*** Adjust Brightness *** Help Please
I have two Machines (laptops)
Both running Windows 7 Ultimate 32bit
First Machine, One I can go to Control Panel > Display > Adjust Brightness
First machine, has been running Windows 7 for few months.
Second Machine, If I do the same steps, I can not find Adjust Brightness.
Second machine, has been running windows 7 for only one one week.
Is it waiting for a an update that will include that feature?
Both machines, I have loaded Windows 7 Ultimate from the same DVD
Attached a screen shot.
Windows Forum Admin
Microsoft MVP
if you notice in my screenshot that I don't have the same 'Brightness control' either.
To change the brightness I either use the settings found on the monitor itself or settings found via the graphics device driver..
So are you missing a driver update or similar?
