Windows 10 BSOD SYSTEM_SERVICE_EXCEPTION
Cardinal System
Honorable Member
My mother's laptop has been gradually crashing more and more with SYSTEM_SERVICE_EXCEPTIONs since Windows 10 pushed an upgrade back in October. I published a thread back then to seek support with some other issues the upgrade was causing, but at that time I was unaware of the BSOD errors. My sister has been experiencing something very similar with her own Windows 7 laptop. Anyway, I tried updating the display driver (because I read something on the internet that said to do so), but this only caused the computer to crash with some kind of kernel error. It has been crashing much more often since then, with a variety of errors, not limited to but including DRIVER_IRQL_NOT_LESS_OR_EQUAL, REGISTRY_FILTER_DRIVER_EXCEPTION, KMODE_EXCEPTION_NOT_HANDLED, ATTEMPTED_WRITE_TO_READONLY_MEMORY, FAT_FILE_SYSTEM, APC_INDEX_MISMATCH, et al.
I am a simple Java developer. I cannot read (let alone understand) Windows dump and debug files. I compiled a zip archive of the all the dump files from my mother's laptop. Hopefully these will be sufficient data to identify the problem.
Thank you!
the first three dumps i opened blamed Norton Symantec AV. Try uninstalling and just using Defender for now. See if the BSOD's stop, Norton is well known for causing issues and I wouldn't recommend it.
Yes, I noticed that SymEvent.sys on the BSOD was associated with Norton. I uninstalled Norton, but the laptop has crashed since then. It hasn't been in very much use lately, so I will wait and see if it crashes a few more times before uploading more dumps.
Ok sounds good. I'd also try running windows update too especially if it hasn't been running for a while.
Yep, it has been crashing again. Unfortunately, I accidentally deleted all the newer dumps while copying them to my USB stick. The laptop crashed three times since then, so I'll include those three new dumps. Hopefully that helps.
I also got the laptop's information, if that is relevant:
Manufacturer  Model             Name             SystemType
HP            HP ENVY Notebook  LAPTOP-D8L9TS62  x64-based PC
  • 021120-5781-01.dmp
  • 021120-5906-01.dmp
  • 021120-7468-01.dmp
the dump files point to various windows process's as the culprits. To ensure that Windows itself is running as it should try running these scans:
1. Open command prompt as administrator and run following commands
2. SFC/Scannow
3. DISM /Online /Cleanup-Image /RestoreHealth
2. SFC/Scannow
It doesn't seem to have found anything:
Microsoft Windows [Version 10.0.18362.592]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>sfc /scannow
Beginning system scan.  This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.18362.1
Image Version: 10.0.18362.592
[==========================100.0%==========================] The restore operation completed successfully.
The operation completed successfully.
Running the DISM scan especially may have helped but only time will tell.
Please upload any new dump files.
Things just got a lot worse. The computer cannot even boot anymore. It gives BSOD errors every time it attempts to boot. It will also say "Preparing automatic repair", and then crash again. It cannot even enter recovery mode. The only thing that seems to be working now is the BIOS menu...
That sounds a lot like a failing HDD, only way to know for sure would be to reinstall windows and then run seatools on the disk
My next suggestion was going to be a chkdsk but if you can't even get into recovery mode then it's not really an option. Have you tried booting from a windows disk or usb and see if you can enter recovery mode that way?
I used the Microsoft media creation tool to create installation media on a USB drive. I then tried many times to boot from the USB drive, but all I got was more BSOD errors. I wish this computer was a tower so I could physically remove the hard drive and work on it from a different computer... Perhaps it might work if I try installing Linux?
I find it funny that the hard drive seems to be failing. This computer is only a few years old.
This is a known issue with the latest cumulative update from last Tuesday with HP machines. Now looking for any fixes Microsoft may suggest,
I was able to recover the newest dumps using Active Boot Disc. I will upload them so you can take a look. In the mean time, I am going to focus on backing up the computer's data with Active Boot Disk before I try to fix anything else...
  • Minidumps3.zip
Active Boot Disc does have a chkdsk command. I gave it a try. Here's the output:
The type of the file system is NTFS.
Volume label is Windows.
Stage 1: Examining basic file system structure ...
Progress: 0 of 538624 done; Stage: 0%; Total: 0%; ETA: 268:21:16 Progress: 144 of 538624 done; Stage: 0%; Total: 0%; ETA: 268:21:16 . Progress: 18252 of 538624 done; Stage: 3%; Total: 0%; ETA: 268:20:59 .. Progress: 37104 of 538624 done; Stage: 6%; Total: 0%; ETA: 7:14:57 ...Progress: 55179 of 538624 done; Stage: 10%; Total: 0%; ETA: 7:17:42 Progress: 73058 of 538624 done; Stage: 13%; Total: 0%; ETA: 7:18:37 . Progress: 87213 of 538624 done; Stage: 16%; Total: 0%; ETA: 7:33:44 .. Progress: 107677 of 538624 done; Stage: 19%; Total: 0%; ETA: 7:23:17 ...Progress: 126465 of 538624 done; Stage: 23%; Total: 0%; ETA: 7:20:39 Progress: 146790 of 538624 done; Stage: 27%; Total: 0%; ETA: 7:15:42 . Progress: 167299 of 538624 done; Stage: 31%; Total: 0%; ETA: 7:11:40 .. Progress: 186982 of 538624 done; Stage: 34%; Total: 0%; ETA: 7:08:24 ...Progress: 205930 of 538624 done; Stage: 38%; Total: 0%; ETA: 7:06:53 Progress: 230730 of 538624 done; Stage: 42%; Total: 0%; ETA: 6:56:40 . Progress: 253318 of 538624 done; Stage: 47%; Total: 0%; ETA: 6:52:03 .. Progress: 277262 of 538624 done; Stage: 51%; Total: 0%; ETA: 6:45:37 ...Progress: 291225 of 538624 done; Stage: 54%; Total: 0%; ETA: 6:48:17 Progress: 311273 of 538624 done; Stage: 57%; Total: 0%; ETA: 6:47:56 . Progress: 345345 of 538624 done; Stage: 64%; Total: 0%; ETA: 6:31:18 .. Progress: 408459 of 538624 done; Stage: 75%; Total: 0%; ETA: 5:51:43 ...Progress: 432602 of 538624 done; Stage: 80%; Total: 0%; ETA: 5:48:35 Progress: 451112 of 538624 done; Stage: 83%; Total: 0%; ETA: 5:51:19 . Progress: 495361 of 538624 done; Stage: 91%; Total: 0%; ETA: 5:36:47 .. Progress: 535041 of 538624 done; Stage: 99%; Total: 0%; ETA: 5:26:47 ...Progress: 538624 of 538624 done; Stage: 100%; Total: 0%; ETA: 5:24:39 538624 file records processed.
File verification completed.
Progress: 7352 of 7352 done; Stage: 100%; Total: 0%; ETA: 5:30:28 . 7352 large file records processed.
Progress: 0 of 0 done; Stage: 99%; Total: 0%; ETA: 5:30:28 .. 0 bad file records processed.
Stage 2: Examining file name linkage ...
Progress: 11463 of 668776 done; Stage: 1%; Total: 0%; ETA: 5:32:28 ...Progress: 39192 of 668776 done; Stage: 5%; Total: 0%; ETA: 5:30:38 Progress: 69103 of 668776 done; Stage: 10%; Total: 0%; ETA: 5:27:48 . Progress: 104088 of 668776 done; Stage: 15%; Total: 0%; ETA: 5:22:36 .. Progress: 139732 of 668776 done; Stage: 20%; Total: 0%; ETA: 5:17:47 ...Progress: 177258 of 668776 done; Stage: 26%; Total: 0%; ETA: 5:12:39 Progress: 218447 of 668776 done; Stage: 32%; Total: 0%; ETA: 5:06:28 . Progress: 259056 of 668776 done; Stage: 38%; Total: 0%; ETA: 5:01:18 .. Progress: 300987 of 668776 done; Stage: 45%; Total: 0%; ETA: 4:55:32 ...Progress: 391599 of 668776 done; Stage: 58%; Total: 0%; ETA: 4:35:55 Progress: 449905 of 668776 done; Stage: 67%; Total: 0%; ETA: 4:27:37 . Progress: 1319 of 2023 done; Stage: 65%; Total: 0%; ETA: 4:12:38 .. Progress: 2023 of 2023 done; Stage: 100%; Total: 0%; ETA: 4:12:25 ... 2023 reparse records processed.
Progress: 542361 of 668776 done; Stage: 81%; Total: 0%; ETA: 4:13:24 Progress: 544963 of 668776 done; Stage: 81%; Total: 0%; ETA: 4:09:45 . Progress: 546952 of 668776 done; Stage: 81%; Total: 0%; ETA: 4:10:40 .. Progress: 549584 of 668776 done; Stage: 82%; Total: 0%; ETA: 4:05:04 ...Progress: 550778 of 668776 done; Stage: 82%; Total: 0%; ETA: 3:56:15 Progress: 559418 of 668776 done; Stage: 83%; Total: 0%; ETA: 3:57:48 . Progress: 562173 of 668776 done; Stage: 84%; Total: 0%; ETA: 3:55:10 .. Progress: 569421 of 668776 done; Stage: 85%; Total: 0%; ETA: 3:57:44 ...Progress: 576611 of 668776 done; Stage: 86%; Total: 0%; ETA: 3:59:52 Progress: 580288 of 668776 done; Stage: 86%; Total: 0%; ETA: 3:58:44 . Progress: 586381 of 668776 done; Stage: 87%; Total: 0%; ETA: 3:58:09 .. Progress: 590629 of 668776 done; Stage: 88%; Total: 0%; ETA: 3:54:15 ...Progress: 597968 of 668776 done; Stage: 89%; Total: 0%; ETA: 3:56:08 Progress: 668776 of 668776 done; Stage: 100%; Total: 0%; ETA: 3:58:28 . 668776 index entries processed.
Index verification completed.
Progress: 1 of 0 done; Stage: 99%; Total: 0%; ETA: 3:59:50 .. Progress: 0 of 0 done; Stage: 99%; Total: 0%; ETA: 4:01:08 ... 0 unindexed files scanned.
Progress: 0 of 0 done; Stage: 99%; Total: 0%; ETA: 4:02:20 0 unindexed files recovered to lost and found.
Progress: 2023 of 2023 done; Stage: 100%; Total: 0%; ETA: 4:04:39 . 2023 reparse records processed.
Stage 3: Examining security descriptors ...
Security descriptor verification completed.
