Can Someone please help with these BSOD minidumps
hi guys,
Win 7 been running quite fine for a while, haven't made any changes really that i thought would cause BSOD's but apparently i have coz i've had 2 in 24 hours. Both minidumps are in attached RAR file.
Cheers dudes View attachment 14188 View attachment 061011-24445-01.rar
Captain Jack
Hello there,
Seems like athrxu6.sys i.e. Atheros WiFi NIC driver seems to crash the system. Updated the drivers from manufacture's website.
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000006511, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88002a9d841, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800034b30e0
 0000000000006511
CURRENT_IRQL:  2
FAULTING_IP:
athrxu6+76841
fffff880`02a9d841 8b402c          mov     eax,dword ptr [rax+2Ch]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff8800311b630 -- (.trap 0xfffff8800311b630)
rax=00000000000064e5 rbx=0000000000000000 rcx=0000000000000001
rdx=fffffa8004a64030 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88002a9d841 rsp=fffff8800311b7c0 rbp=0000000000000000
 r8=fffffa8004a0c328  r9=0000000000000000 r10=fffffa80028bb020
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
athrxu6+0x76841:
fffff880`02a9d841 8b402c          mov     eax,dword ptr [rax+2Ch] ds:00000000`00006511=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff8000327ac69 to fffff8000327b700
STACK_TEXT:
fffff880`0311b4e8 fffff800`0327ac69 : 00000000`0000000a 00000000`00006511 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`0311b4f0 fffff800`032798e0 : 00000000`00000000 fffffa80`03925fbb 00000000`00000000 fffff880`016f562e : nt!KiBugCheckDispatch+0x69
fffff880`0311b630 fffff880`02a9d841 : fffff880`01695110 fffffa80`02e1f050 00000000`00000282 fffff880`02a38340 : nt!KiPageFault+0x260
fffff880`0311b7c0 fffff880`01695110 : fffffa80`02e1f050 00000000`00000282 fffff880`02a38340 00000000`00000000 : athrxu6+0x76841
fffff880`0311b7c8 fffffa80`02e1f050 : 00000000`00000282 fffff880`02a38340 00000000`00000000 fffffa80`02e1f050 : ndis!WPP_GLOBAL_Control
fffff880`0311b7d0 00000000`00000282 : fffff880`02a38340 00000000`00000000 fffffa80`02e1f050 00000000`00000000 : 0xfffffa80`02e1f050
fffff880`0311b7d8 fffff880`02a38340 : 00000000`00000000 fffffa80`02e1f050 00000000`00000000 fffff880`02a633f1 : 0x282
fffff880`0311b7e0 00000000`00000000 : fffffa80`02e1f050 00000000`00000000 fffff880`02a633f1 00000001`04642810 : athrxu6+0x11340
STACK_COMMAND:  kb
FOLLOWUP_IP:
athrxu6+76841
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  athrxu6+76841
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: athrxu6
IMAGE_NAME:  athrxu6.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  468c5e5a
FAILURE_BUCKET_ID:  X64_0xD1_athrxu6+76841
Followup: MachineOwner
