BSOD randomly, no rules!!
hi guys,
im from croatia and i have a large issue with a new computer...
month ago, i bought a new computer, new components except the old ati graphics 3850 512 mb...
my components are these and its my personal build:
intel core i5 2500 3,3ghz
asrock pro3 p67 B3 chipset (so the new revision, i had the old one with the buggy chipset now i have the new with B3 chipset)
4 gb of RAM corsair1600 mhz
1tb samsung spinpoint f3
corsair 550 w
my cpu z prtscr are below with the minidump.zip!
the computer works great, except the BSOD that i thought they will be gone affter i changed my asrock pro 3 with buggy sata chipset with the new revision asrock motherboard pro 3 p67. but no, the BSOD are still happening...
there is no rule, it can work for 10 hours in a row and nothing can happen or it can go wild and display the BSOD 10 times in a row, after each reset... the BSOD that happened to me not 20 minutes ago are theese in the minidump folder...
if anyone can give me an advice what to do, i will be gratefull!!
also, the problems that are occuring me, this happens before the BSOD and when it happens i know in a couple of minutes the BSOD is gonna occure... its this..
im surfing the web, and suddenly, the AERO theme changes to normal nontransparent theme and there is a sound coming out from the speakers, its a windows 7 start up sound! then after a couple of minutes it changes back to aero!! and after that the BSOD can come up, or maybe not, there is no strict rule!!
i have genuine windows 7 professional edition, i did not make any update because i formated my disk not 2 days ago and im scared if i do so, the BSOD will even more pop out!!
anyone,please help
niksa , croatia!!
TNX
Something's not right with your RAM. Give me this stuff:
1) CPU-Z memory and CPU tabs snips
2) Rammon HTML report
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
Update drivers:
FNet User Proxy
FNETURPX.SYS Fri Oct 03 22:27:02 2008
ATI
atikmdag.sys Fri Apr 24 06:51:57 2009
CRASH DUMPS
Loading Dump File [F:\DMP\032511-15522-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`0285a000 PsLoadedModuleList = 0xfffff800`02a97e50
Debug session time: Fri Mar 25 11:42:08.674 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:18.938
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 34, {50830, fffff88005456408, fffff88005455c60, fffff800028d7170}
Probably caused by : ntkrnlmp.exe ( nt!ObFastReferenceObject+10 )
Followup: MachineOwner
1: kd> !analyze -v
CACHE_MANAGER (34)
    See the comment for FAT_FILE_SYSTEM (0x23)
Arguments:
Arg1: 0000000000050830
Arg2: fffff88005456408
Arg3: fffff88005455c60
Arg4: fffff800028d7170
Debugging Details:
EXCEPTION_RECORD:  fffff88005456408 -- (.exr 0xfffff88005456408)
ExceptionAddress: fffff800028d7170 (nt!ObFastReferenceObject+0x0000000000000010)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000040
Attempt to read from address 0000000000000040
CONTEXT:  fffff88005455c60 -- (.cxr 0xfffff88005455c60)
rax=0000000000000010 rbx=0000000000000010 rcx=0000000000000040
rdx=0000000000000022 rsi=fffff8a001d12810 rdi=0000000000000040
rip=fffff800028d7170 rsp=fffff88005456640 rbp=fffff880054568d0
 r8=fffffa8004c488cf  r9=fffffa800612fb60 r10=000000000000000f
r11=34b000011c6f5921 r12=fffffa8006192350 r13=fffffa800619f7c0
r14=0000000fffffffff r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
nt!ObFastReferenceObject+0x10:
fffff800`028d7170 4c8b01          mov     r8,qword ptr [rcx] ds:002b:00000000`00000040=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000040
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002b020e0
 0000000000000040
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR:  0x34
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
LAST_CONTROL_TRANSFER:  from fffff8000293bd49 to fffff800028d7170
STACK_TEXT:
fffff880`05456640 fffff800`0293bd49 : 00000000`00000008 00000000`00000010 fffff8a0`01d12808 fffffa80`0620a6f8 : nt!ObFastReferenceObject+0x10
fffff880`05456670 fffff800`028e8e6f : fffff6fc`c0035680 00000000`00000001 fffff880`00000010 ffffffff`ffffffff : nt! ?? ::FNODOBFM::`string'+0x2a34d
fffff880`054567e0 fffff800`0291080e : fffff980`06ac0000 00000000`000c9000 00000000`00000000 00000000`00000005 : nt!MmCheckCachedPageStates+0x3ef
fffff880`05456990 fffff800`02b300ce : 00000000`00100000 00000000`00100000 00000000`000c9000 00000000`00040001 : nt!CcFetchDataForRead+0x10e
fffff880`054569f0 fffff800`0287cb2c : fffffa80`03c9db30 00000000`00100000 00000000`00040000 fffff800`02a6f501 : nt!CcMapAndCopyFromCache+0xba
fffff880`05456a90 fffff800`028bfdb6 : fffffa80`06192350 00000000`00000000 fffff800`00000005 fffff800`02bb2201 : nt!CcPerformReadAhead+0x3b8
fffff880`05456bc0 fffff800`028d9161 : fffffa80`03cd5d60 fffff800`028bfb98 fffff800`02ad1150 00000000`00000002 : nt!CcWorkerThread+0x21e
fffff880`05456c70 fffff800`02b6f166 : 00000000`0387ee39 fffffa80`0612fb60 00000000`00000080 fffffa80`03cb8040 : nt!ExpWorkerThread+0x111
fffff880`05456d00 fffff800`028aa486 : fffff880`009e9180 fffffa80`0612fb60 fffffa80`04ba7b60 fffff880`0124fa90 : nt!PspSystemThreadStartup+0x5a
fffff880`05456d40 00000000`00000000 : fffff880`05457000 fffff880`05451000 fffff880`054566a0 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ObFastReferenceObject+10
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc600
STACK_COMMAND:  .cxr 0xfffff88005455c60 ; kb
FAILURE_BUCKET_ID:  X64_0x34_nt!ObFastReferenceObject+10
