Windows 7 BSOD every few hours
Yinning
Hi, I am getting BSOD every few hours of computer usage, and rather often recently. Attached is the info needed and I'd love any help. I'm not a heavy computer user, usually just surf net, facebook, youtube.
Thanks in advance!
There are some reports missing from the uploaded files. Please run the report collection app again and let it run for at least 15 minutes (or until the app itself says it's done).
Please ensure that you have ALL Windows Updates
If using a wireless USB networking device, please note this:
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more...
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
anodlwfx.sys Fri Mar 6 05:10:08 2009 (49B0F680)
ALPHA Networks Filter Driver
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics: Link Removed. Let us know the results and we can move on from there.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sat May  4 11:54:01.833 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050413-12714-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) UP Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:40:36.614[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )[/B]
BugCheck [B]1A, {41790, fffffa8009ba5370, ffff, 0}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
    contains the address of the PFN for the corrupted page table page.
    On a 32 bit OS, parameter 2 contains a pointer to the number of used
    PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa8009ba5370
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084[/B]
**************************Thu May  2 15:23:51.221 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050313-17269-01.dmp]
System Uptime:[B]0 days 0:43:39.002[/B]
*** WARNING: Unable to verify timestamp for Ntfs.sys
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by :[B]Ntfs.sys ( Ntfs+8c5c7 )[/B]
BugCheck [B]24, {1904fb, fffff88006999408, fffff88006998c60, fffff880012915c7}[/B]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88006999408
Arg3: fffff88006998c60
Arg4: fffff880012915c7
PROCESS_NAME:  System
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_0x24_Ntfs+8c5c7[/B]
**************************Thu May  2 14:39:32.769 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050313-12979-01.dmp]
System Uptime:[B]0 days 0:01:48.550[/B]
Probably caused by :[B]win32k.sys ( win32k+c79ec )[/B]
BugCheck [B]3B, {c0000005, fffff960001979ec, fffff88007a96ea0, 0}[/B]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff960001979ec, Address of the instruction which caused the bugcheck
Arg3: fffff88007a96ea0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  MUIStartMenu.e
FAILURE_BUCKET_ID: [B]X64_0x3B_win32k+c79ec[/B]
**************************Wed May  1 08:29:48.401 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050113-13150-01.dmp]
System Uptime:[B]0 days 0:06:41.182[/B]
BugCheck [B]1A, {41790, fffffa800acc17c0, ffff, 0}[/B]
Arguments:
Arg2: fffffa800acc17c0
PROCESS_NAME:  conhost.exe
**************************Wed May  1 08:22:22.239 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050113-17472-01.dmp]
System Uptime:[B]0 days 0:00:54.019[/B]
BugCheck [B]1A, {41790, fffffa800acc17f0, ffff, 0}[/B]
Arguments:
Arg2: fffffa800acc17f0
PROCESS_NAME:  Dropbox.exe
**************************Mon Apr 29 11:51:24.989 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042913-15178-01.dmp]
System Uptime:[B]0 days 0:02:02.770[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+13702 )[/B]
BugCheck [B]1A, {41201, fffff680001ed040, 3f, fffffa800cf8e6a0}[/B]
Arguments:
Arg1: 0000000000041201, The subtype of the bugcheck.
Arg2: fffff680001ed040
Arg3: 000000000000003f
Arg4: fffffa800cf8e6a0
BUGCHECK_STR:  0x1a_41201
FAILURE_BUCKET_ID: [B]X64_0x1a_41201_nt!_??_::FNODOBFM::_string_+13702[/B]
**************************Fri Apr 26 10:32:42.566 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042613-15584-01.dmp]
System Uptime:[B]0 days 0:03:20.347[/B]
BugCheck [B]1A, {41790, fffffa8009ba53d0, ffff, 0}[/B]
Arguments:
Arg2: fffffa8009ba53d0
PROCESS_NAME:  wermgr.exe
**************************Wed Apr 24 02:52:24.620 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042413-18501-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
System Uptime:[B]0 days 0:01:07.400[/B]
Probably caused by :[B]memory_corruption ( nt!MiAgeWorkingSet+425 )[/B]
BugCheck [B]50, {fffffb4c0ace8cbb, 0, fffff800034c17bf, 7}[/B]
Arguments:
Arg1: fffffb4c0ace8cbb, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800034c17bf, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000007, (reserved)
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_nt!MiAgeWorkingSet+425[/B]
[/FONT]
3rd Party Drivers:
[B]anodlwfx.sys                Fri Mar  6 05:10:08 2009 (49B0F680)[/B]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
tap0901.sys                 Fri Dec 11 18:48:03 2009 (4B22DA33)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
ew_jubusenum.sys            Fri Apr  9 03:24:31 2010 (4BBED62F)
IntcDAud.sys                Fri Oct 15 04:28:17 2010 (4CB810A1)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
asahci64.sys                Wed Mar 23 03:36:15 2011 (4D89A2EF)
Dnetr28ux.sys               Thu Apr 28 02:18:18 2011 (4DB906AA)
asmtxhci.sys                Wed Jun  1 22:27:46 2011 (4DE6F522)
asmthub3.sys                Wed Jun  1 22:27:58 2011 (4DE6F52E)
igdkmd64.sys                Sun Jun 26 21:55:42 2011 (4E07E31E)
Rt64win7.sys                Tue Aug 23 09:55:41 2011 (4E53B15D)
RTKVHD64.sys                Thu Aug 25 22:51:31 2011 (4E570A33)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
[/FONT]
