Stefan Billieri
Well-Known Member
The Aero Flip 2D does not work anymore although the Flip 3D does . When I press Alt+Tab I only see the classic list of active tasks:
An image from 'Aero Flip 2D is not working anymore'. Desktop screen showing various software and folder icons, including Chrome, Word, Skype, and PDF.
And I cannot use the directional keys to select a task.
Facts about the problem:
Ø Only one user account is affected.
Ø The Desktop Composition is active .
Ø Ctrl + Alt + Tab does not work.
Ø Ctrl + Win + Tab works and shows the Flip 3D .
Ø All other Aero effects work well: Flip 3D, Snap, Shake, Peek, ...
Verifications that have already been made:
ü $> chkdsk /f c:
ü Aero troubleshooting.
ü $> sfc /verifyonly
ü $> gpedit.msc . Nothing prevents Aero from working properly.
ü All the relevant services are active: DWM, Themes.
I will only create another user account as a last resort, so I hope someone can help me.
The "Tarefa" could point towards a dictionary, viz. Portuguese. Have you installed something like that? If you have, uninstall it and check the situation.
