VIDEO Acronis True Image 2012 Quick Review
Mike
Windows Forum Admin
Get Acronis: Link Removed
While I have been disatisfied with the latest versions of Acronis applications for SMB workstations, mid-range businesses, and enterprise environments, it is hard not to like Acronis True Image Home 12. The application is easy to use, making backup and restore of entire systems an easy task. The great feature set makes up for the strict licensing and activation agreement, but avoid, in my opinion, the online backup options, as there are better alternatives.
Acronis True Image Home 12 Quick Review In a video review from 2012, Mike from Windows 7 Forums discusses Acronis True Image Home 12, highlighting its usability and feature set. While the user expresses dissatisfaction with later versions of Acronis applications for SMB workstations and enterprises, this version stands out for its simplicity in backup and restoration processes, which is a key benefit for personal and business applications.
Key Features and Recommendations​
  1. User-Friendliness: True Image Home 12 offers an intuitive interface that simplifies the process of backing up entire systems. This is contrasted with previous versions which had more complexity and issues during backup operations.
  2. Licensing and Activation: The review notes that each installation requires a legitimate license for activation, emphasizing that the software is tied to per-machine licensing. Users should be aware of this if they plan on using it across multiple devices.
  3. Backup Options: The program supports various backup methods, including full backups, and allows users to choose different partitions for backup. Mike mentions that while he prefers full backups, there are incremental options available as well. However, he suggests avoiding reliance on incremental backups due to occasional performance issues.
  4. Performance: The backup process is described as seamless, with enhancements in the latest version enabling users to backup while the system is online. This adds a layer of convenience that was lacking in earlier versions.
  5. Online Backup Alternatives: Mike critiques the online backup feature of Acronis, finding it expensive and suggesting that alternative services like Windows Live SkyDrive or Dropbox may offer better value for users looking to store backup files online.
  6. Create Bootable Media: The ability to create bootable media for offline backups is highlighted as an essential feature. This allows users to perform system recoveries without needing to access the operating system.
  7. Need for Caution: While Acronis True Image Home 12 is seen as a reliable backup solution, the review stresses the importance of not running background processes during backups to ensure stability and performance.
  8. Best Application for Personal Use: In conclusion, the reviewer considers Acronis True Image Home 12 as a top choice for individuals looking for thorough backup solutions, although businesses with complex needs may require different solutions like Acronis’s enterprise offerings.
    Community Discussion​
    This review raises interesting points about the evolution of backup solutions in the years since its release. With newer versions of Acronis and other competitors continuously improving, what are your thoughts on the effectiveness of backup software in 2024? Has your experience with Acronis changed, or have you found better alternatives? Feel free to share your experiences or questions below!
