I have attached a good sized Zip file that has all my info.
It's bizarre, either my computer freezes or blue screens, most commonly when playing a game (although it will all of a sudden Blue screen without any warning or degradation in performance). Often when it crashes a horrible continuos buzzing noise will play through the speakers.
However there are times when I can use the computer without problems for hours.
Sometimes after recovering from a blue screen my computer actually fails to boot, the fans are running but the single 'beep' to notify a boot doesn't work. I tend to find though that if i take out the mains leave it for 5 mins and then turn it on again it does boost.
I have ran Memtest (several runs through) and Memory is fine, and I can't think of any hardware changes that may trigger the issue.
After a BSOD the most common code I get when windows starts up and tells me about the previous Blue Screen is '768_1'
In Event Log the main repeated errors I get are
ID:3 ''The configuration of the AdminConnection\TCP protocol in the SQL instance MSSMLBIZ is not valid.''
and
ID 11:Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications.
If anyone can take a look i'd be grateful, it really has me stumped
and
