This thread discusses an innovative DIY water cooling solution for managing high temperatures in a server room, featuring a creative use of a car radiator and other household items. The initial post outlines the team's approach, installation process, and positive results in reducing ambient temperature, with plans for future improvements. Overall, the tone is positive and encourages experimentation with unconventional cooling methods in tech setups.
whoosh
Cooler King
:iee:
Water Cooling My House - Whole Server Room Pool Watercooling Part 2 In the latest episode of "Water Cooling My House," the team tackles a persistent problem: excessive heat building up in their server room. The current temperature of 31 degrees Celsius has become alarming, leading to overheating issues with their hard drives. This video not only dives into the creative DIY solutions they employ to cool their setup but also showcases a unique application of water cooling normally reserved for data centers.
Key Highlights​
The video begins with a recount of the challenges posed by the high temperatures where the PCs are operating. In a typical response to overheating, air conditioning is a straightforward fix. However, the team opts for a more unconventional approach, proposing to use a car radiator from a Chrysler PT Cruiser, duct tape, and some creativity to manage their server room's heat. Their method is inspired by techniques used in large-scale data centers which typically use a combination of air and water cooling to efficiently manage thermal conditions. They plan to install a radiator at the back of the server, where the hottest air is expelled, thus maximizing the heat exchange efficiency.
DIY Cooling Setup​
What follows is a fascinating look at their installation process:
  • Piping and Radiator Setup: The team runs pipes from the mechanical room outside to the pool area, where they hope to dump excess heat. Although their pool isn't finished, they devise a temporary solution to effectively channel heat away from the server room.
  • Utilization of Car Radiators: By employing a Chrysler PT Cruiser radiator, they draw upon a commonly available part to facilitate the cooling process.
  • Innovative Fan Usage: To properly circulate air through the radiator, the team mounts fans. They discuss power management for these fans and the unique challenges they face during installation, such as the need to adapt old connections.
Temperature Results​
After setting up the system, they measure the effectiveness of their adjustments. The intake air temperature drops significantly, illustrating that their temporary cooling solution is more effective than anticipated.
Conclusion and Future Plans​
The video's playful tone intersperses technical analysis with humorous banter, making it engaging for viewers. As they close, they reflect on their successes and the potential need for more permanent solutions in the future, especially with plans to scale further. This inventive approach demonstrates that with some ingenuity, even seemingly mundane components can provide critical solutions to modern thermal management challenges. If you're interested in energy efficiency and innovative problem-solving within your tech setups, this video is a must-watch!
Join the Discussion!​
What do you think about using creative methods like repurposing car parts for tech cooling? Have you tried anything unconventional in your own setups? Share your thoughts and experiences below!
