The Server Side practice set for AZ‑204 — “Azure Developer Practice Exams — The Server Side” — offers a dense, scenario‑driven collection of question items and explanations that do more than teach test tactics: they force readers to reason about platform trade‑offs, operational limits, and secure defaults. The material is useful as a study aid because it explains why particular answers are correct and why tempting alternatives fail, but several technical claims in the document require correction or verification against Microsoft’s product docs. This feature unpacks the most important lessons from the practice set, verifies the critical platform claims against official documentation, highlights where the practice material errs or over‑simplifies, and gives practical guidance developers can use when designing production systems and preparing for AZ‑204 style questions.
Blue-tinted cloud computing setup with exam notes and a glowing Key Vault.Background / Overview​
The Server Side collection mixes question‑level reasoning with short operational rules‑of‑thumb: prefer platform metrics when writing autoscale rules, enable both soft‑delete and purge protection to prevent accidental permanent removal of Key Vault objects, use BlobClient.Upload with an explicit overwrite when targeting a single blob, use AzCopy for large automated transfers, and mount Azure Files for persistent mounts in Azure Container Instances. These are mostly solid exam‑focused heuristics and they align with real operational best practices, but a few numeric claims and wording choices in the practice set are inaccurate or incomplete and need correction before you trust them in production. The Server Side guidance also emphasizes avoiding “dump”‑style practice banks and pairing practice tests with hands‑on labs — a point reiterated across the community and reproduced in the practice material.
Key Vault: soft delete + purge protection — what exam writers really test​
The practical rule​
When protecting keys, secrets, certificates, or an entire vault against accidental or malicious permanent deletion, think in two parts:
  • Soft delete — when you delete an object (or the vault), the resource becomes recoverable for a configured retention window.
  • Purge protection — when enabled, it prevents any actor (including administrators or scripts) from purging the soft‑deleted object until the retention window expires.
The practice set repeatedly points to the combination of soft delete and purge protection as the correct way to make deletions recoverable. That guidance is correct as a concept and as an exam heuristic.
Correcting a numerical claim (important)​
The practice material contains a definitive statement that deleted key vault objects will be recoverable for 60 days and that the combined configuration yields a 60‑day recovery window. That assertion is not consistent with Microsoft’s current Key Vault documentation. The official Key Vault guidance states that the soft‑delete retention period is configurable between 7 and 90 days, and the default retention is 90 days if no other value is set; the same retention interval applies to purge protection behavior. In short: you may see “60 days” on some practice items or older materials, but the platform supports a configurable window (7–90 days) and the documented default is 90 days. Treat “60 days” in third‑party practice text as a candidate error unless the exam question explicitly states a changed policy that you can verify.
Permanence of purge protection​
Another common exam‑style trap: once purge protection is enabled on a vault or Managed HSM, it is irreversible — it cannot be disabled later. That immutability is intentional: purge protection is designed to block premature, permanent deletion even by privileged administrators. The official docs and vendor guidance confirm that purge protection cannot be turned off once set, so treat any answer that suggests you can toggle purge protection back off as incorrect.
Quick operational checklist​
  • When a question asks “how to ensure an accidental deletion of the key vault or its objects can be recovered for a specified retention window,” pick the option that enables both soft delete and purge protection.
  • If the exam text gives a retention value (e.g., 60 days), validate that value against current product docs — defaults and allowed ranges have changed historically. Flag mismatched numbers as potential traps.
App Service autoscale: use platform pressure signals, not ad‑hoc app metrics​
Why the practice set recommends CPU Percentage​
For scale‑out and scale‑in decisions on App Service plans, CPU Percentage is a built‑in, platform metric that Azure Monitor and the Autoscale engine expose for App Service plans. Using CPU Percentage is a reliable platform‑level signal for resource pressure and is the standard exam answer when a scenario asks for a built‑in autoscale metric to absorb sudden spikes in traffic. Application-level signals (average response time) typically require Instrumentation (Application Insights) and bespoke custom metrics, while memory percentage or HTTP queue length may not be universally available or consistent across all App Service environments. Use CPU Percentage unless the question explicitly permits or expects a custom metric.
Practical considerations​
  • Autoscale settings target the App Service Plan, not the individual app. When creating rules, confirm metric source and aggregation (e.g., average CPU across instances for a 5–10 minute window).
  • Scheduled autoscale rules require a Standard tier or higher; Basic and Free tiers do not support the scheduler feature, so watch for tier constraints in exam options.
