Windows 10 BSOD: driver_irql_not_less_or_equal ndis.sys
Quyeno
Hi
I've been get an ndis.sys BSOD the past few days. I've done a system file scan and no issues were found. I would really appreicate it someone could please debug my dump files? I've attached the 3 dump files from the past few days, the latest being today.
Thanks
Quyeno
  • minidump.rar
BugCheck D1, {28, 2, 0, fffff8010039e039}
*** WARNING: Unable to verify timestamp for e22w10x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e22w10x64.sys
Probably caused by : e22w10x64.sys ( e22w10x64+6cab )
Followup: MachineOwner
all three dump files were the same and point to your ethernet driver,
e22w10x64.sys Mon Apr 27 20:36:50 2015; Killer e2200 PCI-E Gigabit Ethernet Controller. Please update this driver using your motherboard support page. You will see its a slightly later version found in the windows 10 64bit section, at the top, called Bigfoot Lan driver.
GIGABYTE - Motherboard - Socket 1151 - GA-Z170X-Gaming 5 (rev. 1.0)
If you find the above driver doesnt seem to work then disable your anti virus, uninstall and then reinstall making sure the AV suite is disabled... I use the same driver so know some of its idiosyncrasies.
Please post any new dump files
Top Bottom