Loading Dump File [F:\DMP\032411-17206-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02815000 PsLoadedModuleList = 0xfffff800`02a52e50
Debug session time: Thu Mar 24 11:41:51.598 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:31.520
BugCheck 1A, {41790, fffffa80014449e0, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+339d6 )
1: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041790, The subtype of the bugcheck.
Arg2: fffffa80014449e0
Arg3: 000000000000ffff
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  dllhost.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff800028f926e to fffff80002886f00
STACK_TEXT:
fffff880`0678f928 fffff800`028f926e : 00000000`0000001a 00000000`00041790 fffffa80`014449e0 00000000`0000ffff : nt!KeBugCheckEx
fffff880`0678f930 fffff800`028c8c4a : 00000000`00000000 00000000`0381afff fffffa80`00000000 fffffa80`04d08b30 : nt! ?? ::FNODOBFM::`string'+0x339d6
fffff880`0678faf0 fffff800`02886153 : ffffffff`ffffffff 00000000`0263d330 00000000`0263d2f8 ffffffff`00008000 : nt!NtFreeVirtualMemory+0x5ca
fffff880`0678fbe0 00000000`7753009a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0263d268 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7753009a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`028f926e cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+339d6
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+339d6
Loading Dump File [F:\DMP\032411-19063-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02858000 PsLoadedModuleList = 0xfffff800`02a95e50
Debug session time: Thu Mar 24 11:36:49.014 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:15.310
BugCheck 3B, {c0000005, fffff800029fbf8c, fffff88005f2dea0, 0}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+100 )
Followup: Pool_corruption
1: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800029fbf8c, Address of the instruction which caused the bugcheck
Arg3: fffff88005f2dea0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`029fbf8c 4c8b02          mov     r8,qword ptr [rdx]
CONTEXT:  fffff88005f2dea0 -- (.cxr 0xfffff88005f2dea0)
rax=fffff8a005b73000 rbx=0000000000000000 rcx=fffff8a005f72b40
rdx=0000018002580320 rsi=fffff8a005b73000 rdi=fffff8a005f66010
rip=fffff800029fbf8c rsp=fffff88005f2e880 rbp=000000000000000e
 r8=0000018002580320  r9=0000000000000000 r10=fffff8a005f76b40
r11=0000000000000000 r12=fffffa8003c493c0 r13=0000000000000000
r14=000000000000000f r15=0000000000000001
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
nt!ExDeferredFreePool+0x100:
fffff800`029fbf8c 4c8b02          mov     r8,qword ptr [rdx] ds:002b:00000180`02580320=????????????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800029fbf8c
STACK_TEXT:
fffff880`05f2e880 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExDeferredFreePool+0x100
FOLLOWUP_IP:
SYMBOL_NAME:  nt!ExDeferredFreePool+100
FOLLOWUP_NAME:  Pool_corruption
IMAGE_NAME:  Pool_Corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: Pool_Corruption
STACK_COMMAND:  .cxr 0xfffff88005f2dea0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!ExDeferredFreePool+100
Loading Dump File [F:\DMP\032511-16614-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0285b000 PsLoadedModuleList = 0xfffff800`02a98e50
Debug session time: Fri Mar 25 11:48:01.911 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:55.176
BugCheck 4E, {99, 120993, 3, 11fa0a}
Probably caused by : memory_corruption ( nt!MiBadShareCount+4c )
3: kd> !analyze -v
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc).  If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000120993, page frame number
Arg3: 0000000000000003, current page state
Arg4: 000000000011fa0a, 0
Debugging Details:
BUGCHECK_STR:  0x4E_99
PROCESS_NAME:  WmiPrvSE.exe
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff8000295b32c to fffff800028ccf00
STACK_TEXT:
fffff880`03a2c0b8 fffff800`0295b32c : 00000000`0000004e 00000000`00000099 00000000`00120993 00000000`00000003 : nt!KeBugCheckEx
fffff880`03a2c0c0 fffff800`02882545 : 00000000`00000000 fffff680`00001758 00000000`00000002 00000000`00000001 : nt!MiBadShareCount+0x4c
fffff880`03a2c100 fffff800`028a1493 : fffffa80`0519ab30 fffff700`00000669 0000007f`fffffff8 fffff8a0`05f9b468 : nt! ?? ::FNODOBFM::`string'+0x322ac
fffff880`03a2c190 fffff800`0289feee : fffffa80`0519ab30 fffffa80`00000007 00000000`000001bc fffff800`00000000 : nt!MiDeleteAddressesInWorkingSet+0x307
fffff880`03a2ca40 fffff800`02baf7af : fffff8a0`025f7af0 00000000`00000001 00000000`00000000 fffffa80`06404450 : nt!MmCleanProcessAddressSpace+0x96
fffff880`03a2ca90 fffff800`02b88cb8 : 00000000`00000000 00000000`00000001 000007ff`fffde000 00000000`00000000 : nt!PspExitThread+0x47f
fffff880`03a2cb60 fffff800`028cc153 : fffffa80`0519ab30 fffff880`00000000 fffffa80`06404450 fffffa80`04f9ec70 : nt!NtTerminateProcess+0x138
fffff880`03a2cbe0 00000000`7789017a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`001cfd18 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7789017a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`0295b32c cc              int     3
SYMBOL_NAME:  nt!MiBadShareCount+4c
MODULE_NAME: nt
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x4E_99_nt!MiBadShareCount+4c
DRIVERS
