Windows XP BSOD 0x0000007F - Help!
Bism
Hello!
Every time I try to run Real Flight 6.5 I get the BSOD *** STOP: 0x0000007F (0x0000000D, 0x00000000, 0x00000000, 0x00000000).
This is the first time I've tried to run this program on xp. It works fine on my friends windows 7 pc.
I've attached six minidump files from today, and my system info.
If anyone can help, I'd really appreciate it!
It looks like a graphics card issue. All of your dump files are showing
nv4_disp.dll 3/21/2013
as the issue which I assume is part of the driver package for your Nvidia GeForce 6200. You can try doing a clean install of the latest version of the driver from here http://www.nvidia.com/download/driverResults.aspx/57493/en-us
If that doesn't help you may consider either rolling back the driver to a previous version, or......
Update the system BIOS from the manufacturer's website.
Or on an older system such as yours you may need to consider updating / upgrading the Power Supply, replacing the card with another if either or both of those are a possible option.
And just to touch all the bases do a memory check ..
Download...
Trouble
Noob Whisperer
Download Memtest86+ from this location here. Burn the ISO to a CD and boot the computer from the CD from a cold boot after leaving it off for an hour or more.
Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test. Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Perform the test RAM sticks individually as well as all possible combinations. When you find a good one then test it in all slots. Post back with the results.
See this Guide to using Memtest 86+
badrobot
Did you check the minimum hardware requirement of the game if it matches the one you have on your PC?
Bug check 0x0000007F occurs when there is a faulty/mismatch memory. It is not very surprising if it runs well on Win 7 and gives you a BSOD on XP. It's a hardware compatibility issue. So switching drivers around may not help solve your problem. You may need to get the right hardware for it.
