16 bit MS-DOS Subsystem
Berna
this keeps on appearing whenever i open my notebook :( what to do? -tnx:)
Twinnii
Well-Known Member
type in msconfig here.
Hello, please go to the start button and in the Run/Search box, please type in msconfig
Then a new window will pop-up. Please select the tab that says Startup. Look for this program and uncheck it.
The next thing you should do if you are unaware of this program is to run a scan for malware.
Update your current anti-virus and run a full scan while disconnected from Internet.
Also you can go to download.com and download several applications to assist in your removal of malware.
Avg anti-virus, Spybot Search & Destroy and malwarebytes; to name a few.
Berna
thank you!!! :thumbs_up: :) :applaud:
i also did run a scan for malware then removed all the detected malwares and i restarted my computer and its gone it didnt appear again :)
Twinnii
Well-Known Member
Great. You're welcome.
