enhanced sensor monitoring on ASRock Z590 Taichi and Z590 PG Velocita.
Consolidated AMD Navi monitoring, added Effective Clock and TGP Power for Navi21.
Added sensor tool tips to provide more details about sensors and their values.
Improved sensor UI responsiveness during some operations.
Improved handling of disappearing/reappearing sensors in custom order.
Fixed a possible hang when logging sensors with large sets of disabled items.
Added monitoring of GPU HotSpot temperature for NVIDIA GPUs.
Improved reporting of GPU memory vendor and ROP count for AMD GPUs.
Enhanced sensor monitoring on ASRock J4105-ITX.
Fixed reporting of effective clock on AMD Ryzen 1st generation CPUs.
Added preliminary support for DDR5 thermal sensors.
HWiNFO has released
v7.02 of it's Hardware monitoring app:
Latest v7.02
Released on Apr-06-2021
Enhanced sensor monitoring on ASRock Z590 OC Formula and Z590 Phantom Gaming-ITX.
Fixed unintentional waking up of some NVIDIA dGPUs disabled by Optimus technology.
Added reporting of PCI Express Resizable BAR capability and status for all devices.
Enhanced sensor monitoring on MSI Z590 PLUS, MEG Z590 UNIFY and B560M PRO WIFI.
Enhanced monitoring of AMD Navi14.
Restored monitoring of AMD Navi21 with Radeon Adrenalin 21.3.1.
Fixed monitoring of Vcore and VDIMM on ASUS PRIME Z590-A and STRIX Z590 series.
Added ability to collapse sensor groups.
Aggregated some sensor values into nodes (collapsed by default) to reduce amount of information on the screen.
Improved GUI responsiveness in some situations.
Enhanced sensor monitoring on EVGA Z590 FTW and Z590 DARK.
Improved support of Intel Rocket Lake.
Fixed reporting of Core Performance Order on AMD Raven, Renoir and Cezanne.
Updated for proper support of AGESA 1.2.0.1 Patch A.
Improved detection of AMD ThreadRipper PRO and next generation ThreadRipper.
Improved reporting of Intel Integrated GPU clock.
Enhanced sensor monitoring on ASUS ROG CROSSHAIR VIII EXTREME.
Added monitoring of Global Frequency Limit on AMD Zen2/3 CPUs.
Added monitoring of DRAM Read/Write Bandwidth on AMD Zen2/3 CPUs.
HWiNFO has released
v7.06 of it's Hardware monitoring app:
Latest v7.06
Released on Jul-06-2021
Added LHR variants of NVIDIA GeForce RTX 3080, 3070 and 3060 Ti.
Fixed reporting of memory clock and some other parameters on Rocket Lake 6c/4c.
Enhanced early support of some Zen4-based systems.
Added workaround for systems with stuck SMBus causing large delays.
Added VRM monitoring on ASRock Z590 Extreme, Z590 Phantom Gaming 4, H570 Phantom Gaming 4, H570 Steel Legend, B550 Extreme4, B550 PG Velocita.
Added several NVIDIA GeForce RTX 3070 Ti and 3080 Ti card models.
Enhanced sensor monitoring on GIGABYTE X570S series.
Added option to use RFC 3339 or ISO 8601 date formats for sensor logging.
Added support of Intel XMP 3.0 for DDR5.
Added per-core temperature monitoring for AMD Zen CPUs.
Added support of PCI Express Revision 6.0.
Enhanced sensor monitoring on MSI X570S series.
HWiNFO has released
v7.10 of it's Hardware monitoring app:
Latest v7.10
Released on Aug-31-2021
Added reporting of Secure Boot support capability.
Added monitoring of IOD (IO Die) hotspot and average temperature on AMD Zen2 and later CPUs.
Fixed monitoring of some MSI X570S series mainboards.
Added reporting of CPPC order for AMD Renoir and later APUs.
Improved Tj,max reporting on some AMD Zen CPUs.
