ADMANITY Persuasion Protocol: Turning AI Outputs into Conversion Across LLMs
ADMANITY says five leading AI systems told the company that the single largest category of business queries — marketing and emotional persuasion — is not being handled reliably by current large language models, and the startup claims its ADMANITY® Protocol and upcoming PRIMAL AI™ solve that gap with a portable emotional persuasion layer that converts factual outputs into predictable, conversion‑oriented copy across multiple LLMs.
Neon blueprint of the Mother Algorithm cube above an Admanity Protocol funnel (Recognition to CTA) with AI icons.Background / Overview​
ADMANITY, a Phoenix‑based startup led by CEO Brian Gregory, recently rolled out an aggressive PR campaign claiming a model‑agnostic persuasion technology that it says was validated in cross‑vendor "Toaster Test" experiments with OpenAI’s ChatGPT, xAI’s Grok, Google’s Gemini, Microsoft Copilot, and Anthropic’s Claude. The company frames the problem bluntly: businesses ask AI for persuasive marketing copy and routinely receive informative but emotionally flat text, producing low conversion and high churn. ADMANITY presents the ADMANITY® Protocol and a sequestered "Mother Algorithm" as a deterministic emotional sequence that LLMs can follow to produce persuasive outputs in one pass.
Two key administrative signals ADMANITY highlights are a filed trademark for PRIMAL AI and a rapidly rising Crunchbase profile with high Heat Scores and founder ranking movements — metrics it uses to demonstrate market traction and interest. The company also published a series of syndicated press releases that recount model interactions and claim significant compute and conversion improvements when PRIMAL AI instructions are applied.
These announcements land at the intersection of two broad industry realities: (1) LLMs are powerful pattern‑matching engines that excel at information synthesis but are not designed as native emotional persuasion engines; and (2) monetization at scale for AI platforms increasingly depends on delivering measurable business outcomes — such as higher conversion rates — not only correct facts. ADMANITY’s pitch: the first platform to offer reliable, auditable, repeatable persuasion that demonstrably lifts conversions will capture a substantial commercial moat.
What ADMANITY is claiming​
The headline assertions​
  • ADMANITY says five major LLMs independently confirmed that roughly 35–50% of business queries concern marketing and persuasion tasks and that current systems lack systematic frameworks for emotional persuasion.
  • The company reports that baseline LLM output is often "flat, logical, and factual" while its ADMANITY® Protocol can transform that same input into persuasive copy in a single pass (the "Toaster Test"), producing faster, iterated‑free outputs with measurable conversion architecture.
  • ADMANITY claims substantive operational and monetization benefits: reduced compute, halved generation time in tests, and potential multi‑billion dollar addressable markets if platforms monetize persuasion as a premium feature.
  • The company also touts rapid Crunchbase rank movement and trademark filings as evidence of traction and imminently strategic acquisition interest.
What’s verifiable today — and what is not​
  • Verifiable: ADMANITY’s public filings and press distribution (trademark filing for PRIMAL AI and an active Crunchbase profile) are visible in the public record and have been widely syndicated. The company has published demonstration narratives (YES! TEST, Toaster Test) and distributed them to press outlets.
  • Unverified: There is no public, vendor‑signed confirmation from OpenAI, Google, Microsoft, Anthropic or xAI that they formally endorsed or independently audited ADMANITY’s claims or Toaster Test methodology. The specific percentage breakdowns (e.g., 35–50% of business queries) and precise failure/churn statistics attributed to each platform appear to come from ADMANITY’s internal interactions and experimental transcripts rather than third‑party telemetry. Treat those headline figures as company‑originated until independent audits are published.
Why the core technical idea is plausible​
LLM behavior and instruction sensitivity​
Large language models are highly sensitive to prompt structure, context and exemplars. Engineering patterns that steer LLM outputs — prompt engineering, instruction tuning, prefix/prompt adapters, LoRA, middleware rewriting and reranking — are already established practices used by practitioners to modify tone, enforce brand voice, and optimize for task‑specific behaviors. Encoding a prescriptive emotional sequencing (e.g., problem recognition → resonance → social proof → urgency → CTA) into prompts or as an external adapter can change output behavior, often dramatically. This makes the concept of a persuasion "overlay" technically plausible.