Blob uploads with Azure.Storage.Blobs: prefer BlobClient for single-blob operations​
Correct pattern​
When your code needs to upload a single file to a specific blob in a container, the recommended and simplest approach is to create a BlobClient (for container + blob), open a FileStream, and call the Upload / UploadAsync overload that explicitly allows overwrite. The modern Azure SDK for .NET (Azure.Storage.Blobs) supports an Upload overload with an overwrite parameter or options object (e.g., blobClient.UploadAsync(BinaryData.FromStream(stream), overwrite: true). That prevents runtime exceptions when the target blob exists or you intend to replace it. The practice set correctly highlights this pattern as the right choice for a single blob upload.
What to avoid​
  • Avoid legacy WindowsAzure.Storage API types (CloudStorageAccount, CloudBlockBlob) when the question or codebase specifies Azure.Storage.Blobs (the newer client library).
  • Avoid calling Upload without explicit overwrite behavior in scenarios where a pre‑existing blob is plausible; that overload can throw exceptions if the blob already exists.
Bulk, resumable transfers: AzCopy is the right tool​
When a requirement calls for automated, unattended bulk copies across many containers and terabytes of data — with resumability after interruptions — AzCopy is the intended tool. AzCopy supports job plan and log files, resumable jobs, parallelism and high throughput, and CLI automation for scripting. The practice material’s recommendation for AzCopy in large automated transfers is correct; Microsoft docs confirm AzCopy’s job, plan file, and resume capabilities. If the question requires an orchestrated, ETL‑style flow with many connectors or long retry semantics, Azure Data Factory could be considered, but for raw, resumable blob transfers AzCopy is the simplest, most reliable choice.
Always On for App Service when hosting background triggers​
The practice set emphasizes that timer or queue triggered functions hosted on an App Service plan require the Always On setting in order to remain reliably active; this is correct. On App Service plans, the Functions runtime can go idle after minutes of inactivity, so enabling Always On prevents the app process from unloading and allows background triggers (storage queue, WebJobs, timer triggers) to fire reliably. Note that Always On is only available on paid tiers (Basic or higher); Free tier apps cannot enable Always On. This alignment between the practice guidance and Microsoft’s docs is accurate.
Durable Functions for long‑running work launched from HTTP​
When an HTTP request needs to start long running processing (for example, processing a large blob) and must not be blocked by platform request timeouts, the proper pattern is Durable Functions (the async orchestrator pattern). An HTTP starter function starts the orchestration and immediately returns a status URL; the orchestration continues work server side and can report progress, results, or outputs to storage. The practice set’s claim that Durable Functions are the correct solution in this scenario is aligned with guidance from Microsoft and is a common exam pattern to look for.
Storage choices for containers and container apps: ephemeral, Azure Files, and Blob​
The practice set gives a short matrix of storage types mapped to requirements. Summarized:
  • Need per‑container local disk only (not shared, not persistent beyond lifecycle): use the container’s writable layer (local disk).
  • Need data retained for the lifetime of a replica and shareable between containers in the same replica: use ephemeral/emptyDir style mounts or container platform ephemeral volumes.
  • Need data to persist beyond replica lifetime, be shareable, and have per‑object permissions: use Azure Blob Storage (object store) for object semantics and Azure Files if you need a mounted file share with SMB/NFS semantics.
Where the practice set recommends Azure Blob Storage for archival object stores, and Azure Files for mountable file shares in ACI, that advice is correct. Azure Container Instances and Container Apps can mount Azure Files shares as volumes; ACI supports Azure Files and emptyDir volumes for ephemeral sharing. The official docs show how to create the share and mount it into the container group.
Archive tiers and rehydration SLA: what you can promise​
The practice material advises the default rehydration window for blobs in the Archive tier is one to fifteen hours (standard priority); that matches Microsoft documentation which states standard priority rehydration may take up to 15 hours (and that high‑priority rehydration can complete in under an hour for objects <10 GB, subject to account‑level limits). Use standard 1–15 hours as the baseline SLA for archive retrieval unless the question explicitly allows expedited (high‑priority) retrieval. For large‑scale rehydration or bulk operations plan for longer durations because throughput limits (e.g., 10 GiB/hour/account for rehydrate priority) apply.
Event ingestion: Event Hubs vs Event Grid vs Service Bus​
The practice set correctly highlights different ingestion patterns:
  • Event Hubs — best for high‑throughput telemetry, partitioning with partition keys, and capture to Blob Storage in partitioned files (suitable when you need capture with partitioning semantics).
  • Event Grid — event routing to many subscribers (push delivery) but not a capture/partitioned file writer.