fffff880`00f27000 fffff880`00f7e000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cc1000 fffff880`02d4b000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06a00000 fffff880`06a16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00dd1000 fffff880`00ddc000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`03944000 fffff880`0394f000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00d9e000 fffff880`00da7000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00da7000 fffff880`00dd1000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`06a23000 fffff880`06f45000   atikmdag atikmdag.sys Fri Apr 24 06:51:57 2009 (49F199CD)
fffff880`01927000 fffff880`0192e000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`069e2000 fffff880`069f3000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02508000 fffff880`02526000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`0757a000 fffff880`075a4000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cc4000 fffff880`00d84000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0188e000 fffff880`018be000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c66000 fffff880`00cc4000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01114000 fffff880`01187000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`06fde000 fffff880`06fee000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`07471000 fffff880`0747f000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`06941000 fffff880`069c4000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`069c4000 fffff880`069e2000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`06932000 fffff880`06941000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01878000 fffff880`0188e000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0743d000 fffff880`0745f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02c00000 fffff880`02c43000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 03:27:08 2011 (4D2EB75C)
fffff880`0748b000 fffff880`07494000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0747f000 fffff880`0748b000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`07494000 fffff880`074a7000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`07465000 fffff880`07471000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`07285000 fffff880`07379000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`07379000 fffff880`073bf000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`07559000 fffff880`07562c00   EtronHub3 EtronHub3.sys Fri Jan 28 16:46:45 2011 (4D433945)
fffff880`07267000 fffff880`07276c00   EtronXHCI EtronXHCI.sys Fri Jan 28 16:46:43 2011 (4D433943)
fffff880`07277000 fffff880`07284000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`010a2000 fffff880`010b6000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01056000 fffff880`010a2000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01821000 fffff880`0182e000   FNETTBOH_305 FNETTBOH_305.SYS Wed Nov 03 02:24:26 2010 (4CD1001A)
fffff880`0192e000 fffff880`01937000   FNETURPX FNETURPX.SYS Fri Oct 03 22:27:02 2008 (48E6D476)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0183e000 fffff880`01878000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01187000 fffff880`011d1000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02812000 fffff800`0285b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`073bf000 fffff880`073e3000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`075a4000 fffff880`07600000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`073e3000 fffff880`073f4000   HECIx64  HECIx64.sys  Tue Oct 19 19:33:43 2010 (4CBE2AD7)
fffff880`02ca8000 fffff880`02cc1000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`069f3000 fffff880`069fb080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`02c9a000 fffff880`02ca8000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02440000 fffff880`02508000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`014b5000 fffff880`014be000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`06f9b000 fffff880`06fb9000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06fc8000 fffff880`06fde000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`06fb9000 fffff880`06fc8000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b9a000 fffff800`00ba4000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`074aa000 fffff880`074ed000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:50:34 2009 (4A5BC84A)
fffff880`0745f000 fffff880`07464200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`018d9000 fffff880`018ee000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`019dc000 fffff880`019ff000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c0e000 fffff880`00c52000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`02c8c000 fffff880`02c9a000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`068b5000 fffff880`068c4000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`02deb000 fffff880`02df8000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d84000 fffff880`00d9e000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02526000 fffff880`0253e000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0253e000 fffff880`0256a000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`0256a000 fffff880`025b7000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`025b7000 fffff880`025da000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`01995000 fffff880`019a0000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f87000 fffff880`00f91000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010b6000 fffff880`01114000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`06927000 fffff880`06932000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`014a3000 fffff880`014b5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014ca000 