Azure Latency Spike as Red Sea Cable Cuts Disrupt Global Cloud Traffic
Global Azure network traffic reroutes around the Red Sea chokepoint.
Microsoft has warned that users of its Azure cloud may see higher-than-normal latency and intermittent disruptions after multiple undersea fiber-optic cables in the Red Sea were cut, forcing traffic onto longer alternate routes while repair work and global rerouting continue.
Background​
The Red Sea is a critical chokepoint for submarine communications: multiple major fiber systems transit the corridor between Europe, the Middle East and Asia, and damage there quickly ripples into higher latencies and degraded throughput for cloud services whose traffic traverses those routes. Recent cuts to several cables in the Red Sea have produced just such an effect, prompting cloud operators — including Microsoft Azure — to reroute traffic around the damaged segments and to alert customers that performance impacts are possible while repairs and alternate routing are in effect. (ft.com)
This episode is not the first time the region’s undersea infrastructure has affected public cloud performance. Previous incidents in 2024–2025 disrupted significant Europe–Asia traffic and required months in some cases to fully restore service because of the complexity of remote undersea repairs and the limited global fleet of cable-repair ships. Industry sources and network operators have repeatedly warned that the ecosystem is brittle when multiple high-capacity segments are affected simultaneously. (datacenterdynamics.com)
What Microsoft said, and what it means for Azure customers​
Microsoft posted a service health update stating that Azure users "may experience increased latency" because of multiple undersea cable cuts in the Red Sea, and that engineers are monitoring, rebalancing and optimizing routing to mitigate customer impact. The update also said undersea repairs take time, and Microsoft will provide daily updates or sooner if conditions change. Key technical implications of that statement:
  • Routing detours will increase round-trip time (RTT). When traffic is forced onto geographic detours — for example, routing through alternate subsea cables, overland fiber through different countries, or via trans-Pacific/around-Africa routes — the physical distance and added network hops increase latency and jitter for affected flows.
  • Performance is likely to be uneven and regional. The service impact will be concentrated on traffic that originates, terminates, or transits between Asia, the Middle East and Europe, depending on which physical paths Azure customers use and where their endpoints are located. Microsoft’s notice specifically flagged traffic traversing the Middle East as a likely area of impact.
  • Cloud control-plane vs. data-plane effects differ. Some Azure control-plane operations (management APIs, provisioning) may remain responsive if they use separate paths or regional endpoints; data-plane workloads (application traffic, database replication, inter-region backups) are more sensitive to added latency and packet loss. Historical outages show that storage partitions and private endpoints can be affected in complex, cascading ways when network routing is stressed.
The operational context: why undersea cable cuts matter to clouds​
Submarine fiber is the backbone for intercontinental cloud traffic. While clouds operate global backbones and peering fabrics, they still rely on a heterogenous mix of submarine systems and terrestrial interconnects. When one or more key segments in a corridor like the Red Sea are severed, the industry faces three practical realities:
  • Repairing undersea cables requires specialized cable ships and safe access to the fault zone, which can be delayed by regional security issues or permitting. Repairs are measured in days-to-months rather than hours.
  • Alternate routing is available but imperfect: reroutes create longer paths and concentrate traffic on other links, potentially causing congestion and increased latency elsewhere. Satellite and microwave backhaul can provide stop-gap capacity but generally at higher cost and latency. (subseacables.net)
  • The cloud’s internal service dependencies can amplify user-visible impact: storage, identity, private endpoint connectivity and replication can be affected differently depending on how providers segment traffic and orchestrate failover. Past Azure incidents show complex cascading effects when storage partitions, private links, or zonal resources are involved.
Timeline and current status (verified claims)​
  • On September 6, 2025, Microsoft posted a service health update warning Azure customers of increased latency following multiple undersea fiber cuts in the Red Sea, and said it had rerouted traffic through alternate paths while monitoring the situation. Microsoft committed to providing daily updates or sooner as conditions evolved.
  • Industry reporting since the initial Red Sea cable incidents (that began in 2024 and recurred in 2025) documents both physical damage to cables and operational complications caused by regional maritime security issues, stranded vessels, and the logistics of cable repair. These complications have in earlier instances delayed repairs and forced rerouting for extended periods. (datacenterdynamics.com)
  • Independent monitoring firms and network operators reported measurable latency increases and notable shifts in traffic patterns during earlier Red Sea outages, with some providers estimating that a substantial share of Europe–Asia traffic was affected — figures that vary by operator and measurement methodology. These assessments corroborate the practical impact Microsoft described. (subseacables.net)
Caveat: a precise single cause (for example, whether a specific incident was caused by a particular vessel, or by hostile action) can be contested and may be subject to ongoing investigation; where attribution is reported it should be treated cautiously until confirmed by multiple credible parties. Several credible outlets have linked prior Red Sea cable damage to broader regional maritime insecurity, but those reports and claims differ in detail and attribution. (en.wikipedia.org)
Technical analysis: how Azure and other cloud providers mitigate subsea disruptions​
Cloud operators have several tools to limit impact from submarine cable failures. Understanding which measures are in play helps explain why the user experience may vary:
  • Dynamic routing and traffic engineering. Providers can change BGP routes, load-balance sessions across multiple undersea systems, or shift flows to different peering points. That reduces packet loss but frequently increases latency because traffic takes a longer path. Microsoft confirmed it was rebalancing and optimizing routing as part of mitigation.
  • Regional failover and multi-region architectures. Workloads architected to tolerate inter-region latency (e.g., eventual-consistency databases, asynchronous replication) are less impacted than synchronous systems. Customers who rely on single-region synchronous replication or private end-to-end topologies are more vulnerable. Historical Azure incidents emphasize the importance of multi-region DR planning.
  • Peering diversity and private interconnects. Enterprises with private clouds or direct-connect arrangements (e.g., ExpressRoute equivalents) may shift over private interconnects that themselves rely on multiple transit paths. That can mitigate some public-internet routing disruptions but does not eliminate the problem if the underlying physical route is damaged.
  • Satellite and alternative last-resort links. Some operators buy satellite capacity to handle urgent traffic during major cable repairs; this reduces capacity constraints but increases latency substantially and is not appropriate for latency-sensitive financial or real-time applications.
Risk assessment: who and what is most exposed​
  • Synchronous replication and low-latency services — Databases that require sub-10ms replication or distributed systems tuned for low RTT will see the greatest functional impact. Increased latency can cause replication timeouts, leader elections, or reduced throughput.
  • Real-time user experiences — Interactive web apps, VoIP, gaming, and remote-desktop services will exhibit higher latency and jitter, leading to degraded quality. Enterprises with remote branches whose traffic must traverse the damaged corridor are particularly vulnerable.
  • Supply-chain and market-sensitive traffic — Financial trading and other latency-monetized applications may experience measurable degradation when long-haul paths are used as detours. Historically, markets have adopted premium fiber and alternative routing precisely to avoid such latency spikes.
  • Organizations with weak multi-region DR — Businesses that have not tested failover to other regions or multi-cloud alternatives are at highest operational risk. Past Azure incidents show that even when providers take corrective action, customer readiness is the decisive factor in recovery speed.
What enterprises should do now — practical, prioritized steps​
  1. Immediately check Azure’s Service Health for your specific subscriptions and regions to confirm whether your resources are flagged. Follow any Microsoft guidance and subscribe to Azure status notifications for your subscriptions.
  2. Verify application-level dependencies: identify any services that require synchronous cross-region communication (databases, caches, identity endpoints) and determine whether they are using paths that transit the Middle East / Red Sea corridor.
  3. Execute tested failover procedures where possible: initiate region or cluster failovers for production workloads that can tolerate the downtime and have been stress-tested.
  4. For latency-sensitive workloads that cannot be failed over: consider temporarily shifting traffic to cached or edge delivery options (CDNs), or redirect important flows via alternative peering or transit providers if you have those contractual options.
  5. Monitor application logs and latency metrics aggressively; enable alerting for RTO/RPO thresholds and look for increased error rates that correlate with routing changes.
  6. For teams without a DR playbook, enact an emergency plan: prioritize critical services, contact Microsoft support and your account team, and document impacts for later post-incident review and possible financial relief considerations.
These steps are deliberately ranked to prioritize detection, containment and minimal business impact.
Microsoft’s response: strengths and limits​
Strengths
  • Rapid notification to customers. Microsoft issued a public service health notice and committed to regular updates, which is the right early step for transparency and operational coordination.
  • Large global backbone and routing options. As one of the hyperscale cloud providers, Microsoft has extensive cross-region fabric and peering relationships it can use to reroute traffic. That capability reduces the chance of total connectivity loss for many customers.
  • Operational experience. Azure’s engineers have handled prior incidents and have playbooks for rebalancing and traffic engineering; that operational maturity mitigates worst-case scenarios. Historical analysis of Azure outages shows Microsoft uses rerouting and storage partition recovery techniques to limit service impact.
Limits and risks
  • Physical repair latency. Rerouting is a short- to medium-term fix; undersea repairs can take weeks or months depending on ship availability, permitting, and security constraints. Microsoft cannot repair third-party cables directly, so some impacts are outside their direct control.
  • Cascading dependencies. Complex cloud architectures mean that a networking issue can surface as storage or identity problems for tenants; past incidents show these cascades can be hard to fully anticipate.
  • Uneven customer impact and communication challenges. Some customers may see degraded service without clear localized messaging. Providers must balance targeted notifications with broad transparency to maintain trust; past Azure incidents included complaints about delay or mismatch between dashboard health states and real user experience.
Wider industry and geopolitical context​
The Red Sea corridor has been a recurring point of fragility in recent years. Attacks on shipping, abandoned vessels, and regional tensions have all been implicated in some reported subsea cable damages; operators and governments have struggled at times to secure safe access for repairs. Industry analyses caution that the submarine cable ecosystem — long optimized for capacity and cost — lacks sufficient geographic redundancy in some chokepoints. The result: simultaneous hits to a small number of cables can have outsized global effects. (networkworld.com)
Operators and hyperscalers are pursuing medium- and long-term engineering responses, including route diversity, private interconnect builds, and new fiber technologies (for example, hollow-core fibers in certain backbone applications) that may reduce latency and increase capacity when deployed at scale. Microsoft itself has invested in advanced fiber research and pilot deployments as part of a broader strategy to control more of its physical network stack — but those are long-lead efforts and will not solve immediate repair-time problems. Caveat on attribution: while some coverage connects cable damage to regional hostilities or specific incidents, attribution is often complicated and contested. Where a claim of deliberate attack appears, it should be treated carefully and cross-checked against reliable reporting and official investigations. (en.wikipedia.org)
Long-term takeaways for IT architects and WindowsForum readers​
  • Resilience must be designed, not hoped for. Dependence on a single region, single synchronous replication domain, or single transit path remains the most common cause of outsized operational risk. Multi-region designs, asynchronous replication, and well-documented failover plans materially reduce exposure.
  • Measure your true risk profile. Run synthetic latency checks, dependency mapping, and chaos testing for critical workflows. Knowing which paths your traffic takes (and who controls them) gives you leverage in contractual and technical mitigation.
  • Consider strategic private connectivity. For latency-sensitive or compliance-bound workloads, private interconnects that the organization can control or contractually guarantee offer stronger SLAs than public transit, though they come with cost and operational trade-offs.
  • Stay pragmatic about alternatives. Satellite or temporary overland re-routes can buy time but are expensive and have performance limitations. They should be part of a contingency playbook but not the mainline solution.
  • Engage with your cloud provider proactively. If your organization runs critical services on Azure, escalate via your account team to understand provider-side mitigations and to document impacts for potential service credits or contractual remedies.
What we still don’t know (and how to treat uncertain claims)​
  • Exact repair timelines for the affected Red Sea cables depend on ship availability, on-site safety and permitting; public reporting has shown repair durations ranging from days to months depending on circumstances. Firm repair ETA’s should be treated as provisional until cable operators or authorities confirm completion. (subseacables.net)
  • Attribution for every cable cut — whether purely accidental (anchors, dragging vessels), due to infrastructure failure, or caused by hostile actions — is frequently disputed and may remain unresolved while investigations proceed. Treat attribution claims cautiously and seek multiple independent confirmations. (en.wikipedia.org)
The September 6 Azure advisory is a reminder that the physical layer of the internet still matters deeply to cloud reliability. Microsoft’s operational response — rerouting and active traffic engineering — is appropriate and likely to minimize worst-case outages. However, physical repairs, geopolitical constraints and the practical limits of alternate routing mean elevated latency and uneven performance are realistic in the near term for traffic traversing the Middle East and Red Sea corridors. Enterprises that rely on Azure should act now: check their Azure Service Health notifications, verify cross-region dependencies, execute tested failovers where appropriate, and reach out to Microsoft account and support teams if workloads are business-critical. The incident underscores a persistent lesson: cloud resilience is as much about network geography and physical infrastructure as it is about software design and platform SLAs. (datacenterdynamics.com)
Source: CNBC https://www.cnbc.com/2025/09/06/microsoft-azure-cloud-computing-service-disrupted-red-sea-fiber-cuts.html
Source: Reuters https://www.reuters.com/world/middle-east/microsoft-says-azure-cloud-service-disrupted-by-fiber-cuts-red-sea-2025-09-06/
Source: Reuters https://www.reuters.com/world/middle-east/microsoft-says-azure-disrupted-by-fiber-cuts-red-sea-2025-09-06/
Internet traffic between Asia, the Middle East and parts of Europe slowed sharply after multiple undersea fibre‑optic cables in the Red Sea were severed on 6 September 2025, forcing cloud operators — most visibly Microsoft Azure — and regional carriers to reroute traffic, warn customers of higher latency, and begin contingency and repair planning.
Blue, futuristic map showing Azure cloud data traffic across Europe and Africa.Background​
The global internet is not an ethereal cloud: it runs on physical arteries of submarine fibre‑optic cables laid across the seafloor. These cables carry the vast majority of intercontinental traffic — commonly cited estimates place that figure above 90% — and concentrate enormous bandwidth through a surprisingly small number of maritime corridors. The Red Sea, and its approaches through Bab el‑Mandeb toward the Suez Canal, is one of those strategic chokepoints connecting South and East Asia to the Middle East, Africa and Europe. (indianexpress.com)
Why this matters in practical terms: when high‑capacity trunk links in that corridor are damaged, traffic engineering (rerouting, reweighting and leasing alternative capacity) can preserve reachability but cannot erase the physics of longer paths. That means higher round‑trip times, increased jitter, packet loss and intermittent access for latency‑sensitive services — everything from cloud APIs and replication to video conferencing and financial feeds. Microsoft’s Azure status update described precisely this effect: traffic that normally transited the Middle East “may experience increased latency” while engineers reroute and rebalance capacity.
What happened — timeline and verified facts​
The clock starts: detection and advisories​
Independent monitoring groups and carrier telemetry registered abnormal routing behaviour early on 6 September 2025, with initial alerts and customer reports showing degraded connectivity across Pakistan, India, the United Arab Emirates and other states served by Red Sea transit routes. Microsoft posted an Azure Service Health advisory warning customers of higher‑than‑normal latency on traffic that traversed the Middle East corridor and said it was rerouting traffic and optimising routing while repairs were organised. (cnbc.com)
Microsoft’s public advisory included the operational detail that the event began around 05:45 GMT on 6 September, and that traffic not routed via the Middle East corridor was unaffected — a useful distinction that reflects how cloud service availability is often intact while cross‑region performance degrades.