  • Service Bus — message broker with topics/subscriptions for pub/sub semantics and rich message filtering and actions.
If a scenario requires partition‑key grouping of events and automatic capture to Blob Storage for downstream joins by device id, Event Hubs (or IoT Hub) is the right fit, not Event Grid. The practice set’s correction on this point is correct.
Kudu zip deploy: PUT /api/zip/{targetPath}/ is the right API​
For zip‑deploy to App Service via the Kudu SCM service the standard REST pattern is to upload a ZIP to the Kudu zip API (for example PUT https://<app>.scm.azurewebsites.net/api/zip/site/wwwroot/) so Kudu can extract it into the target path. The practice set tells readers to select the Kudu zip endpoint for zip deploy operations — this is correct and aligns with the Kudu docs and community examples. If you need to script deployments, prefer the Kudu zip API or the Publish‑AzWebApp helper for PowerShell.
Where the practice set shines — and where it risks confusing candidates​
Strengths​
  • The explanations consistently push readers from rote recall toward applied reasoning: “why won’t a managed identity alone protect a vault from permanent deletion?”; “why is CPU Percentage a better autoscale signal than HTTP queue length?”; “why choose BlobClient for single‑blob uploads?” These are exam‑valuable and production‑useful points.
  • The content favors platform primitives for common tasks (AzCopy for bulk transfers, Az Files for mounts, Blob Storage for durable object storage) and explains the limitations of tempting alternatives.
  • The material flags security and governance edge cases (e.g., Key Vault protection, reauth/redemption flows for guest users) rather than pretending defaults are always safe.
Risks and mistakes to watch for​
  • Numeric drift: as shown above, the sample set’s 60‑day retention claim for Key Vaults contradicts the official docs that document a configurable 7–90 day window with a default of 90 days. When studying, always verify retention and timeout numbers against vendor docs — these are frequently changed or clarified. Flag such numeric mismatches when you see them.
  • Over‑simplification: some items imply a single correct operational recipe for broad scenarios (e.g., “Store scanned forms in Key Vault secrets”). That is wrong — Key Vault secrets are for small, sensitive values, not documents; for large binary artifacts use Blob Storage with client‑side or CMK encryption. The practice set generally warns against that pattern, but if an item claims it as correct treat it as a trap.
  • Vendor policy traps: the Server Side commentary included a broader warning about exam “dump” markets. The practical effect is that exam questions often test operational constraints and policy implications, not just API names. Avoid rote memorization of Q&A banks that promise verbatim exam content. Use practice tests as diagnostics and remediation tools, paired with hands‑on labs.
Study & ops checklist — what to memorize and what to verify​
  • Memorize patterns and platform primitives:
  • Soft delete + purge protection for Key Vault recoverability (and that purge protection cannot be disabled).
  • CPU Percentage for App Service Plan autoscale triggers (Standard+ tiers).
  • BlobClient.Upload with overwrite for single‑blob uploads using Azure.Storage.Blobs.
  • AzCopy for resumable, large automated transfers.
  • Verify numbers and windows on the day of the exam:
  • Retention windows, default values, archive rehydration times, and rate limits can change; cross‑check the vendor docs if a question depends on a specific time or numeric value. Confirm any “60‑day” or similar numeric claims against Microsoft Learn.
  • Practice using the actual SDK and CLI:
  • Spin up a sandbox subscription and run BlobClient.UploadAsync, azcopy copy jobs, zip deploy to Kudu, and create a Key Vault with purge protection to see the portal behavior. Real muscle memory prevents exam pitfalls.
The Server Side AZ‑204 practice materials are valuable because they emphasize operational trade‑offs, platform primitives, and the reasoning behind correct answers. Most of the rule‑of‑thumb guidance (use AzCopy for large transfers, use BlobClient.Upload with overwrite, prefer CPU Percentage for App Service autoscale, enable Always On for background triggers on App Service plans) is accurate and aligns with Microsoft docs. However, treat numeric specifics (retention durations, SLA windows cited in third‑party practice text) as verify‑first items: the official documentation is the final authority and sometimes differs from older practice sets. Use practice exams as diagnostics, not shortcuts; pair them with hands‑on labs, and correct any mismatches you find against Microsoft’s product pages before committing answers to memory.
Acknowledgments: the Server Side practice set supplies high‑quality scenario explanations that make it worth studying — but always validate retention periods, irreversible flags (like Key Vault purge protection), and priority/time windows using Microsoft documentation before treating any numeric claim as definitive.
Source: The Server Side AZ-204 Azure Developer Practice Exams