Progress: 7 of 7 done; Stage: 100%; Total: 0%; ETA: 4:05:17 .. 65077 data files processed.
CHKDSK is verifying Usn Journal...
Progress: 2 of 2 done; Stage: 100%; Total: 0%; ETA: 4:08:20 ... 17800 USN bytes processed.
Usn Journal verification completed.
Stage 4: Looking for bad clusters in user file data ...
Progress: 0 of 538608 done; Stage: 0%; Total: 0%; ETA: 4:08:58 Progress: 1322 of 538608 done; Stage: 0%; Total: 0%; ETA: 4:09:34 . Progress: 1886 of 538608 done; Stage: 0%; Total: 0%; ETA: 3:59:22 .. Progress: 2255 of 538608 done; Stage: 0%; Total: 0%; ETA: 3:40:14 ...Progress: 2966 of 538608 done; Stage: 0%; Total: 0%; ETA: 3:35:02 Progress: 3648 of 538608 done; Stage: 0%; Total: 0%; ETA: 3:30:44 . Progress: 3696 of 538608 done; Stage: 0%; Total: 0%; ETA: 3:24:50 .. Progress: 3758 of 538608 done; Stage: 0%; Total: 0%; ETA: 2:02:17 ...Progress: 4466 of 538608 done; Stage: 0%; Total: 0%; ETA: 1:59:49 Progress: 4648 of 538608 done; Stage: 0%; Total: 1%; ETA: 1:56:44 . Progress: 4679 of 538608 done; Stage: 0%; Total: 1%; ETA: 1:19:26 .. Progress: 5042 of 538608 done; Stage: 0%; Total: 1%; ETA: 1:12:11 ...Progress: 5448 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:08 Progress: 5827 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:04 . Progress: 6080 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:11:55 .. Progress: 6367 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:03 ...Progress: 7165 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:11:58 Progress: 7562 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:10 . Progress: 8037 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:03 .. Progress: 8905 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:12:04 ...Progress: 9458 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:11:58 Progress: 9793 of 538608 done; Stage: 1%; Total: 1%; ETA: 1:11:49 . Progress: 9840 of 538608 done; Stage: 1%; Total: 2%; ETA: 1:11:29 .. Progress: 10347 of 538608 done; Stage: 1%; Total: 2%; ETA: 1:07:30 ...Progress: 11014 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:28 Progress: 11300 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:32 . Progress: 11832 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:31 .. Progress: 12146 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:39 ...Progress: 12587 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:34 Progress: 13421 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:34 . Progress: 13778 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:30 .. Progress: 14132 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:28 ...Progress: 14819 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:25 Progress: 15227 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:30 . Progress: 15637 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:26 .. Progress: 15800 of 538608 done; Stage: 2%; Total: 2%; ETA: 1:07:21 ...Progress: 16513 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:21 Progress: 16796 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:16 . Progress: 17023 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:22 .. Progress: 17475 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:28 ...Progress: 17859 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:24 Progress: 18359 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:26 . Progress: 19301 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:26 .. Progress: 19633 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:25 ...Progress: 19848 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:31 Progress: 20506 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:34 . Progress: 20825 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:32 .. Progress: 21425 of 538608 done; Stage: 3%; Total: 2%; ETA: 1:07:29 ...Progress: 22213 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:27 Progress: 24126 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:29 . Progress: 24847 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:35 .. Progress: 25077 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:42 ...Progress: 25952 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:46 Progress: 26025 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:42 . Progress: 26217 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:47 .. Progress: 26383 of 538608 done; Stage: 4%; Total: 2%; ETA: 1:07:43 ...Progress: 27054 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:42 Progress: 27150 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:41 . Progress: 27212 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:40 .. Progress: 28313 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:41 ...Progress: 29021 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:40 Progress: 29559 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:37 . Progress: 29996 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:32 .. Progress: 30130 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:33 ...Progress: 31029 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:37 Progress: 32001 of 538608 done; Stage: 5%; Total: 2%; ETA: 1:07:40 . Progress: 32838 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:40 .. Progress: 33453 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:42 ...Progress: 33486 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:43 Progress: 33702 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:44 . Progress: 35129 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:52 .. Progress: 36855 of 538608 done; Stage: 6%; Total: 2%; ETA: 1:07:53 ...Progress: 37846 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:00 Progress: 38134 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:04 . Progress: 38330 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:00 .. Progress: 38927 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:02 ...Progress: 39239 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:11 Progress: 39486 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:08 . Progress: 39652 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:05 .. Progress: 39682 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:08:04 ...Progress: 39730 of 538608 done; Stage: 7%; Total: 2%; ETA: 1:07:56 Progress: 40131 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:59 . Progress: 40387 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:56 .. Progress: 41011 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:55 ...Progress: 41279 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:53 Progress: 41989 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:50 . Progress: 42215 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:07:45 .. Progress: 42585 of 538608 done; Stage: 7%; Total: 3%; ETA: 1:06:54 ...Progress: 43330 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:54 Progress: 43752 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:52 . Progress: 44640 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:49 .. Progress: 46411 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:52 ...Progress: 46433 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:51 Progress: 46943 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:36 . Progress: 47591 of 538608 done; Stage: 8%; Total: 3%; ETA: 1:06:36 .. Progress: 48542 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:43 ...Progress: 50141 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:46 Progress: 50569 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:51 . Progress: 50972 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:51 .. Progress: 51637 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:49 ...Progress: 51660 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:46 Progress: 51797 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:43 . Progress: 52234 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:51 .. Progress: 52929 of 538608 done; Stage: 9%; Total: 3%; ETA: 1:06:49 ...Progress: 53867 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:48 Progress: 54198 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:52 . Progress: 54815 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:51 .. Progress: 55120 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:48 ...Progress: 55163 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:45 Progress: 55450 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:40 . Progress: 55849 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:36 .. Progress: 56510 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:35 ...Progress: 57216 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:32 Progress: 58013 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:36 . Progress: 58433 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:34 .. Progress: 58771 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:31 ...Progress: 58861 of 538608 done; Stage: 10%; Total: 3%; ETA: 1:06:30 Progress: 59540 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:25 . Progress: 59842 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:23 .. Progress: 60526 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:22 ...Progress: 61298 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:22 Progress: 62447 