Monitoring organisations and networks point to specific systems​
Outage trackers and NetBlocks attributed the disruptions to faults on major trunk systems that use the Jeddah approach, with SMW4 (SEA‑ME‑WE‑4) and IMEWE (India‑Middle East‑Western Europe) repeatedly named in public reporting. Several regional carriers and independent monitors also cited FALCON GCX and other regional feeders as implicated in the incident. The pattern of route flaps and BGP reconvergence was consistent with multiple, near‑simultaneous subsea faults. (datacenterdynamics.com)
End‑user and carrier impacts​
Telecom firms and national ISPs reported user‑visible slowdowns: Pakistan Telecommunications (PTCL) warned customers to expect degraded service during peak hours while alternative channels were provisioned; users of UAE carriers Du and Etisalat reported poorer streaming and browsing performance; and social and outage trackers recorded spikes in complaints from India and Pakistan during the incident window. Cloud customers saw higher API latencies, longer replication windows and degraded quality for real‑time services. (datacenterdynamics.com)
The cables involved and the geography of failure​
The systems most often named in reporting — SMW4 and IMEWE — are long‑haul trunk cables that carry substantial Asia⇄Europe and Asia⇄Middle East traffic. These systems, together with additional regional feeders, converge near landing points on the western Arabian coast around Jeddah and feed onward via the Suez/Mediterranean routes to Europe or via alternative southern routes around Africa. Because multiple major cables share this narrow corridor, a cluster of cuts in the same vicinity produces outsized consequences. (datacenterdynamics.com)
A single cable break is disruptive; multiple simultaneous breaks in the same corridor are a different class of event, rapidly exhausting low‑latency alternatives and forcing traffic onto longer, sometimes congested detours that were never provisioned to handle the full displaced load.
What caused the breaks — evidence, claims and caution​
Attribution remains provisional and must be treated with caution. Multiple public reports discussed two plausible — and distinct — causes:
  • Mechanical damage (anchor drags, fishing activity, accidental vessel groundings) is historically the single largest cause of subsea cable faults. Industry bodies and experts estimate a substantial share of faults are caused by ship anchors and bottom contact. AP and other outlets reported that a likely anchor drag by a commercial ship could have severed several cables in this incident.
  • Deliberate action is an alternative scenario. The Red Sea has been the scene of recent maritime hostilities and attacks on shipping. Houthi rebels in Yemen have carried out strikes on shipping in the corridor and have been accused, at times, of threatening undersea infrastructure; they have denied responsibility for past cable breaks. Media coverage has noted this context while stressing that forensic confirmation of intentional damage is often slow and technically complex. (washingtonpost.com)
Precise forensic attribution of subsea cable faults requires cable‑owner diagnostics, ship location logs, and sometimes physical inspection of the broken section — steps that can take days to weeks. Early telemetry and monitoring data show where circuits flapped and where AS paths lengthened, but they do not, on their own, prove intent.
Cautionary note: treat early attribution claims as provisional until consortiums and investigative agencies publish technical fault reports.
Why repairs are slow and operationally heavy​
Repairing submarine cables is a maritime operation with multiple logistical and legal constraints. Typical repair steps include locating the fault with specialised survey ships, acquiring permissions to work in the affected waters, deploying a cable repair vessel, hauling the damaged cable to the surface, performing a splice, testing the restoration, and re‑burying the repaired section if needed. Weather, shipping traffic, ice or security risks can all delay operations. In geopolitically sensitive waters, the complexity multiplies: insurers, flag states and local authorities can impose restrictions that lengthen timelines. (washingtonpost.com)
Industry experience shows repair times can range from a few days for shallow, easily accessible faults to weeks or months if the damage is both extensive and located in contested or remote waters. That operational reality is why the initial cloud‑provider mitigation toolkit focuses on rerouting and capacity rebalancing: it is the only immediate lever to reduce customer impact while ships are mobilised.
Security, policy and the growing strategic importance of subsea cables​
This incident is both an engineering outage and a national‑security question. The reasons are straightforward:
  • Subsea cables carry banking transactions, government communications, cloud services, and military voice/data flows. An outage that affects cross‑region connectivity can therefore have economic and operational consequences far beyond consumer nuisance.
  • The physical concentration of bandwidth in narrow corridors creates systemic risk. When redundancy is logical but not physically diverse — i.e., when “diverse” routes still pass through the same narrow chokepoint — apparent resilience can be illusory.
  • Geopolitical tensions around the Red Sea raise the stakes for both protection and diplomatic coordination. States and industry consortia will increasingly press for legal frameworks that speed up repair authorisations and declare certain subsea assets as critical infrastructure. (datacenterdynamics.com)
Risk calculus: deliberate disruption of submarine cables, even if unlikely, has asymmetric consequences. The inability to move data reliably erodes trust in cloud continuity guarantees and forces enterprises and governments to treat these undersea routes as strategic assets that must be defended and diversified.
How cloud operators and carriers mitigated the immediate impact​
Cloud operators and large transit providers followed textbook traffic‑engineering playbooks: reroute packets, rebalance weights across remaining paths, and lease temporary transit or wavelengths where possible. Microsoft’s public status updates described ongoing rerouting and optimisation measures designed to “reduce customer impact in the meantime.” Those measures preserved reachability for most services while trading off higher latency and congestion. Key operational approaches applied:
  • Move latency‑sensitive edge services closer to users where possible (CDN reconfiguration).
  • Redirect cross‑region traffic via alternative subsea systems or terrestrial backhaul.
  • Lease short‑term capacity from third‑party carriers or provision satellite fallback for critical lanes.
  • Prioritise traffic shaping and rate controls for essential services to prevent congestion collapse.
These mitigations work, but they are not free: they increase operating cost and often degrade user experience for latency‑sensitive workloads.
Practical implications for enterprises, developers and Windows admins​
This incident is a live reminder that cloud resilience must be multidimensional. Logical redundancy in a cloud provider — multiple regions, availability zones and failover groups — is necessary but not sufficient unless the physical diversity of network paths is explicit and tested.
Immediate and medium‑term actions for infrastructure teams:
  • Map your transit geometry: know which submarine corridors and landing stations your traffic uses. Include third‑party SaaS dependencies in this inventory.
  • Identify latency‑sensitive components: mark services where tens of milliseconds matter (real‑time trading, VoIP, interactive apps) and design specific failover behavior.
  • Implement multi‑path designs:
  • Multi‑carrier transit (dedicated diverse providers).
  • Multi‑region or multi‑cloud replication with truly separate physical paths.
  • Use content delivery networks and edge caching aggressively to reduce cross‑continent dependencies for static and semi‑static assets.
  • Test failovers and monitor the impact of intentional route changes to ensure application behavior under higher latency and packet loss.
  • Negotiate SLA transparency with cloud and transit providers: ask for exposure maps and real‑time notification about undersea incidents.
  • Prepare DNS and session‑stickiness policies to reduce failover pain during BGP reconvergence.
For Windows‑centric ops teams, this means validating VPN and RDS/AD replication behavior under higher latency, checking Windows Update delivery optimizations, and ensuring Active Directory and file‑replication services have appropriate throttles and resilience settings.
Economic and market consequences​
While a short‑lived incident may not tilt wholesale market pricing, prolonged chokepoint outages can raise transit costs on alternative routes and force short‑term capacity purchases that affect carrier margins. Financially sensitive applications that depend on deterministic latency can incur measurable costs from longer replication times, failed trades, or degraded customer experiences — all of which translate into real economic impact. Industry commentary following the event emphasised that market and regulatory responses will likely accelerate investments in route diversity and repair capacity. (investing.com)
Longer‑term fixes: engineering, policy and investment​
The solutions fall into three broad categories and none are cheap:
  • Engineering: deploy more geographically diverse cables, invest in faster repair vessel fleets, and develop automated telemetry and cross‑operator coordination tools that speed root‑cause diagnosis and repair planning.
  • Commercial: encourage multi‑carrier procurement by large cloud customers and promote private fibre overlays for mission‑critical lanes (financial institutions, governments).
  • Policy & diplomacy: designate essential subsea infrastructure as protected assets, streamline cross‑border permissions for repair missions, and create multilateral protocols for security and incident response.
Successful implementations will require cooperation between cable owners, carriers, cloud providers, insurers and national governments. The industry has already been moving in these directions, but events like this accelerate urgency.
Cross‑checking the public record (important verifications)​
When reporting and responding to subsea incidents, a healthy journalistic and operational posture includes corroboration from multiple independent sources. In this event:
  • Microsoft’s own Azure service‑health advisory confirmed that Azure users would likely see higher latency and explained the mitigation actions under way.
  • NetBlocks and independent monitoring groups documented route changes and degraded throughput in multiple countries and linked the anomaly to SMW4 and IMEWE faults near Jeddah. (aljazeera.com)
  • Major news organisations — Reuters, AP and DatacenterDyanamics among them — reported on the event, the likely cables affected and the range of potential causes while emphasising that forensic attribution often lags initial reports. (apnews.com, datacenterdynamics.com, Internet disrupted across Asia and Middle East after undersea cable cuts
Microsoft Azure customers experienced measurable performance degradation after multiple undersea fiber‑optic cables in the Red Sea were cut, forcing traffic onto longer, often congested detours and exposing persistent structural vulnerabilities in the global internet backbone.
Global data network: cables link Africa to the world, with cloud analytics and a cable-laying ship.Background / Overview​
The internet is a physical network as much as it is a logical one. A dense web of submarine fiber‑optic cables laid on the ocean floor carries the overwhelming majority of international data traffic; these systems connect continents and underpin cloud platforms, financial markets, streaming services, and day‑to‑day communications. Modern mapping and industry trackers show the number of active submarine cable systems has grown substantially in recent years, with TeleGeography and other analysts documenting several hundred active systems and hundreds more planned or under construction. A handful of narrow maritime corridors concentrate an outsized share of east–west capacity. The Red Sea and the approaches to the Bab al‑Mandeb and the Suez Canal are among the most consequential chokepoints connecting South and East Asia with the Middle East, Africa and Europe. When several trunk segments in the same corridor are damaged, the shortest physical paths vanish and traffic must be rerouted onto alternate routes that are longer and sometimes already saturated—producing higher round‑trip times, jitter, and packet loss for flows that cross the damaged corridor. (datacenterdynamics.com)
Industry and government bodies have been warning about these vulnerabilities for years: intergovernmental organizations and telecom authorities estimate that submarine cables carry virtually all long‑distance internet traffic, and parliamentary inquiries have emphasised the difficulty of monitoring and protecting these long, remote assets. The UK parliamentary inquiry and the International Telecommunication Union both note the scale of the infrastructure and the difficulty of making it invulnerable. (itu.int)
What happened: the Red Sea cable incident (concise summary)​
  • Early on 6 September 2025, monitoring groups and carrier telemetry detected abrupt routing anomalies and degraded throughput for traffic transiting the Red Sea corridor. (apnews.com)
  • Microsoft published an Azure Service Health advisory stating that customers “may experience increased latency” for traffic that previously traversed the Middle East, and explained engineers were rerouting and rebalancing capacity while repairs were planned. The advisory stressed that traffic not traversing the Middle East corridor should be unaffected. (reuters.com)
  • Internet monitoring organisations, including NetBlocks, and several national carriers reported degraded connectivity and slower speeds in countries such as India, Pakistan, the United Arab Emirates and Saudi Arabia; early reporting identified candidate systems affected near Jeddah, Saudi Arabia (notably SEA‑ME‑WE‑4 and IMEWE among others). (aljazeera.com)
These combined facts—multiple reported subsea faults, Microsoft’s targeted advisory, and corroborating telemetry from independent monitors—make the operational picture straightforward: reachability was largely preserved by rerouting, but performance for a swath of cross‑region traffic was degraded until physical repairs or routed capacity could fully restore normal paths.
Why Microsoft framed this as "latency" rather than an outage​
Large cloud providers distinguish between control‑plane reachability (management APIs, service provisioning) and data‑plane performance (cross‑region API calls, synchronous replication, user traffic). The Azure advisory aligns with standard practice: retain reachability and service continuity where possible while signalling to customers that performance characteristics—especially for latency‑sensitive workloads—may be degraded. That approach preserves availability but shifts the immediate problem into the performance domain.
Timeline and verification​
  • Detection: automated routing telemetry and outage trackers first flagged anomalies at roughly 05:45 UTC on 6 September 2025. Independent monitors then displayed route flaps and longer AS‑paths for Asia⇄Europe and Asia⇄Middle East flows. (reuters.com)
  • Provider response: Microsoft posted a Service Health notice the same day describing increased latency for traffic that traversed the Middle East and explaining rerouting and capacity rebalancing efforts. Other cloud and transit operators also adjusted routing and confirmed degraded throughput. (datacenterdynamics.com)
  • Public monitoring: NetBlocks and national carriers posted localized impact reports (Pakistan, India, UAE and beyond) and named candidate cables implicated in the Red Sea corridor. (aljazeera.com)
  • Repair and recovery: subsea repairs are maritime operations that require fault localisation, cable‑repair ship availability, permissioning and mid‑sea splicing; repair timelines can range from days to weeks depending on circumstances. Microsoft and carriers used traffic engineering and temporary leases to reduce impact while repairs were organised.
The uploaded briefing collected the same operational facts and timeline and highlighted the distinction between a platform outage and a corridor‑level performance event—an important nuance for cloud customers assessing business impact.
The technical anatomy: how a cable cut becomes a cloud incident​
Submarine cable faults cascade through a predictable technical chain:
  • Physical break removes primary capacity on a corridor.
  • Border Gateway Protocol (BGP) reconverges and route advertisements change; traffic flows along alternate AS‑paths.
  • Packets traverse additional hops and longer distances—raising propagation delay (milliseconds to potentially hundreds of milliseconds on circuitous detours).
  • Alternate paths absorb sudden volume, causing queuing delays, jitter and packet loss if they were not provisioned for the displaced load.
  • Latency‑sensitive workloads surface symptoms first: video and voice calls, synchronous database replication, chatty APIs, and certain trading or streaming flows.
Cloud control‑plane traffic often remains resilient because providers operate separate peering and backbone fabrics for management and telemetry, meaning customers may still be able to manage resources even while user traffic suffers higher latency. That reality explains why Microsoft and others can report “no platform‑wide outage” while still warning of meaningful customer impacts.
Who and what were affected​
  • End users in affected countries experienced slower page loads, choppy streaming, higher call jitter, and intermittent slowdowns during peak periods. NetBlocks and national telcos logged complaint spikes in Pakistan, India and the UAE. (indianexpress.com)
  • Enterprise customers using Azure for cross‑region workloads saw higher API latencies, longer backup/replication windows, and increased retry rates for chatty services—effects that can cascade into application‑level timeouts and degraded SLAs for real‑time systems.
  • Cloud providers and transit carriers were forced into capacity rebalancing, temporary transit leasing, and active traffic engineering to reduce congestion and preserve reachability. These operational levers are effective short term but cannot instantly substitute for lost subsea capacity. (datacenterdynamics.com)
What we know about the cause — and what remains provisional​
Public reporting as of the incident confirms multiple cuts in the Red Sea corridor near Jeddah, but definitive operator forensic diagnostics and formal consortium fault reports typically lag early media coverage. Early fields of investigation include anchor strikes by commercial shipping, accidental fishing/anchoring incidents, and the prospect of deliberate targeting—each of which has precedent. Independent analysts and the International Cable Protection Committee note that anchor strikes account for a substantial share of annual cable faults, even as geopolitical tensions in the region raise the risk profile. These causal claims should be treated with caution until cable owners publish conclusive findings. (itu.int)
How subsea cable repair works — why fixes take time​
Repairing an undersea cable is a logistics‑heavy, specialist maritime task:
  • Fault localization uses cable‑landing station telemetry and time‑domain reflectometry to pinpoint damage.
  • A purpose‑built cable‑repair vessel must be scheduled (specialised ships are a finite global resource).