fffff880`015bc000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06a16000 fffff880`06a22000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0684a000 fffff880`06879000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`07565000 fffff880`0757a000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02dbf000 fffff880`02dce000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d4b000 fffff880`02d90000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`019a0000 fffff880`019b1000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0691b000 fffff880`06927000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0285b000 fffff800`02e38000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`0125b000 fffff880`013fe000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0191e000 fffff880`01927000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02d99000 fffff880`02dbf000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fd1000 fffff880`00fe6000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f91000 fffff880`00fc4000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e63000 fffff880`00e73000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`02889000 fffff880`0292f000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`07400000 fffff880`0743d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c52000 fffff880`00c66000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`06826000 fffff880`0684a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06879000 fffff880`06894000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`06894000 fffff880`068b5000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`02c72000 fffff880`02c8c000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`068ca000 fffff880`0691b000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`06fee000 fffff880`06ff9000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`0197a000 fffff880`01983000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01983000 fffff880`0198c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0198c000 fffff880`01995000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`015bc000 fffff880`015f6000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`018ee000 fffff880`01906000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06f45000 fffff880`06f9b000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`0292f000 fffff880`0293a000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`073f4000 fffff880`07400000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02dce000 fffff880`02deb000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0149b000 fffff880`014a3000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`038d3000 fffff880`03944000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`0383b000 fffff880`038d3000   srv      srv.sys      Mon Jul 13 19:25:11 2009 (4A5BC257)
fffff880`02979000 fffff880`029e2000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`0293a000 fffff880`02967000   srvnet   srvnet.sys   Mon Jul 13 19:24:58 2009 (4A5BC24A)
fffff880`06ff9000 fffff880`06ffa480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`02967000 fffff880`02979000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`019cf000 fffff880`019dc000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`019b1000 fffff880`019cf000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c5e000 fffff880`02c72000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00570000 fffff960`0057a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`06800000 fffff880`06826000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`074ed000 fffff880`074ff000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`07563000 fffff880`07564f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`07200000 fffff880`07211000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`074ff000 fffff880`07559000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`07211000 fffff880`07267000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`018be000 fffff880`018d9000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00fc4000 fffff880`00fd1000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01937000 fffff880`01945000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01945000 fffff880`0196a000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0148b000 fffff880`0149b000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fe6000 fffff880`00ffb000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c43000 fffff880`02c5e000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0196a000 fffff880`0197a000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e74000 fffff880`00f18000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f18000 fffff880`00f27000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d90000 fffff880`02d99000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`0038f000   win32k   win32k.sys   Mon Jul 13 19:40:16 2009 (4A5BC5E0)
fffff880`00f7e000 fffff880`00f87000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01800000 fffff880`01821000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`018be000 fffff880`018cc000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018cc000 fffff880`018d8000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018d8000 fffff880`018e1000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018e1000 fffff880`018f4000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`018f4000 fffff880`0191e000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
Need your Rammon html.