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:22 . Progress: 63570 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:22 .. Progress: 64044 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:20 ...Progress: 64521 of 538608 done; Stage: 11%; Total: 3%; ETA: 1:06:16 Progress: 64703 of 538608 done; Stage: 12%; Total: 3%; ETA: 1:04:01 . Progress: 65852 of 538608 done; Stage: 12%; Total: 3%; ETA: 1:04:03 .. Progress: 66279 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:04:03 ...Progress: 66720 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:04:01 Progress: 67737 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:04:01 . Progress: 68321 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:04:01 .. Progress: 69031 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:03:55 ...Progress: 69680 of 538608 done; Stage: 12%; Total: 4%; ETA: 1:03:59 Progress: 70120 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:04:00 . Progress: 70428 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:59 .. Progress: 70538 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:57 ...Progress: 70703 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:46 Progress: 70706 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:43 . Progress: 70900 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:24 .. Progress: 71856 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:24 ...Progress: 72558 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:23 Progress: 72975 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:21 . Progress: 73842 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:21 .. Progress: 74253 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:23 ...Progress: 74649 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:28 Progress: 75080 of 538608 done; Stage: 13%; Total: 4%; ETA: 1:03:32 . Progress: 76287 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:32 .. Progress: 77298 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:37 ...Progress: 78087 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:40 Progress: 78311 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:37 . Progress: 78358 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:12 .. Progress: 78584 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:05 ...Progress: 78662 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:02 Progress: 78983 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:02 . Progress: 79240 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:03:00 .. Progress: 79589 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:02:59 ...Progress: 80137 of 538608 done; Stage: 14%; Total: 4%; ETA: 1:02:38 Progress: 81832 of 538608 done; Stage: 15%; Total: 4%; ETA: 1:02:39 . Progress: 83634 of 538608 done; Stage: 15%; Total: 4%; ETA: 1:02:41 .. Progress: 84780 of 538608 done; Stage: 15%; Total: 4%; ETA: 1:02:46 ...Progress: 87753 of 538608 done; Stage: 16%; Total: 4%; ETA: 1:02:48 Progress: 91101 of 538608 done; Stage: 16%; Total: 4%; ETA: 1:02:49 . Progress: 93254 of 538608 done; Stage: 17%; Total: 4%; ETA: 1:02:49 .. Progress: 94271 of 538608 done; Stage: 17%; Total: 4%; ETA: 1:02:48 ...Progress: 96165 of 538608 done; Stage: 17%; Total: 4%; ETA: 1:02:50 Progress: 96209 of 538608 done; Stage: 17%; Total: 4%; ETA: 1:02:53 . Progress: 98108 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:02:56 .. Progress: 98931 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:02:59 ...Progress: 99330 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:03:00 Progress: 100359 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:03:00 . Progress: 100902 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:03:02 .. Progress: 100988 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:03:00 ...Progress: 101491 of 538608 done; Stage: 18%; Total: 4%; ETA: 1:02:57 Progress: 102788 of 538608 done; Stage: 19%; Total: 4%; ETA: 1:02:57 . Progress: 102888 of 538608 done; Stage: 19%; Total: 4%; ETA: 1:03:00 .. Progress: 103028 of 538608 done; Stage: 19%; Total: 4%; ETA: 1:02:59 ...Progress: 103542 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:02:58 Progress: 103690 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:01 . Progress: 103748 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:04 .. Progress: 104001 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:08 ...Progress: 104066 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:08 Progress: 104495 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:05 . Progress: 104960 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:05 .. Progress: 105422 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:05 ...Progress: 105875 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:07 Progress: 105893 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:06 . Progress: 105921 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:04 .. Progress: 106153 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:05 ...Progress: 106536 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:03 Progress: 107117 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:04 . Progress: 107323 of 538608 done; Stage: 19%; Total: 5%; ETA: 1:03:05 .. Progress: 108476 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:02 ...Progress: 108712 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:03 Progress: 108752 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:04 . Progress: 108768 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:03 .. Progress: 108784 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:01 ...Progress: 108920 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:59 Progress: 109127 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:57 . Progress: 109243 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:58 .. Progress: 109316 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:59 ...Progress: 109822 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:59 Progress: 109840 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:59 . Progress: 109973 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:01 .. Progress: 109978 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:00 ...Progress: 110425 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:55 Progress: 110426 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:55 . Progress: 110959 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:53 .. Progress: 111082 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:57 ...Progress: 111856 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:02:58 Progress: 112747 of 538608 done; Stage: 20%; Total: 5%; ETA: 1:03:00 . Progress: 113782 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:00 .. Progress: 115066 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:04 ...Progress: 116338 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:07 Progress: 117350 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:07 . Progress: 117546 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:05 .. Progress: 117675 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:08 ...Progress: 118020 of 538608 done; Stage: 21%; Total: 5%; ETA: 1:03:10 Progress: 118696 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:12 . Progress: 119981 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:15 .. Progress: 120927 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:18 ...Progress: 121540 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:16 Progress: 122416 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:19 . Progress: 123564 of 538608 done; Stage: 22%; Total: 5%; ETA: 1:03:20 .. Progress: 125999 of 538608 done; Stage: 23%; Total: 5%; ETA: 1:03:23 ...Progress: 127485 of 538608 done; Stage: 23%; Total: 5%; ETA: 1:03:26 Progress: 130224 of 538608 done; Stage: 24%; Total: 5%; ETA: 1:03:32 . Progress: 132869 of 538608 done; Stage: 24%; Total: 5%; ETA: 1:03:39 .. Progress: 135119 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:45 ...Progress: 136202 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:48 Progress: 136423 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:50 . Progress: 137718 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:52 .. Progress: 138944 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:53 ...Progress: 139875 of 538608 done; Stage: 25%; Total: 5%; ETA: 1:03:52 Progress: 141688 of 538608 done; Stage: 26%; Total: 5%; ETA: 1:03:56 . Progress: 144321 of 538608 done; Stage: 26%; Total: 5%; ETA: 1:04:00 .. Progress: 147263 of 538608 done; Stage: 27%; Total: 5%; ETA: 1:04:04 ...Progress: 150247 of 538608 done; Stage: 27%; Total: 5%; ETA: 1:04:09 Progress: 152715 of 538608 done; Stage: 28%; Total: 5%; ETA: 1:04:12 . Progress: 154354 of 538608 done; Stage: 28%; Total: 5%; ETA: 1:04:14 .. Progress: 157365 of 538608 done; Stage: 29%; Total: 5%; ETA: 1:04:20 ...Progress: 160357 of 538608 done; Stage: 29%; Total: 5%; ETA: 1:04:27 Progress: 163022 of 538608 done; Stage: 30%; Total: 5%; ETA: 1:04:32 . Progress: 165360 of 538608 done; Stage: 30%; Total: 5%; ETA: 1:04:38 .. Progress: 166695 of 538608 done; Stage: 30%; Total: 5%; ETA: 1:04:40 ...Progress: 169085 of 538608 done; Stage: 31%; Total: 5%; ETA: 1:04:44 Progress: 170617 of 538608 done; Stage: 