  • The fault zone is accessed, the damaged section lifted, and a mid‑sea splice performed; in shallow or contested waters, permissions and security measures add time.
  • After splicing, thorough testing and system reintegration are required before operators declare the route restored. (www2.telegeography.com)
In politically sensitive waters, ship availability and safety/permission constraints can stretch a repair from days into weeks. That operational reality was reflected in Microsoft’s advisory noting that “undersea fibre cuts can take time to repair.”
Strategic analysis: strengths shown and risks exposed​
Notable strengths (operational resilience)​
  • Automated routing and multi‑path architectures preserved reachability for most services. Microsoft and carriers successfully rerouted traffic to avoid outright outages, demonstrating the value of diverse peering and a multi‑backbone approach.
  • Rapid customer communication via Service Health notices helped customers triage incidents and apply mitigations (throttling, retry adjustments, temporary failover). Transparent advisories reduce uncertainty and support rapid incident management at scale.
Real and persistent risks​
  • Geographic concentration risk: multiple cables share the same landing corridors; simultaneous faults in a narrow corridor produce outsized impact that logical redundancy alone cannot always hide.
  • Repair capacity constraints: the limited global fleet of cable‑repair vessels and regional security constraints make restoration timelines uncertain, particularly in contested or busy shipping lanes.
  • Attribution and security ambiguity: when incidents occur in conflict zones or near areas of maritime unrest, the inability to immediately attribute cause complicates both operational response and policy choices—raising questions around protection and deterrence for critical infrastructure. (itu.int)
Policy and national‑security implications​
Governments and international bodies have already been reacting to the problem:
  • The ITU and allied organisations set up advisory bodies and summits to improve submarine cable resilience, citing the near‑complete dependence of international exchanges on undersea fiber. The advisory work focuses on faster repair processes, improved monitoring and multistakeholder protection regimes.
  • Parliamentary inquiries (for example in the UK) explicitly highlight the number of cables serving national connectivity and the consequences of simultaneous damage to multiple links. Those reviews underscore a policy priority: combine technical investment in route diversity with diplomatic and maritime security measures.
The incident should accelerate concrete action on three fronts: investment in route diversity and new landings, faster access to repair assets, and improved cross‑sector information‑sharing and legal frameworks for protecting and repairing subsea infrastructure.
What enterprises and cloud customers should do right now​
For IT teams and architects running production workloads on Azure or any cloud:
  • Map exposure: identify which cross‑region flows rely on the Red Sea / Suez corridor or other single‑corridor transit paths.
  • Harden timeouts and retries: increase sensible timeouts for cross‑region replication and back off aggressive retries to avoid amplifying congestion.
  • Defer large bulk transfers: delay non‑urgent bulk data migrations, backups or container image pulls until path performance stabilises.
  • Validate failovers: test alternate-region failovers that avoid affected corridors and ensure their data consistency and DNS/telemetry implications are understood.
  • Negotiate transparency: ask cloud and carrier partners for path‑level visibility when possible and include traffic‑engineering contingency terms in contracts.
Practical checklist (quick actions):
  • Run an impact scan against Azure Service Health to identify affected resources.
  • Suspend or throttle non‑essential cross‑region sync jobs.
  • Shift latency‑sensitive traffic to local/regional endpoints if feasible.
  • Communicate with customers and stakeholders about likely latency impacts and expected timelines.
Longer‑term architecture recommendations​
  • Design for geographic path diversity: don’t assume “N+1” virtual redundancy equals physical diversity; explicitly plan for alternate seafloor/land routes.
  • Adopt asynchronous replication for cross‑continent data: make synchronous, chatty replication paths avoid single‑corridor dependencies.
  • Use edge caching and distributed CDNs: reduce the need for frequent long‑distance round trips in user‑facing applications.
  • Contract for contingency capacity: where latency and continuity are critical, arrange with carriers for rapid temporary transit or priority capacity during incidents.
Broader industry lessons and likely follow‑ups​
This episode is unlikely to be a one‑off. The combination of increased maritime traffic, more cables sharing narrow approaches, and heightened geopolitical tensions means the industry must do three things concurrently:
  • Build more route diversity and push critical content providers to stitch meshes of cables that avoid common chokepoints. TeleGeography’s mapping shows continued growth in cable deployments, which helps but takes time and capital.
  • Expand the cable‑repair fleet and regional coordination to shorten mean time to repair; that requires both commercial investment and international permissioning improvements.
  • Strengthen multistakeholder protection: legal frameworks, maritime notices, and cooperative surveillance around high‑value corridors can reduce accidental damage and help deter deliberate sabotage. International bodies such as the ITU and ICPC are already pursuing these agendas.
Caveats and cautionary notes​
  • Attribution of the physical damage remains provisional in many public reports; while some analysts point to anchor strikes, others raise the spectre of deliberate action—formal cable owner consortium statements and maritime investigations are the authoritative sources for cause. Treat early speculation with caution. (timesofindia.indiatimes.com)
  • Metrics and counts cited in public commentary vary by source and methodology: TeleGeography and ITU publish different but complementary figures about the number and total length of active cables; both perspectives are valuable for understanding scale. When precise accounting matters for decisions, rely on the latest TeleGeography/ITU datasets and operator bulletins. (itu.int)
The Red Sea subsea cable cuts that produced elevated latency for Microsoft Azure users are a sober reminder that even the most abstract, cloud‑native services rest on very physical infrastructure. Microsoft’s response—rapid advisory notices, traffic engineering, and capacity rebalancing—limited the incident’s worst effects, but did not eliminate the user‑visible performance degradation for traffic dependent on the damaged corridor. For enterprises, the lesson is straightforward: treat submarine cable risk as real operational risk. For policymakers and the cloud industry, the imperative is also clear: accelerate investments that increase route diversity, improve repair capacity, and tighten cross‑sector protections for the cables that constitute the arteries of the global digital economy. The combination of technical, commercial and diplomatic effort will determine whether future incidents become manageable performance events or catastrophic outages. (datacenterdynamics.com)
(Uploaded briefing files summarising the Azure advisory and network monitoring corroboration are included in the newsroom packet.
Source: National Technology News Microsoft’s Azure cloud services impacted by undersea cable cuts in Red Sea
Multiple undersea fibre-optic cables in the Red Sea were cut on 6 September 2025, triggering measurable slowdowns and intermittent connectivity across South Asia and the Middle East and forcing major cloud and carrier operators — most visibly Microsoft Azure — to reroute traffic, warn customers of higher latency, and begin contingency and repair operations.
Underwater ROVs inspect a deep-sea oil pipeline as surface ships monitor a stormy sea.Background​
The global Internet runs on an undersea skeleton of high‑capacity fibre‑optic cables that carry the vast majority of intercontinental traffic. A narrow maritime corridor through the Red Sea and the Bab el‑Mandeb approaches the Suez route is one of the planet’s most strategic east–west chokepoints. When cables that share this corridor are damaged, the shortest, lowest‑latency paths between Asia, the Middle East and Europe vanish and traffic is forced onto longer, often already congested detours — which produces higher round‑trip times, jitter and packet loss for latency‑sensitive services.
Key cable systems that commonly use the Jeddah/Red Sea corridor include SEA‑ME‑WE‑4 (SMW4) and IMEWE (India‑Middle East‑Western Europe), among other regional feeders. Those systems act as trunk arteries for enterprise traffic, content distribution networks (CDNs) and cloud backbones. A fault in this geography has outsized effects because multiple consortium cables and operators concentrate through a handful of landing sites.
What happened: timeline and confirmed operational facts​
The detection window​
Network monitoring and carrier telemetry began reporting anomalies early on 6 September 2025. Microsoft’s Azure Service Health posted an advisory that traffic traversing the Middle East “may experience increased latency” and noted engineering teams were rerouting traffic and rebalancing capacity; Microsoft indicated the event began at approximately 05:45 UTC on 6 September.
Independent outage monitors reported route flaps, reconvergence events and spikes in round‑trip time for Asia↔Europe and Asia↔Middle East paths, consistent with multiple subsea cable faults near the Jeddah landing corridor. National carriers in affected markets issued localized advisories about reduced international capacity and expected peak‑hour degradation.
Cables and landing points named in early reporting​
Early public reporting and monitoring groups repeatedly flagged SMW4 and IMEWE as systems likely implicated in the faults. Additional regional feeder systems such as FALCON/GCX were also cited by operators and local regulators. Those identifications are operationally plausible given landing geography, but final forensic confirmation normally follows detailed operator diagnostics and fault‑location procedures.
Geographic and human impacts​
Countries that reported measurable performance issues included India, Pakistan, the United Arab Emirates, Saudi Arabia, Kuwait and other regional operators served by east–west trunk links. End users experienced slower page loads, choppy VoIP/video conferencing, elongated backup windows and higher API latencies for cross‑region services.
Major cloud customers and enterprises saw higher application latency when traffic flowed between regions that ordinarily used the Red Sea corridor. Pakistan Telecommunications (PTCL) warned customers of degradation during peak hours while alternate capacity was provisioned, and UAE subscribers on Du and Etisalat reported slower speeds. Microsoft said it redirected traffic through other network routes to avoid a total service outage, but users still noticed slow response times in several countries while rebalancing was underway.
Why a cable cut becomes a cloud outage: the technical anatomy​
The sequence that turns a seafloor fault into customer pain is straightforward and repeatable:
  • Physical capacity reduction: a cut removes fibre pairs or entire segments of a trunk route.
  • BGP and route‑control reconvergence: carriers and transit providers withdraw affected paths and announce alternatives.
  • Longer or saturated detours: alternate routes are often physically longer (propagation delay) and may already be near capacity.
  • Application effects: latency‑sensitive workloads (VoIP, video conferencing, synchronous replication, real‑time trading feeds) exhibit timeouts, retries and visible degradation.
Cloud providers operate logically redundant fabrics across regions, but those fabrics still depend on a finite set of physical sea‑lines for inter‑region traffic. Rerouting preserves reachability but cannot instantly replace lost raw subsea capacity, which is why Azure warned about increased latency rather than a full outage.
How operators responded (immediate mitigations)​
Cloud and carrier operator playbook in this incident followed a familiar pattern:
  • Detect: monitoring systems and telemetry showed anomalies and route changes.
  • Notify: Microsoft posted public Service Health notices and national carriers issued advisories for customers.
  • Reroute and rebalance: affected flows were shifted onto alternate submarine routes, terrestrial transit and peering arrangements to maintain reachability.
  • Plan physical repairs: consortium owners and cable operators prepared for fault‑location and schedule of repair ships to splice and test cable cuts.
These steps limited the risk of a complete regional blackout, but the mitigation trade‑off was higher latency and degraded experience for many cross‑region services while traffic engineering took effect.
Repair realities and timelines​
Repairing subsea cables is complex and resource constrained. A typical repair cycle includes locating the fault using specialised instruments, dispatching a cable‑repair vessel, recovering the damaged ends, performing mid‑sea splices and testing before the system is returned to service. Under benign conditions this can take days; in geopolitically sensitive or busy shipping lanes the process can extend into weeks or longer because of vessel availability, maritime permissions, insurance/warlike‑risk considerations and safety for crews.
The Red Sea corridor presents additional operational friction: wartime activity, naval operations and contested waters complicate the ability of repair ships to work safely and quickly. Industry veterans warn that repair ship availability is a global bottleneck and that insurers may demand higher premiums for operations in risky zones, further delaying on‑site work.
Attribution, politics and the security angle​
The timing of the cuts coincides with heightened regional tensions and prior incidents of undersea infrastructure damage. Yemen’s internationally recognised government‑in‑exile criticised the event and said it could not be separated from Houthi activities, urging international action to protect critical digital lifelines; Houthi‑run Al Masirah TV acknowledged the cable reports in the media. Past incidents in the region have prompted similar allegations, and while some observers point to deliberate interference as a plausible cause, operator forensic work is required before attribution can be considered reliable. Premature public attribution risks escalation and may be inaccurate.Where public attribution is made, reporters and analysts generally wait for consortium bulletins or cable‑owner fault‑location reports, which provide precise coordinates, cable‑pair diagnostics and physical evidence. Until those operator reports are published, any claim of deliberate sabotage should be treated as provisional.
Immediate risks and knock‑on effects​
  • Economic and business continuity risk: degraded connectivity affects e‑commerce, payment clearing, stock‑trading feeds and enterprise backups, producing quantifiable economic impact during prolonged disruptions.
  • Cloud service performance: cross‑region applications, synchronous replication, and latency‑sensitive SaaS offerings face higher failure rates and user complaints. Azure’s reroute preserved reachability but did not eliminate customer impact in affected regions.
  • National security and public services: critical public services that depend on transcontinental data exchanges (e‑government, telemedicine, interbank messaging) can suffer degraded performance, increasing operational risk.
  • Cascading network congestion: detours push load onto other cables and terrestrial links, increasing the likelihood of secondary congestion incidents until traffic returns to normal.
What this means for WindowsForum readers — practical, prioritized actions​
This incident is a real‑world test of resilience planning for cloud consumers, network engineers, IT managers and sysadmins. The guidance below focuses on measurable, immediate steps to reduce exposure and restore acceptable service levels.
Short‑term checklist (first 24–72 hours)​
  • Consult cloud status and carrier advisories: check Azure Service Health and your transit providers for targeted guidance and timelines.
  • Identify exposed traffic: map which applications and services use Asia↔Europe or Asia↔Middle East paths that likely transit the Red Sea corridor. Prioritize mission‑critical flows.
  • Increase retries and timeouts selectively: for chatty APIs and replication jobs, temporarily increase request timeouts and back‑off/retry windows to avoid spurious failures.
  • Defer non‑critical bulk transfers: move large backups and non‑urgent data migrations to off‑peak hours or until alternate capacity is confirmed.
  • Leverage regional caching/CDN: push static and cacheable assets to edge nodes closer to users to reduce cross‑continent round trips.
  • Monitor telemetry and alerts: pay close attention to application latency SLOs, packet loss metrics and BGP path changes. Use synthetic tests from affected geographies.
Mid‑term tactical actions (days to weeks)​
  • Configure or test multi‑region failover: ensure applications can run with degraded throughput by shifting to local region replicas or read‑only fallbacks.
  • Negotiate temporary capacity: if you are a large enterprise, work with your transit provider or cloud account team to secure alternate bandwidth or private interconnects.
  • Harden DNS and CDN strategies: adopt geo‑aware DNS failover and increase TTL sensitivity for faster reroute if endpoints change.
  • Review disaster‑recovery scripts: verify they don’t amplify congestion (e.g., automatic simultaneous global job restarts).
Architectural recommendations (medium to long term)​
  • Diversify physical paths: where possible, choose cloud and network partners that offer diverse landing points and non‑Red‑Sea transit options.
  • Adopt edge‑first design: move latency‑sensitive logic toward the edge using CDNs, regional caches and local processing.
  • Test realistic failures: include subsea‑corridor outages in SRE runbooks and chaos tests so teams can rehearse the mitigation playbook.
  • Contract for transparency: insist on clear escalation paths and communication windows with your CSPs and transit providers.
Policy and industry implications​
This disruption amplifies several systemic issues:
  • Concentration risk: a handful of strategic corridors still carry a disproportionate share of east–west capacity, which creates single‑point vulnerability at the level of landing corridors.
  • Repair capacity limits: the global pool of cable‑repair vessels and trained crews is limited; demand spikes during incidents can extend outages.
  • Protection of critical infrastructure: repeated incidents in contested waters raise legitimate questions about protective measures, cooperative naval escorts for repair vessels, and legal frameworks to safeguard subsea assets.
Governments, carriers and cloud operators must coordinate on three pragmatic fronts: fund and fast‑track physical route diversity projects, expand global repair‑ship availability and insurance mechanisms, and enhance real‑time cross‑operator monitoring and early‑warning systems.
