BSOD When I plugged in my Logitech Camera
nerfuin13
Well-Known Member
My logitech camera wasn't working when it was plugged in so I unplugged it, and plugged it back in. I looked back and I had a blue screen. I have no idea if it has any relevance to the bluescreen but please help. I don't want this problem again.
Windows Forum Admin
Microsoft MVP
BugCheck C2, {7, 109b, 40f0006, fffffa80127beec0}
*** WARNING: Unable to verify timestamp for asmthub3.sys
*** ERROR: Module load completed but symbols could not be loaded for asmthub3.sys
*** WARNING: Unable to verify timestamp for asmtxhci.sys
*** ERROR: Module load completed but symbols could not be loaded for asmtxhci.sys
GetPointerFromAddress: unable to read from fffff800032ff100
GetUlongFromAddress: unable to read from fffff800032ff1c0
Probably caused by : asmthub3.sys ( asmthub3+3288 )
Followup: MachineOwner
looks like USB3 drivers were the culprit and some, depending on age, are known for causing bsod. I'll have a look through the dmp file and see what crops up:
AE2500w764.sys Tue Mar 29 01:22:08 2011: Linksys Network Adapter Wifi driver update if possible:
http://homesupport.cisco.com/en-us/support/linksys
asmthub3.sys Fri Aug 16 20:28:54 2013: ASMedia ASM1042 USB3 driver and the one cited above as the culprit (along with the firmware driver). A later version of the driver can be found here (top in the central list of downloads):
http://www.station-drivers.com/index.php/10-drivers/40-asmedia
asmtxhci.sys Fri Aug 16 20:28:42 2013: As above. Please update using the webpage specified above, it's the second download down in the central list.
lvuvc64.sys Fri Sep 21 20:03:12 2012: Logitech USB Video Class Driver (WebCam) please update:
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Please post any further dmp files.
