[BSOD] BC code: 16 GeForce 7300
Hello, I'm experiencing a BSOD on a vista machine which seems to be pointing at a graphics card driver problem, BC code: 16
I'm trying to ascertain whether or not a new graphics card would fix the problem. I'm concerned that there is an additional cause in the system's software, possibly virus related.
I apologize if I've gone about this the wrong way, I couldn't find any instructions for preferred format of posting dump files.
Thanks in advance
Hello deadhandman,
to Windows 7 Forums,
No apology necessary, you're in the right place and posted correctly.
Thanks for the PM, however, we would like to leave this thread viewable for others that may run across the same issue.
Would it be too much to ask, if you could post your resolution to your issue. It may prove beneficial to others.
Regards
Don
