Azure Linux Exposure to CVE-2025-37822: Artifact Level Verification and Attestations
A glowing Azure cloud hovers above server racks with security icons.
Microsoft’s wording that “Azure Linux includes this open‑source library and is therefore potentially affected” is an authoritative, product‑level attestation for that distro — but it is not a categorical statement that no other Microsoft product ships the same vulnerable component.
Background / Overview​
The Linux kernel vulnerability tracked as CVE‑2025‑37822 fixes a RISC‑V specific correctness issue in the uprobes support: the code that builds the XOL (execute‑out‑of‑line) buffer did not perform an instruction‑cache flush (fence.i) after constructing the buffer, which can let stale or partially‑constructed instructions execute and lead to random failures when reproducing user instructions for single‑step probes. Upstream kernels received a small, targeted patch that inserts the missing fence.i in the RISC‑V uprobes path. This is primarily a correctness/availability issue: the practical worst‑case impacts reported in vendor trackers include random test failures, kernel OOPSes and correctness surprises on RISC‑V hardware rather than a confirmed remote code‑execution vector. Multiple distribution advisories classify it as medium severity with real operational impact for RISC‑V hosts that run the affected kernel code.
What Microsoft actually said — precise reading​
Microsoft’s Security Response Center entry for this CVE makes two clear statements:
  • Azure Linux (Microsoft’s Azure‑distributed Linux images) includes the implicated open‑source component and is therefore potentially affected.
  • Microsoft has started publishing machine‑readable CSAF/VEX attestations (inventory‑level, automatable vulnerability/exposure statements) and will update the CVE/VEX mapping if additional Microsoft products are later identified as carriers of the same upstream component.
That language is intentionally scoped: the attestation is authoritative for the named product family (Azure Linux), and the public commitment to expand VEX mappings is procedural — it promises future updates if more Microsoft SKUs are discovered to ship the vulnerable code. It does not mean Microsoft has claimed that no other Microsoft product could possibly include the component today.
Short answer to the question​
No — Azure Linux is not necessarily the only Microsoft product that includes the open‑source library and is therefore potentially affected. Microsoft has publicly attested that Azure Linux includes the component; that attestation establishes a confirmed exposure for Azure Linux images, but it is a snapshot of Microsoft’s inventory work at the time the VEX/CSAF entry was published. Other Microsoft‑supplied Linux artifacts may include the same kernel code depending on how they were built and which kernel versions/configurations they use.
Why that nuance matters for operations and risk teams​
  • Vendor attestations are per‑product and per‑artifact. Large vendors with many images and kernel artifacts commonly publish attestations one product family at a time as their automated inventory and SBOM processes complete. The presence of an attestation for one product is an authoritative yes for that product and nothing more.
  • Microsoft ships several different Linux artifacts and kernels (Azure VM images, Marketplace images, CBL‑Mariner bases, WSL2 kernels, curated containers, marketplace appliances). Each artifact is built separately and may include or omit the affected kernel code depending on build flags, kernel version, or whether a vendor‑specific backport was applied. That means exposure is an artifact‑level question, not a blanket corporate yes/no.
  • Until Microsoft publishes expanded VEX/CSAF attestations for other product families, customers should not infer safety from silence; instead they must verify the individual artifacts they run. Microsoft has said it will update the CVE attestation if additional products are found to include the vulnerable code, which is the mechanism by which Microsoft will provide authoritative answers for other SKUs.
Technical summary of CVE‑2025‑37822 (what was wrong)​
  • Component: Linux kernel, RISC‑V uprobes implementation.
  • Fault: Missing fence.i (instruction‑cache flush) after creating the XOL buffer used to single‑step replaced instructions for uprobes.
  • Consequence: CPU could execute stale or partially written instructions from the XOL buffer, causing random failures, test failures, or unexpected behavior on RISC‑V hardware that enforces instruction cache coherency rules strictly.
  • Fix: Upstream added the missing fence.i in the RISC‑V uprobes code path; the patch is small and focused on ensuring instruction cache correctness after buffer construction.
