Windows 7 Audigy 2zs
cdx30
:mad:Well the windows update drivers work but when the creative labs cd is installed there is following problems
1.no EQ
2.no cmss
3. no creative mixer
4.No 5.1 sound
Popup says no device found .
:mad:
Moosetek13
My Audigy4 was messing up when I first installed W7, so I went to Soundblasters website and downloaded the latest Vista drivers. It helped the problem, but it also means that I could not install the CD apps. The latest drivers are not compatible with those apps. The description also said that the Creative mixer would be installed with the new drivers, but I have not found it.
UnKnOwN
i too have an audigy 2zs with 5.1 speakers. i cannot get 5.1 sound to work. at best, was getting 4 speakers to work. i was able to get cmss, but not cmss3d. i just purchased an optical cable so hopefully that will get my 5.1 sound back.
Top Bottom
