idk what to do...i'm so tierd of these bsod's, sometimes i think about throwing away my pc.
please help me if u can
.View attachment W7F_01-02-2013.rar
[FONT=Lucida Console]3: kd> [B]!errrec fffffa80062e28f8[/B]
Common Platform Error Record @ fffffa80062e28f8
Record Id : 01ce0001b5ef57a6
Severity : Fatal (1)
Length : 928
Creator : Microsoft
Notify Type : Machine Check Exception
Timestamp : 1/31/2013 22:24:35
Flags : 0x00000002 PreviousError
Section 0 : Processor Generic
Descriptor @ fffffa80062e2978
Section @ fffffa80062e2a50
Offset : 344
Length : 192
Flags : 0x00000001 Primary
Severity : Fatal
Proc. Type : x86/x64
Instr. Set : x64
Error Type : BUS error
Operation : Generic
Flags : 0x00
Level : 0
CPU Version : 0x000000000001067a
Processor ID : 0x0000000000000000
Section 1 : x86/x64 Processor Specific
Descriptor @ fffffa80062e29c0
Section @ fffffa80062e2b10
Offset : 536
Length : 128
Flags : 0x00000000
Severity : Fatal
Local APIC Id : 0x0000000000000000
CPU Id : 7a 06 01 00 00 08 04 00 - 9d e3 08 0c ff fb eb bf
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0 @ fffffa80062e2b10
Section 2 : x86/x64 MCA
Descriptor @ fffffa80062e2a08
Section @ fffffa80062e2b90
Offset : 664
Length : 264
Flags : 0x00000000
Severity : Fatal
Error : [COLOR="#FF0000"]BUSL0_SRC_ERR_M_NOTIMEOUT_ERR (Proc 0 Bank 0)[/COLOR]
Status : [COLOR="#FF0000"]0xf200084000000800[/COLOR][/FONT]
Vir Gnarus said:Error : BUSL0_SRC_ERR_M_NOTIMEOUT_ERR (Proc 0 Bank 0)
Status: 0xf200084000000800
In this example, the error is BUSL0_SRC_ERR_M_NOTIMEOUT_ERR, which means that the L0 cache memory on a processor suffered a generic non-timeout-related error while something was trying to access data in it. The source of the requested operation was the processor itself. This helpfully provides the exact processor number (Proc 0) and memory bank (Bank 0) for multi-core/multi-cpu systems to further diagnose.
To decipher the mnemonics presented in the error message, consult the CPU developer manual associated with the CPU installed in the offending system. For Intel CPUs, it's in Intel 64 and IA-32 Architectures Software Developer's Manual Volume 3: System Programming Guide (for 64-bit of course), and the tables for the mnemonics are located in section 15.9.2 (that's chapter 15, section 9, subsection 2). While Intel and AMD CPUs present their errors differently, typically the mnemonics are the same.
Start with these free diagnostics: Hardware Diagnostics
Post back with the results and we can move on from there.
While not really bad, 87ºC isn't all that good. Check the cooling on your video card (to include the airflow to the card).
Let's see what the other tests show us.
Open up the case and point a house fan into it.
See if that decreases the frequency of the BSOD's
