Quite a few problems with most of your games (Civ5, Rome Total War, Napolean etc.)(Steam) -
might wanna check the hardware specs for those games and make sure you've got hardware good enough to play them properly.
Also check that your DirectX and Video Drivers are up to date.
purendis.sys Tue Oct 28 15:31:28 2008 (490695A0)
Pure Networks, Inc. Network Magic NDIS Relay Driver
http://www.carrona.org/drivers/driver.php?id=purendis.sys
pnarp.sys Tue Oct 28 16:57:00 2008 (4906A9AC)
Pure Networks, Inc. Network Magic Address Resolution Protocol Driver
http://www.carrona.org/drivers/driver.php?id=pnarp.sys
See if you can uninstall or update these drivers to the latest.
You've also got HotSpot shield running - I recommend removing this (it's really useless if you have a competent AV (MSE, McAfee, Avast etc))
Looking at your dump files:
Problem with Google Chrome (and possibly any other browsers you're using):
Try clearing your cache with all your browsers.
Several problems coming from nwifi.sys (your native wifi driver). I'd probably update it to the latest version (check your motherboard/NIC manufacturer's website for updates).
To update the driver:
Use Driver Sweeper (download here:
Guru3D - Driver Sweeper) to remove all related files to the current driver.
Download and install a fresh copy of the driver.
[COLOR=#ff0000]purendis.sys Tue Oct 28 15:31:28 2008 (490695A0)[/COLOR]
[COLOR=#ff0000]pnarp.sys Tue Oct 28 16:57:00 2008 (4906A9AC)[/COLOR]
netr28x.sys Fri Jun 19 17:56:06 2009 (4A3B4496)
ASACPI.sys Thu Jul 16 13:31:29 2009 (4A5E9F11)
AtiPcie.sys Mon Aug 24 18:25:26 2009 (4A924E76)
amdxata.sys Sat Mar 20 03:18:18 2010 (4BA3A3CA)
AsIO.sys Tue Aug 24 11:53:02 2010 (4C7325FE)
ASFLTDrv64.sys Thu Sep 16 18:30:49 2010 (4C91D5B9)
VDiskBus64.sys Tue Sep 21 13:22:53 2010 (4C98250D)
SmartDefragDriver.sys Fri Nov 26 20:29:40 2010 (4CEF7E04)
Rt64win7.sys Fri Jun 10 16:33:15 2011 (4DF1BAAB)
UrlFilter.sys Fri Sep 16 17:46:34 2011 (4E72FEDA)
hardlock.sys Fri Sep 23 19:35:18 2011 (4E7C52D6)
asmtxhci.sys Thu Nov 3 14:00:22 2011 (4EB203C6)
asmthub3.sys Thu Nov 3 14:00:32 2011 (4EB203D0)
aksdf.sys Mon Nov 21 22:09:56 2011 (4ECA3184)
FileMonitor.sys Thu Jan 5 21:03:38 2012 (4F05757A)
aksfridge.sys Mon Apr 16 22:43:45 2012 (4F8C1401)
GEARAspiWDM.sys Fri May 4 05:56:17 2012 (4FA2E2E1)
RTKVHD64.sys Tue Jun 19 18:50:56 2012 (4FE03D70)
regfilter.sys Thu Jul 5 13:05:41 2012 (4FF50485)
SCDEmu.SYS Fri Aug 17 14:19:38 2012 (502DC65A)
nvhda64v.sys Wed Dec 19 16:41:41 2012 (50D15395)
[COLOR=#0000ff]hssdrv6.sys Fri Feb 22 12:43:02 2013 (5126CD26)[/COLOR]
nvlddmkm.sys Fri Mar 15 12:37:00 2013 (51427B3C)
Drivers in red: Update.
Drivers in blue: Remove (if possible)
