pstein
Whenever I came back to these forums I have to re-enter my login name and password.
Other forums offer an automatic re-login with the login name and password stored in the local browser cookie.
I HAVE enabled the cookie
windows7forums.com
but the auto-re-login does not work.
Is this feature completely disabled here?
Or is there an expiry time?
Peter
Mitchell_A
Former Moderator
I'm unsure if it expires, but if it does, it wouldn't be for at least a month.
If you're using IE 9, you may find the checkbox to be there, but no text (right under the login field).
Check the box and you should stay logged in. If not, check your browser settings (cookies, etc).