hi guys,
there, ive put my rammon text in the attachments...
tnx for the effort!!
hi guys,
You have 2 identical sticks of Corsair CMX4GX3M2A1600C9:
DDR3 1600
9-9-9-24
1.65V
From what I see in your screenshots, you have it set right. However, you may need to set the voltage in the bios manually 1.65v. Update the 2 drivers mentioned in my 1st post. Then, if you get more crashes, run 10 passes of memtest.
#7
hi and tnx for the replys,
ive already set my xmp profile in the bios and i think ive set the voltage to 1.65, memtest also i ran for 6 passes it reported no errors but i think i will leave it workin one day for maybe 10 15 passess!
can anyone tell me about the mysterious sound and the aero change problem?? i will update my driver but the problem is that i think it will happen again beacuse i tried it on my first build month ago with buggy asrock pro3....
#8
DDR3 1600
9-9-9-24
1.65V
hi,
tnx for the reply ,
ive allready set my ram voltage to 1,65V and ive set my xmp profile to profile 1 and it has its own preferences, it was on auto... but still i think the problem is not resolved...
i will update the drivers soon in a couple of minutes...
#9
Your memory looks good: 2 identical Corsair's CMX4GX3M2A1600C9 1600Mhz 9 9 9 24 1.65v.
1. Update the drivers as listed in my 1st post.
2. If you get more crashes, set the voltage manually 1.65.
#10
ive updated ati drivers but im not sure how to update the fnet proxy???
if you can help, ive google it but i cant find any site that i think it can help me...
sorry for my ignorrance...
and tnx!!
#11
If you get more crashes, then just uninstall the fnet proxy.
#12
ive deleted my fnet proxy driver in the system32 folder, i hope it helps...
if i get more crashes ill post here...
tnx again!!
#13
hi cybercore,
ive done as youve told me 3 days ago and removed the fnret proxy driver but this morning i got extra 3 BSOD's when i started my computer... also ive got that wierd change from aero to nontransparent theme and the google chrome crashed for a couple of times before the BSOD...
what else are you suggesting to me??
also, all you other guys...
tnx
IRQL_NOT_LESS_OR_EQUAL (a)
memory_corruption
RAM is the culprit of your latest crashes.
032911-22729-01.dmp
BugCheck 1A, {41790, fffffa80014c6940, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+33906 )
032911-23384-01.dmp
BugCheck 1A, {41790, fffffa80014e35c0, ffff, 0}
Probably caused by : win32k.sys ( win32k!NtGdiCreateDIBSection+3e4 )
032911-37549-01.dmp
BugCheck A, {8, 2, 0, fffff80002b4157b}
Probably caused by : memory_corruption ( nt!MiStoreSetEvictPageFile+b )
CRASH DUMPS
Loading Dump File [F:\DMP\032911-22729-01.dmp]
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a05000 PsLoadedModuleList = 0xfffff800`02c42e50
Debug session time: Tue Mar 29 04:16:46.408 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:54.329
1: kd> !analyze -v
Arguments:
Arg2: fffffa80014c6940
Debugging Details:
PROCESS_NAME:  chrome.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002ae8f9e to fffff80002a75740
STACK_TEXT:
fffff880`097c07e8 fffff800`02ae8f9e : 00000000`0000001a 00000000`00041790 fffffa80`014c6940 00000000`0000ffff : nt!KeBugCheckEx
fffff880`097c07f0 fffff800`02aa8df9 : 00000000`00000000 00000000`713eafff fffffa80`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x33906
fffff880`097c09b0 fffff800`02d8c010 : fffffa80`06574160 0007ffff`00000000 00000000`00000000 00000000`00000000 : nt!MiRemoveMappedView+0xd9
fffff880`097c0ad0 fffff800`02d8c41b : 00000980`00000000 00000000`713a0000 fffffa80`00000001 fffffa80`066e8e60 : nt!MiUnmapViewOfSection+0x1b0
