Windows 8 BSOD Citing Memory_Management
arhartm58
For Christmas I rebuilt my computer and since I am a college student and qualify for Dreamspark, formally known as MSDN Academic Alliance, I had access to a free copy of Windows 8 Pro I decided to take the great leap forward.
Build went smoothly, no problems until today when I had two BSODs within minutes of each other. The first while playing Bastion, and the second time while watching a youtube video. In both cases memory_management was cited.
All the requested files are attached, thank you for the assistance!
  • W7F_29-12-2012.zip
    W7F_29-12-2012.zip
  • RAMMon - SPD Info.txt
BugCheck 50, {fffff680403b2850, 0, fffff8038106ea73, 2}
Probably caused by : memory_corruption ( nt!MiDeleteAddressesInWorkingSet+134 )
Followup: MachineOwner
Please run memtest to check for RAM errors:
Memtest86+ - Advanced Memory...
Memtest86+ - Advanced Memory Diagnostic Tool
Run for 7/8 passes and on one stick at a time so errors aren't confused.
Checking your moBo's manufacturer's page I notice you have bios updates.
Also please update the following:
Broadcom Lan driver: ASRock > Z77 Extreme4
Realtek HiDef driver: Link Removed
You also have running a Xconnex or ViXs network hub or similar? I notice the drivers are from 2008 and really should be updated if possible.