31%; Total: 5%; ETA: 1:04:46 . Progress: 170731 of 538608 done; Stage: 31%; Total: 5%; ETA: 1:04:44 .. Progress: 170911 of 538608 done; Stage: 31%; Total: 5%; ETA: 1:04:43 ...Progress: 172115 of 538608 done; Stage: 31%; Total: 5%; ETA: 1:04:44 Progress: 174310 of 538608 done; Stage: 32%; Total: 5%; ETA: 1:04:51 . Progress: 175858 of 538608 done; Stage: 32%; Total: 5%; ETA: 1:04:54 .. Progress: 177610 of 538608 done; Stage: 32%; Total: 5%; ETA: 1:04:59 ...Progress: 180722 of 538608 done; Stage: 33%; Total: 5%; ETA: 1:05:03 Progress: 183802 of 538608 done; Stage: 34%; Total: 5%; ETA: 1:05:07 . Progress: 185278 of 538608 done; Stage: 34%; Total: 5%; ETA: 1:05:07 .. Progress: 188435 of 538608 done; Stage: 34%; Total: 5%; ETA: 1:05:10 ...Progress: 189363 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:10 Progress: 189377 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:10 . Progress: 189405 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:10 .. Progress: 189414 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:09 ...Progress: 189419 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:07 Progress: 189862 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:02 . Progress: 191537 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:02 .. Progress: 193431 of 538608 done; Stage: 35%; Total: 5%; ETA: 1:05:05 ...Progress: 196278 of 538608 done; Stage: 36%; Total: 5%; ETA: 1:05:07 Progress: 197153 of 538608 done; Stage: 36%; Total: 5%; ETA: 1:05:07 . Progress: 197826 of 538608 done; Stage: 36%; Total: 5%; ETA: 1:05:08 .. Progress: 198812 of 538608 done; Stage: 36%; Total: 5%; ETA: 1:05:08 ...Progress: 199254 of 538608 done; Stage: 36%; Total: 5%; ETA: 1:05:07 Progress: 200410 of 538608 done; Stage: 37%; Total: 5%; ETA: 1:05:08 . Progress: 201246 of 538608 done; Stage: 37%; Total: 5%; ETA: 1:05:08 .. Progress: 202088 of 538608 done; Stage: 37%; Total: 5%; ETA: 1:05:07 ...Progress: 202328 of 538608 done; Stage: 37%; Total: 5%; ETA: 1:05:09 Progress: 203205 of 538608 done; Stage: 37%; Total: 5%; ETA: 1:05:08 . Progress: 204083 of 538608 done; Stage: 37%; Total: 6%; ETA: 1:05:08 .. Progress: 204186 of 538608 done; Stage: 37%; Total: 6%; ETA: 1:05:05 ...Progress: 204884 of 538608 done; Stage: 38%; Total: 6%; ETA: 1:05:04 Progress: 205832 of 538608 done; Stage: 38%; Total: 6%; ETA: 1:05:04 . Progress: 207580 of 538608 done; Stage: 38%; Total: 6%; ETA: 1:05:05 .. Progress: 208805 of 538608 done; Stage: 38%; Total: 6%; ETA: 1:05:05 ...Progress: 214589 of 538608 done; Stage: 39%; Total: 6%; ETA: 1:05:10 Progress: 221204 of 538608 done; Stage: 41%; Total: 5%; ETA: 1:06:41 . Progress: 226014 of 538608 done; Stage: 41%; Total: 5%; ETA: 1:06:43 .. Progress: 228745 of 538608 done; Stage: 42%; Total: 5%; ETA: 1:06:48 ...Progress: 230651 of 538608 done; Stage: 42%; Total: 5%; ETA: 1:06:52 Progress: 232175 of 538608 done; Stage: 43%; Total: 5%; ETA: 1:06:56 . Progress: 234951 of 538608 done; Stage: 43%; Total: 5%; ETA: 1:07:02 .. Progress: 235664 of 538608 done; Stage: 43%; Total: 5%; ETA: 1:07:04 ...Progress: 238306 of 538608 done; Stage: 44%; Total: 5%; ETA: 1:07:10 Progress: 239930 of 538608 done; Stage: 44%; Total: 6%; ETA: 1:07:12 . Progress: 242386 of 538608 done; Stage: 45%; Total: 6%; ETA: 1:07:16 .. Progress: 247734 of 538608 done; Stage: 45%; Total: 6%; ETA: 1:07:23 ...Progress: 253259 of 538608 done; Stage: 47%; Total: 6%; ETA: 1:07:26 Progress: 255105 of 538608 done; Stage: 47%; Total: 6%; ETA: 1:07:26 . Progress: 256566 of 538608 done; Stage: 47%; Total: 6%; ETA: 1:07:28 .. Progress: 258874 of 538608 done; Stage: 48%; Total: 6%; ETA: 1:07:32 ...Progress: 263699 of 538608 done; Stage: 48%; Total: 6%; ETA: 1:07:36 Progress: 264403 of 538608 done; Stage: 49%; Total: 6%; ETA: 1:07:35 . Progress: 265121 of 538608 done; Stage: 49%; Total: 6%; ETA: 1:07:34 .. Progress: 266268 of 538608 done; Stage: 49%; Total: 6%; ETA: 1:07:32 ...Progress: 268377 of 538608 done; Stage: 49%; Total: 6%; ETA: 1:07:34 Progress: 269129 of 538608 done; Stage: 49%; Total: 6%; ETA: 1:07:34 . Progress: 271843 of 538608 done; Stage: 50%; Total: 6%; ETA: 1:07:37 .. Progress: 274036 of 538608 done; Stage: 50%; Total: 6%; ETA: 1:07:39 ...Progress: 276304 of 538608 done; Stage: 51%; Total: 6%; ETA: 1:07:39 Progress: 279300 of 538608 done; Stage: 51%; Total: 6%; ETA: 1:07:40 . Progress: 281948 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:45 .. Progress: 282365 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:44 ...Progress: 283822 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:34 Progress: 283864 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:34 . Progress: 283907 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:35 .. Progress: 284745 of 538608 done; Stage: 52%; Total: 6%; ETA: 1:07:37 ...Progress: 285856 of 538608 done; Stage: 53%; Total: 6%; ETA: 1:07:40 Progress: 287085 of 538608 done; Stage: 53%; Total: 6%; ETA: 1:07:40 . Progress: 288095 of 538608 done; Stage: 53%; Total: 6%; ETA: 1:07:40 .. Progress: 301276 of 538608 done; Stage: 55%; Total: 6%; ETA: 1:07:44 ...Progress: 302406 of 538608 done; Stage: 56%; Total: 6%; ETA: 1:07:45 Progress: 302479 of 538608 done; Stage: 56%; Total: 6%; ETA: 1:07:43 . Progress: 302512 of 538608 done; Stage: 56%; Total: 6%; ETA: 1:07:42 .. Progress: 307433 of 538608 done; Stage: 57%; Total: 6%; ETA: 1:07:40 ...Progress: 308121 of 538608 done; Stage: 57%; Total: 6%; ETA: 1:07:43 Progress: 308952 of 538608 done; Stage: 57%; Total: 6%; ETA: 1:07:42 . Progress: 309510 of 538608 done; Stage: 57%; Total: 6%; ETA: 1:07:42 .. Progress: 310828 of 538608 done; Stage: 57%; Total: 6%; ETA: 1:07:44 ...Progress: 314656 of 538608 done; Stage: 58%; Total: 6%; ETA: 1:07:47 Progress: 315155 of 538608 done; Stage: 58%; Total: 6%; ETA: 1:07:48 . Progress: 316446 of 538608 done; Stage: 58%; Total: 6%; ETA: 1:07:50 .. Progress: 316803 of 538608 done; Stage: 58%; Total: 6%; ETA: 1:07:52 ...Progress: 317904 of 538608 done; Stage: 59%; Total: 6%; ETA: 1:07:53 Progress: 319957 of 538608 done; Stage: 59%; Total: 6%; ETA: 1:07:56 . Progress: 320231 of 538608 done; Stage: 59%; Total: 6%; ETA: 1:07:56 .. Progress: 321084 of 538608 done; Stage: 59%; Total: 6%; ETA: 1:07:55 ...Progress: 323383 of 538608 done; Stage: 60%; Total: 6%; ETA: 1:07:57 Progress: 328148 of 538608 done; Stage: 60%; Total: 6%; ETA: 1:07:58 . Progress: 332900 of 538608 done; Stage: 61%; Total: 6%; ETA: 1:08:01 .. Progress: 355048 of 538608 done; Stage: 65%; Total: 6%; ETA: 1:08:01 ...Progress: 382308 of 538608 done; Stage: 70%; Total: 6%; ETA: 1:08:04 Progress: 410631 of 538608 done; Stage: 76%; Total: 6%; ETA: 1:08:09 . Progress: 412015 of 538608 done; Stage: 76%; Total: 6%; ETA: 1:08:08 .. Progress: 418790 of 538608 done; Stage: 77%; Total: 6%; ETA: 1:08:11 ...Progress: 419786 of 538608 done; Stage: 77%; Total: 6%; ETA: 1:08:14 Progress: 422807 of 538608 done; Stage: 78%; Total: 6%; ETA: 1:08:17 . Progress: 427396 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:19 .. Progress: 428774 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:20 ...Progress: 428915 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:21 Progress: 429417 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:19 . Progress: 430507 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:19 .. Progress: 430674 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:17 ...Progress: 430815 of 538608 done; Stage: 79%; Total: 6%; ETA: 1:08:14 Progress: 431447 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:14 . Progress: 432283 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:14 .. Progress: 433080 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:14 ...Progress: 434049 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:16 Progress: 434869 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:16 . Progress: 435561 of 538608 done; Stage: 80%; Total: 6%; ETA: 1:08:17 .. Progress: 436814 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:19 ...Progress: 438293 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:20 Progress: 439248 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:20 . Progress: 439889 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:20 .. Progress: 440984 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:20 ...Progress: 441542 of 538608 done; Stage: 81%; Total: 6%; ETA: 1:08:21 Progress: 442494 of 538608 done; Stage: 82%; Total: 6%; ETA: 1:08:22 . Progress: 443807 of 538608 done; Stage: 82%; Total: 6%; ETA: 1:08:22 .. Progress: 444921 of 538608 done; Stage: 82%; Total: 6%; ETA: 1:08:24 ...Progress: 445734 of 538608 done; Stage: 82%; Total: 6%; ETA: 1:08:25 Progress: 447240 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:25 . Progress: 448119 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:25 .. Progress: 448836 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:24 ...Progress: 449983 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:24 Progress: 450749 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:23 . Progress: 451518 of 538608 done; Stage: 83%; Total: 6%; ETA: 1:08:22 .. Progress: 452500 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:22 ...Progress: 453646 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:20 Progress: 454458 