Integration patterns and trade‑offs​
  • Prompt wrapper (fastest, vendor‑agnostic): cheap to deploy but token‑expensive and brittle across differing system prompts and safety overlays.
  • Adapter/internalization (LoRA/prefix tuning): efficient at scale, persistent behavior across calls, but requires hosting access or vendor cooperation.
  • Middleware/orchestration (post‑generation rewrite or ranking): works across closed APIs and is auditable, but adds latency and operational complexity.
If the ADMANITY Protocol reduces the number of iterations required for publishable copy, token costs and latency can fall in practice. That is an empirically testable claim and a legitimate engineering path to reduce compute expense. However, cross‑model portability at scale is non‑trivial: vendor system prompts, decoding strategies, safety filters and verbosity settings vary, so a one‑size‑fits‑all "zero‑shot" portability claim needs reproducible benchmarks.
Critical analysis: strengths, credibility, and evidence gaps​
Notable strengths​
  • The pitch meets a real market pain: many SMBs and mid‑market buyers want measurable sales outcomes from AI — not only coherent descriptions. Automation that reliably increases conversion rates could deliver major ROI and become a premium platform capability. ADMANITY’s framing aligns with this commercial logic.
  • The technical idea maps cleanly to known LLM controls. There is nothing conceptually impossible about codifying persuasion sequences and using them as guidance or adapters to bias outputs toward emotional resonance.
  • Administrative signals (trademark filing, Crunchbase momentum) indicate market visibility and a go‑to‑market push that could attract partner interest if the product proves reproducible.
Major evidence gaps and credibility issues​
  • The most consequential assertions — that five major AI platforms independently confirmed the 35–50% persuasion‑query figure and agreed they lack native emotional persuasion frameworks — are presented in ADMANITY’s PR materials based on interactions the company controlled. There is no public, vendor‑signed telemetry or independent auditing that corroborates those platform‑level percentages or vendor endorsements. Those claims should be read as claims, not platform policy statements.
  • Conversion uplift and latency improvements are reported in company demos, not in reproducible, third‑party randomized trials with published raw logs, model versions, prompt transcripts, and statistically powered A/B analyses. Extraordinary commercial claims (multi‑billion dollar monetization upside, guaranteed conversion rates) require extraordinary evidence — which is not yet publicly available.
  • Crunchbase rank and Heat Score movements are interesting attention signals but are not technical validation. They can reflect PR traction rather than product efficacy; treat them as market interest metrics, not proof of universal effectiveness.
Independent corroboration where available​
Independent technical literature and industry research confirm two crucial premises: (1) LLMs operate largely as statistical, pattern‑matching systems and can produce outputs that sound persuasive without a model of human emotion, and (2) affective computing and emotional AI remain nascent with serious challenges around dataset bias, cultural nuance and ethical constraints. These independent findings support the plausibility of ADMANITY’s thesis — that emotional persuasion is a distinct engineering problem — but they do not validate the company's specific numeric claims or vendor endorsements.
Business and monetization implications​
Why platforms would pay for reliable persuasion​
  • Ad economics scale: small percentage conversion uplifts on massive advertising and commerce funnels translate into billions of dollars in incremental value for platform owners and merchants. ADMANITY frames the opportunity as a new monetization layer for LLMs, CRMs and martech stacks. The arithmetic is straightforward and compelling at scale.
  • Productization paths: vendors could offer persuasion as a premium API add‑on, a "Copilot Revenue Edition", or outcome‑based pricing. Martech vendors and CRM providers could upsell this capability to SMEs lacking agency budgets.
Business risks and vendor calculus​
  • Build, partner, or block: platform owners face three choices — build an in‑house persuasion stack (control, high cost), partner/license (speed, vendor dependency), or block/limit features (avoid regulatory and reputational exposure). Any decision will hinge on reproducible evidence, safety audits, contractual protections and the vendor’s appetite for regulatory risk.
  • Vendor dependency and antitrust risk: if a single third party becomes the gatekeeper to conversion performance, platforms and advertisers could face vendor lock‑in and antitrust scrutiny — a material strategic consideration.
Ethics, safety and regulatory perspective​
Manipulation vs. persuasion​
The line between legitimate persuasion (transparent, non‑exploitative) and unethical manipulation (covert, exploiting vulnerabilities) is legally and ethically salient. Recent academic and regulatory discussion increasingly treats manipulative automated systems as high‑risk. A persuasion layer that systematizes emotional nudging at scale invites scrutiny under consumer protection law, advertising standards and emerging AI regulation frameworks.
