Ryan Plant
I've been getting a couple of blue screens over the past couple of weeks but I don't know how I should go about fixing them. I've recently restored my computer to factory settings. I didn't have my driver disk though so I just deleted all my partitions and installed windows 7 from there. From that point I installed what I thought was all the drivers I needed but i've been getting a lot of random shut downs, as well as blue screens for memory management.
Attached is the dump for the blue screen, screen shots for the CPU-z and RAMMon.
  • SF_11-06-2013.rar
    SF_11-06-2013.rar
  • RAMMon - SPD Info.txt
Hi -
The 7 dumps indicate unknown hardware failure, possibly RAM.
Unknown_Image & Unknown_Module should not be seen in dumps -- it should be a driver name:
[FONT=lucida console]
BugCheck 1A, {5003, fffff70001080000, 9ea, 9ec000013d5}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2984f )
[FONT=Lucida Console]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨``[/FONT]
BugCheck 1E, {ffffffffc00000fd, fffff80002b106e4, 0, a243b00}
Probably caused by : ntkrnlmp.exe ( nt!KiDispatchException+348 )
BugCheck 1A, {5100, fffff6fc50008700, 1, 1}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+aed7 )...
Hi -
BugCheck 1E, {0, 0, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )
BugCheck 1E, {ffffffffc0000005, fffff80002b006f8, 0, ffffffffffffffff}
Probably caused by : memory_corruption ( nt!MiIssueHardFault+64 )
BugCheck 3B, {c000001d, fffff80002da42af, fffff8800ac65eb0, 0}
Probably caused by : Unknown_Image ( Unknown_Module_fffffa80_0547c8c0+f0c0d0 )
BugCheck 1E, {ffffffffc0000005, fffff80002a74eb4, 0, ffffffffffffffff}
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+2f4 )
¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨`[/FONT]
The others contain exception error codes such as 0xc0000005 = memory access violation & 0xc000001d = illegal program instruction, e.g., division by zero
2 dumps had Bugcheck 0x1a = memory management error
Run memtest86+, one stick at a time; alternate the slots -
http://www.sysnative.com/forums/hardware-tutorials/3909-test-ram-memtest86.html
Regards. . .
jcgriff2
So I ran that program overnight, no errors showed up for any of my RAM sticks. I'm wondering if I installed a driver that I don't need or something.