Changed high temperature warning limit from Tj,max-10 to Tj,max-5 ºC.
Improved rounding of DDR4/DDR5 nCK parameters.
Added support of Aquacomputer Leakshield.
Enhanced sensor monitoring on NZXT N7 Z590.
Improved support of AMD Navi23.
Enhanced sensor monitoring on ASUS ProArt X570-CREATOR.
Fixed monitoring of some GIGABYTE X570S series mainboards.
Improved DDR5 SPD readout.
Added monitoring of Average Active Core Count for AMD Ryzen 2xxx and later series.
Updated EVGA ICX3 monitoring on GPUs with new firmware.
Improved support of some future AMD CPU generations.
Added preliminary support of some future AMD GPUs.
Added monitoring of static PL1/PL2 power limits.
Added option to write sensor log directly to disk.
HWiNFO has released
v7.12 of it's Hardware monitoring app:
Latest v7.12
Released on Oct-04-2021
Added a darker (black) Dark Mode skin.
Increased font and window size of the summary window.
Updated summary window for improved support of Hybrid CPUs.
Changed core naming in Hybrid CPUs to better reflect the type.
Added a workaround for missing CPU clocks on AMD CPUs with Core Isolation / Memory Integrity enabled.
Fixed a possible crash when opening sensor settings multiple times.
Added support of Alder Lake-N.
Enhanced sensor monitoring on some ASUS MAXIMUS, STRIX, TUF, ProArt, PRIME Z690 and B660 series.
Added ability to define a custom range for invalid sensor values.
Redesigned Summary window.
Enhanced sensor monitoring on MSI Z690 and B660 series.
Added readout of DDR5 SPD via I3C on Sapphire Rapids (preliminary).
Enhanced sensor monitoring on GIGABYTE Z690, B660 and H610 series.
Added monitoring of CPU Utility – same utilization as reported by Task Manager in Windows 8 and later.
HWiNFO has released
v7.16 of it's Hardware monitoring app:
Latest v7.16
Released on Dec-21-2021
Enhanced sensor monitoring on ASUS ROG STRIX Z690-I, PRIME Z690-P, PRIME Z690M-PLUS.
Improved monitoring of D3D usage.
Fixed recognition of down-cored Alder Lake CPUs.
Added monitoring of L3 Cache temperatures and clocks for AMD Zen CPUs.
Optimized EC communication on ASUS Z690 series mainboards.
Enhanced sensor monitoring on ASRock Z690 AQUA, B660M Pro RS, B660M-HDV, H610M series.
Updated kernel driver for compatibility with HVCI.
Fixed reporting of Total Host/NAND Reads/Writes for some drives.
Enhanced sensor monitoring on MSI MEG Z690 GODLIKE, H670, B660 and H610 series.
Added preliminary Intel Granite Rapids support.
Enhanced sensor monitoring on ASRock H670, B660 and H610 series.
Added monitoring of Raspberry Pi running Windows on ARM.
HWiNFO has released
v7.20 of it's Hardware monitoring app:
Latest v7.20
Released on Feb-15-2022
HWiNFO64 ported to UNICODE.
Enhanced Intel XMP 3.0 Revision 1.2 support.
Enhanced sensor monitoring on some ASRock B660 and H610 series.
Enhanced support of future AMD AM5 platforms.
Enhanced sensor monitoring on ASUS B660, H670 and H610 series.
Initial localization to 24 languages.
Added NVIDIA GeForce RTX 3080 12GB.
Added NVIDIA GeForce RTX 3050.
Enhanced sensor monitoring on ASRock Z690 Steel Legend/D5.
Added support of Nuvoton NCT6799D.
Added ability to override embedded language file by using a custom lang.txt file
HWiNFO has released
v7.26 of it's Hardware monitoring app:
Latest v7.26
Released on Jun-21-2022
Improved support of Intel Arc GPUs.
Added several new GPU models.
Fixed a potential race condition between sensors and summary screen.