Regulatory landscape and enforcement trends​
  • EU AI Act: includes provisions that address manipulative systems and categorizes some forms of emotional targeting as prohibited or high‑risk; automated persuasion used to exploit vulnerabilities could trigger compliance obligations and audits under the Act.
  • U.S. oversight: the Federal Trade Commission has signaled scrutiny of deceptive or manipulative chatbot and AI uses; the regulatory tide is moving toward enforcement on transparency, unfair practices and deceptive claims. Companies must be prepared for consequence management if persuasion features mislead consumers.
Practical governance requirements​
Any vendor or platform integrating automated persuasion should implement these safeguards:
  • Human‑in‑the‑loop approvals for high‑impact content and regulated domains.
  • Auditable experiment logs (full prompts, model versions, token accounting, time‑stamped outputs) for contractual and regulatory review.
  • Explicit redlines and non‑deployment zones (e.g., political messaging, health claims, offers to vulnerable groups) baked into both technology and contracts.
  • Clear consumer disclosures where persuasive automation is used and opt‑out mechanisms where appropriate.
How IT, marketing and procurement teams should evaluate ADMANITY (or any persuasion‑layer vendor)​
  • Define outcome metrics clearly: conversion rate, average order value, refund/complaint rates, and customer retention.
  • Demand auditable evidence: raw prompts, model parameters (temperature, decoding), model versions, token counts and time‑stamped output logs under NDA or in a sandbox.
  • Run randomized A/B tests with statistically powered sample sizes: baseline (current copy) vs. vendor‑augmented outputs vs. human high‑quality control. Publish methodology and guard for p‑hacking.
  • Insist on human approval gates and safety filters during rollout; define explicit redlines for vulnerable populations and regulated messages.
  • Negotiate contractual protections: indemnities, non‑training clauses (to prevent model retraining), audit rights and SLAs tied to auditable metrics.
A recommended 12‑week pilot roadmap (high level):
  • Weeks 1–2: Select representative funnel and capture baseline metrics.
  • Weeks 3–6: Integrate vendor guidance via middleware or prompt wrapper; generate multiple variants and instrument tracking.
  • Weeks 7–10: Run randomized experiments, collect downstream metrics and monitor safety signals.
  • Weeks 11–12: Evaluate results, conduct legal and compliance reviews, and decide on scale and contract terms.
The ADMANITY narrative — measured verdict​
ADMANITY’s central thesis — that current LLMs do not natively encode a formal, repeatable emotional persuasion framework and that a portable, auditable persuasion layer could unlock substantial commercial value — is credible at a conceptual level and anchored in known model dynamics and marketing science. The ADMANITY® Protocol maps onto well‑understood engineering patterns and addresses a genuine market pain: turning AI‑generated content into measurable revenue.
However, the company’s most headline‑grabbing assertions — that five leading AI platforms independently confirmed specific usage percentages and endorsed PRIMAL AI — rest on ADMANITY’s controlled interactions and press transcripts rather than on vendor‑signed confirmations, published audits or reproducible A/B test artifacts. Those company‑originated numbers and platform quotes should be treated with caution until independent verification (audited logs, third‑party labs, or vendor statements) appears in the public record.
What to watch next​
  • Independent replication: publication of raw prompts, model versions, and reproducible A/B test logs will move ADMANITY’s claims from interesting demo to production proof.
  • Vendor responses: formal statements from OpenAI, Google, Microsoft, Anthropic or xAI either corroborating or distancing themselves from the Toaster Test will materially affect credibility and partnership prospects.
  • Regulatory cues: concrete enforcement actions or clarifying guidance on automated persuasion from bodies like the FTC, EU regulators or national advertising authorities will shape acceptable product designs.
  • Market adoption signals: pilots with verifiable, published outcomes in enterprise customers (with audit logs) will be the clearest indicator of product‑market fit and durable monetization.
There is a clear and credible opportunity at the intersection of emotional persuasion and LLM output control: businesses want not just coherent content but copy that reliably drives human action. ADMANITY has packaged a compelling narrative, administrative traction and demonstration artifacts around PRIMAL AI and the ADMANITY® Protocol. Technically, a persuasion overlay is plausible and maps to known instruction and adapter patterns; commercially, conversion uplift is an easy sell because of the enormous downstream value.