The technical record is corroborated by multiple independent trackers (NVD, Debian, SUSE and vendor advisories), which all describe the same root cause and the same targeted fix. Cross‑referencing these independent sources is recommended before declaring an environment safe.
Why other Microsoft products could be affected​
  • Microsoft maintains and distributes multiple Linux kernel artifacts: the Azure Linux images (attested), CBL‑Mariner artifacts (used as container hosts and base images), WSL2 kernel builds (published source tree used to produce the WSL kernel), and Marketplace images or partner images. Any of those artifacts that were built from upstream trees containing the vulnerable commit (or that were configured to include uprobes support on RISC‑V) could be affected.
  • Inclusion of the vulnerable code is a function of both kernel version and kernel configuration. An Azure Marketplace image built from a given kernel tree could include the vulnerable path while another image might not, depending on build-time options and whether the vendor backported the upstream fix. That’s why artifact‑level verification is necessary.
Practical verification and discovery steps (artifact‑level checks)​
The only reliable way to determine exposure for any Microsoft‑supplied image or kernel is to inspect the artifact itself. The following prioritized checklist is practical and automatable:
  1. Inventory Microsoft artifacts you run:
    • Azure VM images (image IDs and SKU names)
    • Marketplace VM images and partner images
    • Container base images used in Azure Container Registry or curated Azure repos
    • WSL2 kernels deployed to developer machines
    • Any Microsoft‑supplied appliances or agent images
  2. For each artifact, perform these checks:
    1. Identify running kernel: uname -r on the instance to get the kernel release string.
    2. Map the kernel package to upstream commits or distribution changelogs; confirm whether the stable upstream commit that adds the fence.i is included.
    3. For custom or vendor kernels, check the kernel .config for uprobes support or for RISC‑V builds that enable uprobes.
    4. For container images or binaries, inspect installed kernel packages and any statically‑linked tooling that may embed kernel code or probe runtimes.
  3. Automate artifact verification where possible:
    • Consume Microsoft’s CSAF/VEX machine‑readable attestations for Azure Linux (authoritative for the attested product).
    • Use image scanning tools that can read kernel package metadata, SBOMs, or build provenance data for Marketplace images.
  4. If an artifact is built in‑house from Microsoft source repositories (for example, you compiled the WSL kernel from Microsoft’s repo), ensure your build uses a fixed upstream commit or contains the patch that inserts fence.i.
Prioritization guidance​
  • Highest priority: RISC‑V hosts running kernels that include uprobes and that are part of multi‑tenant or security‑sensitive infrastructure. These are most likely to suffer operational impacts (random failures, kernel panics) and to be high‑value targets for service availability concerns.
  • Medium priority: Development or test systems where RISC‑V emulation or RISC‑V hardware is used. These may be less critical but should be patched to avoid developer disruption.
  • Lower priority: Environments that do not run RISC‑V kernels, or where uprobes is not enabled or accessible. But validate the kernel configuration rather than assume absence.
Recommended remediation steps​
  • Apply vendor/distribution kernel updates that include the upstream fix; reboot to activate the updated kernel. This is the definitive remediation. Multiple distributors (Debian, Ubuntu, SUSE, Red Hat canonical trackers) have already listed fixed package versions or backports.
  • For environments that cannot immediately patch:
    • Isolate untrusted workloads from RISC‑V hosts running the vulnerable kernel.
    • Avoid running untrusted code that can attach uprobes or load BPF programs that exercise uprobes logic on RISC‑V.
    • Consider restricting access to privileged interfaces that can cause probe installations.
  • For WSL2 or other Microsoft‑published kernels:
    • Check the WSL2 kernel build provenance and version. If your WSL2 kernel was built from a tree that predates the fix, apply the updated WSL kernel release once Microsoft publishes it or compile a fixed kernel yourself following Microsoft’s published WSL kernel sources.
Detection and monitoring tips​
  • Look for unusual OOPS traces or reproducible failures in places where uprobes or uprobe‑related BPF selftests were running. The original bug was discovered during the BPF selftests “test_progs: uprobe_autoattach, attach_probe,” so failures in those test paths are a signal.