Critical analysis: strengths in the response and remaining weaknesses​
What worked​
  • Rapid detection and public advisories: monitoring groups and cloud operators quickly alerted customers and the public, which reduced surprise and guided mitigation.
  • Traffic engineering preserved reachability: Azure and other carriers successfully rerouted traffic to avoid a full outage, demonstrating that logical redundancy and agile traffic engineering still prevent catastrophic failures.
What didn't​
  • Persistent performance degradation: reroutes mitigate total loss but cannot eliminate the physics of longer paths and constrained capacity, leaving latency‑sensitive services exposed for the duration of repairs.
  • Attribution and information gaps: operator confirmation of exactly which cable pairs and the root cause take time; public attribution amid geopolitical tension risks misinformation and escalation. Until consortium confirmatory reports are released, attribution remains provisional.
  • Structural fragility: the incident underscores that logical cloud redundancy is necessary but not sufficient; physical route diversity and investment in maritime repair logistics remain under‑prioritised.
Practical checklist for Windows and on‑prem administrators (condensed)​
  • Check Azure Service Health and your provider alerts immediately.
  • Delay bulk syncs and increase timeouts for critical APIs.
  • Use regional endpoints, CDNs and caches for public‑facing assets.
  • Ensure application health checks and failover flows are tested for increased latency.
  • Prepare communications templates for customers and internal stakeholders describing degraded performance rather than claiming uptime issues.
The Red Sea cable cuts are a stark operational reminder that the cloud and the Internet are only as resilient as the physical fibre that spans the ocean floor. Microsoft Azure’s rapid rerouting and public advisories preserved reachability for many customers, but the incident exposed a fragile dependency: when a handful of subsea trunks fail in a concentrated corridor, even the world’s largest cloud platforms cannot instantly restore low‑latency capacity.For IT teams and WindowsForum readers, the incident is actionable: map exposure, test failovers against realistic network failures, adopt edge‑forward delivery patterns, and negotiate clearer response and escalation commitments with cloud and transit partners. At an industry and policy level, the episode should accelerate investments in route diversity, repair logistics and protection for the undersea lifelines that underpin modern commerce and communication.The technical and geopolitical factors that complicate repair and attribution mean the situation could persist for days or weeks; treat any attribution claims as provisional until operators publish forensic fault‑location reports and repair confirmations.
Source: Marine Insight Undersea Cable Damage In Red Sea Disrupts Internet Across Asia & Middle East
Microsoft Azure customers experienced measurable slowdowns and higher-than-normal latency after multiple undersea fiber-optic cables in the Red Sea were cut, forcing cloud traffic onto longer, congested detours and exposing brittle physical chokepoints beneath modern cloud resilience.
Neon underwater fiber-optic cables link Bab El-Mandeb to Atlantic routes beneath the ocean.Background​
The global internet is built largely on submarine fiber-optic cables that carry the vast majority of intercontinental data traffic. These physical links — laid on the seabed and terminating at a relatively small number of landing stations — concentrate east–west traffic through a few narrow maritime corridors. The Red Sea and the approaches to the Suez Canal are among the internet’s most important chokepoints, linking South and East Asia with the Middle East, Africa and Europe. That concentration gives logical redundancy a veneer of safety: multiple providers and cloud regions exist, but if those network paths share the same submarine corridor, a single physical event can produce wide-ranging performance degradation. The September incident made that reality visible to many enterprises and consumers through degraded Azure performance and slower internet in multiple countries.
What happened — a concise timeline​
  • Around 05:45 UTC on 6 September 2025, routing telemetry and independent monitors began detecting route flaps and degraded throughput for paths transiting the Red Sea corridor. Microsoft posted an Azure Service Health advisory that customers “may experience increased latency” for traffic traversing the Middle East while engineers rerouted traffic. (cnbc.com)
  • Independent monitoring organisations and national carriers reported degraded connectivity in countries including India, Pakistan, the United Arab Emirates and Saudi Arabia. Groups such as NetBlocks documented changes in routing and localized slowdowns. (apnews.com)
  • Operators and industry analysts identified candidate systems likely affected by faults near Jeddah and the Bab el‑Mandeb approaches, naming submarine systems that commonly use the corridor — for example, SEA‑ME‑WE‑4 (SMW4), IMEWE, FALCON GCX and in some reports the Europe‑India Gateway. Final, operator-level forensic confirmations take time and are typically published later by consortiums or cable owners. (techcrunch.com)
  • Microsoft and carriers rerouted traffic through alternate subsea and terrestrial paths, which preserved reachability but increased round-trip times (RTT), jitter and intermittent packet loss until traffic rebalancing stabilised and repairs progressed. By some subsequent updates, Microsoft reported that Azure was no longer detecting platform-wide issues, though repairs of the physical cable segments would continue over days-to-weeks. (cnbc.com)
The technical anatomy: how a cable cut becomes an Azure problem​
Submarine cable faults translate into cloud performance issues through a short, deterministic chain of events.
  • A physical disruption severs or impairs one or more fiber pairs on a submarine system.
  • Border Gateway Protocol (BGP) and carrier routing tables reconverge; operators withdraw the damaged paths and advertise alternate next-hops.
  • Traffic that previously followed the shortest, highest-capacity trunk follows longer geographic detours (e.g., around the Cape of Good Hope or via different Mediterranean/Atlantic paths).
  • Alternate links absorb redirected load; where capacity is limited or previously near-utilized, congestion appears, introducing higher RTT, jitter and packet loss for latency-sensitive flows.
For cloud platforms like Microsoft Azure, which run distributed datacenters and rely on a mix of private backbone, leased transit and public peering, the data plane (application traffic, replication, backups) is most exposed. Management and control planes may remain reachable if they use other peering relationships or regional endpoints, which is why incidents often manifest as performance degradation rather than a total service blackout.
Key technical symptoms reported during the incident included:
  • Increased application latency for cross‑region traffic (notably Asia⇄Europe and Asia⇄Middle East).
  • Higher jitter and transient packet loss affecting VoIP, video conferencing and real‑time gaming.
  • Slower bulk transfers, extended backup windows and retries for chatty APIs.
These are classic data‑plane impacts when physical transit capacity is constrained.
Which cables and regions were affected (what’s verified and what’s provisional)​
Public reporting and independent monitors consistently pointed to several high‑capacity systems that transit the Jeddah corridor and Bab el‑Mandeb approaches as affected. Early lists included:
  • SEA‑ME‑WE‑4 (SMW4)
  • IMEWE (India–Middle East–Western Europe)
  • FALCON GCX
  • Europe‑India Gateway (EIG) mentioned in some assessments
These identifications were reported by multiple outlets and monitoring groups, but operator-level confirmation — which identifies exact fault coordinates and the fiber pairs impacted — typically follows later. Treat attribution and precise cable lists as provisional until consortium bulletins or cable owners publish formal diagnostics. (aljazeera.com)
Geographically, the countries and regions that reported user-visible slowdowns included parts of:
  • South Asia (India, Pakistan)
  • The Gulf (UAE, Saudi Arabia)
  • Adjacent regions in East Africa and Europe for certain routed flows
NetBlocks and carriers logged degraded throughput and route changes consistent with a multi‑cable event near the Red Sea. (aljazeera.com)
Cause analysis: accident, anchor drag, or deliberate action?​
Publicly available evidence and expert commentary point toward two plausible cause classes, with different operational and policy implications:
  • Accidental mechanical damage (e.g., ship anchor dragging or grounding): Shallow coastal waters and busy shipping lanes increase the risk that commercial vessels dragging anchors can strike and sever cables. Industry specialists and the International Cable Protection Committee note such accidents are common causes of cable faults. In this incident, several reputable outlets and analysts cited anchor-drag as a likely cause. (aljazeera.com)
  • Deliberate interference or hostile action: The Red Sea has seen heightened maritime security incidents in recent years, and earlier cable incidents in nearby waters prompted speculation about deliberate targeting. However, forensic confirmation of deliberate sabotage requires careful physical inspection, forensic recovery of cut fiber ends and, often, cooperation among multiple national authorities and owners. Public reporting so far does not provide definitive, operator-confirmed evidence of deliberate sabotage; several outlets explicitly caution that attribution remains unverified.
Because operator diagnostics and official consortium statements typically follow the first wave of media reporting, any claim assigning a single verified cause should be treated cautiously until owners publish formal findings. The responsible editorial posture is to flag attribution as provisional and to emphasise operational facts (cuts, reroutes, latency impact) that are already corroborated.
Why repairs take time — the maritime realities​
Repairing submarine cables is not like patching a terrestrial fiber: it requires specialised vessels, favourable weather, navigational safety and, when incidents occur in sensitive waters, permissions and security arrangements.
  • An incident diagnosis must first determine the fault zone using telemetry.
  • A cable ship must be mobilised — global repair-vessel capacity is limited and often scheduled weeks ahead.
  • The vessel locates the damaged segment, retrieves the cable to the surface, performs a splice, and re‑buries the cable where necessary.
  • Where fault zones are near contested or restricted waters, insurers, navies and authorities may slow operations.
As a result, repair timelines commonly range from days to weeks and can stretch longer where geopolitics or vessel availability constrain operations. That explains why routing and rebalancing are the principal short‑term mitigations for cloud operators.
Microsoft’s operational response — reroute, rebalance, inform​
Microsoft followed industry-standard mitigations for a corridor-level subsea incident:
  • Rapid public advisory via Azure Service Health to inform customers about expected latency impacts and the geographic scope.
  • Traffic engineering and dynamic rerouting of backbone flows to avoid damaged paths, including leasing temporary transit where available.
  • Prioritisation of control-plane stability and continuous monitoring while rebalancing data-plane traffic.
  • Regular status updates — Microsoft committed to daily updates or sooner if conditions changed.
These steps preserved reachability and prevented a broader platform outage, but they cannot instantly replace raw physical capacity lost on the seafloor. The user-visible result was mainly performance degradation on affected cross‑region flows rather than a global service blackout.
Impact assessment: who felt it, and how bad was it?​
The event’s practical impact varied by workload, geography and network design.
  • Consumer-facing, latency-sensitive services (real-time conferencing, streaming, gaming) showed the most visible degradation for affected routes.
  • Enterprise workloads experienced longer backup windows, slower cross-region replication and increased retry storms in chatty APIs.
  • Regions that rely heavily on the Red Sea corridor for Asia⇄Europe transit reported the highest effects; some national ISPs issued advisories to customers about peak-hour slowdowns.
  • For many Azure customers, the control plane and regional compute remained functional; the disruption primarily affected data-plane performance for trans‑corridor flows.
The overall pattern matches historical subsea incidents: reachability can often be maintained by rerouting, but latency-sensitive applications pay a performance tax until physical repairs restore normal capacity.
Risks and second-order effects​
This incident highlights several underappreciated risks:
  • Concentration risk: Logical redundancies in cloud fabrics can be undermined by physical route concentration. Multiple providers and transit arrangements are insufficient if they share the same seabed corridor.
  • Cascading congestion: Rerouting large volumes onto alternate cables increases utilisation on those links, creating the potential for congestion to cascade into additional regional slowdowns.
  • Operational opacity: Enterprises often lack visibility into the physical geometry of their providers’ transit; without that, it’s hard to quantify exposure to specific corridor failures.
  • Security and geopolitics: Repair and protection efforts in contested waters can be complicated by national security concerns, limiting the speed of recovery and raising policy questions about protecting subsea infrastructure.
These are not theoretical: they translate into measurable business costs — missed SLAs, delayed transactions, degraded user experience and, in tightly coupled systems, potential financial exposure for latency-sensitive trading or real‑time services.
Practical guidance for IT and infrastructure teams​
Enterprises should treat subsea-cable incidents as part of normal operational risk and prepare accordingly. Practical, actionable steps include:
  • Map exposure: Identify which application flows and regions depend on the Red Sea corridor or similar chokepoints. Use traceroutes, BGP path analysis and provider topology information to map physical transit where possible.
  • Harden timeouts and retries: For chatty APIs and replication, implement exponential backoff, longer timeouts and idempotent retries to avoid retry storms under elevated latency.
  • Test failovers: Regularly validate failover procedures to regions and alternative providers that use diverse physical routes. Ensure data sovereignty and regulatory constraints are considered.
  • Use asynchronous replication: Where feasible, convert synchronous cross-region replication to asynchronous models during emergencies to avoid performance tail latency.
  • Negotiate transit transparency: In contracts with cloud and network providers, request clarity on physical route diversity and escalation paths for subsea incidents.
  • Consider multi‑cloud or multi‑region architectures with genuine path diversity, not just logical redundancy.
Adopting these measures reduces the operational and business impact when submarine infrastructure incidents occur.
The incident underscores an urgent need for coordinated policy and industry action:
  • Expand repair capacity: The global fleet of cable repair vessels is limited. Investment in more ships and regional repair hubs would shorten mean-time-to-repair for major corridor incidents.
  • Improve transparency: Greater visibility into route geometry and shared risk groupings (cable paths that traverse the same corridor) should be standardised so enterprises and critical services can measure exposure.
  • Protect infrastructure: International cooperation to protect submarine cables — including deconfliction of shipping lanes, stronger enforcement of anchor‑drag rules and security measures in contested waters — reduces accidental and deliberate risk.
  • Incentivise diversity: Regulators and large purchasers (cloud buyers, content providers) can incentivise physical path diversity through procurement practices and resilience requirements.
These policy moves require cross-border cooperation because seabed infrastructure and global shipping operate across national jurisdictions. The economic and strategic value of resilient subsea connectivity argues strongly for coordinated investment and protection.
Strengths in the response ecosystem — and remaining weaknesses​
Notable strengths displayed during the incident:
  • Major cloud providers and carriers were able to reroute traffic quickly, preserving reachability and avoiding a full-scale outage.
  • Public advisories (such as Azure Service Health) gave enterprise customers actionable, time‑bound information about expected impacts.
  • Independent monitoring groups and national carriers supplied corroborating telemetry that helped operations teams understand the scope.
Persistent weaknesses:
  • Physical dependence on a small set of corridors remains a single point of failure for many east–west routes.
  • Repair‑ship scarcity and geopolitics can extend recovery timelines beyond what logical redundancy alone can tolerate.
  • Many enterprises still lack concrete visibility into the physical transit their providers rely on, impeding rapid risk assessments.
The net effect is that operational playbooks work — up to a point — but resilient outcomes require investments in both physical infrastructure and greater transparency from providers.
What to watch next​
  • Operator bulletins: Formal consortium releases from cable owners will provide definitive fault coordinates, affected fiber pairs and repair schedules — those confirm or refute provisional attributions.
  • Repair-ship mobilisation: Watch for announcements about cable‑repair vessel deployments and expected timelines; these determine how fast full capacity returns.
  • Regulatory and industry responses: Expect calls for improved protection measures and possible cooperative arrangements for regional repair capacity and seabed monitoring.
Flag: any early claim that assigns definitive blame for the cuts (accident vs. sabotage) remains provisional until operator forensic findings are published.
The Red Sea cable incident that slowed Microsoft Azure and degraded internet performance across parts of South Asia and the Middle East is a practical reminder that cloud computing ultimately depends on ships, splices and the seafloor as much as on code and virtual networks. Rapid rerouting and provider transparency limited the immediate damage, but the event exposed enduring structural risks: corridor concentration, limited repair capacity and opacity about physical transit.
