Windows 7 BSOD unknown cause
BExDeath
Been getting BSOD the past few week's and i haven't currently found the fix to my problem.
running on a custom build pc, did some of the hotfixes found on the web (update drivers, disk check, ect) but BSOD is still quite frequent.
here's in my system info and dumps:
View attachment W7F_26-01-2013.rar
Here the cpuZ info (my graphics card is there twice because it is considered 2 different cards)
and my RAMMon info (changed to txt would upload with .html extension):
View attachment RAMMon - SPD Info.txt
help would be greatly appreciated, thanks :)
usasma
Fantastic Member
Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
You have a 32 gB SSD, I'm not certain about these, but please have a look at this canned speech:
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
Wireless network adapter is disabled. Is this deliberate? If so, why?
Please enable it, then update it's drivers, then re-disable it (if so desired).
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions). I strongly suspect that this hold true for Win8 systems also.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
I see both problems with your video and problems with networking. I suggest that you (in addition to the steps above):
- stop overclocking while we're troubleshooting. Feel free to resume the overclock once the BSOD's have stopped.
- do this to replace your video drivers: nVidia Video Cards - DRIVER ONLY installation procedure
- remove your Avast Internet Security - and replace it (temporarily) with a different, free anti-virus (list here: Free AntiVirus )
wacommousefilter.sys Fri Feb 16 13:12:17 2007 (45D5F401)
Wacom(tablet) Mouse Filter
http://www.carrona.org/drivers/driver.php?id=wacommousefilter.sys
WinRing0x64.sys Sat Jul 26 09:29:37 2008 (488B26C1)
many different programs that center around the using of the WinRing libraries (RealTemp, Corsair Link2 (known BSOD issues w/Win8), Razer GameBooster, etc)
http://www.carrona.org/drivers/driver.php?id=WinRing0x64.sys
hamachi.sys Thu Feb 19 05:36:41 2009 (499D3639)
LogMeIn Hamachi Virtual network interface driver
http://www.carrona.org/drivers/driver.php?id=hamachi.sys
PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
Sonic CD/DVD driver (used by many different CD/DVD programs)
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
AiCharger.sys Wed Oct 20 08:00:33 2010 (4CBED9E1)
Asus Charger Driver [br] Likely BSOD cause - haven't seen recently (15Jan2013)
http://www.carrona.org/drivers/driver.php?id=AiCharger.sys
dtsoftbus01.sys Fri Jan 13 08:45:46 2012 (4F10358A)
Daemon Tools driver [br] Possible BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
sptd.sys Sat Aug 18 17:05:38 2012 (503003A2)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
http://www.carrona.org/drivers/driver.php?id=sptd.sys
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sat Jan 26 19:34:27.092 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012613-34850-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 1:50:18.935[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+1df )[/B]
BugCheck [B]3B, {c0000005, fffff8000360ba9b, fffff88015b2c280, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8000360ba9b, Address of the instruction which caused the bugcheck
Arg3: fffff88015b2c280, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]hl2.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ExDeferredFreePool+1df[/B]
CPUID:        "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:     3500
CurrentSpeed: [B]3605[/B]
Processor may be overclocked!
Expected Frequency:   3500
Actual Frequency:     3605
Overclock Ratio:      [color=red]1.03[/color]
  BIOS Version                  1504
  BIOS Release Date             08/03/2012
**************************Sat Jan 26 17:42:26.719 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012613-33415-01.dmp]
System Uptime:[B]0 days 14:22:29.547[/B]
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+142710 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff880087c2710, fffff8800436b978, fffff8800436b1d0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x1000007E]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/url]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff880087c2710, The address that the exception occurred at
Arg3: fffff8800436b978, Exception Record Address
Arg4: fffff8800436b1d0, Context Record Address
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nvlddmkm+142710[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Fri Jan 25 19:26:00.077 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012513-38579-01.dmp]
System Uptime:[B]0 days 0:48:56.920[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeSetEvent+2ce )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80003489800, fffff8800e4407a8, fffff8800e440000}[/B]
Arguments:
Arg2: fffff80003489800, The address that the exception occurred at
Arg3: fffff8800e4407a8, Exception Record Address
Arg4: fffff8800e440000, Context Record Address
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!KeSetEvent+2ce[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Fri Jan 25 18:35:31.533 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012513-29967-01.dmp]
System Uptime:[B]0 days 16:43:02.377[/B]
Probably caused by :[B]ndis.sys ( ndis!ndisDoOidRequests+85 )[/B]
BugCheck [B]19, {20, fffffa801baaae20, fffffa801baabde0, 4fcfff5}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000019]BAD_POOL_HEADER (19)[/url]
Arguments:
Arg1: 0000000000000020, a pool block header size is corrupt.
Arg2: fffffa801baaae20, The pool entry we were looking for within the page.