  • Monitor vendor / distribution trackers for explicit kernel package mappings to the upstream fix commit IDs. Don’t rely on generic kernel version numbers without checking changelogs or stable commit references.
  • For Microsoft environments, consume Microsoft’s CSAF/VEX feed if you operate Azure Linux at scale; it provides machine‑readable attestations that are authoritative for the attested product. But do not treat the absence of an attestation for other product families as proof of safety — artifact verification is still required.
Risks, caveats, and unresolved items​
  • Microsoft’s attestation practice reduces uncertainty by publishing definitive mappings for product families as the vendor completes inventory work. However, the phased nature of that publication means there will be windows of uncertainty until Microsoft expands VEX/CSAF coverage to all relevant artifacts. Treat Microsoft’s Azure Linux attestation as an authoritative “yes” for Azure Linux and as a prompt to validate other Microsoft artifacts you run.
  • It is possible that third‑party Marketplace images or partner‑supplied images hosted in Azure include older or vendor‑patched kernels that differ from Microsoft’s attested Azure Linux baseline. Those images must be checked individually.
  • Some public trackers show differing CVSS/impact scoring interpretations for the same upstream issue. That divergence reflects differences in how vendors assess confidentiality and integrity impacts for architecture‑specific kernel correctness bugs; prioritize remediation based on operational exposure rather than relying solely on a single CVSS number.
Flag: any claim that “no other Microsoft product is affected” is unverifiable until Microsoft publishes explicit attestations or other vendors publish confirmed mappings; treat such claims as unproven and proceed with artifact‑level verification.
Actionable checklist for WindowsForum readers and admins​
  1. Identify whether you run any RISC‑V hosts or RISC‑V guest hypervisors in your estate. If yes, escalate to immediate inventory.
  2. For each Microsoft image you operate (Azure VM images, Marketplace images, CBL‑Mariner hosts, WSL2 kernels):
    • Query kernel version: uname -r
    • Check kernel package changelog or published vendor advisory for explicit inclusion of the upstream fix commit or the CVE.
  3. Apply vendor/distribution kernel updates that include the fixed commits and schedule reboots.
  4. For managed Azure workloads: consult Microsoft’s CSAF/VEX outputs for Azure Linux artifacts and subscribe to update feeds; treat those attestations as authoritative for the attested product.
  5. If patching is delayed: restrict untrusted code from installing uprobes or running the BPF tests that exercised the defective path; isolate vulnerable hosts from multi‑tenant workloads.
  6. Validate fixes in a staging ring by reproducing the previously failing BPF selftests if you have RISC‑V test hardware or emulation available. Monitor for residual OOPS traces.
Final assessment​
Microsoft’s statement that “Azure Linux includes this open‑source library and is therefore potentially affected” is accurate and operationally useful: it provides an authoritative, machine‑readable attestation customers can rely on for that product family. However, that attestation is limited in scope and should not be read as a proof that all other Microsoft products are unaffected. Artifact‑level verification remains the only reliable way to confirm exposure for other Microsoft images or kernels. Microsoft’s commitment to expand CSAF/VEX attestations and to update CVE entries if new product impacts are found is meaningful and will reduce uncertainty over time, but customers must act now to inventory and patch the actual artifacts they run.
For any environment that includes RISC‑V kernels or Microsoft‑distributed Linux artifacts, the recommended path is straightforward: verify artifact provenance, apply the kernel update that carries the fence.i fix, and reboot. Where immediate patching is not possible, apply isolation and capability restrictions and prioritize high‑value multi‑tenant hosts for remediation.
Conclusion: Azure Linux is a confirmed attested carrier of the vulnerable component; it is not necessarily the only Microsoft product that could include it. Treat Microsoft’s Azure Linux attestation as an authoritative starting point, then verify the kernel artifacts you actually run — across WSL2, CBL‑Mariner, Marketplace images and any vendor‑supplied kernels — and apply upstream or vendor kernel updates that include the fence.i patch as the primary remediation.
