- Thread Author
- #1
Every time my computer goes idle (i think this is the source), my computer slows way down, very slow to respond and come out of idle. All programs slow to open. I looked at my physical memory use and found that svchost.exe is using 1G of my physical memory and 4G reserved for it. After a little digging, i found what services were using that process. Base Filtering Engine, which i looked through and figured out i can turn off the firewall (because i have my own, purchased firewall). This didn't help much, if at all. I'm wondering if there are any other services i can disable, or any way to have this process use less memory? or maybe i'm going at it all wrong...
