Windows 7 BSOD code 0x109, please help
redsiamesecat
hello,
im having this bsod when i playing at bluestacks (play android games on PC),well it sometimes happen, so i want to know the solution to stop the Bsod.
i already attach the W7F folder ( include cpu z SS , rammon on one zip)
thank you :o
(sorry bad english)
W7F_21-05-2013.zip
(cant upload using attachments, always failed)
There just aren't that many of us that do this - so it may take a while. I, for example, can only get online once a day - in the early morning in the Eastern Time Zone in the US.
Only 110 Windows Updates installed. Most systems have 160 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
SSD's were temperamental when they first came out, but their reliability has improved greatly over the last year or two. There are 2 things that MUST be checked on systems with BSOD's and SSD's:
1) That the SSD firmware is the latest available for the SSD
2) That the storage controller drivers on the motherboard are the most recent. They must date from late 2012 or later. This is ALL controllers, not just the one that the SSD is attached to.
Not much here that will let us nail it down. Try these free diagnostics: Link Removed
Please be sure to run the memory tests (MemTest86+; Prime95; and the 2 sets of video tests) as this sort of error is sometimes associated with bad memory.
AiCharger.sys Thu Sep 22 22:04:40 2011 (4E7BE938)
Asus Charger Driver [br] Likely BSOD cause - haven't seen recently (15Jan2013)
If the memory dumps continue (and you don't find any hardware problems) - please run Driver Verifier according to these instructions: Link Removed
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Tue May 21 06:24:05.178 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052113-9500-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 6:02:31.521[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]109, {a3a039d89ba6d918, b3b7465eee2514fa, fffff8800334c540, 3}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: a3a039d89ba6d918, Reserved
Arg2: b3b7465eee2514fa, Reserved
Arg3: fffff8800334c540, Failure type dependent information
Arg4: 0000000000000003, Type of corrupted region, can be
    0 : A generic data region
    1 : Modification of a function or .pdata
    2 : A processor IDT
    3 : A processor GDT
    4 : Type 1 process list corruption
    5 : Type 2 process list corruption
    6 : Debug routine modification
    7 : Critical MSR modification
BUGCHECK_STR:  0x109
PROCESS_NAME:  System
CPUID:        "Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz"
MaxSpeed:     2500
CurrentSpeed: [B]2494[/B]
  BIOS Version                  N46VZ.409
  BIOS Release Date             12/25/2012
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product Name                  N46VZ
[/font]
3rd Party Drivers:
intelppm.sys       Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys        Fri Mar 19 12:18:18 2010 (4BA3A3CA)
Rt64win7.sys       Tue Aug 23 09:55:41 2011 (4E53B15D)
atkwmiacpi64.sys   Tue Sep  6 21:44:52 2011 (4E66CC94)
[COLOR=RED][B]AiCharger.sys      Thu Sep 22 22:04:40 2011 (4E7BE938)[/B][/COLOR]
iaStor.sys         Tue Nov 29 22:39:19 2011 (4ED5A567)
igdkmd64.sys       Thu Jan  5 22:36:45 2012 (4F066C4D)
athrx.sys          Tue Jan 10 23:47:50 2012 (4F0D1476)
RtsBaStor.sys      Wed Feb  1 03:06:18 2012 (4F28F27A)
RTKVHD64.sys       Tue Feb 21 08:23:55 2012 (4F439AEB)
iusb3hub.sys       Mon May 21 03:21:36 2012 (4FB9ED00)
iusb3xhc.sys       Mon May 21 03:21:40 2012 (4FB9ED04)
iusb3hcs.sys       Mon May 21 03:23:42 2012 (4FB9ED7E)
HECIx64.sys        Mon Jul  2 18:14:58 2012 (4FF21D62)
btath_bus.sys      Tue Jul  3 07:06:55 2012 (4FF2D24F)
btath_lwflt.sys    Tue Jul  3 07:07:14 2012 (4FF2D262)
btath_avdt.sys     Tue Jul  3 07:07:18 2012 (4FF2D266)
btath_hcrp.sys     Tue Jul  3 07:09:01 2012 (4FF2D2CD)
btath_flt.sys      Fri Aug  3 07:09:44 2012 (501BB178)
btath_rcp.sys      Fri Aug 24 11:27:40 2012 (50379D6C)
AsusTP.sys         Mon Aug 27 01:11:32 2012 (503B0184)
btfilter.sys       Thu Sep 13 03:13:45 2012 (505187A9)
btath_a2dp.sys     Thu Sep 27 05:49:18 2012 (5064211E)
