Windows 7 2 monitor screens running independently
TsAmE
Well-Known Member
Hi all. I have a Dell Inspiron 1420 and a Samsung SyncMaster 226BW, which are both connected to each other. My graphics card is the NVIDIA 8400 GS and I am using Windows 7.
I have setup the dual screen e.g. my laptop screen is a mirror image of the Samsung and vice a versa.
What I want is to run Linux via a virtual machine on the one screen, while reading tutorials and other media on the other screen, with out constantly minimizing and maxing on one screen.
What is the procedure to do this? Help would be much appreciated.
To achieve the setup you're looking for, where you can run Linux via a virtual machine on one screen while using the other screen for tutorials and media, you can follow these general steps: 1. Set Up a Virtual Machine: - Download a virtual machine software like VirtualBox or VMware Player on your Windows 7 machine. - Install a Linux distribution of your choice within the virtual machine. Ubuntu, Linux Mint, or CentOS are popular options for beginners. 2. Adjust Virtual Machine Display Settings: - In the virtual machine software, configure the display settings to run the virtual machine in full-screen mode on one monitor. - You can typically find these settings under "Display" or "Screen Resolution" within the virtual...
To achieve the setup you're looking for, where you can run Linux via a virtual machine on one screen while using the other screen for tutorials and media, you can follow these general steps: 1. Set Up a Virtual Machine: - Download a virtual machine software like VirtualBox or VMware Player on your Windows 7 machine. - Install a Linux distribution of your choice within the virtual machine. Ubuntu, Linux Mint, or CentOS are popular options for beginners. 2. Adjust Virtual Machine Display Settings: - In the virtual machine software, configure the display settings to run the virtual machine in full-screen mode on one monitor. - You can typically find these settings under "Display" or "Screen Resolution" within the virtual machine software. 3. Extend Desktop Across Multiple Monitors: - Ensure that your graphics card supports multiple monitors and that both monitors are correctly detected in the NVIDIA control panel (NVIDIA Control Panel > Set up multiple displays). - Configure the displays to extend desktop rather than mirror them (NVIDIA Control Panel > Change resolution > Multiple displays). 4. Work Across Both Screens: - Once the virtual machine is set to full-screen on one monitor, you can interact with it as if it were a physical machine. - Use your primary screen for tutorials, media, or any other tasks you want to perform simultaneously. By following these steps, you should be able to run Linux on one screen via a virtual machine while using the other screen for different tasks without needing to constantly minimize and maximize windows between screens. For more specific guidance on configuring screen settings or setting up the virtual machine, feel free to ask for additional help!
