Azure Linux CVE-2024 36024: Attestation Limits and Exposure Risk
Microsoft’s public advisory that “Azure Linux includes this open‑source library and is therefore potentially affected” is accurate for the product inventory Microsoft has completed — but it is not proof that Azure Linux is the only Microsoft product that could possibly include the vulnerable Linux kernel component tracked as CVE‑2024‑36024.
Neon blue cloud and CVE shield hover above a processor on a server motherboard.Background / Overview​
CVE‑2024‑36024 is a Linux‑kernel vulnerability fixed in the AMD DRM display driver (the drm/amd/display tree). The upstream change disables an “idle reallow” path when executing certain mailbox/GPINT commands against the DMCU microcontroller (DMCUB). The defect is a timing/race issue where the microcontroller can be in a power‑state transition (committing to IPS1 or IPS2) during a handshake; if the driver issues back‑to‑back wake_and_execute sequences it risks touching the INBOX1 RPTR at the wrong time and causing a hardware hang. The upstream remediation avoids the back‑to‑back wake sequence by disabling the reallow so there’s a safe gap between entry and exit of the mailbox operation. This is an availability/robustness bug: the reported impact is driver hang / kernel stall / host instability (denial‑of‑service). Public vulnerability records and vendor advisories characterize the flaw as a local attack surface (a process that can exercise DRM device nodes or GPU ioctl paths) rather than a direct remote code‑execution or privilege‑escalation primitive. Multiple distributions and vendor advisories published kernel updates that contain the upstream change.
What Microsoft actually said — and why it matters​
Microsoft’s Security Response Center (MSRC) entry for the CVE includes a short, product‑scoped attestation: “Azure Linux includes this open‑source library and is therefore potentially affected.” The statement also declares Microsoft’s intention to publish machine‑readable CSAF/VEX attestations (beginning with Azure Linux) and to update the CVE/VEX mapping if additional Microsoft products are later discovered to include the same upstream component. That is a process statement about Microsoft’s inventory work and disclosure model, not an engineering proof that other Microsoft products cannot ever contain the same kernel component. Why this wording is important:
  • It is an authoritative attestation for Azure Linux — if you run Microsoft‑published Azure Linux images, treat Microsoft’s VEX/CSAF output as the canonical, machine‑readable signal for that product family and act on Microsoft’s remediation guidance.
  • It is not a blanket exclusion of other Microsoft products — the phrase records what Microsoft has validated so far and promises updates as inventory work continues. Absence of a Microsoft product name in the attestation is absence of attestation, not positive proof that the product is unaffected.
Put plainly: Microsoft has completed an inventory for the Azure Linux images and found the vulnerable driver there; they will expand the published mapping if further Microsoft artifacts are identified as carriers. That sequencing is responsible and useful for automation (VEX/CSAF), but it changes the nature of the question from “is this true?” into “what else should I check?” for my environment.
Technical anatomy: why this is a distribution‑level issue​
Two separate, concrete facts determine whether any given Microsoft product or image is affected:
  • Kernel commit/branch: the product must ship a kernel built from an upstream commit range that includes the pre‑fix code. If the vendor (or distribution) has cherry‑picked the stable upstream commits or backported the fix, the shipped kernel may already be safe. Public stable commits and the kernel‑tree references are available in the kernel stable history.
  • Kernel configuration / module presence: many drivers in the Linux kernel are optional. The component is present in kernel source under the AMD display DRM code; a particular product is only exposed if the kernel build configuration enabled the AMD DRM driver (built‑in or as a module) and the module is shipped and loaded at runtime. If the driver is absent from the kernel binary or disabled in configuration, the product is not practically affected.
Because both conditions are per‑artifact (per kernel image, per product SKU), you cannot infer product exposure solely from the upstream CVE text — you must check the specific kernel artifacts shipped with each Microsoft product.
Is Azure Linux the only Microsoft product that could include the library?​
Short answer: No — Azure Linux is the only Microsoft product Microsoft has publicly attested (so far) as including the vulnerable component, but other Microsoft‑distributed Linux artifacts could include the same upstream code depending on kernel version and build configuration. Examples of plausible Microsoft artifacts that might carry the same code include:
  • The WSL2 (Windows Subsystem for Linux) kernel builds Microsoft publishes and maintains. Microsoft publicly manages and publishes the WSL2 kernel source tree, which includes the drivers/gpu/drm area where AMDGPU lives; whether any specific WSL kernel binary built by Microsoft is vulnerable depends on its configuration and version.
  • Other Microsoft Linux kernel images — for example linux‑azure, Marketplace images with Microsoft‑maintained kernels, or specialized appliance/IoT images that include a Linux kernel. These artifacts are built separately and may or may not include the AMD DRM driver.
  • Any Microsoft White‑label or partner images, third‑party Marketplace appliances, or internal testing images that bundle Linux kernels. Those are out of scope for the Azure Linux VEX attestation unless Microsoft explicitly inventories them and updates the CVE mapping.
