The original poster, pstein, is experiencing issues with auto-login on windows7forums.com despite enabling cookies, questioning whether the feature is disabled or if there's an expiry time. Mitchell_A suggests that if the auto-login feature does expire, it would be after at least a month and advises checking the "Remember Me" checkbox in IE 9 or reviewing browser cookie settings. The overall discussion revolves around troubleshooting persistent login issues on the forum.
pstein
Whenever I came back to these forums I have to re-enter my login name and password.
Other forums offer an automatic re-login with the login name and password stored in the local browser cookie.
I HAVE enabled the cookie
windows7forums.com
but the auto-re-login does not work.
Is this feature completely disabled here?
Or is there an expiry time?
Peter
Mitchell_A
Former Moderator
I'm unsure if it expires, but if it does, it wouldn't be for at least a month.
If you're using IE 9, you may find the checkbox to be there, but no text (right under the login field).
Check the box and you should stay logged in. If not, check your browser settings (cookies, etc).
