Windows 10 Automove script
Patters
Hi everyone
Was wondering if anyone can help me with this problem, of moving files off a c: drive to a network drive.
So at work we have a machine that outputs .txt files now as an example these files include data about ..pets so in the folder I have hundreds of files that are named similar to dogs_123456_10062019.txt then cats_123457_10062019.txt
Now the first number is a reference number than changes per .txt file that is created and the other is a date, as said I can have hundreds of these per day.
Now I have a network folder structure of Y:dogs & Y:cats and wanted a automated script that transfers all dog & cat text files to the corresponding network drive.
Is this possible?
Cheers
Neemobeer
Windows Forum Team
It would be pretty simply with powershell
# Change -Path C:\Test\ to the location the files need to be moved from with the trailing \
$Files = Get-ChildItem -Path C:\Test\ -Filter "*.txt" -Recurse
foreach($File in $Files)
    if ($File.Name -like "dogs*.txt")
        Move-Item -Path $File.FullName -Destination "Y:\Dogs\"
    elseif ($File.Name -like "cats*.txt")
        Move-Item -Path $File.FullName -Destination "Y:\Cats\"