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:20 . Progress: 455083 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:24 .. Progress: 455954 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:24 ...Progress: 457563 of 538608 done; Stage: 84%; Total: 6%; ETA: 1:08:25 Progress: 458063 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:27 . Progress: 460196 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:28 .. Progress: 460525 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:28 ...Progress: 460623 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:27 Progress: 460789 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:26 . Progress: 461168 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:24 .. Progress: 461300 of 538608 done; Stage: 85%; Total: 6%; ETA: 1:08:24 ...Progress: 468190 of 538608 done; Stage: 86%; Total: 6%; ETA: 1:08:25 Progress: 512213 of 538608 done; Stage: 95%; Total: 6%; ETA: 1:08:30 . Progress: 514356 of 538608 done; Stage: 95%; Total: 6%; ETA: 1:08:30 .. Progress: 514969 of 538608 done; Stage: 95%; Total: 6%; ETA: 1:08:30 ...Progress: 517248 of 538608 done; Stage: 96%; Total: 6%; ETA: 1:08:30 Progress: 518933 of 538608 done; Stage: 96%; Total: 6%; ETA: 1:08:31 . Progress: 520226 of 538608 done; Stage: 96%; Total: 7%; ETA: 1:08:32 .. Progress: 520933 of 538608 done; Stage: 96%; Total: 7%; ETA: 1:08:32 ...Progress: 523059 of 538608 done; Stage: 97%; Total: 7%; ETA: 1:08:32 Progress: 530832 of 538608 done; Stage: 98%; Total: 7%; ETA: 1:08:35 . Progress: 530923 of 538608 done; Stage: 98%; Total: 7%; ETA: 1:08:32 .. Progress: 532778 of 538608 done; Stage: 98%; Total: 7%; ETA: 1:08:30 ...Progress: 533412 of 538608 done; Stage: 99%; Total: 7%; ETA: 1:08:30 Progress: 533675 of 538608 done; Stage: 99%; Total: 7%; ETA: 1:08:31 . Progress: 534579 of 538608 done; Stage: 99%; Total: 7%; ETA: 1:08:30 .. Progress: 535786 of 538608 done; Stage: 99%; Total: 7%; ETA: 1:08:30 ...Progress: 538608 of 538608 done; Stage: 100%; Total: 7%; ETA: 1:08:30 538608 files processed.
File data verification completed.
Stage 5: Looking for bad, free clusters ...
Progress: 2773 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:07:04 . Progress: 97801 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:06:48 .. Progress: 284728 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:06:11 ...Progress: 599346 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:05:03 Progress: 1035657 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:03:34 . Progress: 1526013 of 229280235 done; Stage: 0%; Total: 7%; ETA: 1:01:56 .. Progress: 2036805 of 229280235 done; Stage: 0%; Total: 8%; ETA: 1:00:19 ...Progress: 2567490 of 229280235 done; Stage: 1%; Total: 8%; ETA: 0:58:42 Progress: 3083303 of 229280235 done; Stage: 1%; Total: 8%; ETA: 0:57:13 . Progress: 3612995 of 229280235 done; Stage: 1%; Total: 8%; ETA: 0:55:46 .. Progress: 4136382 of 229280235 done; Stage: 1%; Total: 8%; ETA: 0:54:25 ...Progress: 4675383 of 229280235 done; Stage: 2%; Total: 9%; ETA: 0:53:04 Progress: 5218161 of 229280235 done; Stage: 2%; Total: 9%; ETA: 0:51:47 . Progress: 5760655 of 229280235 done; Stage: 2%; Total: 9%; ETA: 0:50:33 .. Progress: 6305881 of 229280235 done; Stage: 2%; Total: 9%; ETA: 0:49:22 ...Progress: 6903924 of 229280235 done; Stage: 3%; Total: 10%; ETA: 0:48:07 Progress: 7451307 of 229280235 done; Stage: 3%; Total: 10%; ETA: 0:47:02 . Progress: 7988759 of 229280235 done; Stage: 3%; Total: 10%; ETA: 0:46:02 .. Progress: 8541046 of 229280235 done; Stage: 3%; Total: 10%; ETA: 0:45:02 ...Progress: 9134046 of 229280235 done; Stage: 3%; Total: 10%; ETA: 0:43:59 Progress: 9684046 of 229280235 done; Stage: 4%; Total: 11%; ETA: 0:43:04 . Progress: 10233046 of 229280235 done; Stage: 4%; Total: 11%; ETA: 0:42:12 .. Progress: 10787046 of 229280235 done; Stage: 4%; Total: 11%; ETA: 0:41:20 ...Progress: 11347046 of 229280235 done; Stage: 4%; Total: 11%; ETA: 0:40:30 Progress: 11904046 of 229280235 done; Stage: 5%; Total: 12%; ETA: 0:39:42 . Progress: 12458046 of 229280235 done; Stage: 5%; Total: 12%; ETA: 0:38:57 .. Progress: 13017046 of 229280235 done; Stage: 5%; Total: 12%; ETA: 0:38:12 ...Progress: 13570046 of 229280235 done; Stage: 5%; Total: 12%; ETA: 0:37:29 Progress: 14106046 of 229280235 done; Stage: 6%; Total: 12%; ETA: 0:36:49 . Progress: 14660046 of 229280235 done; Stage: 6%; Total: 13%; ETA: 0:36:10 .. Progress: 15205046 of 229280235 done; Stage: 6%; Total: 13%; ETA: 0:35:32 ...Progress: 15759046 of 229280235 done; Stage: 6%; Total: 13%; ETA: 0:34:55 Progress: 16308046 of 229280235 done; Stage: 7%; Total: 13%; ETA: 0:34:19 . Progress: 16874046 of 229280235 done; Stage: 7%; Total: 14%; ETA: 0:33:43 .. Progress: 17426046 of 229280235 done; Stage: 7%; Total: 14%; ETA: 0:33:10 ...Progress: 17985046 of 229280235 done; Stage: 7%; Total: 14%; ETA: 0:32:36 Progress: 18538046 of 229280235 done; Stage: 8%; Total: 14%; ETA: 0:32:04 . Progress: 19101046 of 229280235 done; Stage: 8%; Total: 14%; ETA: 0:31:32 .. Progress: 19656046 of 229280235 done; Stage: 8%; Total: 15%; ETA: 0:31:03 ...Progress: 20191046 of 229280235 done; Stage: 8%; Total: 15%; ETA: 0:30:35 Progress: 20749046 of 229280235 done; Stage: 9%; Total: 15%; ETA: 0:30:06 . Progress: 21355046 of 229280235 done; Stage: 9%; Total: 15%; ETA: 0:29:35 .. Progress: 21973046 of 229280235 done; Stage: 9%; Total: 16%; ETA: 0:29:05 ...Progress: 22541046 of 229280235 done; Stage: 9%; Total: 16%; ETA: 0:28:39 Progress: 23093046 of 229280235 done; Stage: 10%; Total: 16%; ETA: 0:28:14 . Progress: 23651046 of 229280235 done; Stage: 10%; Total: 16%; ETA: 0:27:49 .. Progress: 24209046 of 229280235 done; Stage: 10%; Total: 17%; ETA: 0:27:25 ...Progress: 24759046 of 229280235 done; Stage: 10%; Total: 17%; ETA: 0:27:02 Progress: 25309046 of 229280235 done; Stage: 11%; Total: 17%; ETA: 0:26:39 . Progress: 25856046 of 229280235 done; Stage: 11%; Total: 17%; ETA: 0:26:17 .. Progress: 26404046 of 229280235 done; Stage: 11%; Total: 17%; ETA: 0:25:56 ...Progress: 26952046 of 229280235 done; Stage: 11%; Total: 18%; ETA: 0:25:35 Progress: 27532046 of 229280235 done; Stage: 12%; Total: 18%; ETA: 0:25:13 . Progress: 28164046 of 229280235 done; Stage: 12%; Total: 18%; ETA: 0:24:51 .. Progress: 28732046 of 229280235 done; Stage: 12%; Total: 18%; ETA: 0:24:30 ...Progress: 29331046 of 229280235 done; Stage: 12%; Total: 19%; ETA: 0:24:09 Progress: 29895046 of 229280235 done; Stage: 13%; Total: 19%; ETA: 0:23:50 . Progress: 30449046 of 229280235 done; Stage: 13%; Total: 19%; ETA: 0:23:32 .. Progress: 31003046 of 229280235 done; Stage: 13%; Total: 19%; ETA: 0:23:14 ...Progress: 31553046 of 229280235 done; Stage: 13%; Total: 20%; ETA: 0:22:57 Progress: 32100046 of 229280235 done; Stage: 14%; Total: 20%; ETA: 0:22:39 . Progress: 32656046 of 229280235 done; Stage: 14%; Total: 20%; ETA: 0:22:23 .. Progress: 33204046 of 229280235 done; Stage: 14%; Total: 20%; ETA: 0:22:07 ...Progress: 33743046 of 229280235 done; Stage: 14%; Total: 20%; ETA: 0:21:51 Progress: 34300046 of 229280235 done; Stage: 14%; Total: 21%; ETA: 0:21:35 . Progress: 34853046 of 229280235 done; Stage: 15%; Total: 21%; ETA: 0:21:19 .. Progress: 35401046 of 229280235 done; Stage: 15%; Total: 21%; ETA: 0:21:05 ...Progress: 35948046 of 229280235 done; Stage: 15%; Total: 21%; ETA: 0:20:51 Progress: 36499046 of 229280235 done; Stage: 15%; Total: 22%; ETA: 0:20:36 . Progress: 37057046 of 229280235 done; Stage: 16%; Total: 22%; ETA: 0:20:22 .. Progress: 37618046 of 229280235 done; Stage: 16%; Total: 22%; ETA: 0:20:07 ...Progress: 38173046 of 229280235 done; Stage: 16%; Total: 22%; ETA: 0:19:55 Progress: 38715046 of 229280235 done; Stage: 16%; Total: 22%; ETA: 0:19:40 . Progress: 39263046 of 229280235 done; Stage: 17%; Total: 23%; ETA: 0:19:27 .. Progress: 39811046 of 229280235 done; Stage: 17%; Total: 23%; ETA: 0:19:15 ...Progress: 40380046 of 229280235 done; Stage: 17%; Total: 23%; ETA: 0:19:02 Progress: 40947046 of 229280235 done; Stage: 17%; Total: 23%; ETA: 0:18:49 . Progress: 41495046 of 229280235 done; Stage: 18%; Total: 24%; ETA: 0:18:38 .. Progress: 42048046 of 229280235 done; Stage: 18%; Total: 24%; ETA: 0:18:25 ...Progress: 42600046 of 229280235 done; Stage: 18%; Total: 24%; ETA: 0:18:14 Progress: 43156046 of 229280235 done; Stage: 18%; Total: 24%; ETA: 0:18:01 . Progress: 43710046 of 229280235 done; Stage: 19%; Total: 24%; ETA: 0:17:50 .. Progress: 44278046 of 229280235 done; Stage: 19%; Total: 25%; ETA: 0:17:39 ...Progress: 44827046 of 229280235 done; Stage: 19%; Total: 25%; ETA: 0:17:27 Progress: 45372046 of 229280235 done; Stage: 19%; Total: 25%; ETA: 0:17:18 . Progress: 45930046 of 229280235 done; Stage: 20%; Total: 25%; ETA: 0:17:07 .. Progress: 46480046 of 229280235 done; Stage: 20%; Total: 26%; ETA: 0:16:55 ...Progress: 47029046 of 229280235 done; Stage: 20%; Total: 26%; ETA: 0:16:46 Progress: 47571046 of 229280235 done; Stage: 20%; Total: 26%; ETA: 0:16:36 . Progress: 48121046 of 229280235 done; Stage: 20%; Total: 26%; ETA: 0:16:27 .. Progress: 48665046 of 229280235 done; Stage: 21%; Total: 26%; ETA: 0:16:17 ...Progress: 49208046 of 229280235 done; Stage: 21%; Total: 27%; ETA: 0:16:07 Progress: 49779046 of 229280235 done; Stage: 21%; Total: 27%; ETA: 0:15:58 . Progress: 50365046 of 229280235 