Arg3: fffffa801baabde0, The next pool entry.
Arg4: 0000000004fcfff5, (reserved)
BUGCHECK_STR:  0x19_20
FAILURE_BUCKET_ID: [B]X64_0x19_20_ndis!ndisDoOidRequests+85[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Wed Jan 23 18:41:06.208 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012313-53742-01.dmp]
System Uptime:[B]1 days 1:23:45.036[/B]
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+bd627 )[/B]
BugCheck [B]C2, {7, 109b, 1bfffd4, fffffa801e33ce40}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C2]BAD_POOL_CALLER (c2)[/url]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000109b, (reserved)
Arg3: 0000000001bfffd4, Memory contents of the pool block
Arg4: fffffa801e33ce40, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7
FAILURE_BUCKET_ID: [B]X64_0xc2_7_nvlddmkm+bd627[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Mon Jan 21 18:12:38.949 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012113-29359-01.dmp]
System Uptime:[B]0 days 1:54:49.792[/B]
*** WARNING: Unable to verify timestamp for aswFW.SYS
*** ERROR: Module load completed but symbols could not be loaded for aswFW.SYS
Probably caused by :[B]aswFW.SYS ( aswFW+5dd6 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff880032a0dd6, fffff88003976fa8, fffff88003976800}[/B]
Arguments:
Arg2: fffff880032a0dd6, The address that the exception occurred at
Arg3: fffff88003976fa8, Exception Record Address
Arg4: fffff88003976800, Context Record Address
BUGCHECK_STR:  0x7E
DEFAULT_BUCKET_ID:  NULL_DEREFERENCE
FAILURE_BUCKET_ID: [B]X64_0x7E_aswFW+5dd6[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Mon Jan 21 16:16:22.557 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012113-25896-01.dmp]
System Uptime:[B]1 days 14:38:03.400[/B]
Probably caused by :[B]memory_corruption ( nt!MiGetPreviousNode+3c )[/B]
BugCheck [B]3B, {c0000005, fffff8000350724c, fffff88017fe5eb0, 0}[/B]
Arguments:
Arg2: fffff8000350724c, Address of the instruction which caused the bugcheck
Arg3: fffff88017fe5eb0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiGetPreviousNode+3c[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Sun Jan 20 00:07:03.751 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012013-25178-01.dmp]
System Uptime:[B]7 days 0:19:12.273[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+249 )[/B]
BugCheck [B]C5, {8, 2, 0, fffff800035b0b05}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C5]DRIVER_CORRUPTED_EXPOOL (c5)[/url]
Arguments:
Arg1: 0000000000000008, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff800035b0b05, address which referenced memory
BUGCHECK_STR:  0xC5_2
FAILURE_BUCKET_ID: [B]X64_0xC5_2_nt!ExDeferredFreePool+249[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Fri Jan 11 17:52:09.196 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011113-30248-01.dmp]
System Uptime:[B]0 days 3:32:05.039[/B]
BugCheck [B]3B, {c0000005, fffff80003602a9b, fffff88019415390, 0}[/B]
Arguments:
Arg2: fffff80003602a9b, Address of the instruction which caused the bugcheck
Arg3: fffff88019415390, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]java.exe[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Sun Dec 30 23:03:22.604 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\123112-29359-01.dmp]
System Uptime:[B]0 days 2:24:16.448[/B]
*** WARNING: Unable to verify timestamp for RTKVHD64.sys
*** ERROR: Module load completed but symbols could not be loaded for RTKVHD64.sys
Probably caused by :[B]RTKVHD64.sys ( RTKVHD64+283054 )[/B]
BugCheck [B]19, {21, fffffa80177df000, 1e10, 22001700221e28}[/B]
Arguments:
Arg1: 0000000000000021, the data following the pool block being freed is corrupt.  Typically this means the consumer (call stack ) has overrun the block.
Arg2: fffffa80177df000, The pool pointer being freed.
Arg3: 0000000000001e10, The number of bytes allocated for the pool block.
Arg4: 0022001700221e28, The corrupted value found following the pool block.