For IT leaders, the takeaway is straightforward: assume the subsea layer matters. Map exposure, harden workloads, test diverse failovers and insist on supplier transparency about physical route diversity. For policymakers and industry leaders, the task is larger: protect and expand the physical lifelines of the internet, invest in repair capability and create incentives for genuine path diversity. Until those investments are made, cloud resilience will remain as much a function of maritime logistics as of software design. (apnews.com)
Source: Computing UK https://www.computing.co.uk/news/2025/cloud/red-sea-cable-damage-hits-microsoft-azure-slows-internet/
Microsoft’s Azure cloud briefly showed the limits of virtual resilience when several undersea fiber-optic cables in the Red Sea were cut on 6 September 2025, forcing traffic onto longer detours, producing higher-than-normal latency for cross‑region traffic, and triggering urgent traffic‑engineering work by Microsoft and multiple carriers to preserve reachability.
Undersea fiber cables glow as a holographic map tracks global data routes and repair ships.Background​
The modern internet is a physical network built on submarine fiber‑optic cables that carry the overwhelming majority of intercontinental traffic. A narrow maritime corridor through the Red Sea and the approaches to the Suez Canal is one of the planet’s primary east–west funnels connecting South and East Asia with the Middle East, Africa and Europe. When multiple trunk systems that share that corridor fail at once, the shortest physical paths disappear and traffic must be rerouted over longer, sometimes congested alternatives — a topology shift that raises round‑trip time (RTT), jitter and the risk of packet loss. On 6 September 2025, monitoring groups and regional carriers reported simultaneous faults on several subsea systems in the Red Sea corridor. Microsoft posted an Azure Service Health advisory telling customers they “may experience increased latency” for traffic that previously traversed the Middle East while its engineers rerouted and rebalanced capacity to reduce customer impact. Within a short period Microsoft reported that primary symptoms had been mitigated and that Azure was running normally. This incident was not a cloud outage in the classic sense — reachability for most services was preserved — but it was an operational reminder that cloud reliability still depends on a finite, geographically constrained physical substrate.
Early detection and advisory​
  • 6 September 2025, ~05:45 UTC — independent monitors and carrier telemetry observed BGP reconvergence, longer AS paths and spikes in latency consistent with physical cable faults in the Red Sea corridor.
  • Same day — Microsoft published an Azure Service Health advisory warning of increased latency for traffic that traverses the Middle East and began active rerouting and capacity rebalancing.
Short-term mitigation​
  • Microsoft, major transit providers and CDNs applied traffic engineering measures — rerouting flows over alternate cables, provisioning temporary transit leases and adjusting routing weights — to preserve reachability while accepting higher latency on affected paths. These networking measures restored much of the platform’s operational surface within hours, and Microsoft later reported Azure operating normally.
Ongoing repair phase​
  • Cable owners and consortiums began diagnostics and plans for maritime repairs; fault localization and mid‑sea splices require specialized cable vessels and safe access to the damage site, processes that can take days to weeks depending on location and security conditions.
Which cables and which regions were affected​
Early public reporting and network telemetry repeatedly flagged trunk systems that historically transit the Jeddah corridor and the Bab el‑Mandeb approaches. Monitoring groups and national carriers named candidate systems including SEA‑ME‑WE‑4 (SMW4) and IMEWE (India–Middle East–Western Europe), with additional reports mentioning systems such as FALCON GCX and other regional branches. Definitive, operator‑level confirmation of each damaged fiber pair typically follows formal consortium bulletins and fault reports and can lag initial media coverage. The practical user impact concentrated on traffic that originates, terminates, or transits between Asia, the Middle East and Europe, with notable slowdowns and complaints reported from India, Pakistan, the United Arab Emirates and other Gulf states. NetBlocks and national telecoms documented degraded connectivity and route flaps consistent with multiple trunk failures.
The immediate cloud effect: why Azure customers felt it​
Cloud platforms separate control‑plane and data‑plane functions, and they design for regional redundancy. But logical redundancy assumes physical route diversity. When several submarine links that occupy the same narrow corridor are severed simultaneously, the redundancy model is stressed: packets must traverse longer geographic detours or pass through terrestrial backhaul and alternate subsea systems that were not engineered for the sudden surge.
The operational mechanics that produced user-visible symptoms:
  • Border Gateway Protocol (BGP) re‑advertisements triggered route reconvergence and selection of longer AS‑paths.
  • Physical detours increased propagation delay — adding tens to hundreds of milliseconds depending on the alternative path chosen.
  • Sudden load on alternate links created queuing delays and packet loss where spare capacity was limited.
  • Latency‑sensitive services — VoIP, video conferencing, synchronous database replication and some real‑time APIs — degraded first, showing increased RTT, jitter and timeouts.
Microsoft framed the incident technically as performance degradation rather than a full platform outage, and its engineers focused on rebalancing flows and optimizing routing while repair operations were scheduled. The result was preserved reachability but uneven performance for cross‑region workloads.
Cause: accident, malice, or something else?​
At the time of reporting, the cause remained unverified. Multiple possibilities exist and must be treated cautiously:
  • Accidental damage (anchor drag or fishing gear) is a common cause of cable faults in shallow corridors and was suggested by maritime and telecom experts soon after the incident. The International Cable Protection Committee and independent analysts often flag anchoring incidents as plausible causes when cuts appear near shipping lanes.
  • Intentional sabotage cannot be dismissed in a region experiencing heightened military activity; the Red Sea has been subject to naval incidents and attacks on shipping since late 2023. However, attribution is delicate and often contested. Yemen’s Houthi movement — previously accused in media reports of disruptive actions in the Red Sea — publicly denied responsibility for targeting cables in this episode. Early media coverage therefore treated any claim of responsibility as provisional pending forensic confirmation.
Because final forensics require physical inspection of the cable and operator consortium reports, any public claim about the precise cause should be treated as tentative until official fault maps and splicing reports are published.
Repair logistics: why fixes take time​
Repairing undersea cables is a complex, resource‑intensive maritime operation:
  • Fault localization requires precise acoustic and electrical measurements and sometimes grapnel runs to recover the damaged segment to the surface.
  • Specialized cable repair ships must be scheduled and routed to the site; there is a global shortage of such vessels relative to demand.
  • Repairs in geopolitically contested waters require security assessments, permits and sometimes international coordination to ensure the safety of repair crews.
  • After recovery, splicing and testing are time‑consuming: restored capacity is validated before routes are returned to normal operation.
These constraints mean that while routing mitigations can reduce user impact quickly, full physical restoration of cut links often takes days to weeks — and in complex cases, months.
Strategic implications: what this reveals about cloud resilience​
This incident exposes several structural truths about cloud resilience that CIOs and network architects must reckon with:
  • Logical redundancy is not a substitute for physical route diversity. Public cloud resilience depends on physical undersea and terrestrial routes; when those routes share the same chokepoints, correlated failures undermine assumptions of independence.
  • Cloud SLAs focus on availability, not necessarily latency. A platform can remain “available” while experiencing performance degradation that breaks real‑time SLAs and user experience expectations. Enterprises that tie business continuity to strict latency SLOs need specific contractual and operational measures.
  • Operational transparency and telemetry are essential. Microsoft’s Service Health advisory and similar carrier communications are necessary but not sufficient; customers need fine‑grained, regionally mapped routing visibility to assess exposure and invoke contingency plans.
  • Geopolitics matters to the network. Cable corridors that traverse contested or high‑traffic maritime zones are strategic assets and vulnerabilities simultaneously; national and corporate risk analyses must include maritime security scenarios.
Practical guidance for enterprise architects (actions and priorities)​
For teams designing cloud‑dependent systems, the Red Sea incident provides a practical checklist. Below are recommended actions, ordered by near‑term to long‑term priorities.
  • Immediate operational actions (hours–days)
  • Review replication and backup topologies to ensure critical control paths do not all rely on the same geographic corridor.
  • Temporarily shift latency‑sensitive workloads to regional peers or alternate providers where possible.
  • Increase retry and timeout thresholds for cross‑region calls, and triage services by criticality.
  • Monitor vendor status pages and request route‑level telemetry where available.
  • Tactical resilience (days–weeks)
  • Implement multi‑cloud or multi‑region replication with geographically diverse endpoints for critical data.
  • Use CDN and edge caching aggressively to reduce cross‑continent dependencies for static or semi‑static content.
  • Establish contingency SLAs or emergency transit arrangements with carriers for critical bandwidth during incidents.
  • Strategic planning (months)
  • Map physical transit geometry for your traffic flows — identify chokepoints and quantify latency exposure under realistic detour scenarios.
  • Design application tiers to degrade gracefully: prefer asynchronous replication for non‑real‑time functions and isolate latency‑sensitive components.
  • Negotiate contractual transparency clauses with cloud providers and carriers that cover routing diversity, notification windows and incident reporting.
  • Benefits of these steps:
  • Reduced business risk during corridor‑level failures.
  • Faster operational response with pre‑mapped contingencies.
  • Clearer cost/benefit calculus for paying for route diversity or premium transit.
Broader industry and policy responses to consider​
The Red Sea cuts are a call to action beyond individual enterprises. Several policy and industry levers could mitigate future risks:
  • Invest in route diversity and new landing stations. Build and fund subsea projects that avoid single chokepoints and increase landing diversity across different coastal corridors.
  • Expand repair capacity and regional repair hubs. Encourage public‑private initiatives to increase the fleet of cable repair ships and pre‑position spares and crews in strategic regions.
  • Strengthen maritime protections for critical infrastructure. International maritime security frameworks and regional navies can provide safe corridors for repair ships and deter deliberate attacks.
  • Improve incident transparency and coordinated response. Cable consortiums, carriers and cloud providers should standardize rapid fault disclosure practices that give customers actionable route‑level data without compromising security.
These measures require time, capital and international cooperation — but the economic and societal reliance on uninterrupted cross‑border digital connectivity makes them strategically important.
Risks, unknowns and caveats​
  • Attribution remains unresolved. Until cable owners publish formal fault reports, claims about specific perpetrators or causes remain provisional. Treat early attributions with caution.
  • Not all cloud customers experienced identical impacts. The observable degradation skewed toward latency‑sensitive, cross‑continent flows; many regionally contained services were unaffected. Assume asymmetric exposure in any risk assessment.
  • Repair timelines are variable. Historical precedents show undersea repairs can take days to months; if repairs occur in contested waterways, access and safety issues may extend those windows. Plan accordingly.
Long‑term outlook for subsea resilience and cloud architecture​
The Red Sea incident is a structural stress test that will accelerate several trends already visible in the telecom and cloud ecosystems:
  • More investment in physical diversity — new cable projects with alternative routes will be prioritized, especially those that avoid single chokepoints and push landing diversity into under‑served geographies.
  • Stronger operational partnerships — enterprises will negotiate greater transparency and routing guarantees from cloud and transit partners, and carriers will develop faster fault disclosure and repair coordination processes.
  • Edge‑first application design — software architects will continue to push compute and cache closer to users to reduce cross‑continent dependence.
  • Policy and security convergence — governments will increasingly treat subsea systems as critical national infrastructure requiring protection, similar to ports and power grids.
None of these changes are instantaneous, but the economic case for resilient physical connectivity has never been clearer.
The Red Sea cable cuts that affected Microsoft Azure in early September 2025 were a vivid operational lesson: cloud services are logically abstract but physically grounded. Microsoft’s rapid traffic‑engineering work preserved reachability for most users, yet the latency spikes and degraded experiences for cross‑region workloads revealed the fragility of corridor‑centric routing and the limits of logical redundancy when multiple physical links fail concurrently. For enterprises, the immediate priority is pragmatic: map exposure, apply tactical mitigations, and bake physical‑path awareness into architecture and procurement decisions. For industry and governments, the episode underlines the need to invest in route diversity, repair capacity and coordinated protection for the subsea arteries that carry the world’s data. The cloud will keep evolving toward greater resilience, but durable service availability ultimately requires both resilient code and resilient cables.
Source: Digital Watch Observatory Microsoft cloud hit by Red Sea cable cuts | Digital Watch Observatory
Internet traffic between South Asia, the Gulf and parts of the Middle East slowed dramatically after multiple subsea fibre‑optic cables in the Red Sea were damaged, forcing carriers and cloud providers to reroute traffic, prompting Microsoft Azure to warn customers of higher latency and exposing fresh questions about the fragility of the world’s undersea communications arteries.
Digital map showing an underwater pipeline network linking offshore facilities worldwide.Background: why one narrow waterway matters for the global internet​
The modern internet is not a nebulous cloud — it rides on a physical network of submarine (subsea) fibre‑optic cables that carry the overwhelming majority of intercontinental data. A handful of maritime corridors concentrate enormous volumes of capacity; the Red Sea and the Bab al‑Mandeb approaches represent one of those strategic chokepoints that link South and East Asia with Europe, Africa and the Middle East. When several high‑capacity trunk links that share that corridor are damaged or disrupted at once, the shortest and lowest‑latency physical paths vanish and traffic must take longer, often congested detours.
These corridors are economically efficient: operators route huge volumes of traffic through the most direct paths to minimise latency and cost. That aggregation is convenient — and hazardous. The recent Red Sea damage shows how correlated physical exposure can translate into rapid, user‑visible slowdowns across continents. Early monitoring and carrier bulletins pointed to routing anomalies and degraded throughput near the Saudi port of Jeddah, implicating trunk systems that commonly traverse the corridor.
What happened — the operational facts​
  • Timeframe: Independent monitoring groups and carrier telemetry first registered anomalies and BGP reconvergence consistent with physical cable faults on or about 6 September 2025.
  • Symptoms: Customers in India, Pakistan and parts of the Middle East — including subscribers of Etisalat and du in the UAE — reported slower page loads, choppy video and voice calls, higher packet loss and intermittent access. NetBlocks and national telcos documented degraded connectivity and route changes.
  • Cloud impact: Microsoft published an Azure Service Health advisory stating that “network traffic traversing through the Middle East may experience increased latency due to undersea fibre cuts in the Red Sea,” and confirmed it had rerouted traffic through alternative paths outside the region to reduce the impact. Azure warned that while reachability was preserved, customers could see higher latency for flows that previously traversed the affected corridor.
Those operational facts are corroborated by multiple independent monitors and contemporaneous carrier and cloud advisories. They represent verified immediate effects: physical faults on subsea routes, traffic engineering mitigations and user‑visible performance degradation for cross‑region traffic.
Technical anatomy: how a cable cut becomes a cloud incident​
Subsea cables are physical assets laid along the seabed in fibre pairs, protected only by a light armouring in deep water and heavier protection near shore. When a trunk cable is cut, operators cannot simply “flip a virtual switch” to restore the same low‑latency path — packets must be steered onto alternative routes that are often:
  • Geographically longer, adding propagation delay.
  • Already carrying heavy loads, producing queuing and congestion.
  • Dependent on terrestrial backhaul or peering arrangements that add extra hops and potential loss.
The routing layer (BGP) reconverges, and carriers and cloud providers perform traffic engineering to reweight paths, lease spare capacity, or use CDN and satellite fallbacks. These mitigations preserve reachability but cannot instantly recreate lost capacity, so latency, jitter and packet loss rise — the exact symptoms Azure described and users observed.
Key operational consequences for cloud services include elongated API response times, slower replication windows, degraded VoIP/video, and interrupted low‑latency workflows such as trading and synchronous database operations. Even resilient cloud platforms can suffer noticeable performance degradation when the physical path diversity collapses.
Which cables and landing points were implicated​
Early monitoring and reporting named major trunk systems that historically use the Jeddah/Red Sea corridor as likely affected routes. Public monitoring groups and carrier bulletins repeatedly flagged candidate systems such as SEA‑ME‑WE‑4 (SMW4) and IMEWE (India‑Middle East‑Western Europe), and some accounts also referenced other regional feeder systems. Those identifications are operationally plausible given landing geography and observed route changes, but final forensic confirmation requires operator diagnostics and fault location data. Treat early cable‑list claims as probable but provisional until consortium owners publish fault reports.
