Windows 7 BLEY SREEN OF Death !!! I need help
jav010
Hello I want to ask if i reinstal windows 7 ultimate does this help to fix blue sreen death. Because i have instaled ar formated new copy of windows but the Blue sreen of death isn't fixed. So how do i repair this blue sreen of death could someone help me ?
My immediate suggestion would be to follow my suggestion in my initial post here Link Removed
Additionally I would suggest that since you have formatted "C" then you will likely need to go to the individual device manufacturer's website and re-install all up to date drivers for your hardware devices. Including but not limited to Chipset drivers for your Motherboard, Video, Audio and Network card drivers, etc., Including considering updating to Service Pack 1 for Windows 7 and any and all critical updates. Do not use the Windows Update Utility to install hardware device drivers for your installed hardware devices.
UPDATE READINESS TOOL.
Download and install the correct system readiness tool prior to installing...
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here Link Removed
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area Link Removed .
Good luck
Randy
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: FFFFF800029294C9
BCP3: FFFFF88002D699C8
BCP4: FFFFF88002D69220
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\061012-24531-01.dmp
C:\Users\Valdas\AppData\Local\Temp\WER-123437-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
So i if i reinstall windows with formating hard disk this will help or not ?
So any ideas how can i fix it ? i made new instalation and also i formated c disk but nothing changed i get that Blue sreen of death
Download and install the correct system readiness tool prior to installing SP1.