Enhanced sensor monitoring on ASUS CROSSHAIR X670E and STRIX X670E series.
Fixed a possible crash when scanning some ASMedia SATA controllers/drivers.
Reduced minimum sensor polling period to 20 ms.
Added monitoring of Thermal Limit percentage for AMD Zen.
Fixed missing CPU Utility and GPU D3D Usage on some non-English Windows systems.
Enhanced sensor monitoring on MSI H610M series.
Added NVIDIA RTX A500, A1000, A2000 8GB, A3000 12GB, A4500, A5500 Laptop.
Added NVIDIA GeForce RTX 3050 OEM, GeForce MX570 A.
Improved support of AMD Genoa, Bergamo, MI300 (A/C).
Added preliminary support of AMD Turin, Strix Point, Granite Ridge.
Improved support of Intel Sapphire Rapids.
Fixed monitoring of VRM temperature on some ASUS Z690 mainboards without EC.
Improved reporting of memory clock on AMD Cezanne and later APUs.
HWiNFO has released
v7.32 of it's Hardware monitoring app:
Latest v7.32
Released on Nov-01-2022
Added reporting of Core Performance Order and PBO Scalar for AMD Raphael.
Added monitoring of Energy Performance Preference for later AMD APUs.
Fixed reporting of CPPC order on systems with gaps in APIC IDs.
Enhanced sensor monitoring on ASUS X670 series.
Fixed a possible hang during USB enumeration when Xbox 360 is connected.
Enhanced sensor monitoring on EVGA Z790 series.
Fixed a rare case when Nuvoton NCT6799 sensor might not be found.
Added early support of some AMD Zen5 families.
Enhanced support of Intel Meteor Lake and Granite Rapids.
Enhanced sensor monitoring on ASRock X670E series.
Enabled VRM monitoring on some ASRock mainboards.
Enhanced sensor monitoring on ASUS B650 and Z790 series.
Added hovering delay for sensor tooltips.
Enhanced sensor monitoring on Intel 13th Gen NUC series.
Added monitoring of GPU Thermal Limit for NVIDIA GPUs.
Added monitoring of GIGABYTE AORUS P1200W PSU.
Updated translations for several languages.
HWiNFO has released
v7.34 of it's Hardware monitoring app:
Latest v7.34
Released on Dec-07-2022
Extended Shared Memory Interface to expose UTF-8 encoded strings.
Fixed Remote Monitoring with localized sensor names.
Added monitoring of Fan Intake Temperature on AMD Navi31.
Added NVIDIA GeForce RTX 4080.
Added highlighting of changing sensor values.
Added support of NZXT Kraken X63 new models.
Added support of Intel Emerald Rapids.
Enhanced support of AMD Navi3X.
Added several NVIDIA GeForce RTX 4090 and 4080 card models.
Fixed reporting of Command Rate on AMD AM5 systems.
Added monitoring of additional temperatures on ASUS MAXIMUS Z790 HERO/APEX.
Improved sensor tooltip.
Added Ukrainian language.
HWiNFO has released
v7.42 of it's Hardware monitoring app:
Latest v7.42
Released on Mar-30-2023
Added reporting of PMIC Validation and DIMM Certification status for XMP 3.0 rev1.3+.
Added NVIDIA GeForce RTX 4050 Laptop.
Fixed monitoring of some EC sensors on EVGA Z790 series.
Enhanced support of AMD Phoenix.
Enhanced sensor monitoring on some MSI H510M, H610M and A620M series.
Improved reporting of Intel HDA sound drivers.
Added limited monitoring of Intel Arc GPUs without drivers installed (oneAPI, IGCL).
Added monitoring of Corsair H100i Elite White and H150i Elite White.
Added NVIDIA GeForce RTX 4070 Laptop.
Added option for creating report files in UTF-8 format.
Added monitoring of Corsair Commander CORE, CORE XT, ST.
Added preliminary support of Arrow Lake-S.