done; Stage: 21%; Total: 27%; ETA: 0:15:47 .. Progress: 50907046 of 229280235 done; Stage: 22%; Total: 27%; ETA: 0:15:39 ...Progress: 51471046 of 229280235 done; Stage: 22%; Total: 28%; ETA: 0:15:29 Progress: 52025046 of 229280235 done; Stage: 22%; Total: 28%; ETA: 0:15:19 . Progress: 52583046 of 229280235 done; Stage: 22%; Total: 28%; ETA: 0:15:11 .. Progress: 53138046 of 229280235 done; Stage: 23%; Total: 28%; ETA: 0:15:02 ...Progress: 53675046 of 229280235 done; Stage: 23%; Total: 28%; ETA: 0:14:54 Progress: 54213046 of 229280235 done; Stage: 23%; Total: 29%; ETA: 0:14:46 . Progress: 54764046 of 229280235 done; Stage: 23%; Total: 29%; ETA: 0:14:38 .. Progress: 55316046 of 229280235 done; Stage: 24%; Total: 29%; ETA: 0:14:30 ...Progress: 55871046 of 229280235 done; Stage: 24%; Total: 29%; ETA: 0:14:22 Progress: 56418046 of 229280235 done; Stage: 24%; Total: 30%; ETA: 0:14:14 . Progress: 56972046 of 229280235 done; Stage: 24%; Total: 30%; ETA: 0:14:06 .. Progress: 57517046 of 229280235 done; Stage: 25%; Total: 30%; ETA: 0:13:58 ...Progress: 58072046 of 229280235 done; Stage: 25%; Total: 30%; ETA: 0:13:50 Progress: 58626046 of 229280235 done; Stage: 25%; Total: 30%; ETA: 0:13:43 . Progress: 59179046 of 229280235 done; Stage: 25%; Total: 31%; ETA: 0:13:35 .. Progress: 59734046 of 229280235 done; Stage: 26%; Total: 31%; ETA: 0:13:27 ...Progress: 60284046 of 229280235 done; Stage: 26%; Total: 31%; ETA: 0:13:21 Progress: 60826046 of 229280235 done; Stage: 26%; Total: 31%; ETA: 0:13:13 . Progress: 61369046 of 229280235 done; Stage: 26%; Total: 32%; ETA: 0:13:07 .. Progress: 61912046 of 229280235 done; Stage: 27%; Total: 32%; ETA: 0:13:00 ...Progress: 62462046 of 229280235 done; Stage: 27%; Total: 32%; ETA: 0:12:54 Progress: 63022046 of 229280235 done; Stage: 27%; Total: 32%; ETA: 0:12:46 . Progress: 63576046 of 229280235 done; Stage: 27%; Total: 32%; ETA: 0:12:39 .. Progress: 64126046 of 229280235 done; Stage: 27%; Total: 33%; ETA: 0:12:33 ...Progress: 64672046 of 229280235 done; Stage: 28%; Total: 33%; ETA: 0:12:27 Progress: 65224046 of 229280235 done; Stage: 28%; Total: 33%; ETA: 0:12:20 . Progress: 65776046 of 229280235 done; Stage: 28%; Total: 33%; ETA: 0:12:14 .. Progress: 66325046 of 229280235 done; Stage: 28%; Total: 34%; ETA: 0:12:07 ...Progress: 66877046 of 229280235 done; Stage: 29%; Total: 34%; ETA: 0:12:01 Progress: 67424046 of 229280235 done; Stage: 29%; Total: 34%; ETA: 0:11:55 . Progress: 67951046 of 229280235 done; Stage: 29%; Total: 34%; ETA: 0:11:50 .. Progress: 68493046 of 229280235 done; Stage: 29%; Total: 34%; ETA: 0:11:43 ...Progress: 69047046 of 229280235 done; Stage: 30%; Total: 35%; ETA: 0:11:37 Progress: 69599046 of 229280235 done; Stage: 30%; Total: 35%; ETA: 0:11:32 . Progress: 70160046 of 229280235 done; Stage: 30%; Total: 35%; ETA: 0:11:26 .. Progress: 70712046 of 229280235 done; Stage: 30%; Total: 35%; ETA: 0:11:19 ...Progress: 71268046 of 229280235 done; Stage: 31%; Total: 36%; ETA: 0:11:15 Progress: 71827046 of 229280235 done; Stage: 31%; Total: 36%; ETA: 0:11:08 . Progress: 72374046 of 229280235 done; Stage: 31%; Total: 36%; ETA: 0:11:03 .. Progress: 72922046 of 229280235 done; Stage: 31%; Total: 36%; ETA: 0:10:57 ...Progress: 73489046 of 229280235 done; Stage: 32%; Total: 36%; ETA: 0:10:52 Progress: 74049046 of 229280235 done; Stage: 32%; Total: 37%; ETA: 0:10:46 . Progress: 74624046 of 229280235 done; Stage: 32%; Total: 37%; ETA: 0:10:41 .. Progress: 75180046 of 229280235 done; Stage: 32%; Total: 37%; ETA: 0:10:36 ...Progress: 75734046 of 229280235 done; Stage: 33%; Total: 37%; ETA: 0:10:30 Progress: 76284046 of 229280235 done; Stage: 33%; Total: 38%; ETA: 0:10:25 . Progress: 76833046 of 229280235 done; Stage: 33%; Total: 38%; ETA: 0:10:20 .. Progress: 77384046 of 229280235 done; Stage: 33%; Total: 38%; ETA: 0:10:15 ...Progress: 77946046 of 229280235 done; Stage: 33%; Total: 38%; ETA: 0:10:11 Progress: 78534046 of 229280235 done; Stage: 34%; Total: 39%; ETA: 0:10:04 . Progress: 79083046 of 229280235 done; Stage: 34%; Total: 39%; ETA: 0:09:59 .. Progress: 79644046 of 229280235 done; Stage: 34%; Total: 39%; ETA: 0:09:55 ...Progress: 80190046 of 229280235 done; Stage: 34%; Total: 39%; ETA: 0:09:50 Progress: 80758046 of 229280235 done; Stage: 35%; Total: 39%; ETA: 0:09:45 . Progress: 81312046 of 229280235 done; Stage: 35%; Total: 40%; ETA: 0:09:40 .. Progress: 81873046 of 229280235 done; Stage: 35%; Total: 40%; ETA: 0:09:36 ...Progress: 82425046 of 229280235 done; Stage: 35%; Total: 40%; ETA: 0:09:32 Progress: 82971046 of 229280235 done; Stage: 36%; Total: 40%; ETA: 0:09:27 . Progress: 83512046 of 229280235 done; Stage: 36%; Total: 41%; ETA: 0:09:23 .. Progress: 84070046 of 229280235 done; Stage: 36%; Total: 41%; ETA: 0:09:18 ...Progress: 84632046 of 229280235 done; Stage: 36%; Total: 41%; ETA: 0:09:13 Progress: 85181046 of 229280235 done; Stage: 37%; Total: 41%; ETA: 0:09:10 . Progress: 85733046 of 229280235 done; Stage: 37%; Total: 41%; ETA: 0:09:05 .. Progress: 86282046 of 229280235 done; Stage: 37%; Total: 42%; ETA: 0:09:00 ...Progress: 86822046 of 229280235 done; Stage: 37%; Total: 42%; ETA: 0:08:57 Progress: 87378046 of 229280235 done; Stage: 38%; Total: 42%; ETA: 0:08:52 . Progress: 87926046 of 229280235 done; Stage: 38%; Total: 42%; ETA: 0:08:49 .. Progress: 88470046 of 229280235 done; Stage: 38%; Total: 43%; ETA: 0:08:44 ...Progress: 89013046 of 229280235 done; Stage: 38%; Total: 43%; ETA: 0:08:40 Progress: 89555046 of 229280235 done; Stage: 39%; Total: 43%; ETA: 0:08:36 . Progress: 90104046 of 229280235 done; Stage: 39%; Total: 43%; ETA: 0:08:33 .. Progress: 90658046 of 229280235 done; Stage: 39%; Total: 43%; ETA: 0:08:28 ...Progress: 91240046 of 229280235 done; Stage: 39%; Total: 44%; ETA: 0:08:23 Progress: 91842046 of 229280235 done; Stage: 40%; Total: 44%; ETA: 0:08:20 . Progress: 92409046 of 229280235 done; Stage: 40%; Total: 44%; ETA: 0:08:15 .. Progress: 92961046 of 229280235 done; Stage: 40%; Total: 44%; ETA: 0:08:12 ...Progress: 93507046 of 229280235 done; Stage: 40%; Total: 45%; ETA: 0:08:07 Progress: 94056046 of 229280235 done; Stage: 41%; Total: 45%; ETA: 0:08:04 . Progress: 94610046 of 229280235 done; Stage: 41%; Total: 45%; ETA: 0:08:01 .. Progress: 95160046 of 229280235 done; Stage: 41%; Total: 45%; ETA: 0:07:56 ...Progress: 95703046 of 229280235 done; Stage: 41%; Total: 45%; ETA: 0:07:53 Progress: 96250046 of 229280235 done; Stage: 41%; Total: 46%; ETA: 0:07:50 . Progress: 96794046 of 229280235 done; Stage: 42%; Total: 46%; ETA: 0:07:47 .. Progress: 97350046 of 229280235 done; Stage: 42%; Total: 46%; ETA: 0:07:42 ...Progress: 97893046 of 229280235 done; Stage: 42%; Total: 46%; ETA: 0:07:39 Progress: 98445046 of 229280235 done; Stage: 42%; Total: 47%; ETA: 0:07:35 . Progress: 99001046 of 229280235 done; Stage: 43%; Total: 47%; ETA: 0:07:32 .. Progress: 99556046 of 229280235 done; Stage: 43%; Total: 47%; ETA: 0:07:29 ...Progress: 100102046 of 229280235 done; Stage: 43%; Total: 47%; ETA: 0:07:26 Progress: 100647046 of 229280235 done; Stage: 43%; Total: 47%; ETA: 0:07:21 . Progress: 101195046 of 229280235 done; Stage: 44%; Total: 48%; ETA: 0:07:18 .. Progress: 101736046 of 229280235 done; Stage: 44%; Total: 48%; ETA: 0:07:15 ...Progress: 102286046 of 229280235 done; Stage: 44%; Total: 48%; ETA: 0:07:11 Progress: 102842046 of 229280235 done; Stage: 44%; Total: 48%; ETA: 0:07:08 . Progress: 103394046 of 229280235 done; Stage: 45%; Total: 49%; ETA: 0:07:05 .. Progress: 103942046 of 229280235 done; Stage: 45%; Total: 49%; ETA: 0:07:02 ...Progress: 104487046 of 229280235 done; Stage: 45%; Total: 49%; ETA: 0:06:59 Progress: 105030046 of 229280235 done; Stage: 45%; Total: 49%; ETA: 0:06:55 . Progress: 105578046 of 229280235 done; Stage: 46%; Total: 49%; ETA: 0:06:52 .. Progress: 106117046 of 229280235 done; Stage: 46%; Total: 50%; ETA: 0:06:49 ...Progress: 106673046 of 229280235 done; Stage: 46%; Total: 50%; ETA: 0:06:46 Progress: 107221307 of 229280235 done; Stage: 46%; Total: 50%; ETA: 0:06:43 . Progress: 107760171 of 229280235 done; Stage: 46%; Total: 50%; ETA: 0:06:39 .. Progress: 108303171 of 229280235 done; Stage: 47%; Total: 51%; ETA: 0:06:36 ...Progress: 108866171 of 229280235 done; Stage: 47%; Total: 51%; ETA: 0:06:34 Progress: 109411171 of 229280235 done; Stage: 47%; Total: 51%; ETA: 0:06:31 . Progress: 109958171 of 229280235 done; Stage: 47%; Total: 51%; ETA: 0:06:28 .. Progress: 110515171 of 229280235 done; Stage: 48%; Total: 51%; ETA: 0:06:25 ...Progress: 111049171 of 229280235 done; Stage: 48%; Total: 52%; ETA: 0:06:22 Progress: 111598171 of 229280235 done; Stage: 48%; Total: 52%; ETA: 0:06:19 . Progress: 112139171 of 229280235 done; Stage: 48%; Total: 52%; ETA: 0:06:16 .. Progress: 112698171 of 229280235 done; Stage: 49%; Total: 52%; ETA: 0:06:14 ...Progress: 113243171 of 229280235 done; Stage: 49%; Total: 53%; ETA: 0:06:11 Progress: 113807171 of 229280235 done; Stage: 49%; Total: 53%; ETA: 0:06:07 . Progress: 114341171 of 229280235 done; Stage: 49%; Total: 53%; ETA: 0:06:04 .. Progress: 114894171 of 229280235 done; Stage: 50%; Total: 53%; ETA: 0:06:03 ...Progress: 115434171 of 229280235 done; Stage: 50%; Total: 53%; ETA: 0:05:59 Progress: 115980171 of 229280235 done; Stage: 50%; Total: 54%; ETA: 0:05:56 . Progress: 