- Joined
- Jul 22, 2005
- Messages
- 9,256
- Thread Author
- #1
Download Revo Uninstaller Pro: http://bit.ly/H2JWXD
In this video, I am going to demonstrate and review Revo Uninstaller. Revo Uninstaller is a freeware application that helps you to uninstall applications on your computer that would otherwise leave registry keys, system files, dynamic link libraries, and other errant files all over your computer, even after you uninstall the program. This is commonplace, with a lot of programs, especially when you look at anti-virus software and anti-malware software. In many cases, in order to fully uninstall a program like Norton or Symantec, you will have to go and actually download, even after you uninstall the program, an additional utility to fully uninstall the anti-virus program. This is kind of ridiculous, but the primary reason that this happens is because of the amount of development time that goes into the uninstaller of a program. When programs are developed, the enormity of the time is often spent on the development of the application itself, and not necessarily the installer or the uninstaller of the application. In fact, there are companies that sell software that help developers quickly create an installer and an uninstaller of a program. For example, you may have heard of TrustedInstaller, InstallShield, and MSI, which of course, is the Microsoft system for the installation, uninstallation, and deployment of applications.
I am going to show you how this software works. First of all again, I would like to re-iterate that it is free, but this program will also help you quickly get rid of registry keys that are left over on your computer that will not be identified by registry cleaning software. It will help you to completely eliminate the files and folders that are left over by tens of thousands of applications, written by some of the best companies in the world, which simply just leave files on your computer. The reason why this is important is that, over time, your computer gets filled up with junk, you're running out of space, and all of a sudden you realize that you have a whole bunch of files on your computer from programs that you uninstalled years ago.
