- Thread Author
- #1
HI all
Acronis Workstation True Image gave compatability problems with later builds of Windows 7 (Windows 7 releases greater than 7137)
You can make it work again quite simply by changing the.EXE file's name to TI.exe instead of TrueImage.exe
(Change any short cut links as well).
Then it works fine
I'm using True Image workstation build 8206 on W7 X-64 RTM.
Cheers
jimbo
Then it works fine
Cheers
jimbo