116531171 of 229280235 done; Stage: 50%; Total: 54%; ETA: 0:05:53 .. Progress: 117077171 of 229280235 done; Stage: 51%; Total: 54%; ETA: 0:05:51 ...Progress: 117606171 of 229280235 done; Stage: 51%; Total: 54%; ETA: 0:05:48 Progress: 118146171 of 229280235 done; Stage: 51%; Total: 55%; ETA: 0:05:45 . Progress: 118702171 of 229280235 done; Stage: 51%; Total: 55%; ETA: 0:05:43 .. Progress: 119258171 of 229280235 done; Stage: 52%; Total: 55%; ETA: 0:05:40 ...Progress: 119805171 of 229280235 done; Stage: 52%; Total: 55%; ETA: 0:05:37 Progress: 120346171 of 229280235 done; Stage: 52%; Total: 55%; ETA: 0:05:35 . Progress: 120906171 of 229280235 done; Stage: 52%; Total: 56%; ETA: 0:05:32 .. Progress: 121462171 of 229280235 done; Stage: 52%; Total: 56%; ETA: 0:05:29 ...Progress: 122015171 of 229280235 done; Stage: 53%; Total: 56%; ETA: 0:05:27 Progress: 122551171 of 229280235 done; Stage: 53%; Total: 56%; ETA: 0:05:24 . Progress: 123101171 of 229280235 done; Stage: 53%; Total: 57%; ETA: 0:05:23 .. Progress: 123679171 of 229280235 done; Stage: 53%; Total: 57%; ETA: 0:05:19 ...Progress: 124260171 of 229280235 done; Stage: 54%; Total: 57%; ETA: 0:05:16 Progress: 124822171 of 229280235 done; Stage: 54%; Total: 57%; ETA: 0:05:15 . Progress: 125373171 of 229280235 done; Stage: 54%; Total: 57%; ETA: 0:05:11 .. Progress: 125924171 of 229280235 done; Stage: 54%; Total: 58%; ETA: 0:05:10 ...Progress: 126473171 of 229280235 done; Stage: 55%; Total: 58%; ETA: 0:05:07 Progress: 127032171 of 229280235 done; Stage: 55%; Total: 58%; ETA: 0:05:04 . Progress: 127582171 of 229280235 done; Stage: 55%; Total: 58%; ETA: 0:05:02 .. Progress: 128171171 of 229280235 done; Stage: 55%; Total: 59%; ETA: 0:04:59 ...Progress: 128724171 of 229280235 done; Stage: 56%; Total: 59%; ETA: 0:04:57 Progress: 129271171 of 229280235 done; Stage: 56%; Total: 59%; ETA: 0:04:54 . Progress: 129818171 of 229280235 done; Stage: 56%; Total: 59%; ETA: 0:04:52 .. Progress: 130376171 of 229280235 done; Stage: 56%; Total: 59%; ETA: 0:04:49 ...Progress: 130940171 of 229280235 done; Stage: 57%; Total: 60%; ETA: 0:04:47 Progress: 131487171 of 229280235 done; Stage: 57%; Total: 60%; ETA: 0:04:44 . Progress: 132035171 of 229280235 done; Stage: 57%; Total: 60%; ETA: 0:04:43 .. Progress: 132577171 of 229280235 done; Stage: 57%; Total: 60%; ETA: 0:04:41 ...Progress: 133142171 of 229280235 done; Stage: 58%; Total: 61%; ETA: 0:04:38 Progress: 133691171 of 229280235 done; Stage: 58%; Total: 61%; ETA: 0:04:36 . Progress: 134230171 of 229280235 done; Stage: 58%; Total: 61%; ETA: 0:04:33 .. Progress: 134778171 of 229280235 done; Stage: 58%; Total: 61%; ETA: 0:04:31 ...Progress: 135323171 of 229280235 done; Stage: 59%; Total: 61%; ETA: 0:04:30 Progress: 135864171 of 229280235 done; Stage: 59%; Total: 62%; ETA: 0:04:27 . Progress: 136415171 of 229280235 done; Stage: 59%; Total: 62%; ETA: 0:04:25 .. Progress: 136972171 of 229280235 done; Stage: 59%; Total: 62%; ETA: 0:04:22 ...Progress: 137551171 of 229280235 done; Stage: 59%; Total: 62%; ETA: 0:04:20 Progress: 138113171 of 229280235 done; Stage: 60%; Total: 63%; ETA: 0:04:19 . Progress: 138666171 of 229280235 done; Stage: 60%; Total: 63%; ETA: 0:04:15 .. Progress: 139203171 of 229280235 done; Stage: 60%; Total: 63%; ETA: 0:04:14 ...Progress: 139737171 of 229280235 done; Stage: 60%; Total: 63%; ETA: 0:04:12 Progress: 140334171 of 229280235 done; Stage: 61%; Total: 64%; ETA: 0:04:09 . Progress: 140945171 of 229280235 done; Stage: 61%; Total: 64%; ETA: 0:04:07 .. Progress: 141517171 of 229280235 done; Stage: 61%; Total: 64%; ETA: 0:04:04 ...Progress: 142055171 of 229280235 done; Stage: 61%; Total: 64%; ETA: 0:04:03 Progress: 142594171 of 229280235 done; Stage: 62%; Total: 64%; ETA: 0:04:01 . Progress: 143140171 of 229280235 done; Stage: 62%; Total: 65%; ETA: 0:03:58 .. Progress: 143688171 of 229280235 done; Stage: 62%; Total: 65%; ETA: 0:03:56 ...Progress: 144243171 of 229280235 done; Stage: 62%; Total: 65%; ETA: 0:03:55 Progress: 144787171 of 229280235 done; Stage: 63%; Total: 65%; ETA: 0:03:53 . Progress: 145331171 of 229280235 done; Stage: 63%; Total: 66%; ETA: 0:03:50 .. Progress: 145877171 of 229280235 done; Stage: 63%; Total: 66%; ETA: 0:03:48 ...Progress: 146425171 of 229280235 done; Stage: 63%; Total: 66%; ETA: 0:03:47 Progress: 146973171 of 229280235 done; Stage: 64%; Total: 66%; ETA: 0:03:45 . Progress: 147530171 of 229280235 done; Stage: 64%; Total: 66%; ETA: 0:03:42 .. Progress: 148096171 of 229280235 done; Stage: 64%; Total: 67%; ETA: 0:03:40 ...Progress: 148644171 of 229280235 done; Stage: 64%; Total: 67%; ETA: 0:03:39 Progress: 149191171 of 229280235 done; Stage: 65%; Total: 67%; ETA: 0:03:37 . Progress: 149735171 of 229280235 done; Stage: 65%; Total: 67%; ETA: 0:03:34 .. Progress: 150274171 of 229280235 done; Stage: 65%; Total: 68%; ETA: 0:03:32 ...Progress: 150823171 of 229280235 done; Stage: 65%; Total: 68%; ETA: 0:03:31 Progress: 151380171 of 229280235 done; Stage: 66%; Total: 68%; ETA: 0:03:29 . Progress: 151923171 of 229280235 done; Stage: 66%; Total: 68%; ETA: 0:03:27 .. Progress: 152471171 of 229280235 done; Stage: 66%; Total: 68%; ETA: 0:03:24 ...Progress: 153028171 of 229280235 done; Stage: 66%; Total: 69%; ETA: 0:03:23 Progress: 153578171 of 229280235 done; Stage: 66%; Total: 69%; ETA: 0:03:21 . Progress: 154135171 of 229280235 done; Stage: 67%; Total: 69%; ETA: 0:03:19 .. Progress: 154692171 of 229280235 done; Stage: 67%; Total: 69%; ETA: 0:03:18 ...Progress: 155247171 of 229280235 done; Stage: 67%; Total: 70%; ETA: 0:03:15 Progress: 155795171 of 229280235 done; Stage: 67%; Total: 70%; ETA: 0:03:13 . Progress: 156357171 of 229280235 done; Stage: 68%; Total: 70%; ETA: 0:03:11 .. Progress: 156902171 of 229280235 done; Stage: 68%; Total: 70%; ETA: 0:03:10 ...Progress: 157441171 of 229280235 done; Stage: 68%; Total: 70%; ETA: 0:03:08 Progress: 157998171 of 229280235 done; Stage: 68%; Total: 71%; ETA: 0:03:07 . Progress: 158552171 of 229280235 done; Stage: 69%; Total: 71%; ETA: 0:03:05 .. Progress: 159094171 of 229280235 done; Stage: 69%; Total: 71%; ETA: 0:03:02 ...Progress: 159647171 of 229280235 done; Stage: 69%; Total: 71%; ETA: 0:03:00 Progress: 160197171 of 229280235 done; Stage: 69%; Total: 72%; ETA: 0:02:59 . Progress: 160748171 of 229280235 done; Stage: 70%; Total: 72%; ETA: 0:02:57 .. Progress: 161308171 of 229280235 done; Stage: 70%; Total: 72%; ETA: 0:02:55 ...Progress: 161868171 of 229280235 done; Stage: 70%; Total: 72%; ETA: 0:02:54 Progress: 162404171 of 229280235 done; Stage: 70%; Total: 72%; ETA: 0:02:52 . Progress: 162973171 of 229280235 done; Stage: 71%; Total: 73%; ETA: 0:02:51 .. Progress: 163519171 of 229280235 done; Stage: 71%; Total: 73%; ETA: 0:02:49 ...Progress: 164054171 of 229280235 done; Stage: 71%; Total: 73%; ETA: 0:02:47 Progress: 164599171 of 229280235 done; Stage: 71%; Total: 73%; ETA: 0:02:44 . Progress: 165152171 of 229280235 done; Stage: 72%; Total: 74%; ETA: 0:02:43 .. Progress: 165695171 of 229280235 done; Stage: 72%; Total: 74%; ETA: 0:02:41 ...Progress: 166250171 of 229280235 done; Stage: 72%; Total: 74%; ETA: 0:02:39 Progress: 166811171 of 229280235 done; Stage: 72%; Total: 74%; ETA: 0:02:38 . Progress: 167361171 of 229280235 done; Stage: 72%; Total: 74%; ETA: 0:02:36 .. Progress: 167913171 of 229280235 done; Stage: 73%; Total: 75%; ETA: 0:02:35 ...Progress: 168465171 of 229280235 done; Stage: 73%; Total: 75%; ETA: 0:02:33 Progress: 169017171 of 229280235 done; Stage: 73%; Total: 75%; ETA: 0:02:31 . Progress: 169571171 of 229280235 done; Stage: 73%; Total: 75%; ETA: 0:02:30 .. Progress: 170117171 of 229280235 done; Stage: 74%; Total: 76%; ETA: 0:02:28 ...Progress: 170659171 of 229280235 done; Stage: 74%; Total: 76%; ETA: 0:02:27 Progress: 171206171 of 229280235 done; Stage: 74%; Total: 76%; ETA: 0:02:25 . Progress: 171765171 of 229280235 done; Stage: 74%; Total: 76%; ETA: 0:02:23 .. Progress: 172307171 of 229280235 done; Stage: 75%; Total: 76%; ETA: 0:02:22 ...Progress: 172864171 of 229280235 done; Stage: 75%; Total: 77%; ETA: 0:02:20 Progress: 173412171 of 229280235 done; Stage: 75%; Total: 77%; ETA: 0:02:19 . Progress: 173945171 of 229280235 done; Stage: 75%; Total: 77%; ETA: 0:02:17 .. Progress: 174489171 of 229280235 done; Stage: 76%; Total: 77%; ETA: 0:02:15 ...Progress: 175050171 of 229280235 done; Stage: 76%; Total: 78%; ETA: 0:02:14 Progress: 175597171 of 229280235 done; Stage: 76%; Total: 78%; ETA: 0:02:12 . Progress: 176138171 of 229280235 done; Stage: 76%; Total: 78%; ETA: 0:02:11 .. Progress: 176694171 of 229280235 done; Stage: 77%; Total: 78%; ETA: 0:02:09 ...Progress: 177235171 of 229280235 done; Stage: 77%; Total: 78%; ETA: 0:02:07 Progress: 177785171 of 229280235 done; Stage: 77%; Total: 79%; ETA: 0:02:06 . Progress: 178333171 of 229280235 done; Stage: 77%; Total: 79%; ETA: 0:02:04 .. Progress: 178881171 of 229280235 done; Stage: 78%; Total: 79%; ETA: 0:02:03 ...Progress: 179429171 of 229280235 done; Stage: 78%; Total: 79%; ETA: 0:02:01 Progress: 179976171 of 229280235 done; Stage: 78%; Total: 80%; ETA: 0:01:59 . Progress: 180504171 of 229280235 done; Stage: 78%; Total: 80%; ETA: 0:01:58 .. Progress: 181055171 of 229280235 done; Stage: 78%; Total: 80%; ETA: 0:01:56 ...Progress: 181614171 of 229280235 done; Stage: 