j0hanSE
- Joined
- Dec 1, 2011
- Messages
- 10
- Thread Author
- #1
Hi, i have getting random bsods since June this summer, after i upgrade memory from4gb to 16gb.
I have sent the new memories to return, so i get new ones, and the memory was defected.
But i still getting the BSOD!!!!!
The dmpfile says
Link RemovedLink RemovedLink Removed
Any idea what it can be?
i've tried to Load Optimized default in BiOS.
The dmpfile says
Crash dump file: C:\Windows\Minidump\120111-43773-01.dmp
Date/time: 2011-12-01 19:48:25 GMT
Uptime: 00:42:05
Machine:
Bug check name: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check code: 0xD1
Bug check parm 1: 0x912413CB
Bug check parm 2: 0x2
Bug check parm 3: 0x0
Bug check parm 4: 0xFFFFF8800599F9A5
Probably caused by: ntoskrnl.exe
Driver description: NT Kernel & System
Driver product: Microsoft® Windows® Operating System
Driver company: Microsoft Corporation
OS build: Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Architecture: x64 (64 bit)
CPU count: 4
Page size: 4096
Bug check description:
This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
Comments:
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
[FONT=Courier New, Courier, FixedSys]Crash dump file: C:\Windows\memory.dmp
Uptime: 00:42:05
Machine:
Probably caused by: stdriver64.sys
Driver description: stdriver.sys
Driver product: stdriver.sys
Driver company: NCH Software
CPU count: 4
Page size: 4096
Comments:
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: stdriver64.sys (stdriver.sys, NCH Software). [/FONT]