Updated monitoring with AMD Adrenalin 23.3.2.
HWiNFO has released
v7.60 of it's Hardware monitoring app:
Latest v7.60
Released on Jul-27-2023
Enhanced sensor monitoring on revised GIGABYTE B550 series.
Added recognition of Renesas RAA229004.
Enhanced fan speed monitoring on later MSI laptops.
Added AMD Radeon RX 6550M and 6450M.
Extended physical drive limit to 256.
Added NVIDIA GeForce RTX 4060 Ti 16GB.
Added monitoring of DIMM temperatures on Ice Lake-SP, Sapphire Rapids, Emerald Rapids.
Improved monitoring of Granite Rapids and Sierra Forest.
Improved power monitoring on later NVIDIA cards with new drivers.
Fixed a possible race condition in CPU monitoring on some Intel systems.
Added fan speed monitoring on ASUS ROG Strix G513I, G513Q, G713I, G713Q notebook series.
Added reporting of AVX10 and APX ISA.
Added ZHAOXIN KaiSheng KH-40000.
Added Intel Raptor Lake Refresh SKUs.
Added GIGABYTE AORUS theme (automatic, optional).
Added detailed Memory Timings window (AORUS-branded).
Added reporting of advanced GIGABYTE BIOS options and AGESA version (Z790+, X670+).
HWiNFO has released
v7.64 of it's Hardware monitoring app:
Latest v7.64
Released on Oct-11-2023
Integrated PresentMon for FPS, Frame Time and GPU Busy monitoring.
Enhanced fan speed monitoring on some ASUS notebooks.
Enhanced VRM monitoring on GIGABYTE Z690 and Z790 series.
Enhanced sensor monitoring on new MSI mainboards.
Extended Sensor name in sensors window to display in full row.
Fixed installing driver on encrypted drives/folders.
Fixed a possible crash on some CPUs with more than 64 cores.
Fixed missing L3 Cache size on some AMD Phoenix APUs.
Improved support of AMD Strix and Storm Peak.
Fixed monitoring of GPU D3D information when GPU is re-enabled after disabling.
Improved sensor monitoring on ASUS ROG MAXIMUS Z790 APEX ENCORE.
Improved support and monitoring of GIGABYTE TRX50 series.
Fixed misreporting of XMP profiles for modules with XMP 3.0 + EXPO.
Improved DDR5 timing calculation per CAS latencies supported.
Enhanced sensor monitoring on ASRock B650I Lightning, A620I Lightning, Z790 Nova.
HWiNFO has released
v7.66 of it's Hardware monitoring app:
Latest v7.66
Released on Nov-13-2023
Added fan speed monitoring on ASUS VivoBook X513.
Added command-line argument to exclude processes in PresentMon.
Fixed monitoring of VRM HS Fan on ASUS ROG STRIX Z690-I and X670E-I.
Enhanced monitoring on ASUS TRX50 and WRX90E series.
Enhanced reading of DIMM SPD on AMD Storm Peak systems.
Added new Intel Arc models.
Minor updates and bugfixes.
Added NVIDIA GeForce RTX 4080 SUPER.
Improved monitoring of chipset temperature for some older Intel PCHs.
Added reporting of AGESA version on some later mainboards.
Fixed VRM monitoring after resume from standby on some GIGABYTE mainboards.
Added VRM VOUT monitoring on later ASUS mainboards.
Fixed a possible crash in NVML during NVIDIA GPU driver update.
Fixed a possible BSOD on systems with locked PCI configuration access.
Added preliminary Intel NPU support.
Added fan speed monitoring on ASUS TUF Gaming F17 FX707ZM.
HWiNFO has released
v7.68 of it's Hardware monitoring app:
Latest v7.68
Released on Dec-19-2023
Enhanced sensor monitoring on ASRock TRX50 WS.
Added monitoring of GIGABYTE WATERFORCE X II series coolers.
Added monitoring of Intel NPUs.