Impact by region and sector​
South Asia (India, Pakistan)​
Users in India and Pakistan reported spikes in outage complaints and slower international connectivity during peak hours. ISPs and national carriers issued temporary advisories and began provisioning alternate capacity where possible. The damage affected not only consumer browsing and streaming but also business traffic and cloud‑based backups that rely on predictable transit.
Gulf states (UAE, Saudi Arabia)​
Subscribers to major UAE operators experienced service degradations; Etisalat and du customers logged issues with streaming and messaging services. The geographic proximity to fault locations — with multiple cables aggregating at landing stations near the Arabian coast — amplified the local impact. Microsoft’s telemetry and regional carrier bulletins confirmed measurable effects for traffic transiting the Middle East corridor.
Cloud customers and enterprises​
Large enterprise customers and SaaS providers reported increased API latency and elongated replication or backup windows when traffic traversed the damaged corridor. For many organisations the outage acted as a stress test for application‑level resilience: timeouts, retries and degraded UX were widespread for flows between Asia and Europe that normally used the Red Sea route.
How operators and cloud providers responded​
Cloud and carrier responses followed a standard triage sequence:
  • Detection: Monitoring platforms observed route flaps, path lengthening and latency spikes consistent with physical faults.
  • Public advisories: Microsoft posted an Azure Service Health notice warning of increased latency for affected flows and began communicating mitigation steps to customers.
  • Traffic engineering: Providers rerouted traffic to alternate subsea systems or terrestrial backhauls, leased spare capacity where available, and reweighted BGP paths to rebalance load. These steps preserved reachability but raised latency as traffic took longer detours.
  • Repair planning: Cable owners and consortiums began fault location and repair mobilisation, which typically involves specialised cable‑repair vessels and mid‑sea splices that can take days to weeks depending on safety, ship availability and permissioning.
Microsoft emphasised that other global services not traversing the Middle East corridor were unaffected, stressing that the incident was a routing/performance event rather than a platform‑wide outage for Azure compute/storage. That distinction is important for architects assessing exposure.
Repair complexity and expected timelines​
Subsea cable repairs are complex and often slow. The process includes:
  • Fault location using time‑domain reflectometry across fibre pairs.
  • Scheduling a dedicated cable‑repair ship (finite global fleet).
  • Mid‑sea splicing operations under maritime and weather constraints.
  • Coordination with coastal authorities and, in contested waters, with naval or security authorities.
Typical repair times range from a few days for nearshore faults to several weeks when faults occur in geopolitically sensitive or logistically constrained waters. In the Red Sea, the combination of heavy maritime traffic, complex seabed topography and recent security tensions can extend repair windows. Industry experts warn that while traffic engineering can mitigate immediate reachability issues, full capacity restoration depends on maritime repair schedules and operational safety.
Attribution: accident, weather, or sabotage?​
As of the initial reporting, the precise cause of the cuts remained unknown and attribution should be treated cautiously. Typical root causes fall into three categories:
  • Accidental vessel activity (anchor drags or fishing operations).
  • Natural seabed movement or environmental factors.
  • Deliberate hostile action or sabotage.
Public reporting highlighted that early statements about intentional damage are provisional; cable operators and maritime investigators normally publish final forensic analyses before ascribing cause. In geopolitically sensitive waters, however, public speculation about deliberate action often appears early. Responsible reporting flags such statements as unverified until operator or investigative confirmations are available.
Strategic risks exposed by the incident​
This event surfaces multiple longer‑term risks:
  • Concentration risk: Many east‑west routes funnel through narrow landing corridors. A small number of physical faults can cascade into wide regional disruptions.
  • Cloud dependency risk: Organisations increasingly assume cloud platforms are redundant. Those assumptions can be undermined by correlated physical infrastructure failures that affect cross‑region connectivity.
  • Repair and maritime risk: The global repair fleet is finite; scheduling splice operations in high‑risk waters may be delayed for safety reasons, prolonging outages.
  • Geopolitical escalation: In contested maritime regions, intentional attacks on cables — while rare — are a growing concern for national security planners, as the downstream economic damage from internet outages can be substantial. Early attribution must be handled with caution.
Practical guidance for IT and network teams​
For WindowsForum readers, IT leaders and architects, this incident is a pragmatic reminder that digital resilience depends on both code and cables. Implement the following checklist to reduce exposure to subsea‑cable risk:
  • Validate exposure now:
  • Check cloud provider status pages (for example, Azure Service Health) and your ISP’s international routing paths. Confirm whether your critical cross‑region flows traverse vulnerable corridors.
  • Increase sensible timeouts, add exponential backoff, and avoid brittle synchronous cross‑region calls for user‑facing flows.
  • Prioritise route diversity:
  • Design multi‑region architectures that do not rely on a single narrow corridor; prefer providers and carriers with geographically diverse transit.
  • Test failovers:
  • Run planned drills that simulate longer RTTs and packet loss, and validate that services degrade gracefully rather than fail catastrophically.
  • Defer bulk transfers:
  • Postpone large, non‑urgent backups or replication during known corridor events to reduce congestion and preserve limited spare capacity for business‑critical traffic.
  • Contractual protections:
  • Review SLAs and contractual clauses with cloud and telecom providers for performance and resilience commitments; consider explicit routing and peering guarantees where available.
Apply these steps in priority order: understanding exposure and immediate mitigations should come before structural investments such as additional peering or paid reserved capacity.
The incident adds momentum to several industry and public policy debates:
  • Investment in route diversity: Governments and industry will likely intensify efforts to fund and permit alternative cable routes, terrestrial backhauls and regional peering to lower single‑point risk.
  • Transparency and timely reporting: Cable‑owner consortiums and national regulators should improve public fault reporting cadence so enterprises can react more quickly. Early, accurate diagnostics reduce harmful speculation.
  • Security posture for subsea assets: Coastal states and maritime authorities are under pressure to improve situational awareness, including better ship‑tracking and anchorage controls in cable corridors to reduce accidental damage and to protect assets from malicious action.
  • Resilience incentives: Policymakers may consider incentives, subsidies or regulatory changes to encourage geographically diverse cable investments and to expand the repair fleet and readiness for high‑risk corridors.
These policy choices will shape whether future incidents produce mere performance nuisances or systemic economic disruptions.
What remains unverified — and why that matters​
Several high‑visibility claims continued to circulate in media and social posts in the immediate aftermath, but should be treated as provisional:
  • Exact cable fault coordinates and the definitive list of cable systems with physical damage require operator confirmation and are therefore not fully verified in early reports.
  • Attribution to deliberate sabotage vs accidental causes is unconfirmed; reliable forensic statements typically follow official operator diagnostics and maritime investigations. Public speculation ahead of those reports risks misattribution.
  • Repair‑completion timelines are variable. While traffic engineering can return most services to functional state within hours to days, full restoration of original capacity depends on scheduling and safety conditions for repair ships and can take longer.
Flagging these uncertainties is essential for responsible risk management: assumptions about cause or rapid restoration can lead organisations to underprepare for prolonged degraded performance.
Longer‑term takeaways for WindowsForum readers and IT decision‑makers​
This Red Sea incident provides a set of hard lessons for architects, network engineers and policy makers:
  • Treat physical route diversity as a first‑class design variable, equal in importance to cloud region selection or encryption.
  • Expect the unexpected: resiliency practice must assume that major chokepoints can be impaired and that rebalancing will increase latency and jitter for some time.
  • Invest in observability: detailed, end‑to‑end telemetry (including synthetic tests across different international corridors) shortens detection and routing decisions during incidents.
  • Demand better transparency: insist that providers share routing maps, contingency plans and clear SLAs that acknowledge the reality of physical chokepoints.
  • Plan for concentrated risk: business continuity planning must include scenarios where large swathes of cross‑region traffic are slower but not entirely unavailable.
Implementing these changes reduces business risk and improves service reliability for the customers who increasingly depend on cross‑continent cloud services.
The Red Sea subsea cable damage that produced internet slowdowns across India, Pakistan, the UAE and the wider region was more than a transient performance incident; it was a practical stress test of how modern cloud architectures interact with a fragile physical substrate. Microsoft’s Azure advisory and industry monitoring confirmed multiple undersea fibre faults near Jeddah and documented measurable increases in latency for traffic that ordinarily traversed the Middle East corridor. Providers successfully rerouted traffic and preserved reachability in most cases, but the event underscored the limits of purely virtual redundancy when the underlying physical routes are concentrated through narrow maritime chokepoints.
For enterprise architects and IT practitioners the immediate imperative is clear: verify exposure, harden application resilience, and design for geographic and routing diversity. For governments and the telecom industry the message is equally stark — invest in cable protection, repair readiness and alternative routes to reduce the odds that a handful of cuts can produce outsized disruption. Until those investments are made and operationalised, incidents in strategic corridors like the Red Sea will remain capable of producing real economic and social ripple effects across continents.
Source: India Shipping News Red Sea cable damage sparks internet outages across Asia and Middle East - India Shipping News
Microsoft’s Azure customers in and around the Middle East experienced measurable latency and service disruption after multiple undersea fibre-optic cables in the Red Sea were damaged, forcing traffic onto longer, more congested routes and exposing persistent fragilities in the global internet backbone.
'Red Sea Subsea Cable Cuts Increase Azure Latency and Cloud Traffic'
Background​
The modern internet is not a cloud floating in the sky; it is a physical network built on submarine fibre-optic cables that carry the vast majority of intercontinental traffic. The Red Sea and its approaches form one of the world’s principal east–west corridors, concentrating multiple trunk systems that link South and East Asia with the Middle East, Africa and Europe. When several of those trunk links are damaged in the same narrow corridor, the shortest physical paths vanish and traffic must travel longer, often already-loaded detours—raising round‑trip time (RTT), jitter and packet loss for latency-sensitive services.
On or around 6 September 2025, network monitors and major providers observed faults consistent with physical cuts to multiple subsea cables in the Red Sea near Jeddah and the Bab el‑Mandeb approaches. Microsoft posted an Azure Service Health advisory warning that customers “may experience increased latency” for traffic that previously traversed the Middle East corridor, and said engineers had rerouted and rebalanced traffic while repairs and diagnostics continued. Independent monitoring groups reported degraded connectivity in several countries, including India, Pakistan, Saudi Arabia and the United Arab Emirates. (aljazeera.com)
What happened: the operational facts​
  • Multiple subsea cables that normally provide the shortest east–west paths were damaged in a small geographic region of the Red Sea.
  • Cloud and carrier operators—including Microsoft Azure—reacted by rerouting traffic onto alternate subsea systems, terrestrial backhaul and leased transit, which preserved reachability but increased latency for affected flows.
  • The observed impacts were concentrated on traffic between Asia, the Middle East and Europe; traffic that did not traverse the Middle East corridor was reportedly unaffected.
These are performance‑degradation events rather than a platform‑wide outage: Azure’s control plane and many regionally-contained services continued to operate, but data‑plane traffic that must cross the damaged corridor saw higher response times and occasional packet loss. Microsoft said it would “continuously monitor, rebalance, and optimize routing to reduce customer impact” while repair works proceed.
Immediate timeline (verified observations)​
  • Early telemetry and BGP reconvergence were reported on 6 September, consistent with physical faults in a Red Sea transit corridor. (reuters.com)
  • Microsoft posted a service-health advisory the same day warning customers of increased latency; carriers and network monitors confirmed degraded connectivity in multiple countries.
  • Operators began traffic-engineering mitigation—rerouting, temporary transit leases and load rebalancing—while cable owners prepared diagnostics and repair planning. Repair timelines remain contingent on fault location, ship availability and local permissioning.
Why submarine cable damage causes cloud latency​
There is a simple physics and topology story behind the user-facing symptoms.
  • Propagation delay: longer physical paths mean higher minimum RTT—every extra kilometre adds latency.
  • More hops: rerouted traffic takes additional network devices (switches, routers, AS hops), each adding processing and queuing delay.
  • Congestion: alternate cables and terrestrial backhaul are often already carrying significant load; when they accept diverted traffic, queues build and jitter rises.
  • Technology diversity: fallbacks such as satellite, CDN caches or private peering have different performance and sometimes different security or cost characteristics.
Put together, these factors typically add tens to hundreds of milliseconds to round‑trip time, which degrades performance for synchronous and latency‑sensitive workloads—voice/video calls, online gaming, database replication and chatty API interactions. Azure’s advisory and independent monitoring both describe exactly these symptoms: elevated latency and intermittent slowdowns for flows that crossed the affected corridor.
Which cables and regions were implicated (what’s known and what’s provisional)​
Early public and monitoring reports named several major systems that commonly route through the Jeddah/Red Sea corridor, including SEA‑ME‑WE‑4 (SMW4), IMEWE and FALCON GCX; some reporting also referenced AAE‑1 and other feeders. However, definitive, operator-level confirmation of every fault and its exact location can take days because cable owners must combine ship-based inspections and instrumented fault-locating before publishing final reports. Treat attributions as provisional until operators publish their diagnostics.
Multiple reputable outlets corroborate that SMW4, IMEWE and FALCON were among the candidate systems listing faults near Jeddah, but the complete fault list and exact break coordinates were still pending formal confirmation when initial reports were published. The cause of the damage is disputed: maritime accident (anchor drag) is a leading hypothesis from independent analysts and the International Cable Protection Committee, but deliberate interference remains an open possibility in the view of some authorities—again, forensic confirmation is required. Flag these attributions with caution.
Repair complexity and likely timelines​
Repairing submarine cables is complex, resource‑intensive and often slow:
  • Locate the fault precisely using cable monitoring telemetry and VLF (very low frequency) detection systems.
  • Dispatch a specialised cable‑repair vessel with grapnels and splice teams.
  • Conduct a mid‑sea recovery or shallow-water shore-end splice, which can take days per fault.
  • In geopolitically sensitive waters, permissions and safety concerns can delay ship operations or mandate guarded convoys. (siliconangle.com)
Past incidents in the Red Sea have shown repair windows from several days to multiple weeks; in some exceptional cases, regional constraints and security issues have extended timelines further. That means traffic-engineering and capacity rebalancing—not immediate physical repair—are the principal levers cloud providers will use in the short term.
Broader implications: cloud resilience, chokepoints and geopolitical risk​
This incident is a reminder that logical redundancy in the cloud still depends on a limited set of physical routes. Large hyperscalers like Microsoft build global backbones and multiple peering/partner arrangements, but when a narrow maritime corridor hosts multiple trunk systems and those trunks are damaged simultaneously, even the largest providers face degraded performance for cross‑region traffic.
Key implications:
  • Strategic chokepoints matter. The Red Sea is a narrow funnel; a handful of cable faults there ripple across continents.
  • Multi‑region or multi‑cloud architecture reduces single-provider risk—but it does not eliminate physical-route correlation if both providers use the same submarine corridors. Customers should validate physical path diversity, not only logical region diversity.
  • The incident renews questions about protecting critical subsea infrastructure. Whether the damage was accidental or intentional, the global economy depends on routes that cross contested waters. Policymakers and industry groups will face heightened pressure to develop protection, redundancy and faster repair logistics.
What Azure customers — and WindowsForum readers — need to know now​
Short, practical guidance for mitigations and hardening:
  • Verify service scope: Check Azure Service Health for targeted advisories about affected regions and specific services; Microsoft’s status message specifically warned of higher latency for traffic traversing the Middle East corridor.
  • Review application topology: Identify latency‑sensitive components (VoIP, synchronous DB replication, trading systems). Consider switching them to local or alternative regions while the corridor is constrained.
  • Use edge and CDN: Offload static and cacheable content to global CDN endpoints or Azure Front Door, reducing cross‑continental fetches.
