Bsod DRIVER_IRQL_NOT_LESS_OR_EQUAL wfplwf.sys
I've been having trouble relating to multiple bug checks I get a bsod at least once a day if not 3-4 times it's very annoying and usually happens while gaming or closing a browser.
I have multiple zip files full of older dumps from last week in a thread i will link on seven forums. I've completed everything they've asked there so please don't ask me to do them again.
http://www.sevenforums.com/bsod-hel...random-crashes-0x00000004e-plenty-others.html
Another BSOD
Windows Forum Admin
BugCheck D1, {0, 6, 0, fffff8800f698c7e}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+1abc7e )
Followup: MachineOwner
the above dmp file is pointing to the gpu driver as the culprit but I suspect that as your Bios is so old that well could be the main issue:
BiosVersion = P1.50
BiosReleaseDate = 05/10/2012
Latest version stands at 2.80 and dated 7/23/2013. Please update:
http://www.asrock.com/mb/Intel/Z77 Extreme6/?cat=Download&os=BIOS
asahci64.sys Wed Sep 21 10:42:57 2011: Asmedia SATA3 driver. A later version is on the motherboard website:
http://www.asrock.com/mb/Intel/Z77 Extreme6/?cat=Download&os=Win764
AsrAppCharger.sys Tue May 10 09:28:46 2011: ASRock App Charger Likely BSOD cause. Uninstall to test.
A later version is on the web page posted above.
iaStor.sys Wed Nov 30 03:39:19 2011: Intel storage
igdkmd64.sys Mon Mar 19 23:31:54 2012: Intel Graphics
ISCTD64.sys Tue Aug 23 18:32:39 2011: Intel smart connect.
All these drivers and later versions are found in the above page.
k57nd60a.sys Tue May 10 05:42:30 2011: Broadcom Network driver. Please update:
LGBusEnum.sys Tue Nov 24 01:36:48 2009: Logitech keyboard. Please update:
http://www.logitech.com/en-us/support-downloads/downloads
nvlddmkm.sys Mon Nov 11 13:24:05 2013: GPU driver. Please uninstall using this app:
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html This will ensure nothing corrupt is left behind. Then re-install gpu driver:
http://www.nvidia.com/Download/index.aspx?lang=en-us
RTCore64.sys Tue Sep 06 13:24:50 2011: RivaTuner/EVGA Precision/MSI Afterburner (known BSOD issues w/Win7). Please uninstall to test.
RTKVHD64.sys Tue Jan 31 10:55:06 2012: Realtek High Definition Audio Function Driver. Please update:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=8&PFid=14&Level=3&Conn=2
vrtaucbl.sys Sun Apr 01 10:08:53 2012: Virtual audio cable. Update if possible:
http://www.ventrilo.com/download.php
WmVirHid.sys Tue Apr 27 21:08:53 2010: Logitech WingMan Virtual Hid Device Driver: Update if possible:
http://www.logitech.com/index.cfm/support_downloads/downloads/
WPRO_41_2001.sys Mon Nov 07 21:04:48 2011: CACE Technologies WinPcap Packet Driver. Update if possible:
http://www.winpcap.org/install/default.htm
Please post any further dmp files after updating the above.
Thanks a lot for the response, I've done almost everything you asked me to and i'll wait it out and see if i get anymore bsod's, I'll post the dmp if i do.
Windows Forum Admin
Thanks for updating.