Operationally: Microsoft’s statement is an inventory result for Azure Linux — it does not provide universal negative assurance for all Microsoft artifacts. Treat the VEX output as authoritative for Azure Linux and treat other Microsoft products as “unverified” until they are explicitly attested or you verify them yourself.
Independent corroboration: what other sources show​
Multiple independent vendors and distribution security trackers record CVE‑2024‑36024, map it to upstream kernel fixes, and list patched package versions for their trees. Examples include NVD, SUSE, Ubuntu trackers, and other public CVE mirrors. These independent entries confirm:
  • The technical nature of the fix (disable idle reallow around GPINT mailbox execution to avoid back‑to‑back wake sequences).
  • That the problem is in upstream kernel code and therefore any product shipping a kernel built from the vulnerable commit range and including the DRM/AMD driver may be affected until patched.
Cross‑validating Microsoft’s product attestation against distro trackers and upstream commits is the sensible way to confirm exposure for any given artifact: vendor attestations tell you what Microsoft has found; distribution trackers tell you whether your distro kernel packages contain the upstream fix.
Practical checklist: how to verify exposure in your environment​
Below is a prioritized, actionable checklist intended for Linux/cloud engineering and security teams. These steps let you determine whether Azure Linux or any other Microsoft artifact you run is affected, and how to remediate or mitigate until patched.
1. Treat Azure Linux as in‑scope — patch first​
  • If you run Azure Linux images, apply Microsoft’s published kernel or image updates immediately. Microsoft’s VEX/CSAF for Azure Linux is the canonical signal for those images.
2. Inventory Microsoft-supplied Linux artifacts​
  • List all VMs and images derived from Microsoft‑published artifacts: Azure VM images, Marketplace appliances published by Microsoft, linux‑azure builds, and WSL installations.
  • Pull the kernel release and module lists for each artifact.
Example commands (run on the target host):
  • uname -r
  • lsmod | grep amdgpu || true
  • ls -l /lib/modules/$(uname -r)/kernel/drivers/gpu/drm/amd 2>/dev/null || true
  • zcat /proc/config.gz 2>/dev/null | egrep -i 'CONFIG_DRM_AMDGPU|CONFIG_DRM' || grep -i CONFIG_DRM_AMDGPU /boot/config-$(uname -r) 2>/dev/null
These quick checks will tell you whether the kernel version predates fixed upstream commits and whether the AMDGPU driver is present.
3. Check WSL kernels specifically​
  • If your developers or CI runners use WSL2, check which WSL kernel you are running (uname -r inside WSL) and compare it to the kernel versions or commit IDs listed in vendor advisories.
  • If you use Microsoft‑shipped WSL kernels and they include the amdgpu code path and are older than the upstream fix, consider applying the WSL kernel update or instructing developers to update the WSL kernel binary.
4. Patch or backport​
  • Apply vendor/distribution kernel updates that include the upstream stable commits that remedied CVE‑2024‑36024.
  • If you maintain your own kernel builds (custom kernels in appliances or embedded devices), apply the upstream stable commit to your build and rebuild/redeploy.
Distribution trackers list the patched kernel images and package names (for example, specific linux‑image packages for Ubuntu and kernel‑updates for SUSE). Use those package names to identify the correct update for your distribution.
5. Short‑term mitigations (if patching is delayed)​
  • Restrict access to DRM device nodes (/dev/dri/*) using udev rules and tighter group membership: remove untrusted users from hardware access groups and avoid exposing GPU device nodes to untrusted containers.
  • Avoid exposing GPUs to untrusted multi‑tenant workloads (device passthrough).
  • Monitor kernel logs and SIEM for oops/panic traces referencing amdgpu or related stack frames (evidence of attempted exploitation or driver instability).
Detection and incident response guidance​
  • Hunting signals: look for kernel oops or panic messages referencing the AMD display driver functions or mailbox/GPINT paths. Capture dmesg and journalctl logs; set SIEM rules to flag amdgpu AND “NULL pointer” / “oops” / “panic.”
  • Reproduction patterns: workloads that exercise GPU mailbox IOCTLs, compositors, or pages that trigger DMCU mailbox interactions are the likely triggers for a crash/hang. Recreate in a test environment with an identical kernel to confirm vulnerability and validate the patch.
  • Recovery: if a host becomes unresponsive due to the hang, a reboot is typically required; ensure runbooks and automation cover safe reboot and evidence capture before reboot if possible (collect serial logs, dmesg).
Why Microsoft’s phased VEX approach is both useful and limited​
Microsoft’s decision to publish machine‑readable VEX/CSAF attestations starting with Azure Linux improves automation for cloud customers: you can programmatically ingest those attestations to triage which images in Azure are affected and prioritize patching. However:
  • Vendors with large numbers of artifacts must phase‑in inventory attestation. Microsoft explicitly stated it began with Azure Linux and will add more products as its inventory matures; that is practical but means not every Microsoft image is covered initially.