EpfwLWF.sys        Fri Dec 21 07:00:01 2012 (50D44F41)
epfw.sys           Fri Dec 21 07:00:05 2012 (50D44F45)
ehdrv.sys          Fri Dec 21 07:03:30 2012 (50D45012)
epfwwfp.sys        Tue Feb  5 03:21:12 2013 (5110C0F8)
eamonm.sys         Tue Feb  5 03:23:32 2013 (5110C184)
nvlddmkm.sys       Thu Mar 14 21:37:00 2013 (51427B3C)
nvpciflt.sys       Thu Mar 14 21:37:25 2013 (51427B55)
nvkflt.sys         Thu Mar 14 21:37:36 2013 (51427B60)
cpuz136_x64.sys    Wed Mar 20 07:05:43 2013 (51499807)
idmwfp.sys         Fri Apr  5 08:46:57 2013 (515EC7C1)
[/font]
AsusTP.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Analysis:
Arguments:
    2 : A processor IDT
    3 : A processor GDT
BUGCHECK_STR:  0x109
MaxSpeed:     2500
  Product Name                  N46VZ
[/font]
3rd Party Drivers:
[/font]
really thx for the answer, its still confusing me ...
well i already upgraded my ssd firmware before bsod happen , and..
its likely it started bsod after playing bluestacks, i dont know what causing it...
maybe compatibility issue or something, i already searched about bluestacks that causes bsod, but from my searching everyone that using bluestacks and bsod have different issue with me , i think its just me that get problem like this
is there any clue in my attachment that brought you to bluestacks causing error or something like that?
well when i bought ssd , i installed windows on it, and the update not all done i think,maybe that causing bsod
once again , thx for answering
I do not see a problem with bluestack.
Please run the free diagnostics at this link as the error is sometimes associated with bad hardware: Link Removed Please let us know the results of the tests.
Most often the error is associated with memory, so it's important to run MemTest86+, Prime95 and the video memory tests that are listed at the above link.
If the free diagnostics don't find a problem, then please run Driver Verifier according to these instructions: Link Removed
oh i forgot to tell you,when i make this thread and right now my virtual memory was set to "no paging file", is that okay ?
i make it like that bcuz i read at some ssd forum, paging file will make ur ssd die fast...
thx sir
I don't know that the lack of a paging file will increase the lifespan of your SSD.
But not having one probably won't cause the problems that we're seeing here.
I ran my system without a paging file for 6 months - and finally put one back on because a game I wanted to play demanded it.
well, it happen my laptop has low memory, the cause is bluestack + google chrome, SS below
actually i buy this laptop from my friend, that time he doesnt use ssd and everything fine..
and that time i even open battlefield 3 + google chrome, but low memory never happened..
then i buying ssd and install windows etc, then low memory happen, like i said b4 i set my virtual memory to no paging file, is it the cause of low memory ???
and i hv question, i already tried to update all windows update, but unfortunately there is some reccomended/important updates were failed, that time i googling to find out how to redownload failed update, then i see forum, someone posted that i hv to delete folder "SoftwareDistribution" on C:\Windows, yes its make my windows update like never updated, but when i tried to "check for updates" it doesnt load the failed update that i want to download again, so i looked on forum w7, im trying with something like .bat file,like script,yes it restarted the windows update again withouth having to delete "softwaredistribution" but the results is the same, there's no failed updates, instead of that there is just some like additional updates ( ex: internet explorer,etc )
can u help me solve this, like u said my windows updates seems lacking, i need all of the updates...
thx for ur help
You can test to see if Bluestack and Google Chrome need a paging file by making one (temporarily) and seeing if that stops the errors.
As for Windows Updates, I'm not real good with them. There are a couple of experts here: Windows Update Please read the pinned topic at the top of the forum BEFORE posting there.