BUGCHECK_STR:  0x19_21
PROCESS_NAME: [B]audiodg.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x19_21_RTKVHD64+283054[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Sun Dec 30 20:37:28.617 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\123012-32697-01.dmp]
System Uptime:[B]1 days 0:56:31.334[/B]
Probably caused by :[B]memory_corruption ( nt!MiIdentifyPfn+26f )[/B]
BugCheck [B]3B, {c0000005, fffff8000358b35f, fffff8800c928b50, 0}[/B]
Arguments:
Arg2: fffff8000358b35f, Address of the instruction which caused the bugcheck
Arg3: fffff8800c928b50, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiIdentifyPfn+26f[/B]
MaxSpeed:     3500
  BIOS Version                  1504
**************************Thu Nov 15 21:02:02.234 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\111512-73726-01.dmp]
System Uptime:[B]0 days 14:32:48.092[/B]
*** WARNING: Unable to verify timestamp for rzudd.sys
*** ERROR: Module load completed but symbols could not be loaded for rzudd.sys
Probably caused by :[B]rzudd.sys ( rzudd+11741 )[/B]
BugCheck [B]D1, {5c, 2, 0, fffff88000ee8993}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 000000000000005c, memory referenced
Arg4: fffff88000ee8993, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_rzudd+11741[/B]
MaxSpeed:     3500
CurrentSpeed: [B]3510[/B]
  BIOS Version                  1504
[/font]
3rd Party Drivers:
[COLOR=RED][B]wacommousefilter.sys        Fri Feb 16 13:12:17 2007 (45D5F401)[/B][/COLOR]
[COLOR=RED][B]WinRing0x64.sys             Sat Jul 26 09:29:37 2008 (488B26C1)[/B][/COLOR]
[COLOR=RED][B]hamachi.sys                 Thu Feb 19 05:36:41 2009 (499D3639)[/B][/COLOR]
[COLOR=RED][B]PxHlpa64.sys                Tue Jun 23 19:16:35 2009 (4A416253)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
wacomvhid.sys               Mon Sep 21 19:29:14 2009 (4AB80C4A)
aswNdis.sys                 Sat Jan  9 16:22:03 2010 (4B48F37B)
IOMap64.sys                 Thu Feb  4 20:55:34 2010 (4B6B7A96)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
ScreamingBAudio64.sys       Thu Jul  1 14:54:32 2010 (4C2CE468)
AsUpIO.sys                  Mon Aug  2 22:47:59 2010 (4C57835F)
AsIO.sys                    Mon Aug 23 21:53:02 2010 (4C7325FE)
[COLOR=RED][B]AiCharger.sys               Wed Oct 20 08:00:33 2010 (4CBED9E1)[/B][/COLOR]
bcmvwl64.sys                Mon Nov 22 08:58:19 2010 (4CEA76FB)
btwl2cap.sys                Fri Feb 11 20:06:04 2011 (4D55DCFC)
mv_process.sys              Tue Feb 22 04:22:20 2011 (4D63804C)
btwdpan.sys                 Mon May 16 10:58:06 2011 (4DD13B7E)
e1q62x64.sys                Tue Jun 21 13:26:21 2011 (4E00D43D)
btwavdt.sys                 Thu Jun 23 10:53:33 2011 (4E03536D)
btwrchid.sys                Thu Jun 23 10:56:51 2011 (4E035433)
btwaudio.sys                Wed Jul  6 18:39:13 2011 (4E14E411)
BCM42RLY.sys                Tue Jul 19 23:22:48 2011 (4E264A08)
e1c62x64.sys                Wed Jul 20 12:37:53 2011 (4E270461)
ndisrd.sys                  Fri Aug 12 06:14:50 2011 (4E44FD1A)
ASUSFILTER.sys              Tue Sep 20 11:46:33 2011 (4E78B559)
btwampfl.sys                Tue Sep 20 13:14:26 2011 (4E78C9F2)
bcbtums.sys                 Tue Oct 18 14:37:25 2011 (4E9DC765)
asmtxhci.sys                Wed Nov  2 23:00:22 2011 (4EB203C6)
asmthub3.sys                Wed Nov  2 23:00:32 2011 (4EB203D0)
aivi0w56.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
asahci64.sys                Thu Jan  5 00:08:19 2012 (4F053043)
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
mv91cons.sys                Thu Jan 19 01:55:35 2012 (4F17BE67)
iaStor.sys                  Wed Feb  1 19:15:24 2012 (4F29D59C)
RTKVHD64.sys                Tue Feb 14 05:55:35 2012 (4F3A3DA7)
iusb3hub.sys                Tue Mar 27 04:09:29 2012 (4F7175B9)
iusb3xhc.sys                Tue Mar 27 04:09:32 2012 (4F7175BC)
iusb3hcs.sys                Tue Mar 27 04:11:21 2012 (4F717629)
automap.sys                 Thu Apr 19 07:30:08 2012 (4F8FF740)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
ICCWDT.sys                  Tue Jul 17 07:04:30 2012 (500546BE)
iocbios2.sys                Mon Aug 13 18:57:20 2012 (50298650)
[COLOR=RED][B]sptd.sys                    Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR]
SynTP.sys                   Wed Oct  3 23:24:55 2012 (506D0187)
aswrdr2.sys                 Mon Oct  8 04:23:43 2012 (50728D8F)
aswFsBlk.SYS                Tue Oct 30 18:43:04 2012 (509057F8)
aswMonFlt.sys               Tue Oct 30 18:43:09 2012 (509057FD)
aswTdi.SYS                  Tue Oct 30 18:43:16 2012 (50905804)
aswKbd.SYS                  Tue Oct 30 18:43:28 2012 (50905810)
aswNdis2.sys                Tue Oct 30 18:43:51 2012 (50905827)
aswSP.SYS                   Tue Oct 30 18:44:06 2012 (50905836)
aswSnx.SYS                  Tue Oct 30 18:44:08 2012 (50905838)
