Leo123
I'm having this BSOD after formating my laptop and installing some softwares later. I included all the dumps created by W7 tool and upload it here. The softwares I'm using is McAfee Antivirus, Nero, Chrome,Firefox,Ccleaner, Virtualbox, Foxit.
Dump File : 022213-16660-01.dmp
Crash Time : 2/22/2013 7:59:12 PM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 00000000`00000000
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000000
Parameter 4 : fffff800`02ee4662
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\022213-16660-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 319,035
Only 2 Windows Updates installed. Most systems have 140 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
This network device isn't installed. Please install it:
Network Controller PCI\VEN_10EC&DEV_8176&SUBSYS_818110EC&REV_01\4&1FB97B6B&0&00E5 The drivers for this device are not installed.
I suspect the Windows Updates are the problem here - but it could also be several different drivers (listed below).
I also suspect your McAfee. Please do the following:
Anti-Virus Removal:
- download a free anti-virus for testing purposes: Link Removed If using Windows 8, enable Windows Defender...
Anti-Virus Removal:
- download a free anti-virus for testing purposes: Link Removed If using Windows 8, enable Windows Defender and the Windows Firewall instead.
- un-install the McAfee from your system (you can reinstall it, if so desired, when we're done troubleshooting)
- remove any remnants of McAfee using this free tool: Link Removed (This link has changed a lot. If it doesn't work, search for McAfee Consumer Products Removal Tool)
- IMMEDIATELY install and update the free anti-virus (if using Win8, enable Windows Defender), then check to ensure that the Windows Firewall is turned on.
- perform a full system scan to ensure that no malware has snuck onto your system while the anti-virus was malfunctioning.
- check to see if this fixes the BSOD's
NOTE: NEVER run more than 1 anti-virus, firewall, Internet Security/Security Center application at the same time.
QIOMem.sys Mon Jun 15 01:58:48 2009 (4A35E318)
TOSHIBA Generic IO & Memory Access
tos_sps64.sys Wed Jun 24 01:31:09 2009 (4A41BA1D)
Toshiba tos_sps64 Service
TVALZ_O.SYS Mon Jul 13 22:19:26 2009 (4A5BEB2E)
TOSHIBA ACPI-Based Value Added Logical and General Purpose Device Driver
If none of this works, please run Driver Verifier according to these instructions: Link Removed
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Fri Feb 22 06:58:46.499 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022213-16660-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17514.amd64fre.win7sp1_rtm.101119-1850
System Uptime:[B]0 days 0:05:06.795[/B]
Probably caused by :[B]Unknown_Image ( nt!KiSignalSynchronizationObject+42 )[/B]
BugCheck [B]A, {0, 2, 0, fffff80002ee4662}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002ee4662, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
[/font]
3rd Party Drivers:
[COLOR=RED][B]QIOMem.sys         Mon Jun 15 01:58:48 2009 (4A35E318)[/B][/COLOR]
[COLOR=RED][B]tos_sps64.sys      Wed Jun 24 01:31:09 2009 (4A41BA1D)[/B][/COLOR]
intelppm.sys       Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]TVALZ_O.SYS        Mon Jul 13 22:19:26 2009 (4A5BEB2E)[/B][/COLOR]
amdxata.sys        Fri Mar 19 12:18:18 2010 (4BA3A3CA)
L1C62x64.sys       Mon Sep 27 02:36:23 2010 (4CA03B67)
IntcDAud.sys       Fri Oct 15 04:28:17 2010 (4CB810A1)
HECIx64.sys        Tue Oct 19 19:33:43 2010 (4CBE2AD7)
pgeffect.sys       Sun Jan 16 21:09:10 2011 (4D33A4C6)
ew_jubusenum.sys   Sun Jan 30 05:19:33 2011 (4D453B35)
SynTP.sys          Thu Feb  3 21:59:28 2011 (4D4B6B90)
ewusbmdm.sys       Tue May  3 03:42:40 2011 (4DBFB1F0)
iaStor.sys         Fri May 20 12:52:24 2011 (4DD69C48)
ewusbwwan.sys      Tue May 31 07:41:34 2011 (4DE4D3EE)
CHDRT64.sys        Thu Jul  7 03:02:12 2011 (4E1559F4)
igdkmd64.sys       Wed Aug 31 15:53:13 2011 (4E5E9129)
HipShieldK.sys     Fri Apr 20 17:32:16 2012 (4F91D5E0)
mfehidk.sys        Tue Dec 18 19:25:11 2012 (50D10967)
mfewfpk.sys        Tue Dec 18 19:25:26 2012 (50D10976)
mfeapfk.sys        Tue Dec 18 19:25:52 2012 (50D10990)
mfeavfk.sys        Tue Dec 18 19:26:11 2012 (50D109A3)
mfefirek.sys       Tue Dec 18 19:27:59 2012 (50D10A0F)
cfwids.sys         Tue Dec 18 19:28:32 2012 (50D10A30)
VBoxNetFlt.sys     Wed Dec 19 08:47:16 2012 (50D1C564)
VBoxNetAdp.sys     Wed Dec 19 08:47:17 2012 (50D1C565)
VBoxUSBMon.sys     Wed Dec 19 08:47:17 2012 (50D1C565)
VBoxDrv.sys        Wed Dec 19 08:48:25 2012 (50D1C5A9)
[/font]
ewusbwwan.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Thanks for your reply and recommendations usasma, I'm going to uninstall McAfee now and follow your suggestions, I scan it using TDSKiller and Windows Defender offline but no malware detected.