fffff880`097c0b90 fffff800`02a74993 : 00000000`00000000 00000000`0032db48 fffffa80`067a29e0 fffffa80`03d6de60 : nt!NtUnmapViewOfSection+0x5f
fffff880`097c0be0 00000000`775cf95a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0011e188 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x775cf95a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02ae8f9e cc              int     3
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+33906
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+33906
Loading Dump File [F:\DMP\032911-23384-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a16000 PsLoadedModuleList = 0xfffff800`02c53e50
Debug session time: Tue Mar 29 04:12:19.826 2011 (UTC - 4:00)
System Uptime: 0 days 0:02:38.122
0: kd> !analyze -v
Arguments:
Arg2: fffffa80014e35c0
Debugging Details:
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002af9f9e to fffff80002a86740
STACK_TEXT:
fffff880`093f94f8 fffff800`02af9f9e : 00000000`0000001a 00000000`00041790 fffffa80`014e35c0 00000000`0000ffff : nt!KeBugCheckEx
fffff880`093f9500 fffff800`02ab9df9 : 00000000`00000000 00000000`04be3fff 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x33906
fffff880`093f96c0 fffff800`02d9d010 : fffffa80`061ab6d0 0007ffff`00000000 00000000`00000000 00000000`00000000 : nt!MiRemoveMappedView+0xd9
fffff880`093f97e0 fffff800`02d9d41b : 00000000`00000000 00000000`048c0000 fffffa80`00000001 00000000`00000000 : nt!MiUnmapViewOfSection+0x1b0
fffff880`093f98a0 fffff800`02a85993 : 00000000`04aa2000 00000000`00000000 fffffa80`06a17060 fffff880`093f9b10 : nt!NtUnmapViewOfSection+0x5f
fffff880`093f98f0 fffff800`02a81f30 : fffff960`00194c58 fffff880`093f9c60 fffffa80`05d88060 00000000`0022e088 : nt!KiSystemServiceCopyEnd+0x13
fffff880`093f9a88 fffff960`00194c58 : fffff880`093f9c60 fffffa80`05d88060 00000000`0022e088 fffff880`093f9b90 : nt!KiServiceLinkage
fffff880`093f9a90 fffff800`02a85993 : 00000000`1c010295 00000000`00000134 00000000`00000000 00000000`00000000 : win32k!NtGdiCreateDIBSection+0x3e4
fffff880`093f9b70 00000000`7319056a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0022e068 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7319056a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff960`00194c58 488bcf          mov     rcx,rdi
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  win32k!NtGdiCreateDIBSection+3e4
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d23ecb0
FAILURE_BUCKET_ID:  X64_0x1a_41790_win32k!NtGdiCreateDIBSection+3e4
Loading Dump File [F:\DMP\032911-37549-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a14000 PsLoadedModuleList = 0xfffff800`02c51e50
Debug session time: Tue Mar 29 04:21:59.524 2011 (UTC - 4:00)
System Uptime: 0 days 0:03:57.445
0: kd> !analyze -v
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000008, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002b4157b, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cbc0e0
 0000000000000008
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`02b4157b 488b5008        mov     rdx,qword ptr [rax+8]
BUGCHECK_STR:  0xA
PROCESS_NAME:  WerFault.exe
TRAP_FRAME:  fffff88006457770 -- (.trap 0xfffff88006457770)
rax=0000000000000000 rbx=0000000000000000 rcx=fffffa8005955740
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002b4157b rsp=fffff88006457908 rbp=0000000000000000
 r8=0000000000000000  r9=fffffa8003f673f8 r10=0000000fffffffff
r11=0000058000000000 r12=0000000000000000 r13=0000000000000000
nt!MiStoreSetEvictPageFile+0xb:
fffff800`02b4157b 488b5008        mov     rdx,qword ptr [rax+8] ds:6970:00000000`00000008=????????????????