At the same time, the boldest claims in ADMANITY’s rollout — uniform vendor confirmations, specific platform telemetry, and guaranteed conversion uplifts — remain company‑originated and have not been independently audited or vendor‑endorsed in the public domain. Buyers, platform owners and investors should therefore proceed with rigorous pilots, auditable evidence requests, contractual protections and ethical guardrails before treating promotional metrics as production facts. The first vendor to produce reproducible, auditable, and governed persuasion outcomes at scale will indeed rewrite monetization plays for LLMs — but proving that to regulators, customers and independent labs will determine whether the claim is transformative or merely persuasive marketing.
Source: The Globe and Mail AI Platforms Are Having Problems Giving Business Customers Persuasion-Oriented Solutions Says Brian Gregory, of ADMANITY – Creator of The ADMANITY Protocol and PRIMAL AI.
Neon AI infographic for Admanity Primal AI featuring Toaster Test and an emotional arc.
ADMANITY, a Phoenix‑based startup led by CEO Brian Gregory, has set off a contentious conversation in AI and marketing circles by announcing that five leading large language model platforms — ChatGPT, Grok, Copilot, Gemini and Claude — admitted they lack a native, systematic framework for emotional persuasion, and that ADMANITY’s ADMANITY® Protocol and forthcoming PRIMAL AI™ persuasion layer can fill that gap across models. The company’s press rollout claims that roughly 35–50% of business‑oriented AI queries are persuasion‑focused, that baseline LLM outputs are often “flat, logical, and factual,” and that a portable overlay can convert those outputs into high‑conversion, emotionally driven copy with measurable speed and cost advantages. The announcement includes demonstrations the firm calls the Toaster Test and the YES! TEST, a trademark filing for PRIMAL AI, and an account of dramatic visibility gains on Crunchbase — but independent analyst collations stress that the most consequential vendor confirmations and quantitative claims remain company‑sourced and have not been corroborated by third‑party audits or vendor‑signed statements.
Background​
The claim in one paragraph​
ADMANITY frames the situation as an “AI monetization crisis”: businesses want persuasive, conversion‑focused content but receive information‑heavy output from LLMs. The startup argues that the largest single category of business AI use — emotional persuasion and marketing — is under‑served because current models were not designed with a codified emotional strategy. ADMANITY says its ADMANITY® Protocol (the so‑called “Mother Algorithm”) encodes that strategy and that PRIMAL AI™ is a model‑agnostic persuasion layer capable of producing predictable conversion‑oriented outputs across major hosted LLMs.
Why this matters now​
Large language models have become mainstream in marketing, sales automation, customer support and content operations. Vendors and enterprises increasingly measure success by downstream outcomes (clicks, leads, conversions) rather than by how “coherent” or “informative” an output looks. If a portable persuasion layer can reliably and ethically lift conversion metrics, platforms and martech stacks could monetize that capability as a premium product — which explains the intensity of interest around ADMANITY’s announcement. Independent analyses find the underlying technical idea plausible — steering LLMs with deterministic instruction sequences, adapters, or middleware is an established pattern — but they also flag a shortfall of verifiable evidence supporting the release’s headline numeric claims and vendor endorsements.
What ADMANITY Says It Did and Claimed Results​
Headline assertions​
  • Five major LLMs independently confirmed that 35–50% of business queries are persuasion and marketing tasks.
  • Baseline LLM responses are probabilistic pattern outputs lacking a systematic emotional persuasion framework.
  • The ADMANITY® Protocol can convert neutral product descriptions into persuasive copy in a single pass (the Toaster Test), reducing iteration and compute time.
  • PRIMAL AI™ (trademark filed) and the protocol are model‑agnostic and commercially productizable as a monetization layer for hyperscalers, CRMs and martech vendors.
Demonstrations and administrative signals​
ADMANITY’s public rollout references two demonstration artifacts — the YES! TEST and the Toaster Test — which the company says show consistent conversion‑ready outputs across multiple LLMs. The firm also cites a PRIMAL AI trademark filing (serial number referenced in its materials) and a rapid rise in Crunchbase metrics as proof of traction. Those administrative facts are visible in the public record and were emphasized throughout ADMANITY’s press distribution.
