Harib0x
Member
- Joined
- Oct 29, 2015
- Messages
- 24
- Thread Author
- #1
Hi, since a few weeks, I keep having some BSOD with either Error: SYSTEM_SERVICE_EXCEPTION or Error: IRQL_NOT_LESS_OR_EQUAL.
Here are the descriptions from "Who Crashed":
On Thu 29/10/2015 12:37:17 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\102915-35031-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14E2E0)
Bugcheck code: 0x3B (0xC000001D, 0xFFFFF8013152BB45, 0xFFFFD001CCA277E0, 0x0)
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sun 25/10/2015 13:31:01 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\102515-62015-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF801F6AFBBA8, 0xFFFFD00020621590, 0x0)
On Sun 25/10/2015 11:39:35 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\102515-40437-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF8009B65A9C3)
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
I'm also attaching the dump files of the BSOD.
Thank you for any help you could provide.