  • Validate physical path diversity: Ask your provider or carrier whether your critical traffic uses alternate subsea routes or whether it funnels through the same chokepoints. Logical multi‑region deployment is not enough if both regions route through the same damaged corridor.
  • Consider ExpressRoute and direct links: Where consistent performance matters, private circuits and dedicated peering can reduce exposure to public internet rerouting—but they still rely on physical routes and must be audited for diversity.
  • Implement graceful degradation: Build client and service-side timeouts, retries with exponential backoff, and fallback flows to preserve UX under higher latency conditions.
  • Explore multi-cloud failover where appropriate: For critical systems, configure automated failover or warm standby in providers with verifiably distinct physical paths—validate the real world route diversity before relying on it.
  • Monitor actively: Use synthetic measurements (ping, traceroute, application-level probes) to detect latency shifts and be ready to execute pre-defined runbooks.
Technical analysis: what Microsoft’s response tells us​
Microsoft’s operational messaging and actions were standard for corridor‑level subsea incidents:
  • Targeted advisory: The company clearly described the symptom (increased latency) and the geographic scope (traffic that traverses the Middle East), which is useful for customers to triage.
  • Traffic engineering: Microsoft rerouted traffic, optimized routing policies and rebalanced capacity across its backbone and partner transit to reduce impact.
  • Ongoing monitoring: Microsoft committed to daily updates or sooner as conditions changed—indicative of a dynamic, telemetry-driven remediation effort.
These are appropriate hands-on responses, but they cannot instantly restore the raw fibre capacity; physical repairs and ship-based splicing remain the ultimate fix. That operational reality explains why Azure customers saw latency instead of a total loss of connectivity—the company was preserving reachability at the cost of performance in affected flows. (reuters.com)
Strengths and weaknesses in the ecosystem revealed by this incident​
Strengths:
  • Rapid detection: Carrier telemetry and independent monitors (NetBlocks, Kentik) identified the anomaly quickly, allowing cloud providers to begin mitigation early. (apnews.com)
  • Resilient routing: BGP and operator traffic engineering preserved global reachability for the vast majority of traffic.
  • Transparent advisories: Microsoft and other operators published timely status updates that helped customers triage impact.
Risks / weaknesses:
  • Physical chokepoints: A small number of geographic corridors continue to concentrate enormous capacity, creating single points of systemic risk.
  • Repair fragility: Dependence on a limited fleet of cable‑repair ships and on local permissions makes physical recovery slow and politically sensitive.
  • Attribution and security: In contested regions, damage may be accidental or malicious; the uncertainty complicates policy, repair access and insurance. Early public speculation about deliberate targeting must be treated carefully until forensic confirmation is available.
Policy and industry outlook​
Expect immediate and medium‑term policy responses:
  • Calls for greater protection: international bodies and national regulators will push for enhanced monitoring and maritime safeguards around cable landings and shallow-water routes.
  • Investment in route diversity: carriers and hyperscalers may accelerate plans for alternative routes—either through longer but less contested paths (around Africa or across new corridors) or via terrestrial overland links where feasible.
  • Repair capacity expansion: industry groups may invest in more repair ships or pre‑position spares to speed response times in high-risk corridors.
  • Insurance and contractual scrutiny: enterprises will re-examine SLAs, force majeure clauses and the insurance landscape for subsea infrastructure disruption.
None of these are quick fixes; the economics of submarine cables and the geopolitics of their environments mean the sector will adapt gradually, but the commercial and national-security stakes are rising. (siliconangle.com)
What we still don’t know — flagged uncertainties​
  • Exact root cause: While anchor-drag by commercial shipping is a plausible and reported hypothesis, and while earlier incidents in the region involved a mix of accidental and intentional damage, authoritative forensic confirmation of cause remains pending. Treat any attribution as provisional. (indiatoday.in)
  • Final list of affected cables: Initial monitoring lists candidate systems, but operators must confirm exact fault coordinates and which cable pairs were severed.
  • Full repair timeline: Estimates range from days to weeks depending on location, ship availability and local security/permit conditions; any specific timeline should be treated as conditional.
Practical checklist for IT teams (actionable, prioritized)​
  • Check Azure Service Health and your subscription alerts for targeted advisories.
  • Measure affected flows: run traceroutes and synthetic tests from key endpoints to identify increased hops and latency.
  • Reroute critical traffic to local regions or alternative providers where latency meets SLAs.
  • Move synchronous workloads to local instances or suspend synchronous replication if risk of data drift outweighs delay.
  • Enable CDN and caching to reduce cross‑continent requests.
  • Review ExpressRoute or direct peering arrangements and confirm their physical path diversity.
  • Update runbooks to handle prolonged repair windows (days/weeks) and maintain communications with customers and stakeholders.
The Red Sea cable damage that produced Microsoft Azure latency is an operational reminder that the internet’s physical underpinnings still matter. Large cloud providers can mitigate, reroute and preserve reachability, but they cannot instantly replace the lost capacity that a cluster of cut submarine cables represents. For enterprises and service owners, the incident is a pragmatic call to action: verify physical path diversity, assume that multi‑region deployment is necessary but not sufficient, harden latency‑sensitive workloads, and keep runbooks and communication channels ready for incidents that can take days or weeks to fully resolve. Industry and governments must also face the uncomfortable truth that critical digital arteries in narrow maritime corridors are strategic assets—and vulnerabilities—that require investment, protection and international cooperation.
Source: PC Gamer Microsoft Azure services experiencing latency to traffic through the Middle East due to undersea fibre cable damage in the Red Sea
Source: TechCentral.ie Microsoft Azure faces delays due to undersea cable damage in the Red Sea - TechCentral.ie
Microsoft Azure customers across Asia, the Middle East and parts of Europe experienced measurable latency and intermittent slowdowns after multiple undersea fiber‑optic cables in the Red Sea were reported cut on September 6, 2025, forcing cloud traffic onto longer detours while Microsoft and carriers rerouted and rebalanced capacity to limit user impact.
3D infographic illustrating Red Sea submarine cable disruption and its global impact.Background​
The global Internet’s east–west backbone depends heavily on submarine fibre‑optic cables that thread narrow maritime corridors. One of the most consequential of these corridors runs through the Red Sea and the approaches to the Suez Canal; many high‑capacity systems land near Jeddah and transit the Bab el‑Mandeb strait, linking South and Southeast Asia to the Middle East and Europe. When a cluster of cables in this corridor is damaged, the effects are disproportionately large because traffic that previously followed short, low‑latency paths must detour along longer routes that often lack spare capacity. Undersea systems commonly named in early operator notices and independent monitoring included the South East Asia–Middle East–Western Europe 4 (SMW4), IMEWE (India–Middle East–Western Europe), and FALCON/GCX family among others. NetBlocks and carrier telemetry confirmed degraded connectivity in multiple countries, and regional ISPs reported visible slowdowns during peak hours.
What happened: timeline and immediate effects​
Detection and first alerts​
Monitoring services, network operators and Microsoft’s own telemetry observed anomalies around 05:45 UTC on September 6, 2025. BGP reconvergence events, longer AS‑paths and spikes in round‑trip time (RTT) pointed to physical faults rather than transient configuration errors. Microsoft posted a Service Health advisory warning customers that “network traffic traversing through the Middle East may experience increased latency due to undersea fiber cuts in the Red Sea,” and said engineering teams were rerouting traffic, rebalancing capacity and monitoring the situation.
Immediate operator responses​
Cloud and carrier engineers applied standard mitigations:
  • Dynamic traffic engineering and BGP policy updates to steer flows away from damaged segments.
  • Temporary transit leases or capacity purchases from alternative carriers where available.
  • Traffic prioritization to protect control‑plane and management channels.
  • Close coordination with submarine cable consortiums and national carriers to triage which landing stations and cable systems were affected.
Those steps preserved general reachability for most services but could not eliminate the physics of longer geographic detours: packets traveling extra distance produced measurable increases in latency and jitter for affected flows.
Why a cable cut becomes a cloud incident: a technical primer​
Physical distance, routing, and latency​
Network latency is primarily a function of physical distance and the number of intermediary hops. When a cable that provides the shortest route between two regions is severed, traffic is advertised over alternate AS paths and often must traverse longer, sometimes circuitous routes (for example: around Africa, transiting different landing chains, or via satellite and terrestrial hop mixes). Each added kilometre and network device adds propagation and queuing delay; the net result is tens to hundreds of additional milliseconds in RTT for cross‑region calls — enough to degrade real‑time communications, synchronous database replication and interactive APIs.
Logical redundancy vs. physical diversity​
Cloud providers design for redundancy at the logical level — multiple regions, multiple routes, multi‑homed transit. That redundancy assumes the underlying physical routes are diverse. When several cables sharing the same narrow corridor fail simultaneously, logical redundancy can become correlated failure: alternate logical paths still share the same physical choke points. This is why incidents in the Red Sea can cause outsized operational impact despite decades of investment in cloud networking.
Control‑plane resilience vs. data‑plane pain​
During these incidents, cloud control‑plane functions (management APIs, provisioning) often remain reachable because providers route them over different ingress/egress networks or use multiple ISPs for control traffic. The data‑plane — user application traffic that must travel between regions — shows the worst effects: higher latency, increased packet loss, and performance‑sensitive failures. Microsoft explicitly framed the September 6 event as a performance‑degradation incident rather than a platform‑wide outage, consistent with this control/data distinction.
Who and what was affected​
  • Geographic impact: Users and services with traffic that originates, terminates or transits between Asia, the Middle East and Europe experienced the largest effects. Countries reporting measurable slowdowns included India, Pakistan, Saudi Arabia, the United Arab Emirates, Kuwait and parts of East Africa.
  • Services: Real‑time services (VoIP, videoconferencing), synchronous database replication, chatty APIs and cross‑region backups were the most sensitive to increased RTT and jitter. Enterprise customers reported longer backup windows, higher retry counts and slower API response times.
  • Cloud posture: Microsoft’s global control plane remained largely functional; the visible customer impact was limited to data‑plane performance where traffic traversed the damaged corridor. Microsoft committed to daily updates while repairs and traffic engineering continued.
Theories about cause — and what we can verify​
Early reporting diverged on attribution. Initial speculation included damage from military activity or sabotage in a geopolitically tense corridor; later, independent analysis and cable‑protection bodies indicated a commercial shipping incident (anchor drag) is the most likely cause in at least some of the damaged segments. At the time of reporting, there was no single, operator‑confirmed public attribution covering all faults, and consortium fault reports typically lag early media accounts. Those uncertainties make definitive public attribution premature. Treat any single‑cause claim as provisional until consortium diagnostics are released. Why this uncertainty matters: the root cause shapes repair logistics and policy response. If the damage was accidental (anchor/drag), familiar maritime safety and route‑protection measures are the obvious remedial focus. If damage were intentional, governments and multinational stakeholders confront criminal and national‑security implications that complicate access and repair permissions. Until cable owners publish forensic fault logs, the cause remains a material but unresolved aspect of this incident.
Repair logistics: why undersea fixes take time​
Repairing a broken submarine cable is a complex marine engineering task that is not measured in minutes. Typical steps include:
  • Fault detection and narrow‑band localization using optical time‑domain reflectometry (OTDR) and operator telemetry.
  • Mobilization and scheduling of specialized repair vessels, winches and splice teams.
  • Safe passage and anchoring of repair ships to the fault zone — a step that can be delayed by regional security issues, weather, or permitting.
  • Recovery of the broken cable ends, sea‑bed work and precision splicing, followed by testing under load.
There is a global shortage of repair ships and qualified crews relative to the increasing number of submarine systems; that queuing factor routinely pushes repair windows from days into weeks or months depending on the complexity and accessibility of the fault site. In geopolitically sensitive waters, permissioning and safety can add further delays.
Microsoft’s response: what they said and what they did​
Microsoft’s public Service Health advisory acknowledged increased latency for traffic transiting the Middle East corridor, said traffic engineering teams were rerouting flows and rebalancing capacity, and committed to ongoing updates. Engineers prioritized reachability and applied traffic‑engineering measures while coordinating with carriers and cable owners about repair plans. Microsoft characterized the event as a performance degradation rather than a system outage and later reported it was no longer detecting Azure platform issues as traffic reconverged on alternate routes. These are the standard and sensible operational steps for a cloud operator facing undersea cable failures:
  • Immediate: preserve reachability, prioritize control‑plane traffic, and reduce oscillation through careful routing policy changes.
  • Short term: lease temporary transit capacity, push customers to regional endpoints where possible, and increase monitoring thresholds.
  • Medium term: coordinate with consortiums on repair windows, and adjust peering/transport arrangements to relieve hot spots.
Microsoft’s transparency — posting a Service Health advisory and committing to regular updates — was appropriate and allowed enterprise customers to apply their playbooks. Still, the company’s ability to remove all customer‑visible effects is limited by the physical availability of alternative capacity and the repair timeline.
Risks, vulnerabilities and systemic lessons​
Notable strengths shown by providers​
  • Rapid detection and traffic‑engineering show the maturity of cloud‑scale network operations.
  • Coordination across carriers and the use of peering/transit markets allowed reachability to be preserved for most workloads.
  • Public advisories gave customers actionable situational awareness and time to execute mitigation plans.
Remaining weaknesses and systemic risks​
  • Physical chokepoints: a handful of maritime corridors concentrate a significant share of east‑west capacity. When multiple systems in the same corridor fail, the redundancy model is undermined.
  • Repair capacity bottlenecks: global scarcity of cable‑repair ships and splicing teams can stretch repair windows and keep traffic on suboptimal routes longer than desired.
  • Transparency gaps: customers lack granular, verifiable visibility into the physical routing geometry and the composition of providers’ transit and peering arrangements. This makes it difficult for enterprises to precisely quantify exposure.
  • Geopolitical overlay: operations in contested or high‑risk waters introduce non‑technical delays and uncertainty that network teams cannot control.
These vulnerabilities mean that—even for highly redundant cloud architectures—physical events on the seafloor remain a persistent and underappreciated source of risk for latency‑sensitive applications.
Practical guidance for Azure customers (short, medium and long term)​
Immediate actions (hours to days)​
  • Check Azure Service Health and any provider advisories for region‑specific guidance and updates.
  • Validate which application flows transit the Middle East corridor by examining traceroutes, BGP AS paths and CDN/edge routing footprints.
  • Redirect critical traffic to alternative regions or edge endpoints where feasible, and increase retry/backoff limits for non‑critical jobs.
  • For real‑time services, switch to regional breakout points or temporary SBC (session border controller) configurations that minimize cross‑region traversals.
Tactical measures (days to weeks)​
  • Apply traffic shaping and QoS to prioritize latency‑sensitive control and heartbeat flows.
  • Negotiate temporary transit or reserved capacity with carriers where critical path dependence exists.
  • Test and runplaybooks for multi‑region failover under elevated latency conditions to uncover hidden dependencies and misconfigured SLAs.
Strategic investments (months to years)​
  • Map true physical path diversity for mission‑critical services: require transit geometry disclosures from cloud and network providers and contractually validate physical diversity.
  • Architect for graceful degradation: prefer eventual‑consistency patterns, asynchronous replication and client‑side buffering for cross‑region operations.
  • Consider multi‑cloud or multi‑region active‑active designs where the physical routes are genuinely diverse (different submarine corridors or overland routes).
  • Lobby for industry and governmental investment in cable protection, repair‑ship capacity, and corridor diversification.
These steps move organizations from reactive firefighting to proactive resilience engineering that accounts for the ocean‑level realities of global networking.
Broader policy and industry implications​
The incident renews long‑running calls for a multi‑pronged response:
  • Expand repair capability: increase the global fleet of repair vessels and trained crews to reduce queuing delays when multiple faults occur.
  • Protect chokepoints: implement navigational safeguards, route protection zones and rapid incident response mechanisms in high‑density cable corridors.