  • For artifacts not yet attested, customers must perform artifact‑level verification rather than relying on absence from the VEX list as proof of safety. The build‑time and run‑time conditions that determine exposure (kernel commit + configuration) remain the final arbiter.
This pattern of “attest what we’ve inspected, expand the list as we inspect more” is a defensible transparency model — it provides firm guidance for the initial set of artifacts while promising expansion — but it places the onus on customers to verify non‑attested artifacts.
Strengths and risks of Microsoft’s wording (critical analysis)​
Strengths​
  • Clarity for Azure Linux customers: Microsoft’s explicit attestation gives Azure Linux tenants a clear, machine‑readable statement that their images include the implicated upstream component and therefore are in scope for remediation. This accelerates triage and reduces detection noise.
  • Process transparency: The promise to publish CSAF/VEX files and to update the CVE mapping as additional artifacts are identified is a measurable, accountable process that improves vendor transparency over time.
Risks / Limitations​
  • Misinterpretation risk: Non‑specialist readers may read “Azure Linux includes this open‑source library and is therefore potentially affected” as a claim that only Azure Linux could ever be affected. That is a misinterpretation of Microsoft’s inventory statement and may lead to complacency for other Microsoft artifacts.
  • Inventory lag: Large vendors have thousands of artifacts. Until the VEX inventory expands, customers must assume other Microsoft kernels and images are “unknown” rather than “not vulnerable.” That creates a potential blind spot for organizations that do not perform artifact‑level checks.
  • Operational complexity: Determining exposure often requires kernel‑level checks (module presence, kernel cfg, package commits) that are sometimes nontrivial in complex cloud estates (marketplace images, custom appliances), raising the bar for effective remediation without automation.
Where Microsoft’s attestation is strongest is in telling Azure Linux customers exactly what to act on. Where it is weakest is in giving binary reassurance for other Microsoft products that simply haven’t been inventoried yet.
Recommended short runbook (copy‑paste commands and steps)​
  • On any host you suspect might be affected, run:
  • uname -r
  • If amdgpu appears present and kernel version predates vendor fixed packages:
  • For Azure Linux: apply Microsoft’s patched image/kernel immediately (follow Microsoft’s VEX guidance).
  • For other distros: apply the distro’s patched kernel package listed in their security advisory (Ubuntu, SUSE, etc..
  • If you cannot patch immediately:
  • Restrict /dev/dri access and block mounting of GPU devices into untrusted containers.
  • Place affected hosts into maintenance mode and isolate them from multi‑tenant workloads.
  • Monitoring:
  • Add SIEM alerts for kernel oops/panic traces mentioning “amdgpu”, “dc_destruct”, “gpint”, or “DMCUB”.
  • Capture serial console logs and dmesg for any host that experiences instability.
  • Documentation:
  • Record the kernel uname, package versions, and module list for each host you patch so you can validate remediation and produce evidence for compliance.
Final assessment and closing advice​
Microsoft’s MSRC entry for CVE‑2024‑36024 and its VEX rollout give Azure Linux customers a definitive, machine‑readable signal that their Azure Linux images do include the upstream component and therefore require remediation attention. That is valuable, actionable transparency — act on it for Azure Linux immediately. However, the attestation is a snapshot of Microsoft’s inventory for a particular product line. It does not logically prove that no other Microsoft product or image can include the same vulnerable kernel code. Any Microsoft artifact that ships a Linux kernel built from the vulnerable commit range and includes the AMD DRM driver could be affected until inventory or attestation proves otherwise. Customers should therefore treat non‑attested Microsoft artifacts as “unverified” and run the artifact‑level checks and runbook steps above.
If your organization runs Azure Linux images, patch now and automate ingestion of Microsoft’s VEX/CSAF feeds so your triage tooling can follow changes in Microsoft’s attestation (MSRC has documented the phased rollout and why it began with Azure Linux). If you run other Microsoft‑distributed images (WSL, Marketplace appliances, linux‑azure) or any Microsoft‑supplied kernel, add them to a prioritized inventory list and verify kernel version and module presence per the runbook before assuming they are unaffected. Caveat: Microsoft will update the CVE entry and VEX/CSAF attestations if it discovers additional Microsoft products that include the same upstream component; operators should monitor those feeds and the vendor advisories from their distributions for final confirmation of remediation status. Until then, follow the inventory → patch → mitigate pattern described above.
Conclusion: Azure Linux is the only Microsoft product Microsoft has publicly attested as including the open‑source library implicated in CVE‑2024‑36024 — that attestation is authoritative and requires immediate action for Azure Linux customers. It is not, however, a categorical guarantee that no other Microsoft product could include the same upstream kernel driver; artifact‑level verification remains necessary for any other Microsoft‑supplied images or kernels in your environment.
Support hub
