backup to 1 TB USB Drive
docweathers
I am trying to make a backup on a one-terabyte USB Drive. When I try to make a file history backup it will appear fine for about 5 minutes. Then it shows an error saying that a file on the drive is corrupted and cannot be read.
After I got this message I checked the drive for corruption. I find a corrupted file. I have the corrupted file removed then try again to back up to the USB. The same thing happens. I have repeated this several times on three different new 1 terabyte USB drives and they all do the same thing. I have a 64 gigabyte USB Drive plugged in and I can back up to it fine.
It seems like you are experiencing issues when attempting to make a file history backup to a one-terabyte USB drive. Here are a few troubleshooting steps you can try to resolve the problem:
  1. Update USB drivers: Make sure you have the latest drivers installed for your USB ports. You can usually download the latest drivers from the manufacturer's website.
  2. Check USB drive for errors: Use the built-in Windows utility called Error Checking to scan and repair any potential issues on the USB drive. Right-click on the USB drive in Windows Explorer, select "Properties," go to the "Tools" tab, and click on "Check" under the Error Checking section.
  3. Format the USB drive: If the error persists, try formatting the USB drive. Be aware that...
  3. Format the USB drive: If the error persists, try formatting the USB drive. Be aware that this will erase all data on the drive, so make sure to back up any important files before proceeding. To format the drive, right-click on it in Windows Explorer, select "Format," choose the desired file system (usually NTFS for large drives), and click "Start."
  4. Test the USB drive on another computer: Connect the USB drive to another computer and attempt to perform a backup there. This will help determine if the issue is specific to your computer or the USB drive itself.
  5. Adjust power management settings: Some power management settings in Windows can interfere with USB devices. Open Device Manager, expand the "Universal Serial Bus controllers" section, right-click on each USB controller, select "Properties," go to the "Power Management" tab, and uncheck the option to "Allow the computer to turn off this device to save power."
  6. Disable any antivirus or firewall software temporarily: Sometimes, third-party security software can interfere with the backup process. Disable any antivirus or firewall software temporarily and try performing the backup again.
    If none of these steps resolve the issue, it may be worth contacting Microsoft support or the manufacturer of your USB drive for further assistance.
the issue is you are working on a USB and they turn off by default [to save power]
a back up software should be sent to internal drives where ever possible... move them to the USB location after for storage
Spot on! USB power management settings often interfere with long-running processes like backups. By default, Windows prioritizes energy efficiency, which can cause USB drives to go into a low-power or idle state if there’s no active communication—leading to interruptions during backups.
Your recommendation to first back up to an internal drive and then move the data to a USB drive for storage is ideal. It ensures there are no hiccups caused by power-saving features or USB bandwidth limitations.
Here's Why Backing Up Directly to USB Isn’t Ideal:​
  1. USB Power-Saving Features:
    • USB drives, especially large external ones, may "disconnect" temporarily during prolonged inactivity. Backup tasks can fail or hang when the connection is disrupted.
  2. Performance Bottlenecks:
    • Even modern USB 3.0 drives have slower write speeds compared to internal SSDs or HDDs. Backups work significantly faster on internal drives.
  3. Data Integrity Risks:
    • If the USB gets ejected unexpectedly (due to connection interruptions or power-saving), partial data could be corrupt or lost.
Solutions to Improve USB Backup Reliability
If you must work directly with the USB, here’s what you can do to minimize interruptions:
1. Disable USB Selective Suspend
USB Selective Suspend is a Windows feature that turns off idle USB devices to save power. Disabling this prevents your external drive from entering sleep mode.
Steps:
  1. Go to Control Panel > Power Options > Change Plan Settings for your active power plan.
  2. Click Change advanced power settings.
  3. Expand USB settings > USB selective suspend setting.
  4. Set it to Disabled for both On Battery (if applicable) and Plugged In.
  5. Save changes.
2. Use Internal Drives for Backups and Transition to USB
As you suggested, this is a much more reliable workflow:
  1. Perform backups to internal drives.
  2. After the backup completes:
    • Manually copy the backup to the USB.
    • This reduces the risk of interruptions during the backup process itself.
3. Keep USB Drives Awake
Some external drives have their own power-saving settings (often for portable HDDs). Adjusting these can also help:
  • For brand-specific external drives (e.g., WD My Passport, Seagate), install the accompanying utility software to disable sleep mode.
Or, manually keep the drive active:
  • Open the USB in File Explorer and play a video file from the drive or create dummy activity to prevent it from idling during backups.
4. Use Dedicated Backup Software
Professional backup tools (e.g., Macrium Reflect, Acronis True Image) often have options to introduce retries or handle external storage more efficiently. They also notify you if the USB becomes disconnected and can even schedule backup tasks for when the drive is connected.
5. Upgrade to SSDs or NAS for Better Long-Term Storage
If backups are frequent and large, consider:
  • SSD-based external drives: Faster and more reliable than spinning HDD-based USB drives.
  • Network Attached Storage (NAS): A NAS device avoids USB connection issues entirely and allows backups via internal wired networking. It’s perfect if you're regularly managing large backups.
Final Thoughts​
While USB drives are great for long-term storage, power-saving quirks during backups make them less ideal for direct reliable backups. Your advice stands strong: store the backups internally first and move them later. This workflow ensures smooth backups and avoids the frustrations caused by USB interruptions.
If this issue keeps cropping up, let me know—I can help identify additional optimizations or alternative solutions! 😊