79%; Total: 80%; ETA: 0:01:55 Progress: 182160171 of 229280235 done; Stage: 79%; Total: 80%; ETA: 0:01:53 . Progress: 182705171 of 229280235 done; Stage: 79%; Total: 81%; ETA: 0:01:51 .. Progress: 183248171 of 229280235 done; Stage: 79%; Total: 81%; ETA: 0:01:50 ...Progress: 183793171 of 229280235 done; Stage: 80%; Total: 81%; ETA: 0:01:50 Progress: 184360171 of 229280235 done; Stage: 80%; Total: 81%; ETA: 0:01:48 . Progress: 184928171 of 229280235 done; Stage: 80%; Total: 82%; ETA: 0:01:47 .. Progress: 185489171 of 229280235 done; Stage: 80%; Total: 82%; ETA: 0:01:45 ...Progress: 186109171 of 229280235 done; Stage: 81%; Total: 82%; ETA: 0:01:43 Progress: 186634171 of 229280235 done; Stage: 81%; Total: 82%; ETA: 0:01:42 . Progress: 187217171 of 229280235 done; Stage: 81%; Total: 82%; ETA: 0:01:40 .. Progress: 187751171 of 229280235 done; Stage: 81%; Total: 83%; ETA: 0:01:39 ...Progress: 188335171 of 229280235 done; Stage: 82%; Total: 83%; ETA: 0:01:37 Progress: 188918171 of 229280235 done; Stage: 82%; Total: 83%; ETA: 0:01:35 . Progress: 189474171 of 229280235 done; Stage: 82%; Total: 83%; ETA: 0:01:34 .. Progress: 190018171 of 229280235 done; Stage: 82%; Total: 84%; ETA: 0:01:32 ...Progress: 190572171 of 229280235 done; Stage: 83%; Total: 84%; ETA: 0:01:31 Progress: 191165171 of 229280235 done; Stage: 83%; Total: 84%; ETA: 0:01:29 . Progress: 191707171 of 229280235 done; Stage: 83%; Total: 84%; ETA: 0:01:27 .. Progress: 192241171 of 229280235 done; Stage: 83%; Total: 85%; ETA: 0:01:26 ...Progress: 192796171 of 229280235 done; Stage: 84%; Total: 85%; ETA: 0:01:26 Progress: 193366171 of 229280235 done; Stage: 84%; Total: 85%; ETA: 0:01:24 . Progress: 193950171 of 229280235 done; Stage: 84%; Total: 85%; ETA: 0:01:23 .. Progress: 194546171 of 229280235 done; Stage: 84%; Total: 85%; ETA: 0:01:21 ...Progress: 195082171 of 229280235 done; Stage: 85%; Total: 86%; ETA: 0:01:19 Progress: 195636171 of 229280235 done; Stage: 85%; Total: 86%; ETA: 0:01:18 . Progress: 196208171 of 229280235 done; Stage: 85%; Total: 86%; ETA: 0:01:16 .. Progress: 196778171 of 229280235 done; Stage: 85%; Total: 86%; ETA: 0:01:15 ...Progress: 197339171 of 229280235 done; Stage: 86%; Total: 87%; ETA: 0:01:13 Progress: 197902171 of 229280235 done; Stage: 86%; Total: 87%; ETA: 0:01:11 . Progress: 198453171 of 229280235 done; Stage: 86%; Total: 87%; ETA: 0:01:11 .. Progress: 199029171 of 229280235 done; Stage: 86%; Total: 87%; ETA: 0:01:10 ...Progress: 199647171 of 229280235 done; Stage: 87%; Total: 88%; ETA: 0:01:08 Progress: 200197171 of 229280235 done; Stage: 87%; Total: 88%; ETA: 0:01:07 . Progress: 200744171 of 229280235 done; Stage: 87%; Total: 88%; ETA: 0:01:05 .. Progress: 201305171 of 229280235 done; Stage: 87%; Total: 88%; ETA: 0:01:03 ...Progress: 201855171 of 229280235 done; Stage: 88%; Total: 88%; ETA: 0:01:02 Progress: 202413171 of 229280235 done; Stage: 88%; Total: 89%; ETA: 0:01:02 . Progress: 202956171 of 229280235 done; Stage: 88%; Total: 89%; ETA: 0:01:00 .. Progress: 203499171 of 229280235 done; Stage: 88%; Total: 89%; ETA: 0:00:59 ...Progress: 204043171 of 229280235 done; Stage: 88%; Total: 89%; ETA: 0:00:57 Progress: 204533171 of 229280235 done; Stage: 89%; Total: 89%; ETA: 0:00:55 . Progress: 205077171 of 229280235 done; Stage: 89%; Total: 90%; ETA: 0:00:55 .. Progress: 205653171 of 229280235 done; Stage: 89%; Total: 90%; ETA: 0:00:54 ...Progress: 206198171 of 229280235 done; Stage: 89%; Total: 90%; ETA: 0:00:52 Progress: 206755171 of 229280235 done; Stage: 90%; Total: 90%; ETA: 0:00:51 . Progress: 207378171 of 229280235 done; Stage: 90%; Total: 91%; ETA: 0:00:49 .. Progress: 207924171 of 229280235 done; Stage: 90%; Total: 91%; ETA: 0:00:47 ...Progress: 208395171 of 229280235 done; Stage: 90%; Total: 91%; ETA: 0:00:47 Progress: 208920171 of 229280235 done; Stage: 91%; Total: 91%; ETA: 0:00:46 . Progress: 209464171 of 229280235 done; Stage: 91%; Total: 91%; ETA: 0:00:44 .. Progress: 210003171 of 229280235 done; Stage: 91%; Total: 92%; ETA: 0:00:43 ...Progress: 210538171 of 229280235 done; Stage: 91%; Total: 92%; ETA: 0:00:41 Progress: 211085171 of 229280235 done; Stage: 92%; Total: 92%; ETA: 0:00:41 . Progress: 211641171 of 229280235 done; Stage: 92%; Total: 92%; ETA: 0:00:39 .. Progress: 212172171 of 229280235 done; Stage: 92%; Total: 93%; ETA: 0:00:38 ...Progress: 212633171 of 229280235 done; Stage: 92%; Total: 93%; ETA: 0:00:36 Progress: 213099171 of 229280235 done; Stage: 92%; Total: 93%; ETA: 0:00:36 . Progress: 213586171 of 229280235 done; Stage: 93%; Total: 93%; ETA: 0:00:35 .. Progress: 214126171 of 229280235 done; Stage: 93%; Total: 93%; ETA: 0:00:33 ...Progress: 214660171 of 229280235 done; Stage: 93%; Total: 94%; ETA: 0:00:33 Progress: 215210171 of 229280235 done; Stage: 93%; Total: 94%; ETA: 0:00:31 . Progress: 215766171 of 229280235 done; Stage: 94%; Total: 94%; ETA: 0:00:30 .. Progress: 216342171 of 229280235 done; Stage: 94%; Total: 94%; ETA: 0:00:28 ...Progress: 216910171 of 229280235 done; Stage: 94%; Total: 94%; ETA: 0:00:27 Progress: 217468171 of 229280235 done; Stage: 94%; Total: 95%; ETA: 0:00:27 . Progress: 218035171 of 229280235 done; Stage: 95%; Total: 95%; ETA: 0:00:25 .. Progress: 218596171 of 229280235 done; Stage: 95%; Total: 95%; ETA: 0:00:23 ...Progress: 219165171 of 229280235 done; Stage: 95%; Total: 95%; ETA: 0:00:22 Progress: 219725171 of 229280235 done; Stage: 95%; Total: 96%; ETA: 0:00:20 . Progress: 220289171 of 229280235 done; Stage: 96%; Total: 96%; ETA: 0:00:20 .. Progress: 220857171 of 229280235 done; Stage: 96%; Total: 96%; ETA: 0:00:19 ...Progress: 221398171 of 229280235 done; Stage: 96%; Total: 96%; ETA: 0:00:17 Progress: 221938171 of 229280235 done; Stage: 96%; Total: 97%; ETA: 0:00:15 . Progress: 222490171 of 229280235 done; Stage: 97%; Total: 97%; ETA: 0:00:15 .. Progress: 223028171 of 229280235 done; Stage: 97%; Total: 97%; ETA: 0:00:14 ...Progress: 223517171 of 229280235 done; Stage: 97%; Total: 97%; ETA: 0:00:12 Progress: 224037171 of 229280235 done; Stage: 97%; Total: 97%; ETA: 0:00:12 . Progress: 224635171 of 229280235 done; Stage: 97%; Total: 98%; ETA: 0:00:11 .. Progress: 225232171 of 229280235 done; Stage: 98%; Total: 98%; ETA: 0:00:09 ...Progress: 225895171 of 229280235 done; Stage: 98%; Total: 98%; ETA: 0:00:07 Progress: 226581171 of 229280235 done; Stage: 98%; Total: 98%; ETA: 0:00:06 . Progress: 227137171 of 229280235 done; Stage: 99%; Total: 99%; ETA: 0:00:04 .. Progress: 227655171 of 229280235 done; Stage: 99%; Total: 99%; ETA: 0:00:04 ...Progress: 228201171 of 229280235 done; Stage: 99%; Total: 99%; ETA: 0:00:03 Progress: 228770171 of 229280235 done; Stage: 99%; Total: 99%; ETA: 0:00:01 . Progress: 229280235 of 229280235 done; Stage: 100%; Total: 100%; ETA: 0:00:00 .. 229280235 free clusters processed.
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
No further action is required.
987664383 KB total disk space.
69710232 KB in 296377 files.
192032 KB in 65078 indexes.
0 KB in bad sectors.
641179 KB in use by the system.
65536 KB occupied by the log file.
917120940 KB available on disk.
4096 bytes in each allocation unit.
246916095 total allocation units on disk.
229280235 allocation units available on disk.
Failed to transfer logged messages to the event log with status 50.
thanks for the feedback.
I went through the dump files but only so many would open.
I saw different probable causes ranging from network, conextant audio (flow.exe) and Intel processor driver (part of windows).
I tried to find your system support page and think it's this one:
HP G62-103XX Notebook PC | HP® Customer Support
I could only find drivers for Windows 7 so could you let us know if that is the correct laptop linked above?
Chkdsk found one or two things, try running it again just to make sure all is ok.
That does not appear to be the correct model. This laptop's model is HP ENVY Notebook 15T-AS100. Also, I do not think I will be able to run chkdsk again. I cannot use Active Boot Disk anymore. It is starting to give me BSOD errors as well.
Assuming we do find the correct drivers, how can I install them if the computer wont even boot?
- UPDATE -
I was successfully able to install Linux on the machine after formatting the disk. It works perfectly now, however I am still getting little messages when I first start the computer and at random:
Also, Chrome and Firefox crash often. However, Linux is courteous enough not to shutdown my computer every time there is an exception thrown. There's no such as a BSOD here (as far as I can tell).
It also seems that you were right about the network driver. Linux recognized the problem and did not use it (however, it still is [somehow] using the wireless network adapter to connect to the internet):
So that fixed the biggest problem. No more BSOD errors. Now I just need to find a linux forum so I can put my linux crash reports there :p
Two years later...
I replaced the internal SSD and tried to install Windows, but it is not working. I am getting the following error:
Windows Installation encountered an unexpected error. Verify that the installation sources are accessible, an restart the installation.
Error code: 0xC0000005
I tried replacing the RAM and well but to no avail. Is the processor failing? (I hope not 😰)
