BSOD occured randomly.
Hi, I need some support as to my BSOD errors.
They happen randomly; ran driver verification tool but could not find the bad driver. :/
Had a PSU problem before; bought a new PSU and that was fixed.
Monitor connected by HDMI if it makes any difference.
SPECS:
A/V: ESET NOD32
Firewall: Windows 7 Firewall
Dump files posted below.
Thanks in advance.
View attachment DUMPFILES.rar
zigzag3143
Honorable Member
Microsoft MVP
Three of 4 driver verified and Related to tcp/ipreg.sys TCP/IP Registry Compatibility Driver from Microsoft Corporation. Part of the OS you should start by running a system file check to verify and repair OS files.
Run a system file check to verify and repair your system files.
To do this type cmd in search, then right click to run as administrator, then
SFC /SCANNOW
Read here for more information SFC /SCANNOW Command - System File Checker - Windows 7 Forums
Let us know the results from the report at the end.
If that doesnt fix it you may need to restore or do a repair install.
SFC /scannow ran in elevated command prompt doesn't work. :C
Verification 6% complete.
Windows Resource Protection could not perform the requested operation.
TT^TT, so its repair install now?
zigzag3143
Honorable Member
Microsoft MVP
Probably but just to be sure can you download malwarebytes and run it (just in case).
Dam, can't upgrade :C I have the Windows 7 Disc w/o SP1...
Malwarebytes ran.
zigzag3143
Honorable Member
Microsoft MVP
You have win 7 dvd without SP-1? whats on your system? you can do a repair install with win 7 sp-0 then upgrade it to sp-1 I think.
kaos
#7
Yes , you can :)
nmsuk
Windows Forum Admin
#8
I'm going to see if I can rustle up a guide for slipstreaming service packs using WAIK or 7Lite. I think it could be useful