LAST_CONTROL_TRANSFER:  from fffff80002a83ca9 to fffff80002a84740
STACK_TEXT:
fffff880`06457628 fffff800`02a83ca9 : 00000000`0000000a 00000000`00000008 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`06457630 fffff800`02a82920 : 00000000`77527000 fffffa80`03e57b60 00000000`7748a000 000007fe`fe480000 : nt!KiBugCheckDispatch+0x69
fffff880`06457770 fffff800`02b4157b : fffff800`02b42abe 00000000`001df000 fffffa80`03e57b60 fffffa80`05955740 : nt!KiPageFault+0x260
fffff880`06457908 fffff800`02b42abe : 00000000`001df000 fffffa80`03e57b60 fffffa80`05955740 00000000`77a30000 : nt!MiStoreSetEvictPageFile+0xb
fffff880`06457910 fffff800`02a34af6 : 00000000`00400000 00000000`0000000b 00000000`00400000 00000000`00000002 : nt!MiReleaseConfirmedPageFileSpace+0x7e
fffff880`06457990 fffff800`02a583f4 : fffffa80`03f673f8 00000000`00000001 00000000`00000000 fffffa80`0000001c : nt! ?? ::FNODOBFM::`string'+0x20a32
fffff880`06457a10 fffff800`02a57686 : 00000000`00000001 fffffa80`03f67060 fffffa80`03f67060 00000000`00000001 : nt!MiDeleteAllHashMappings+0xe4
fffff880`06457a50 fffff800`02d67abf : fffff8a0`0b160060 00000000`00000001 00000000`00000000 fffffa80`03e57b60 : nt!MmCleanProcessAddressSpace+0xa2
fffff880`06457aa0 fffff800`02d4095b : 00000000`00000000 00000000`00000001 000007ff`fffde000 00000000`00000000 : nt!PspExitThread+0x92f
fffff880`06457b60 fffff800`02a83993 : fffffa80`03f67060 fffff880`00000000 00000000`001a3a70 fffffa80`03e57b60 : nt!NtTerminateProcess+0x25b
fffff880`06457be0 00000000`77a5f97a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0012f8f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77a5f97a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiStoreSetEvictPageFile+b
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0xA_nt!MiStoreSetEvictPageFile+b
DRIVERS
fffff880`00f7d000 fffff880`00fd4000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c16000 fffff880`02ca0000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`07bcb000 fffff880`07be1000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c2a000 fffff880`00c35000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0a4ab000 fffff880`0a4b6000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00de3000 fffff880`00dec000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c00000 fffff880`00c2a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`07226000 fffff880`07b22000   atikmdag atikmdag.sys Wed Jan 26 17:48:28 2011 (4D40A4BC)
fffff880`03f69000 fffff880`03fb7000   atikmpag atikmpag.sys Wed Jan 26 17:13:33 2011 (4D409C8D)
fffff880`018fe000 fffff880`01905000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03f32000 fffff880`03f43000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`038cc000 fffff880`038ea000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00650000 fffff960`00677000   cdd      cdd.dll      unavailable (00000000)
fffff880`00d09000 fffff880`00dc9000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01865000 fffff880`01895000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cab000 fffff880`00d09000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010da000 fffff880`0114d000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`07bbb000 fffff880`07bcb000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`039a0000 fffff880`039a9000   cpuz135_x64 cpuz135_x64.sys Wed Jan 19 11:42:06 2011 (4D37145E)
fffff880`06c28000 fffff880`06c36000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e91000 fffff880`03f14000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03f14000 fffff880`03f32000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02dc9000 fffff880`02dd8000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0184f000 fffff880`01865000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06c00000 fffff880`06c22000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06c42000 fffff880`06c4b000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06c36000 fffff880`06c42000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06c4b000 fffff880`06c5e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06df2000 fffff880`06dfe000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`06a90000 fffff880`06b84000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`06b84000 fffff880`06bca000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`06d0e000 fffff880`06d17c00   EtronHub3 EtronHub3.sys Fri Jan 28 16:46:45 2011 (4D433945)
fffff880`06a67000 fffff880`06a76c00   EtronXHCI EtronXHCI.sys Fri Jan 28 16:46:43 2011 (4D433943)
fffff880`06a77000 fffff880`06a84000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01068000 fffff880`0107c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0101c000 fffff880`01068000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`025ad000 fffff880`025ba000   FNETTBOH_305 FNETTBOH_305.SYS Wed Nov 03 02:24:26 2010 (4CD1001A)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01815000 fffff880`0184f000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01597000 fffff880`015e1000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ff1000 fffff800`0303a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06bca000 fffff880`06bee000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06d59000 fffff880`06db5000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`06bee000 fffff880`06bff000   HECIx64  HECIx64.sys  Tue Oct 19 19:33:43 2010 (4CBE2AD7)
fffff880`0258b000 fffff880`025a4000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`025a4000 fffff880`025ac080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0257d000 fffff880`0258b000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03804000 fffff880`038cc000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0121b000 fffff880`01224000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`07b78000 fffff880`07b96000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`07ba5000 fffff880`07bbb000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`07b96000 fffff880`07ba5000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00baa000 fffff800`00bb4000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`06c5f000 fffff880`06ca2000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`013e3000 fffff880`013fd000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0156c000 fffff880`01597000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06c22000 fffff880`06c27200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02444000 fffff880`02459000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02400000 fffff880`02423000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c53000 fffff880`00c97000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`025d5000 fffff880`025e3000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`03e56000 fffff880`03e65000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`025e3000 fffff880`025f0000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00dc9000 fffff880`00de3000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`038ea000 