Windows 10 Boot Surface Laptop to USB - no Volume button
Jimmy59601
I have a new Surface Laptop and want to boot to a USB thumb. Unlike the Surface Pro, the laptop does not have a Volume button. It does use F5/F6, but neither work for booting. I know that I can select a custom startup from within Win 10 Pro, but want to go from power off to USB boot. Thanks.
FWIW, you can get the system to boot to a USB device from startup, if you open the on-screen keyboard at power up, click Shift to highlight it, and restart. That actually just takes you to the Windows System menu where you can choose to boot to USB on the next startup. I don't know whether this would work if you can't access Windows normally in the first place. I suppose you could boot to a Linux USB USB and thereby get sector level access to the drive. Still, there should be a way to access the UEFI and set a boot order.
BIGBEARJEDI
Hi and welcome to the forum :up:
You should know that Windows PCs are not designed to boot from external media such as hard drives and flash drives. This is a limitation of Windows and is also part of the licensing agreement they have with PC makers *including Surface which is a division of Microsoft*.
That being said, if you Google it and also look around at YouTube, lots of people are doing this for one reason and another such as better protection from viruses/malware, privacy protection (in W10 primarily), and over-all security. Some folks have kids or grandkids in their house and when they leave, they don't want them to be able to use their laptop at all. Pulling the hard drive where the Windows 10 OS normally resides clearly makes that work if you have to have external media plugged into the laptop to make it work. This is analogous in the old days where parents who were owners of desktop PCs would lock up their keyboards and or mice in a locking file cabinet or gun safe. You should also know that you basically have to Hack your W10 in order to do this with the various tricks out on the Internet. When you do this, and you encounter a problem with it; bear in mind Microsoft will not assist you with it since they don't support it, and also considers it a violation of the W10 EULA (End User License Agreement) for the software on your Surface laptop. If that weren't enough to dissuade you, and you return the Surface to your place of purchase, say Best Buy or Staples to get an In-Warranty repair, they won't touch it with your OS on external media for all the above reasons. You could remove the SSD drive or HDD drive from the Surface and take it to their repair centers or ship it back to Microsoft, but the act of removing the Drive with the W10 OS on it, most likely will Void your factory warranty (if it's less than 1 yr. old), and they will only fix it if you pay for a new drive (SSD or HDD)!! :waah:
Depending on the EXACT Surface model number, you may also have one that has the SSD embedded in the Motherboard circuitry; in other words it's a Chip that's hardwired into the Circuit Board and therefore NOT removable. :noway: I haven't seen any Surface laptops with this configuration but have read about them, that's why I mention it. Also, I've run into at least 2 smaller laptops and netbooks (including my Dell Mini Netbook 11) that have SSDe (or Solid State Drive chips) in them. Those of course can't be removed for either repair or modification as in your case where you want to run W10 from a flash drive external to the computer.
Don't get me wrong; you may still be able to run your Surface in this fashion, but you are going to run into a lot of headaches if something goes awry.
Best of luck,:encouragement:
<<BIGBEARJEDI>>
Neemobeer
Windows Forum Team
What model? If this is the surface book it does have a volume button on top That should bring up the boot menu, you'll need to disable secure boot and make usb boot before the ssd and it should work.
Jimmy59601
Thanks very much, guys! This is the new Surface Laptop, which you can check out at the MS store. I attached a scan from the MS booklet. One issue with having to restart from within Win 10 is that you may be unable to access Windows normally. Also, I typically backup my drives by creating a bitstream image of the drive from a boot disk, and I wouldn't even dream of cracking open a Surface. I have three of the more typical Surface Pros, which allow for the volume-down option.
An image from 'Boot Surface Laptop to USB - no Volume button'. Diagram of a laptop showing labeled parts like camera, USB-C, headphone jack, and power button.
Jimmy59601