Added monitoring of NVIDIA GPU Crossbar Clock.
Optimized sensor polling with disabled CPU sensors.
Improved appearance of some controls in Dark Mode with high scaling.
Improved support of Intel Arrow Lake.
Enhanced preliminary support of Intel Panther Lake.
Fixed a possible crash in PresentMon when launching an application with non-ANSI name.
Added fan speed monitoring on ASUS ROG Strix G614JV.
Improved support of some ASPEED BMCs.
Added temperature monitoring of AMD CPU VRMs via SVI3.
Added monitoring of IPU Clock and Usage on AMD Phoenix and Strix.
Enhanced sensor monitoring on Maxsun mainboards.
Improved S.M.A.R.T. reporting on some USB NVMe drives with ASMedia controller.
Added HWiNFO Manual in the installer package
HWiNFO has released
v7.72 of it's Hardware monitoring app:
Latest v7.72
Released on Feb-05-2024
Fixed a possible crash on some older NVIDIA GPUs.
Fixed erratic behavior during hiding of sensor items.
HWiNFO has released
v8.02 of it's Hardware monitoring app:
Latest v8.02
Released on May-07-2024
Added workaround for Windows Defender messing up Effective Clock and C0 Residency counters.
Added improvements for Auto Start.
Enhanced support and monitoring of Moore Threads GPUs.
Updated PresentMon to v2.0.0.
Added support of Razer PWM PC Fan Controller.
Added preserving of independent OSD window position.
Added monitoring of VR VOUT, IOUT and POUT via SVID (Intel).
Improved accessibility controls.
Restored WinPE compatibility.
Improved support of AMD Zen5 family.
Added limited support of OnSemi NCP81530 and NCP81537 PWMs.
Minor GUI updates.
Fixed sensor monitoring on some GIGABYTE Z790/B760 A series.
Fixed fan names on GIGABYTE TRX50 AERO D.
HWiNFO has released
v8.04 of it's Hardware monitoring app:
Latest v8.04
Released on Jun-12-2024
Fixed stuck PresentMon values after terminating graphics application.
Enhanced detection of NCP8153x PWMs.
Always On Top setting is also applied to OSD Independent Window.
Enhanced reporting of connected USB device speed and connector type.
Added new Intel Battlemage, Melville Sound and Celestial models.
Enhanced support of next-generation AMD APUs.
Improved AMD SMU access synchronization.
Added support of Nuvoton NCT6701D.
Enhanced support of some next-generation ASUS systems.
Enhanced support of Intel Arrow Lake.
Updated launcher to pass arguments through.
HWiNFO has released
v8.06 of it's Hardware monitoring app:
Latest v8.06
Released on Jul-23-2024
Updated PresentMon to v2.1.0.
Minor GUI updates, graphs use shading.
Added displaying of PresentMon monitored process in sensor title.
Added reporting of PresentMon CPU Wait, CPU Busy, GPU Wait.
Added support of Corsair HX1200i PSU (new model).
Added monitoring of Thermal Zones via ACPI sensor.
Enhanced support of Intel Panther Lake.
Enhanced sensor monitoring on next-generation MSI mainboards.
HWiNFO has released
v8.10 of it's Hardware monitoring app:
Latest v8.10
Released on Aug-20-2024
Introducing HWiNFO® ARM64.
Updated hybrid core naming.
Improved support of AMD Strix1 and Granite Ridge.
Enhanced support of ZHAOXIN KaiXian KX-7000.
Added support of ITE IT8696E LPC/SIO.
Enhanced sensor monitoring on next-generation GIGABYTE mainboards.
ARM64: Improved reporting of Qualcomm Snapdragon X1P and X1E.
Improved enumeration of some JMicron and ASMedia USB-SATA bridges.
Enhanced sensor monitoring on ASUS ROG MAXIMUS Z890 series.
Added support of Infineon XDPE192C3 PWM.
Added ASUS ROG theme. Available on ASUS ROG boards only.