fffff880`03902000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03902000 fffff880`0392f000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0392f000 fffff880`0397d000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0397d000 fffff880`039a0000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01963000 fffff880`0196e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fdd000 fffff880`00fe7000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0107c000 fffff880`010da000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02dbe000 fffff880`02dc9000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01400000 fffff880`01412000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0141a000 fffff880`0150c000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`07be1000 fffff880`07bed000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03fb7000 fffff880`03fe6000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06d1a000 fffff880`06d2f000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d14000 fffff880`02d23000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02ca0000 fffff880`02ce5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0150c000 fffff880`0156c000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0196e000 fffff880`0197f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02db2000 fffff880`02dbe000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a14000 fffff800`02ff1000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01240000 fffff880`013e3000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`018f5000 fffff880`018fe000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02cee000 fffff880`02d14000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fe7000 fffff880`00fee000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03a97000 fffff880`03b3d000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06db5000 fffff880`06df2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c97000 fffff880`00cab000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`07200000 fffff880`07224000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03e00000 fffff880`03e1b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`03e1b000 fffff880`03e3c000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`03e3c000 fffff880`03e56000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`019aa000 fffff880`019fb000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`07bed000 fffff880`07bf8000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01948000 fffff880`01951000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01951000 fffff880`0195a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0195a000 fffff880`01963000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01199000 fffff880`011d3000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02459000 fffff880`02471000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`07b22000 fffff880`07b78000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`03b3d000 fffff880`03b48000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06a84000 fffff880`06a90000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d23000 fffff880`02d40000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015f1000 fffff880`015f9000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0a43a000 fffff880`0a4ab000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`03a00000 fffff880`03a96000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03b87000 fffff880`03bee000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`03b48000 fffff880`03b75000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`07bf8000 fffff880`07bf9480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`03b75000 fffff880`03b87000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0199d000 fffff880`019aa000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0197f000 fffff880`0199d000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d9e000 fffff880`02db2000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00420000 fffff960`0042a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03f43000 fffff880`03f69000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06ca2000 fffff880`06cb4000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06d18000 fffff880`06d19f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06a00000 fffff880`06a11000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06cb4000 fffff880`06d0e000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`06a11000 fffff880`06a67000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`025ba000 fffff880`025d5000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01905000 fffff880`01913000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01913000 fffff880`01938000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015e1000 fffff880`015f1000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0114d000 fffff880`01199000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d83000 fffff880`02d9e000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01938000 fffff880`01948000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eca000 fffff880`00f6e000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f6e000 fffff880`00f7d000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02ce5000 fffff880`02cee000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00380000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`00fd4000 fffff880`00fdd000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02423000 fffff880`02444000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`024cf000 fffff880`0257d000   xnacc    xnacc.sys    Mon Jul 13 20:01:05 2009 (4A5BCAC1)
Unloaded modules:
fffff880`02d40000 fffff880`02d83000   dtsoftbus01.
    Checksum:  00000000
    ImageSize:  00043000
fffff880`06d2f000 fffff880`06d59000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
fffff880`01895000 fffff880`018a3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018a3000 fffff880`018af000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018af000 fffff880`018b8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018b8000 fffff880`018cb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`018cb000 fffff880`018f5000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
#15
im at work now, i left my computer to run memtest for 9 hours, and when i get home i hope it says it has error because im really pissed at my computer... :(.... yesterday i installed dawn of war 2 and steam, played for a couple of hours, today in the morning i turned on my computer and it crashed... when i did a system resotre to a point before i installed the game, computer wokred normally for 4 hours until i left for work today...
is that maybe helpful??
if its the RAM ill go to the store and change them for new ....
tnx and peace
#16
It's a good idea to first test sticks one by one and in different slots, to be sure the motherboard is OK.
