whoosh
Cooler King
:iee:
MORE FPS | Nvidia Resizable Bar | How to enable it on your system | Nvidia 3000 series and above. In the latest video by Sim Hangar, viewers receive a comprehensive guide on enabling the Nvidia Resizable Bar feature, specifically tailored for Nvidia graphics cards from the 3000 series and above. The Resizable Bar is a technology that can potentially enhance overall system performance, particularly in gaming scenarios.
What is Resizable Bar?​
Resizable Bar is an extension of the PCI Express expansion bus, allowing the CPU to access the GPU's memory more efficiently. It operates similarly to AMD's Smart Access Memory, providing the CPU with broader access to the graphics card’s framebuffer, resulting in improved performance in certain applications.
Key Insights from the Video​
  • Compatibility Checks: Before enabling the feature, users must ensure their system supports it. This involves verifying that you are using a compatible motherboard and CPU, and that both the motherboard and GPU have the latest BIOS updates.
  • Steps to Enable: The guide walks viewers through the various checks required:
  1. Nvidia Control Panel: Users are encouraged to check if Resizable Bar is available by navigating to the system information section within the Nvidia Control Panel.
  2. Disk Management: Confirming that the boot drive is initialized with a GPT partition style is essential, as MBR will not support the feature.
  3. System Information: Users should also check BIOS mode to ensure it is set to UEFI, required for Resizable Bar function.
    Detailed Instructions​
    The video then details the BIOS configuration process:
    1. Updating the BIOS: Ensure it’s the latest version to support Resizable Bar. Different graphics cards have specific methods for this, so users may need to refer to their manufacturer’s site for the correct procedures.
    2. Modifying BIOS Settings: Navigate to advanced settings to enable features like Above 4G Decoding and Resizable Bar Support.
    3. Disabling Compatibility Support Module (CSM): This step is crucial and should only be attempted if the previous checks confirm compatibility.
      Performance Impact​
      While the boost in FPS may not be monumental, every bit counts, especially in demanding scenarios like VR gaming or detailed aircraft simulations. The overall message emphasizes that users should not expect dramatic performance increases, but rather incremental improvements that could enhance gaming experiences.
      Enabling the Resizable Bar can be a worthwhile endeavor for gamers using compatible systems. The video concludes by encouraging viewers to take these steps carefully and to share their experiences in the comments. If you’ve tried enabling the Resizable Bar or have questions about the process, feel free to share your experiences or ask for further assistance!​
      This analysis is designed to provide a summary and insights from the video to engage our community here at WindowsForum.com. What are your thoughts on this feature? Have you noticed performance improvements from similar tweaks in your system?