aswFW.SYS                   Tue Oct 30 18:44:20 2012 (50905844)
rzendpt.sys                 Wed Nov  7 02:49:46 2012 (509A129A)
rzhnet.sys                  Wed Nov  7 02:49:46 2012 (509A129A)
rzudd.sys                   Wed Nov  7 02:49:47 2012 (509A129B)
nvlddmkm.sys                Sat Dec 29 01:47:52 2012 (50DE9218)
af1cxfv7.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
aej6gpj8.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
acqpe8ss.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
ams8c17l.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
nvlddmkm.sys                Fri Nov 30 22:24:02 2012 (50B97852)
a1xdrzn7.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
acqaynvg.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
amvdhkda.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
akgmw3zf.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
ajs9krwe.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
abnou9we.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
bcmwl664.sys                Wed Oct 26 22:45:09 2011 (4EA8C5B5)
a5i5yzop.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
rzudd.sys                   Fri Aug 17 03:01:22 2012 (502DEC42)
aswFsBlk.SYS                Tue Aug 21 05:04:55 2012 (50334F37)
aswMonFlt.sys               Tue Aug 21 05:05:00 2012 (50334F3C)
aswTdi.SYS                  Tue Aug 21 05:05:01 2012 (50334F3D)
aswKbd.SYS                  Tue Aug 21 05:05:15 2012 (50334F4B)
aswrdr2.sys                 Tue Aug 21 05:05:16 2012 (50334F4C)
aswNdis2.sys                Tue Aug 21 05:05:38 2012 (50334F62)
aswSP.SYS                   Tue Aug 21 05:05:54 2012 (50334F72)
aswSnx.SYS                  Tue Aug 21 05:05:56 2012 (50334F74)
aswFW.SYS                   Tue Aug 21 05:06:08 2012 (50334F80)
nvlddmkm.sys                Thu Aug 30 11:50:16 2012 (503F8BB8)
rzendpt.sys                 Tue Sep 18 02:21:54 2012 (50581302)
rzhnet.sys                  Tue Oct  9 23:13:26 2012 (5074E7D6)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=wacomvhid.sys
http://www.carrona.org/drivers/driver.php?id=aswNdis.sys
http://www.carrona.org/drivers/driver.php?id=IOMap64.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=ScreamingBAudio64.sys
http://www.carrona.org/drivers/driver.php?id=AsUpIO.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
http://www.carrona.org/drivers/driver.php?id=bcmvwl64.sys
http://www.carrona.org/drivers/driver.php?id=btwl2cap.sys
mv_process.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=btwdpan.sys
http://www.carrona.org/drivers/driver.php?id=e1q62x64.sys
http://www.carrona.org/drivers/driver.php?id=btwavdt.sys
http://www.carrona.org/drivers/driver.php?id=btwrchid.sys
http://www.carrona.org/drivers/driver.php?id=btwaudio.sys
http://www.carrona.org/drivers/driver.php?id=BCM42RLY.sys
http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys
http://www.carrona.org/drivers/driver.php?id=ndisrd.sys
http://www.carrona.org/drivers/driver.php?id=ASUSFILTER.sys
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
aivi0w56.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=asahci64.sys
http://www.carrona.org/drivers/driver.php?id=mv91cons.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
http://www.carrona.org/drivers/driver.php?id=automap.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=ICCWDT.sys
http://www.carrona.org/drivers/driver.php?id=iocbios2.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
aswrdr2.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=aswFsBlk.SYS
http://www.carrona.org/drivers/driver.php?id=aswMonFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswTdi.SYS
http://www.carrona.org/drivers/driver.php?id=aswKbd.SYS
http://www.carrona.org/drivers/driver.php?id=aswNdis2.sys
http://www.carrona.org/drivers/driver.php?id=aswSP.SYS
http://www.carrona.org/drivers/driver.php?id=aswSnx.SYS
http://www.carrona.org/drivers/driver.php?id=aswFW.SYS
http://www.carrona.org/drivers/driver.php?id=rzendpt.sys
rzhnet.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=rzudd.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
af1cxfv7.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
aej6gpj8.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
acqpe8ss.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ams8c17l.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a1xdrzn7.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
acqaynvg.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
amvdhkda.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
akgmw3zf.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ajs9krwe.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
abnou9we.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=bcmwl664.sys
a5i5yzop.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
usasma
Fantastic Member
Duplicate post deleted.
Top Bottom