  • Increase transparency: standardize operator reporting and accelerate the publication of consortium fault diagnostics so customers and regulators have accurate situational awareness.
  • Invest in route diversity: governments, carriers and cloud providers should incentivize submarine routes that avoid single‑point maritime chokepoints and strengthen overland and satellite alternatives where practical.
These steps require capital, coordination and political will. The operational reality, however, is stark: the cloud era depends not just on code and virtual networks but also on ships, splices and stable seas.
What remains uncertain — and what to watch next​
  • Final forensic confirmations: consortium bulletins and fault logs will eventually list the precise cable segments, fault coordinates and root causes. Until those are published, public cause attribution remains provisional and should be treated with caution.
  • Repair schedule: the time to full restoration depends on ship availability, sea conditions and any regional access constraints. Expect updates from cable owners and Microsoft’s Service Health channel as primary indicators of restored capacity.
  • Secondary congestion: watch for knock‑on congestion and elevated latencies on alternate routes as rebalanced traffic persists; these secondary effects can cause new hotspots beyond the initial corridor. Monitoring nets and carrier telemetry will reveal where load shifts create new pressure points.
The Red Sea subsea cable cuts and Microsoft Azure’s consequential latency advisory are a clear, operational reminder that digital resilience is inseparable from physical infrastructure. Microsoft’s engineering response — rapid detection, traffic rerouting and transparent customer notices — limited the damage to performance degradations rather than a platform collapse. Yet the incident exposed systemic fragilities: concentrated maritime corridors, constrained repair capacity and incomplete customer visibility into physical routing geometry.
For enterprises, the practical imperative is twofold: treat this event as a live test of failover playbooks and rebuild resilience assumptions to include the seafloor. For industry and policymakers, the lesson is equally stark: durable cloud availability demands not only robust software stacks but also investments in undersea route diversity, repair logistics and protective measures for the infrastructure that underpins modern life.
Source: SubTel Forum https://subtelforum.com/microsoft-azure-faces-delays-after-red-sea-undersea-cables-cut/
Microsoft’s Azure cloud platform suffered measurable performance degradation after multiple undersea fiber‑optic cables in the Red Sea were severed on September 6, 2025, forcing large volumes of traffic onto longer, congested routes and exposing brittle points in the global internet backbone.
Global cloud network coordinates data-driven shipping routes worldwide.Background​
The modern internet is a physical network built on submarine fiber‑optic cables that carry the vast majority of intercontinental data. A handful of maritime corridors concentrate east–west traffic between Asia, the Middle East, Africa and Europe; the Red Sea and the Bab al‑Mandeb approaches are one of those strategic chokepoints. When multiple trunk systems that share the same corridor fail simultaneously, the shortest physical paths disappear and traffic must be rerouted via longer, frequently already‑loaded alternatives. Microsoft’s Azure is a global cloud platform that depends on these undersea routes to deliver low‑latency, high‑availability services across continents. On September 6, 2025, Azure’s service‑health messaging acknowledged increased latency for traffic traversing the Middle East corridor and said engineers were actively rerouting traffic and rebalancing capacity while carrier and cable owners worked on diagnostics and repairs. That public advisory became the focal point for customers and operators assessing exposure and performance impacts.
  • When: Monitoring systems flagged anomalies beginning at approximately 05:45 UTC on September 6, 2025, with BGP reconvergence and route changes consistent with physical cable faults.
  • Where: Fault telemetry and independent monitors placed the disturbance in the Red Sea corridor near the Saudi port of Jeddah and the Bab al‑Mandeb approaches, an aggregation point for several long‑haul cables.
  • What: Multiple subsea fiber‑optic cable systems experienced cuts or faults that reduced available transit capacity and forced traffic onto alternative routes. Microsoft warned that traffic traversing the Middle East between Asia and Europe — and traffic originating or terminating in those regions — could see higher latency.
Independent monitoring groups and national carriers reported degraded throughput and elevated latency across several countries including India, Pakistan, the United Arab Emirates, Saudi Arabia and parts of East Africa. Those effects were visible in slower web loads, choppy real‑time communications, longer backup windows and intermittent timeouts on latency‑sensitive workloads.
Which cables were implicated — provisional vs. confirmed​
Early public reporting and internet monitors identified several long‑haul systems that transit the Jeddah/Red Sea approaches as likely affected. Names commonly reported included:
  • SEA‑ME‑WE‑4 (SMW4) — a long‑running trunk linking Europe and Southeast Asia through the Middle East.
  • IMEWE (India–Middle East–Western Europe) — another key trunk often carrying Asia↔Europe traffic.
  • FALCON GCX and other regionals — several reports also mentioned these and other feeders in early lists.
It is important to treat early cable attributions as provisional; initial identifications came from monitoring‑based correlation and national carriers, not always from formal consortium fault bulletins. Several reputable outlets and monitoring services named SMW4 and IMEWE among the candidate systems, but final operator‑level forensic confirmations typically follow later when cable owners publish precise coordinates and splice‑level diagnostics. Practical takeaway: multiple news and monitoring sources agreed a cluster of trunk systems using the same narrow corridor were disrupted, but exact failure lists and pair‑level details remained subject to consortium confirmation.
Immediate impact on Azure and cloud customers​
Microsoft framed this incident as a performance degradation rather than a full platform outage: the control plane and most regional services continued to function, but data‑plane traffic that needed to cross the damaged corridor experienced elevated round‑trip times, jitter and occasional packet loss. Engineers applied traffic engineering, rerouted flows, and leased spare transit where available to preserve reachability. Common customer‑visible symptoms included:
  • Higher API and application latency for cross‑continent calls between Asia and Europe.
  • Degraded real‑time communication quality (VoIP, video conferencing, online gaming) due to jitter and packet loss.
  • Longer backup and replication windows for cross‑region storage and database replication jobs.
Large enterprises with multi‑region architectures reported measurable slowdowns and had to invoke contingency measures. Independent monitors and ISPs logged spikes in complaint volumes and performance alerts that matched Microsoft’s advisory window.
The technical anatomy: why a cable cut becomes a cloud incident​
At the IP layer, outages are handled by BGP and carrier‑controlled traffic engineering. When a trunk disappears, routers withdraw prefixes and selection shifts to alternative AS paths. The available alternatives often have three problematic characteristics:
  • They are longer geographically, adding propagation delay.
  • They are already provisioned for normal load and can become congested when forced to carry sudden diverted volumes.
  • They may use different security and routing policies, increasing path complexity and jitter.
For cloud services that rely on low‑latency synchronous replication, chatty APIs, or financial trading feeds, even tens of milliseconds can degrade user experience or break time‑sensitive workflows. Rerouting preserves reachability but cannot recreate the raw capacity and short propagation delay that a damaged trunk provided.
Cause and attribution — accident, sabotage, or something else?​
Initial forensic work and expert commentary produced competing hypotheses:
  • Several technical analysts and the International Cable Protection Committee suggested the most likely cause in this incident was accidental anchor damage from commercial shipping near a shallow route, where cables are more exposed. Those assessments were based on fault patterns and the geography of known anchor grounds.
  • Geopolitical observers immediately considered the possibility of hostile action because the Red Sea region has seen maritime insecurity in recent years; however, there was no public operator confirmation attributing the cuts to deliberate sabotage at the time of initial reporting. Some groups that have previously been linked to maritime disruption had denied involvement in similar earlier cases.
Given the divergence of early public claims, industry best practice is to treat immediate attribution as provisional until maritime forensics and cable owner consortium statements provide definitive evidence. The prevailing early narrative balanced technical plausibility of anchor drag with the geopolitical reality that contested waters increase operational risk for repair ships and crews.
Repair complexity and expected timeframe​
Repairing submarine cables is a slow, resource‑intensive operation that typically follows this sequence:
  • Fault localization using repeaters, OTDRs and cable telemetry to identify approximate coordinates.
  • Mobilization of a cable repair vessel with grapnel gear, mid‑sea splice teams and spare fiber pairs (or new cable if a long segment is lost).
  • Recovery and splicing of the damaged cable on deck, then coordinated testing before returning the repaired segment to the seabed.
  • Post‑repair validation and traffic migration back onto the restored route.
These steps require specialized vessels and equipment that are in limited supply globally. When repairs must occur in contested or insecure waters, permissioning, naval coordination and safety windows add further delay. Industry commentary and historic precedent show that similar Red Sea repairs can take anywhere from days to several weeks, and in rare, complex scenarios, months. Microsoft and carriers warned that no definitive time‑to‑repair estimate was available immediately. Key practical constraints affecting timelines:
  • Limited global availability of cable‑repair ships and scheduling conflicts.
  • Local sea‑state and weather windows needed for safe recoveries.
  • Security and permissioning constraints in geopolitically sensitive zones.
Taken together, these factors make short, precise repair timelines difficult to promise in the early hours after a fault is detected.
Economic and operational fallout: who feels it, and how badly?​
The incident’s ripple effects varied by region and by how much traffic relied on the damaged corridor:
  • South Asia (India, Pakistan): ISPs and cloud customers reported slower internet, congested peering points, and performance issues affecting enterprise and consumer traffic. Some enterprise customers resorted to local fallbacks for critical systems.
  • Gulf states (UAE, Saudi Arabia): Financial markets, trading systems and latency‑sensitive services experienced alerts and higher execution times in certain cases, prompting conservative trading thresholds. Telecom operators warned customers of intermittent performance hits.
  • Europe–Asia interconnectivity: Multinational corporations depending on cross‑region file syncs, CI/CD pipelines, and remote work saw elongated job windows and occasional failures requiring retries or postponement.
Claims of highly specific business impacts — for example, a reported "60% drop in response speed" for a named conglomerate’s ERP system — circulated in some local reporting. Those company‑level figures were not confirmed by direct company statements available in the immediate reporting window, and therefore should be treated as unverified until corroborated. Business continuity plans that assumed immediate parity with pre‑incident performance found that some operations needed temporary local fallbacks, while others tolerated degraded performance after engineering mitigations.
How Microsoft and operators responded​
Microsoft’s public posture followed a standard operational playbook:
  • Publish a Service Health advisory that scoped the geographic impact and described symptoms customers should expect.
  • Apply traffic engineering and rerouting to maintain reachability and minimize service interruption.
  • Commit to frequent status updates while carrier repair work progressed and capacity was rebalanced.
Major carriers and CDNs also adjusted peering and leased additional transit capacity where available to absorb diverted flows. Independent monitoring groups (NetBlocks and others) traced route changes and elevated latency, providing a public view of the operational impact while consortia prepared formal diagnostic bulletins.
Short‑ and medium‑term remediation actions for enterprises​
For organizations relying on cloud services, the incident offers a concrete resilience checklist:
  • Map physical transit dependencies. Understand which region‑to‑region flows rely on chokepoints such as the Red Sea and document alternative paths.
  • Validate failover plans. Exercise and verify cross‑region failover in non‑disruptive ways and ensure runbooks include network‑level contingencies.
  • Implement regional caches and edge strategies. Reduce reliance on cross‑continent round trips for latency‑sensitive workloads.
  • Consider multi‑cloud or multi‑region replication that explicitly diversifies physical routes and providers.
  • Negotiate transit transparency with providers: ask for details on transit geography and peering footprints to evaluate true path diversity.
Short‑term technical mitigations that engineering teams commonly used during the disruption included increasing timeouts, switching to asynchronous replication, throttling chatty multi‑region APIs, and temporarily moving critical workloads to local regions or on‑prem backups.
Longer‑term industry and policy implications​
The Red Sea incident is a reminder that cloud resilience depends on the physical world — ships, cables, splices and geopolitics — and not just logical redundancy. The event sharpens three policy and industry priorities:
  • Invest in physical route diversity. Adding alternate cables that avoid concentrated corridors reduces correlated risk. Regional terrestrial backhauls and Arctic or southern circumnavigation routes can add resilience, albeit at cost.
  • Expand repair capacity and logistics. Ensuring more repair vessels and forward staging points would reduce mean time to repair for major trunk faults.
  • Coordinate protection and maritime safety. Better mapping of shipping anchor grounds, coordinated navigation warnings, and international agreements for cable protection reduce accidental damage risk. In contested waters, naval coordination and safe operating windows are also necessary for repair missions.
Finally, the episode rekindles interest in non‑subsea alternatives such as high‑capacity satellite constellations for emergency backhaul. Satellite solutions currently trade cost and latency for availability; they function as useful contingency links for critical traffic but are not yet a wholesale replacement for submarine fiber.
Security and geopolitical angles — what to watch for​
Two intersecting security dynamics should shape short‑term monitoring:
  • Maritime insecurity and denial‑of‑service risk: In regions with active maritime conflicts or proxy engagements, cable repair operations can be complicated or delayed, increasing economic exposure. Operators and governments will need to assess threat models and coordinate naval or diplomatic safeguards for repair assets.
  • Information risk and rumor control: In the immediate hours after disruption, incomplete or exaggerated claims proliferated across social and local media. Industry actors must prioritize clear, factual operator bulletins and resist premature attribution. Specific company impact claims lacking direct confirmation should be flagged as unverified.
What this means for cloud resilience thinking​
The incident should reset cloud resilience conversations in three practical ways:
  • From logical to physical: Redundancy must include physical path diversity, not just multiple regions within one geographic corridor.
  • From single‑provider assumptions to multi‑vector planning: Relying on a single major cloud region or a single transit corridor is increasingly risky. Multi‑cloud and multi‑transit approaches should be evaluated for mission‑critical systems.
  • From reactive to proactive: Map, simulate, and rehearse corridor‑level incidents in tabletop exercises that include network, application, and business continuity stakeholders.
Caveats, uncertainties and unverified claims​
Several specific numeric claims and company‑level impacts circulated early. These include precise latency deltas (for example, quoted ranges of 150–250 ms) and a reported “60% drop” in response speed for a named ERP system. Those figures appeared in localized or secondary reports and were not corroborated by operator telemetry or public company statements in the immediate reporting window. Treat such claims as unverified until confirmed by primary sources such as Microsoft’s diagnostic telemetry or the affected company’s official statement.
Similarly, early lists of affected cables varied across monitoring organizations and news outlets. Use consortium fault bulletins and operator postings as the final word for cable identities and splice‑level diagnostics.
Practical checklist for IT leaders (immediate actions)​
  • Verify which customer‑facing and backend flows rely on Asia↔Europe east–west routes that transit the Middle East corridor.
  • Ensure timeouts and retry logic are tuned to tolerate elevated latency in the short term.
  • Fail over synchronous replication to asynchronous where possible to prevent backpressure and cascading retries.
  • Move critical workloads or caches into the most geographically local region with sufficient capacity.
  • Communicate to business stakeholders clearly about expected degraded performance and contingency actions.
The Red Sea submarine cable incident of September 6, 2025 was a practical reminder that cloud reliability is inseparable from the physical network beneath the internet. Microsoft Azure’s engineers applied established mitigations — traffic rerouting, capacity rebalancing and transparent status updates — and reachability was preserved in most cases. Yet the event exposed persistent structural vulnerabilities: concentrated chokepoints, constrained repair capacity, and the gap between logical redundancy and actual physical diversity. For enterprises and cloud architects, the lesson is clear and immediate: map real‑world transit geometry, validate failovers under realistic route failures, and incorporate physical‑path diversity into resilience planning. For industry and governments, the imperative is to invest in cable protection, repair readiness and alternative routes so that a handful of damaged fibers cannot produce outsized, cross‑border disruption. The internet’s surface‑level conveniences depend on ships, splices and secure seas — and until those elements are robustly managed, cloud performance will remain exposed to the maritime environment.
Source: openPR.com Red Sea submarine cable break hits Microsoft's cloud services