What Independent Reviewers and Analysts Verify — and What They Don’t​
Verifiable items​
  • The trademark application for PRIMAL AI is publicly recorded and visible in registries referenced by ADMANITY.
  • ADMANITY’s Crunchbase profile exists and shows elevated attention signals (Heat Score and rank movement) that the company cites in its PR.
Items that remain unverified in the public domain​
  • There is no vendor‑signed confirmation from OpenAI, Google, Microsoft, Anthropic, or xAI that they formally validated ADMANITY’s methodology or the numeric telemetry ADMANITY attributes to those platforms.
  • The precise percentage ranges (e.g., 35–50% of business queries) and the failure/churn statistics attributed to each platform appear to derive from ADMANITY’s controlled interactions and experimental transcripts, not from vendor logs or independent telemetry. Those are company‑originated operating metrics at this stage.
Analysts conclude the central technical idea is plausible but emphasize that extraordinary commercial claims require reproducible, auditable results: raw prompts and logs, model versions, A/B plans, and statistically powered outcome studies. Until those artifacts are published or third parties replicate the results, treat headline claims as promising but not proven.
Why the Technical Idea Is Plausible — and How It Would Work​
LLMs are manipulable via instruction and adapters​
Modern LLM families are sensitive to instructions, exemplars and context. Software engineering patterns to bias behavior already exist:
  • Prompt engineering and carefully structured instruction wrappers.
  • Adapter techniques (prefix tuning, LoRA) that persist behavior without full fine‑tuning.
  • Middleware that rewrites or re‑ranks candidate outputs to favor a given persuasive structure.
These approaches make a portable persuasion overlay technically feasible in constrained tests. ADMANITY’s proposal — encoding a repeatable emotional arc (problem → resonance → social proof → urgency → CTA) as a compact instruction set — aligns with known engineering practices.
Practical integration patterns and trade‑offs​
  1. Prompt wrapper (fastest, vendor‑agnostic)
    • Pros: Rapid deployment, works with closed APIs.
    • Cons: Token‑expensive at runtime; brittle across system prompts and safety overlays.
  2. Adapter/internalization (LoRA / prefix tuning)
    • Pros: Efficient at scale; lowers per‑query cost once deployed.
    • Cons: Requires hosting control or vendor cooperation; may be unavailable on closed APIs.
  3. Middleware/orchestration (post‑generation rewriting or ranking)
    • Pros: Works with closed hosted models; auditable externally.
    • Cons: Adds latency and operational complexity; requires robust monitoring.
A persuasion layer that materially reduces the number of edits and iterations can lower token usage and latency in practice — but the degree of improvement depends heavily on model family, decoding strategy, and model safety filters.
Evidence Gaps and Credibility Concerns​
Vendor endorsements versus claimed model outputs​
ADMANITY’s press materials include quoted model outputs and statements attributed to each named LLM family. Independent reviewers point out that presenting model responses as confirmations is not the same as a vendor endorsement or telemetry disclosure. There is a meaningful distinction between a transcript of a prompt exchange and an official validation from a platform provider, and that distinction matters for buy‑side decisions.
Need for reproducible benchmarks​
To convert a compelling prototype into an enterprise‑grade product, ADMANITY or any vendor must publish or permit independent verification of:
  • Raw prompt and system context logs.
  • Model versions and decoding settings.
  • A/B test plans with pre‑registered metrics and statistical power.
  • Longitudinal metrics for brand health and churn (30–90 day windows).
    Absent these artifacts, headline claims (e.g., specific conversion rates, “85% faster / 85% cheaper” assertions) remain self‑reported and should be treated with caution.
Commercial and Strategic Implications​
Monetization upside is real — and large​
If a persuasion overlay reliably increases conversions even modestly at scale, the arithmetic is compelling: small percentage uplifts on very large ad and commerce funnels translate into multi‑billion dollar annual value for platforms and merchants. This explains why a working persuasion layer would be attractive as a premium capability in Copilots, CRMs or martech stacks. Industry analysis included in the rollout underlines this economic logic.
Vendor choices: build, partner, or block​
Platform owners face three strategic options:
  • Build an internal persuasion stack (control, high cost).
  • Partner/license a third party like ADMANITY (speed to market, dependency risk).
  • Block or restrict such features (avoid regulatory reputational exposure).
