Windows 10 BSOD Issue
SirSmith
Hey, Im curious if anyone could help me on this issue. Ever since i built my PC ive been having this problem with multiple different bsod's here is the error message from the Event Viewer
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000124 (0x0000000000000000, 0xffffc285cac40028, 0x00000000b2000000, 0x0000000000030005). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 5297de64-0c52-47cc-a1ff-1e8cb1a0e915.
Ive looked for a solution and have tried many different things but haven't found a fix and am trying to avoid getting new hardware to see if something internal is the reason for this. Any and all help is appreciated
HI
HI First, move your structure to the table.
Then check the functionality of your device, that is, you will get some image on the screen Then ?
Top Bottom