    Each pathway carries technical, legal and reputational trade‑offs; vendors will demand auditability, indemnities and compliance guarantees before embedding persuasion features.
The agency angle​
Agencies could be disrupted at the tactical level (ad creative commoditization) while gaining efficiency at the strategic level (experiment design, brand stewardship). The net effect depends on whether automation is used to scale high‑quality creative workflows or to replace strategic human judgment.
Ethics, Safety, and Regulatory Risks​
Manipulation versus legitimate persuasion​
A systematized persuasion layer shades into ethically sensitive territory when it targets emotional vulnerabilities, children, or regulated decisions (financial, health, legal). The difference between legitimate persuasion and manipulative exploitation is both ethical and legal.
Regulatory context​
  • The EU AI Act and other emerging frameworks flag manipulative and high‑risk AI uses; automated persuasion at scale could attract regulatory scrutiny.
  • U.S. regulators (FTC) have signaled interest in deceptive or unfair AI practices, and consumer protection doctrines could apply where persuasion becomes coercive or misleading.
    Companies must bake in transparency, opt‑ins, human review gates and claims substantiation from the start.
Practical Recommendations for Enterprise Teams Evaluating PRIMAL AI‑Style Claims​
  1. Define outcome metrics precisely: conversion rate lift, lifetime value, churn, refund rates and complaint volume.
  2. Demand auditable artifacts: raw prompts, system context, model versions, token accounting and time‑stamped output logs.
  3. Require randomized A/B tests with pre‑registered analysis plans and statistically powered sample sizes.
  4. Monitor brand health over 30–90 days: lift that increases returns but erodes trust is a net loss.
  5. Insist on human‑in‑the‑loop gating for regulated messages and sensitive audiences.
  6. Negotiate contractual protections: indemnities, non‑training clauses, data privacy guarantees and clear termination rights.
A practical 12‑week pilot roadmap many analysts recommend:
  1. Weeks 1–2: Select a representative funnel and capture baseline metrics.
  2. Weeks 3–6: Integrate the persuasion layer as a middleware or prompt wrapper; generate variants and instrument tracking.
  3. Weeks 7–10: Run randomized experiments; collect conversion and downstream metrics.
  4. Weeks 11–12: Evaluate results; examine brand, legal and compliance outcomes; decide on scale.
Balanced Verdict — Strengths and Risks​
Strengths​
  • The problem ADMANITY identifies is real: enterprises care about measurable outcomes, and LLMs frequently produce logically correct but emotionally flat content.
  • The technical approach maps to established engineering patterns (prompting, adapters, middleware), making the concept plausible.
  • Administrative traction (trademark filing, Crunchbase visibility) demonstrates market attention and potential deal flow.
Risks and open questions​
  • The most consequential claims (multi‑vendor confirmations, precise failure rates and conversion uplifts) are company‑originated and lack vendor signatures or independent replication. Treat those as hypotheses needing verification.
  • Ethics and regulatory compliance pose substantive hurdles: a persuasion engine that scales without transparency and guardrails risks consumer harm and regulatory enforcement.
  • Cross‑model robustness is non‑trivial: system prompts, safety filters and decoding strategies vary across vendors, so a “one‑size‑fits‑all” zero‑shot portability claim requires reproducible benchmarks.
Final Takeaway​
ADMANITY’s PRIMAL AI™ narrative surfaces an urgent and commercially consequential fault line in applied generative AI: the gap between informative correctness and emotional persuasion that converts. The company packages a technically plausible solution — a portable persuasion layer codifying emotional sequences — and supports it with demos, a trademark filing and visible marketplace signals. Those elements make the story worth attention from product teams, martech buyers and investors. However, the decisive test is empirical reproducibility and governance.
Enterprises and platform owners should approach the claims with cautious curiosity: design rigorous pilots, demand auditable experimentation artifacts, and prioritize transparency and consumer protection before rolling persuasion features into production. If ADMANITY or any other vendor can publish auditable, independently replicated A/B results that survive scrutiny — and show sustained brand health as well as short‑term conversion gains — the commercial and product implications will be profound. Until then, the space is an intriguing technical hypothesis with real economic upside and equally real ethical and verification challenges.
Source: openPR.com AI Platforms Are Having Problems Giving Business Customers Persuasion-Oriented Solutions Says Brian Gregory, of ADMANITY - Creator of The ADMANITY Protocol and PRIMAL AI.
